Old 10th April 2020, 10:09   #7321  |  Link
v0lt
@Klaus1189
1. Was there a problem when using the D3D11 decoder? If it was, does it fix her test build?
2. Was there a problem for DX9 mode with DXVA2 VP? If there was, does its test build fix it?
v0lt is online now   Reply With Quote
Old 10th April 2020, 10:15   #7322  |  Link
Klaus1189
I get the green line on both DX9 and DX11 (MPC VR options page, "Use Direct3D11" enabled and disabled) when I am using software decoding. If I use DXVA filters ("GPU" shown on player ui) the issue disappears. It doesn't matter if I use internal filters of MPC-BE or external LAV Filters.
And with new testbuild I do not get any green line at all -> for me it is working
Old 10th April 2020, 11:20   #7323  |  Link
v0lt
@Klaus1189
Ok. Fixed in 1228_git2020.04.10-fd7b624.
Old 11th April 2020, 09:17   #7324  |  Link
Klaus1189
@devs: Thank you
Old 14th April 2020, 20:34   #7325  |  Link
pirlouy
_
Are there particular goals for MPC Video Renderer ?
If I had a request, I'm really interested in Smooth Motion algorithm from madVR (light on CPU/GPU and very eye-friendly).
Old 15th April 2020, 07:24   #7326  |  Link
v0lt
Please show the open source implementation of such an algorithm, then we will think about it.
Old 15th April 2020, 08:10   #7327  |  Link
Klaus1189
Updated german translation based on r5202 "Show milliseconds"
Old 15th April 2020, 10:03   #7328  |  Link
wushantao
https://send.firefox.com/download/58...VB8FJiGPUmQgUQ
Simplified Chinese is here xD
wushantao is offline   Reply With Quote
Old 15th April 2020, 13:25   #7329  |  Link
Butterflow
Old 15th April 2020, 13:35   #7330  |  Link
pirlouy
_
I think Butterflow aim is to create a new video, not to do it in real time. Plus if it uses OpenCL, there's a high chance it uses ressources.
And no, there's no open source algorithm (I forgot MPDN is also able to do it but it's also closed-source). That's why I asked if you were interested in having it in MPC renderer. Like I don't know your goal, I hoped maybe you were interested in anti-judder stuff.
Old 15th April 2020, 15:47   #7331  |  Link
v0lt
@Klaus1189, @wushantao
Thanks. Updated in r5209.
@pirlouy
I planned to implement the frame rate change with the D3D11 Video Processor (available on some graphics cards). It may not be difficult, but the video processor will need some improvements. I do not know when it will happen.
Old 15th April 2020, 22:45   #7332  |  Link
s0meone_new
What is the new text? Information should be needed about this at all times.
Only this is a text that has changed or is new? "Show milliseconds"
Hungarian translation updated (5212):
https://www85.zippyshare.com/v/2UMihQWK/file.html
s0meone_new is offline   Reply With Quote
Old 16th April 2020, 00:51   #7333  |  Link
dahnen
Hi
I suspect this may not be a player problem but maybe I can get help.
TL;DR
: Correct AR is not set when an external decoder is being used and the file has non-square pixels.
I have this hevc video file with 720x476 dimensions and 4:3 AR.
  • MPC-BE with its stock settings and internal filters displays it correctly.
  • But when I play it using an external decoder it is shown with incorrect AR (1.51:1).
I tried it using different combinations of decoders (Powerdvd decoder, Lentoid decoder) and different renderers (EVR-CP and madVR) and the result is same.
Different AR settings in the video decoder settings in the options window is also not effective since I'm not using the internal decoder.
Yeah, yeah, I know the file is broken but since internal filters can display it correctly,
I wonder if there is a way I can get the player to recognize the correct AR without having to set it manually for every video?
Mediainfo (redacted):
General
Format                                   : Matroska
Format version                           : Version 4
File size                                : 333 MiB
Duration                                 : 20 min 21 s
Overall bit rate                         : 2 284 kb/s
Encoded date                             : UTC 2019-05-22 23:31:06
Writing application                      : mkvmerge v33.0.0 ('A Little Bit of Madness') 64-bit
Writing library                          : libebml v1.3.7 + libmatroska v1.5.0
Encoding Gui                             : Hybrid 2019.05.05.1
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L3@Main
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 2 058 kb/s
Width                                    : 720 pixels
Height                                   : 476 pixels
Display aspect ratio                     : 4:3
Frame rate                               : 23.976 (24000/1001) FPS
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.250
Stream size                              : 300 MiB (90%)
Writing library                          : x265 3.0_Au+21-bac0e1acb874:[Windows][GCC 8.3.0][64 bit] 10bit
Encoding settings                        : cpuid=1111039 / frame-threads=2 / numa-pools=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=720x476 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=8 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=40 / lookahead-slices=0 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=19.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / qp-adaptation-range=1.00
Forced                                   : Yes
dahnen is offline   Reply With Quote
Old 16th April 2020, 03:51   #7334  |  Link
Klaus1189
Rightclick on time in right lower corner of Player you can enable this feature for one session. After closing the player, it is automatically disabled.
Old 17th April 2020, 05:20   #7335  |  Link
v0lt
MPC Video Renderer v0.4.5.1242.
Description.
Changes:
Fixed problem with old frame output after play-stop-play.
Fixed the green line on the right side of the frame when using a DXVA2 or D3D11 video processor and a software decoder on AMD graphics cards.
Added support for IMFVideoMixerBitmap. Now some players can draw images over video (OSD).
Recommended version of MPC-BE v1.5.5.5183 or later.
Old 20th April 2020, 03:13   #7336  |  Link
beter
Update of translation for Chinese traditional and Dutch
https://www.sendspace.com/file/7rx2yu
beter is offline   Reply With Quote
Old 20th April 2020, 04:36   #7337  |  Link
v0lt
s0meone_new
Thanks. Updated in r5213.
beter
Thanks. Updated in r5222.
Old 20th April 2020, 10:22   #7338  |  Link
littleD
littleD's Avatar
Originally Posted by dahnen View Post
Hi
TL;DR
General
Format                                   : Matroska
File size                                : 333 MiB
Video
Format                                   : HEVC
Width                                    : 720 pixels
Height                                   : 476 pixels
Bit depth                                : 10 bits
Forced                                   : Yes
Remux file again in mkvtoolnix and set Aspect ratio of 4:3 and it should be no problem. Make sure you have newest mkvtoolnix installed.
The only problem sometimes is when there is a sar in the stream and the container both them. But its not this case.
littleD is offline   Reply With Quote
Old 20th April 2020, 11:44   #7339  |  Link
tormento
Acid fr0g
tormento's Avatar
How is it different from standard renderers in MPC-BE? Or MadVR?
@turment on Telegram
Old 20th April 2020, 14:22   #7340  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Hi
TL;DR
General
Format                                   : Matroska
File size                                : 333 MiB
Video
Format                                   : HEVC
Width                                    : 720 pixels
Height                                   : 476 pixels
Bit depth                                : 10 bits
Forced                                   : Yes
MPC-BE Source filter read AR from container and Video Decoder can read it data from Source filter, that’s all
