29th May 2010, 11:26 | #8381 | Link | |
Programmer (or just 教务长)
If you get an error when you insert the disc (which you were able to play before), Google for the error code. In most cases with heavily used PS3, the blue 'laser' wears off and needs a replacement, but it has nothing to do with playing backups - usually some game discs refuse to load, too. Dean |
29th May 2010, 14:00 | #8382 | Link | |
29th May 2010, 14:06 | #8383 | Link | |
And me myself just noticed this, this spring i was doing movie only BD25 pretty much every time so havent seen it before but now some reason try full movie mode (Armageddon disc) and it dit not worked tryed 2 different BD-RE (Verbatims), also i try 2 different BD-rebuilder versions because that time i though it was some bug in program... same result invalid disc and error code in PS3. So i then googled error codes and get answers what you suggest above that bluray laser is getting old. But in my case i dont think it is reason, my PS3 is never used heavily, just havent been time before, and bluray drive even less... also because original blurays work fine and movie only BD25 backups works fine, plus bluray disc game what i tested... i quess it is unlikely faulty drive causing this. Also that time when i googled this i remember someone reporting this to jDobbs and it was just BD25 and full backup mode not working, so thats why i did not report same thing myself back then. |
29th May 2010, 14:15 | #8384 | Link | |
29th May 2010, 14:30 | #8385 | Link |
BD Rebuilder v0.34.01 (beta)
I have updated the first post of this thread with a link to a new release of BD-RB (v0.34.01). Changes for this update:
- Changed the secondary intermediate file so it follows the same rules as primary. Now the intermediate will be .264 except when MKV_INTERMEDIATE is set. This is necessitated by changes to X264, and should correct issues experienced with secondary video on PS3 and other players that might be sensitive to it. - Added "Remove OUTPUT folder" in the SETUP dialog. If selected, the output folder will be deleted after a successful burn (with ImgBurn). - Created a workaround for an issue with X264's internal FFMS decoding that could result in extremely blocky output on multi-part features as a result of confused bitrate interpretation. BD-RB no longer uses FFMS for multi-part features, it now uses X264's internal LAVF demuxing. - Updated the included version of X264.EXE to the latest release (r1613). - Other minor corrections and cosmetic fixes. |
29th May 2010, 14:37 | #8386 | Link | |
Sorry you missing my point or did not understand correctly my bad european english. I mean when i first time encountered this invalid disc thing in my PS3 / full movie backup disc i did not know what is happening so i try different things like two different BD-RE discs and two different BD-Rebuilder versions with slightly different quality settings and so on... I dont blame BD-RB about this. |
29th May 2010, 15:41 | #8387 | Link |
Tried another Universal title, The Scorpion King, full movie backup to BD5, with BD-RBV03309, with the same results as before, when the movie starts there is no audio heard and the subtitles are not selectable from the remote or menu.
The picture quality is excellent though! If I select display with the remote, it says 1080/24, but does not display an audio present like a normal working backup. ( DD 5.1, etc...) It does play the audio perfectly when using TMT3 on my PC, so even the Sony S360 cannot work properly on BD5 media with this title. |
29th May 2010, 15:50 | #8388 | Link | |
29th May 2010, 16:01 | #8389 | Link | |
The other one I have that has not worked is U571. This one and Scorpion King are original BD-25, with PiP, which I have disabled since the secondary audio is DTS Express, and both behave the same way. I was going to try U571 with your new release, though it probably won't make a difference, just to see if the results are consistent with Scorpion King. [EDIT] Just checked and the structure of both of these discs are identical, VC1, U-Control for PiP, DTS HD, DTS Express Secondary audio, main motion menu, etc... Last edited by Capsbackup; 29th May 2010 at 16:08. |
29th May 2010, 17:17 | #8391 | Link |
Question on forced subtitles
First of all, this is an amazing program for BD backup, the best out there. The only thing I seem to have trouble with (and I've searched the forums and elsewhere for clues, without success) are movies with forced subs (Avatar, District 9, 2012, etc.). It doesn't seem that BD Rebuilder has the capability yet to program these into the finished backup. Subtitles either have to be "on" or "off", with no consideration for scenes with non-English dialog necessitating subtitles. I know others have taken the extra steps to rip the subtitles with other programs, convert them, and then fit them back in, but I was hoping for an easier solution from within BD Rebuilder if possible.
29th May 2010, 17:41 | #8392 | Link |
@jdobbs @capsbackup
Just as a point of information - In mid-April, I had done a DVD9 full disc version of "U571". Although the burned disc exhibits the same problems described by "Capsbackup" when played on the SONY BDP-S360, that same burned disc plays perfectly under PowerDVD v.7.3xxx. |
29th May 2010, 17:54 | #8393 | Link | |
FORCED SUBS IE: Avatar
I have had no problems with (forced subs) doing movie only backups. All you have to do is be sure you leave --ALL-- the ENG subs (if you want eng subs to be shown) in the backup and it will still show them even with subs turned off. |
29th May 2010, 18:01 | #8394 | Link | |
When I load the image with Virtual Clone, and then try to play the movie, it will then start and proceed to the menu, but when I select play, PowerDVD just shuts down! Both the disc and the loaded image play perfectly with TMT3 though. |
29th May 2010, 18:17 | #8395 | Link | |
I think the more appropriate goal would be for the PS3 to change. I could spend the rest of my life trying to work around Sony's mistakes in firmware. As has been mentioned, it once worked (firmware 2.50). Full (BD-25) backups should work now. I have to be honest, my primary focus is on real players -- not computers or games that pretend to be players. That's where the majority of users are and the only place I can reliably believe that bugs are truly bugs. Also, since I don't own a PS3, I have no way of testing it anyway. Last edited by jdobbs; 29th May 2010 at 18:30. |
29th May 2010, 18:19 | #8396 | Link | |
I recommend keeping all subs on most discs. |
29th May 2010, 18:20 | #8397 | Link | |
29th May 2010, 18:48 | #8398 | Link |
Forgive me if I'm wrong, but it seems that it's impossible to select an "alternate movie only" if the alternate option are within the same playlist.
I've found some movies where the main playlist has three different possible m2ts files at the beginning (opening credits in three different languages) and then one big m2ts for the remainder movie and it seems that right now it's impossible to choose any of the alternate beginnings (as you can you per playlist, but not inside it, and then you always get the first optional beginning). Greetings |
29th May 2010, 18:55 | #8399 | Link | |
@jdobbs
