Old 29th September 2010, 21:59   #601  |  Link
Marshy
There is a bug reversion using encode xvid with avi. If you move it to "slower" setting and save settings, close program and then reopen the setting is always showing "balanced" instead of slower.
Marshy is offline   Reply With Quote
Old 6th October 2010, 08:42   #602  |  Link
buzzqw
HDConvertToX author
new full package uploaded
new version of mencoder/mplayer
added support for external subtitle (mencoder and avisynth x264 only)
added support for denoise in avisynth x264
code optimization for resizing
fixed queue for encoding with avisyntx264
fixed encoding label when automen read settings
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
Old 7th October 2010, 15:56   #603  |  Link
azmoth
azmoth is offline   Reply With Quote
Old 8th October 2010, 10:36   #604  |  Link
buzzqw
HDConvertToX author
thanks Azmoth
please report any problems found
BHH
Old 8th November 2010, 01:06   #605  |  Link
Kaiser Bill
I've just downloaded the latest full package (06/10/2010) and have been unable to get this version (v6.1571.319) to open most VOB files, some MPG files and all .d2v project files from DGIndex. With .d2v project files it keeps saying there was some problem analyzing the file and that it will try a different demuxer, but then gives an error that it couldn't detect the number of frames so adds 9999 as a fake value. The few VOB files it has loaded have all had the wrong running time and frame count under the summery tab.
Previous version/package opens them all without problems.
Kaiser Bill is offline   Reply With Quote
Old 16th January 2011, 05:25   #606  |  Link
Sp3kt3r
File size
Hi ,
I'm having trouble converting to a specific file size with 2 Pass at 1750 bitrate
The supposed file size should be around 1400mb but I alway end up between 784mb and 850mb.
I tried different settings and always the same result
It is not just AUTOMEN because I'm having the same issue with HDConvertToX.
My source is a MKV file
my output is a Xvid AVI
I even try to put a freaking high bitrate like 4000kbps and I end up with an average of 1576kbps with a 1gb file.
Thx
Sp3kt3r is offline   Reply With Quote
Old 22nd January 2011, 06:54   #607  |  Link
Koby
Every time I try to use this on Windows 7 Home Premium 64bit, it says handbrake crashes.
If I try XVID, then it says mencoder crashed. I cannot encode with any format.
Any word on when it will be compatible with Windows 7?
Koby is offline   Reply With Quote
Old 19th February 2011, 22:32   #608  |  Link
postmike
Bug report for AutoMen6_beta.rar package.
Here is the part of the command from automen.bat file
... -vf crop=592:304:64:0,scale=320:160-sws 9 ...
There is no space before -sws option
postmike is offline   Reply With Quote
Old 17th March 2011, 12:03   #609  |  Link
feeling_enhancer
feeling_enhancer's Avatar
Update the Software ! Please !
feeling_enhancer is offline   Reply With Quote
Old 21st October 2011, 14:58   #610  |  Link
Kaiser Bill
I'm just trying version 7 (7.690.1580) but after 42 minutes it's still analysing the file I'm trying to open in it. With previous versions it takes seconds to analyse and open the very same file.
The main GUI has 'Not Responding' in the title bar but the CPU usage is about 40% and there is a 'deleteme.avi' being created in the program directory, so is it supposed to be taking this long or has it crashed? If this is normal for this version there is no way I’m going to wait this long each time I want to convert a file, and this is only a half hour long file I’m trying to load. What will it be for a full movie.
Update: Over an hour now and it's still creating this 'deleteme.avi' file which is nearly 60MB in size. What's it doing? Version 6 didn't do this.
This is from MediaInfo for the deleteme.avi file still being created. The file I'm opening is a half hour MPEG-2 file at 720x576 so I don't know why it's upscaled it to 1280x720.
Complete name : C:\Downloads\Automen_v7_full\deleteme.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 58.0 MiB
Writing application : Lavf53.13.0
Video
Format : MPEG-4 Visual
Codec ID : FMP4
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Compression mode : Lossy
Old 21st October 2011, 16:03   #611  |  Link
Kaiser Bill
It's finally finished analysing the file but none of the info in the summary is correct. It says the file is 1280x720 and 41 minutes long but it is in fact 720x576 and 25 minutes long.
Info from MediaInfo for original file that it's just taken over 1 hour 40 minutes to analyse. Version 6 took about 30 seconds and got all the info correct.
Format : MPEG-PS
File size : 784 MiB
Duration : 25mn 4s
Overall bit rate mode : Variable
Overall bit rate : 4 375 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 25mn 4s
Bit rate mode : Variable
Bit rate : 4 064 Kbps
Maximum bit rate : 6 144 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.588
Stream size : 729 MiB (93%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 25mn 4s
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Delay relative to video : -80ms
Stream size : 40.2 MiB (5%)
Old 13th March 2012, 21:15   #612  |  Link
zacharias
y no *nix version?
kudos
Orient-Express
zacharias is offline   Reply With Quote
automen, ffmpeg, handbrake, mencoder, x264
