Old 28th July 2018, 20:15   #51861  |  Link
franketto
So, in the Events of the last 3 months, I found out 9 critical errors, but only one BSOD with the hex code 119 Video_scheduler as I wrote before.
And I know of this BSOD in this date because I did the pic of it , I'll post the log on the next post.
Anyway, the non-BSOD event, the same I found in Reliability Monitor, starts with:
the igfx driver stops working:
 - Provider
   [ Name]  Display
  - EventID 4101
   [ Qualifiers]  0
   Level 3
   Task 0
   Keywords 0x80000000000000
  - TimeCreated
   [ SystemTime]  2018-07-15T20:14:39.635676800Z
   EventRecordID 10355
   Channel System
Followed by 17x Warnings Win32k 263 err code, of "pointing device", not having info on connected monitor.
Provider
   [ Name]  Win32k
  - EventID 263
   [ Qualifiers]  32768
   Level 3
   Task 0
  - TimeCreated
   [ SystemTime]  2018-07-15T20:14:51.254358500Z
   EventRecordID 10356
   Channel System
Then a warning not been able to start again the video driver.
Provider
   [ Name]  Display
  - EventID 4115
   [ Qualifiers]  0
   Level 3
   Task 0
  - TimeCreated
   [ SystemTime]  2018-07-15T20:14:55.891991800Z
   EventRecordID 10373
   Channel System
Then 12x Error of Service Control manager, 7031 Err code,
service OneSyncSvc_2f064 blocked abruptely, reboot it in 10000ms.
Provider
   [ Name]  Service Control Manager
   [ Guid]  {555908d1-a6d7-4695-8e1e-26931d2012f4}
   [ EventSourceName]  Service Control Manager
  - EventID 7031
   [ Qualifiers]  49152
   Version 0
   Level 2
   Task 0
   Opcode 0
   Keywords 0x8080000000000000
  - TimeCreated
   [ SystemTime]  2018-07-15T20:15:05.786066400Z
   EventRecordID 10375
   Correlation
  - Execution
   [ ProcessID]  988
   [ ThreadID]  18112
   Channel System
 EventData
  param1 OneSyncSvc_2f064
  param2 1
  param3 10000
  param4 1
  param5 Riavvia il servizio
   4F006E006500530079006E0063005300760063005F00320066003000360034000000
Then:
PimIndexMaintenanceSvc_2f064
UnistoreSvc_2f064
UserDataSvc_2f064
CDPUserSvc_2f064
WpnUserService_2f064
followed by timeout of the services blocked that don't reboot.
and finally... the crash-freezing.
franketto is offline   Reply With Quote
Old 28th July 2018, 20:16   #51862  |  Link
franketto
Instead the BSOD one has these:
3x Warning Kernel-PnP:
cannot load driver \Driver\VMSP for the device ROOT\VMS_VSMP\0000
then for ROOT\VMS_VSMP\0001 and ROOT\VMS_VSMP\0002
Provider
   [ Name]  Microsoft-Windows-Kernel-PnP
   [ Guid]  {9C205A39-1250-487D-ABD7-E831C6290539}
   EventID 219
   Version 0
   Level 3
   Task 212
   Opcode 0
   Keywords 0x8000000000000000
  - TimeCreated
   [ SystemTime]  2018-06-15T11:57:47.536750800Z
   EventRecordID 6018
   Correlation
  - Execution
   [ ProcessID]  4
   [ ThreadID]  420
   Channel System
  - Security
   [ UserID]  S-1-5-18
- EventData
  DriverNameLength 18
  DriverName ROOT\VMS_VSMP\0000
  Status 3221226092
  FailureNameLength 12
  FailureName \Driver\VMSP
  Version 0
Then the Warning of pointing device not knows the monitor,
then an error Hyper-V-VmSwitch:
Failed to get Device VlanID Regkey for Physical NIC /DEVICE/{3E39B7FB-8071-4D58-A3CE-E6F29F1786E6}. vSwitch will be created on this Physical NIC without VlanID being inherited by HostVNic. Status = can't find object name.
Then another Warning of pointing device not knows the monitor,
Then again 4x Errors Hyper-V-VmSwitch:
-) The operation 'Get Info' failed on nic 37044452-FBC8-4E5B-B8BD-D5B3060C51F5 (Friendly Name: ). Status = Parametro non valido passato ad un servizio o ad una funzione..
-) Failed to connect NIC 37044452-FBC8-4E5B-B8BD-D5B3060C51F5 (Friendly Name: Opzione predefi) to port (Friendly Name: ) on switch C08CB7B8-9B3C-408E-8E30-5E16A3AEB444 (Friendly Name: Opzione predefinita), status = Impossibile trovare il nome dell'oggetto..
-) Failed to enable miniport NIC 37044452-FBC8-4E5B-B8BD-D5B3060C51F5 (Friendly Name: Opzione predefi), status = Impossibile trovare il nome dell'oggetto..
And finally the BugCheck:
Il computer è stato riavviato da un controllo errori. Controllo errori: 0x00000119 (0x0000000000100000, 0x0000000000000001, 0x0000000000000000, 0xffffe00a4b512000).
I dettagli sono stati salvati in: C:\WINDOWS\MEMORY.DMP. ID segnalazione: 77ea78e5-3300-41b2-887c-6fef0cb21c72.
Sadly I have not looked at the memory.dmp and I don't find it now...
So, that's all, let me know if you have some ideas or request some more details of these events and I'll post them.
Thank you a lot fot the patience and the support, I'm really upset with these crashes that don't let me use madVR!
Old 28th July 2018, 20:17   #51863  |  Link
franketto
Originally Posted by Clammerz View Post
Unlikely though as that particular bugcheck should only be caused by bad hardware or bad drivers.
Have you tried other driver versions?
Unfortunately intermittent issues such as these are the hardest to diagnose when they only show up after a few weeks at a time. If you can find a temporary replacement CPU to use it will at least rule out if the GPU is at fault or not.
No, I haven't tried any other drivers apart W10 automatic updates.
I cannot use another CPU...
Old 28th July 2018, 20:19   #51864  |  Link
franketto
I'll try an intense DXVA checker, but I see it does not use madVR as a renderer, so I think it will not cause anything wrong...
Old 28th July 2018, 20:20   #51865  |  Link
veggav
Anyone noticed that Nvidia Control Panel when using custom resolution timming by Madvr you only get 8bits output? Or am I don't something wrong here?
The 10 and 12bpc option is gone.
Even the OSD showing D3D11 Windowed full screen (10bits).
EDIT: Nevermind, you have to enable 12bits before going into custom timming.
veggav is offline   Reply With Quote
Old 28th July 2018, 21:08   #51866  |  Link
franketto
Did the DXVA checker: nothing wrong.
Old 28th July 2018, 22:54   #51867  |  Link
Asmodian
I believe this is not directly the fault of madVR. Please create a new thread, maybe in this sub-forum, to keep this thread on topic.
Also, try installing the newest drivers for your GPU.
madVR options explained
Old 29th July 2018, 00:04   #51868  |  Link
veggav
Well, it worked for 5 minutes and suddenly it's gone.
How do you guys get 12bpc with custom timing?
Old 29th July 2018, 00:06   #51869  |  Link
jkauff
The graphics drivers from Intel for your CPU/GPU are what you need (found on intel.com in the Downloads section). The generic Windows drivers are old and far less capable.
Old 29th July 2018, 00:17   #51870  |  Link
Asmodian
I don't think anyone has gotten it to work through a reboot.
Old 29th July 2018, 00:25   #51871  |  Link
veggav
That sucks, for the first time I was able to get my TV to recognize 23p as 24hz if I use CVT CRT timings.
But giving up on 12bpc it's not a good trade off.
One idea would be actually change the timing for 23hz based on the findings with MadVR and put those on CRU (custom resolution utility).
But I don't know how to modify timings of specific hertz like 3840x2160.
EDIT: Got 12bpc to stick after a reboot.
Used CRU with the timings I wanted, added as a detailed resolution, moved it up to be together 3840x2160@60 and after rebooting I selected 23hz, changed to 12bpc and the 24hz (23.976) I had as 12bpc.
Rebooted once more, changed resolutions and still 12bpc.
So, yay!
Old 29th July 2018, 10:47   #51872  |  Link
el Filou
el Filou's Avatar
@franketto other things to try:
- change LAV hardware decoding mode (DXVA2/D3D11) or madVR rendering mode (D3D9/D3D11, Full Screen Exclusive/Windowed)
- temporarily remove your 3DLUT from madVR
Old 29th July 2018, 12:10   #51873  |  Link
franketto
Thank you, I'll try.
I also installed the latest Intel drivers.
I have not installed LAV: should I install it?
Old 29th July 2018, 12:57   #51874  |  Link
pirlouy
_
You should open your own thread, as you were told. Not everybody is interested in your problem which could result in 50 other posts.
Old 29th July 2018, 14:33   #51875  |  Link
Zaoshi
My render queue fails to fill up and sometimes I get frame drops (even though OSD reports low render times), however in FSE mode there are no frame drops and queue is full (although it reports significantly higher render time).
I heard this is an issue with Windows 10 version 1803. I tried searching this thread but failed to find any fix. Perhaps anyone remembers what it is, assuming it exists?
Zaoshi is offline   Reply With Quote
Old 29th July 2018, 17:07   #51876  |  Link
Vincent Vega
its weird i just noticed dx11 exclusive fullscreen no longer works here.
OSD says dx11 windowed despite the setting to exclusive.
and i did not change a thing, no new software or settings, or drivers.
must of been another shitty win10 weekly update or something.
does anyone else have this issue?
Vincent Vega is offline   Reply With Quote
Old 29th July 2018, 17:51   #51877  |  Link
Warner306
The rendering times are artificially low in windowed mode after the Windows 1803 update. Only FSE is reporting the correct rendering times. A couple have had trouble filling the present queue when using NGU.
Old 29th July 2018, 17:53   #51878  |  Link
Warner306
It is not uncommon. It happens all the time. Not all systems work well with fullscreen exclusive mode in Windows 10. Try another media player. Updates and drivers can change things.
Old 29th July 2018, 18:55   #51879  |  Link
Vincent Vega
just rebooted pc and problem went away, at least for now -)
next time will try to just restart gpu driver with devmanview.
Old 29th July 2018, 23:48   #51880  |  Link
Please don't quote in entirety a post directly above yours it's pointless.
