31st July 2019, 22:31 | #6481 | Link |
I understand you - but can't reproduce. Very often using pause/resume.
1st August 2019, 01:16 | #6483 | Link | |
Do you check "Release device when idle" in MPC Audio Renderer options ? If yes - try uncheck.
1st August 2019, 03:30 | #6484 | Link |
I didn't get "Release device when idle" checked. However, untheck the "Use system layout channels" seems do the trick.
Edit: No, it happened that something else not keeping up with the pace. It just appeared when playing back a video, using MPC Video Renderer. Edit2: Sanear Audio Renderer has no problem at all for my environment. Edit3: My htpc setup in using Windows 8.1, configured with an asynchronous usb DA converter, and I am willing to do some tests if developers has some debug build to gather more info about this issue. And BTW, my other laptop under Windows 10 also has similar issue with MPC-BE's audio renderer, and that one dosn't have an usb audio output. Last edited by Anima123; 1st August 2019 at 05:35. |
1st August 2019, 06:40 | #6485 | Link |
Debug build - https://yadi.sk/d/dOgvRk1TzDgHew
Before start MPC-BE - start DbgView(https://docs.microsoft.com/en-us/sys...oads/debugview). After bug - upload log from DbgView for me. P.S. What version use ?
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 1st August 2019 at 07:19. |
2nd August 2019, 00:49 | #6487 | Link | |
2nd August 2019, 01:13 | #6488 | Link | |
2nd August 2019, 01:55 | #6489 | Link |
The playing suddenly became like slow-motion, and the audio warbling when it happend, and it reject to get back to normal.
BTW, before the issue occurred, the logs in DebugView is far less frequent than after. I am willing to help if further testing needed. Last edited by Anima123; 2nd August 2019 at 02:01. |
2nd August 2019, 02:27 | #6490 | Link | |
Make a video from screen(in MPC-BE on statistics - Ctrl+J).
2nd August 2019, 03:57 | #6492 | Link |
cosmic entity
i have also stutter when using MPC VR, but ONLY if im using 2 monitors..
I watch the video on the right monitor then work on the left one, or browse. Then after some time i get stutter (droped , repeated frames etc). If i only use ONE Monitor everything is fine.. This does not happen with EVR CP.. i thought im gonna post it also... Greetz |
2nd August 2019, 05:03 | #6493 | Link |
Anima123
BetA13 What mode using - DX9/11, swap effect - Discard/Flip ??
2nd August 2019, 05:04 | #6494 | Link |
MPC Video Renderer in developing, if some bug - don't use always
2nd August 2019, 05:05 | #6495 | Link |
I'm using DX11 + Flip - there is no any stutter.
2nd August 2019, 05:38 | #6497 | Link | |||
cosmic entity
as i understand DX11 only runs on win 8.1 and up. Since im on windows 7 im using: Dx9 ex and the other one not shure. Ill post a screen, makes it more easy Information Tab: Quote:
EDIT: Quote:
+1 on "what does swap effect" mean? is it like "presentationmode" in EVR-CP ? Good Morning by the way Last edited by BetA13; 2nd August 2019 at 05:42. |
2nd August 2019, 17:18 | #6498 | Link | |
@BetA13
DirectX 11 mode works on Windows 8, but we recommend using Windows 8.1. Current version of MPC VR is 0.2.1.786. Quote:
We did not notice a big difference in speed.
MPC-BE 1.6.11 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
3rd August 2019, 05:03 | #6500 | Link |
Record a video with audio from screen with statistics when stutter.
