1st May 2018, 13:30 | #5302 | Link |
@yonta
Thank you for the information. We have different issues with MPC Audio Renderer after r3572.
1st May 2018, 20:51 | #5303 | Link |
I installed Win10 Pro 1803 on a separate SSD, and recognized lots of dropped frames with madVR at start (abot 3 seconds of the video is static at first frame.
I updated Radeon Driver to 18.4.1, but it is still the same thing. Anybody else having trouble? I have my Win10 1709 installation on another SSD and put it already back in the computer and everything works fine. Newest version of madVR, LAV Filters nightly, except MPC-BE r3571. Is that a AMD Driver or Win10 issue? Maybe anything else? Is Nvidia fine? AND: MKV files don't get thumbnails anymore without thirdparty apps in 1803. Is that intended? 1709 is fine. Last edited by Klaus1189; 1st May 2018 at 20:53. |
2nd May 2018, 16:01 | #5304 | Link |
Acid fr0g
Ok, today problem of windows persistency, after having closed MPC-BE, appeared again and, even after resetting registry + ini file, now it stays.
Can't really understand reason. It's the only windows program to act like this.
@turment on Telegram |
2nd May 2018, 17:12 | #5306 | Link |
@tormento
Does this issue always occur or when you close after playback? Take a screenshot of the list of active filters (Play->Filters).
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 2nd May 2018 at 17:17. |
2nd May 2018, 17:36 | #5307 | Link | |
In windowed mode, there is no problem. |
3rd May 2018, 22:27 | #5309 | Link | |
This fixed bug from almost 3 years ago reappears in recent builds. Basically most of the PGS subtitles are affected. Some samples: https://www.sendspace.com/file/gan6ej https://www.sendspace.com/file/2cv8ka https://www.sendspace.com/file/ljzjqt |
4th May 2018, 01:19 | #5310 | Link |
beter
Options -> Internal Filters - "Buffer length" set to 10 sec.
4th May 2018, 08:15 | #5311 | Link | |
https://www.sendspace.com/file/f51kzk https://www.sendspace.com/file/18xrfl |
4th May 2018, 09:18 | #5312 | Link |
it's not very important
4th May 2018, 12:42 | #5314 | Link |
Acid fr0g
Ok. It's a multitab issue. If I add MPC-BE to the list of the apps that don't have to use multitab, I get that bug. If I remove it, it works ok.
If any developer has Windows 10 RS5, get a try.
5th May 2018, 05:25 | #5316 | Link |
No. But you could check it yourself.
5th May 2018, 14:40 | #5318 | Link |
I did a clean installation of lav filters, now, without adding the lav audio, video and splitter to external filter list inside mpc be, the lav is working fine on its own. How possibile?
I had to disable all internal filter to make this happen.
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM Last edited by steakhutzeee; 5th May 2018 at 16:00. |
6th May 2018, 05:44 | #5319 | Link |
A very large buffer creates a lot of problems. But I still made it possible to increase it to 15 seconds in r3595. I hope this is temporary and we will find another way to fix this. The default value (3 seconds) will not change.
