Old 29th December 2017, 19:46   #15341  |  Link
Danette
I'm converting many TV shows that are NTSC 29.97 fps. Of course, these need to be IVTC'd, which RipBot264 generally handles well. However, about half of them have vfr (variable frame rate) and RipBot264 makes a mess of them (out-of-sync audio and duplicated video at the end to fit the audio). Is there a solution for this?
Danette is offline   Reply With Quote
Old 1st January 2018, 17:57   #15342  |  Link
silverback
Happy New Year Atak,
Great work with ripbot as always.
I am getting a Green Screen in the AviSynth preview window running on 8.1, any ideas?
silverback is offline   Reply With Quote
Old 1st January 2018, 21:01   #15343  |  Link
GZZ
I think you need to look at the demux for subtitle when it set the language.
I have this info in the mediainfo list
Text #1
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Language : English
Text #2
Format : PGS
Muxing mode : zlib
Language : English
Text #3
Format : PGS
Muxing mode : zlib
Language : English
Text #4
Format : PGS
Muxing mode : zlib
Language : English
Text #5
Format : PGS
Muxing mode : zlib
Language : Arabic
Text #6
Format : PGS
Muxing mode : zlib
Language : Chinese
Text #7
Format : PGS
Muxing mode : zlib
Language : Chinese
Text #8
Format : PGS
Muxing mode : zlib
Language : Czech
Text #9
Format : PGS
Muxing mode : zlib
Language : Danish
Text #10
Format : PGS
Muxing mode : zlib
Language : Dutch
Text #11
Format : PGS
Muxing mode : zlib
Language : Finnish
Text #12
Format : PGS
Muxing mode : zlib
Language : French
Text #13
Format : PGS
Muxing mode : zlib
Language : German
Text #14
Format : PGS
Muxing mode : zlib
Language : Greek
Text #15
Format : PGS
Muxing mode : zlib
Language : Hebrew
Text #16
Format : PGS
Muxing mode : zlib
Language : Hungarian
Text #17
Format : PGS
Muxing mode : zlib
Language : Indonesian
Text #18
Format : PGS
Muxing mode : zlib
Language : Italian
Text #19
Format : PGS
Muxing mode : zlib
Language : Japanese
Text #20
Format : PGS
Muxing mode : zlib
Language : Korean
Text #21
Format : PGS
Muxing mode : zlib
Language : Norwegian
Text #22
Format : PGS
Muxing mode : zlib
Language : Polish
Text #23
Format : PGS
Muxing mode : zlib
Language : Portuguese
Text #24
Format : PGS
Muxing mode : zlib
Text #25
Format : PGS
Muxing mode : zlib
Language : Slovak
Text #26
Format : PGS
Muxing mode : zlib
Language : Spanish
Text #27
Format : PGS
Muxing mode : zlib
Language : Spanish
Text #28
Format : PGS
Muxing mode : zlib
Language : Swedish
Text #29
Format : PGS
Muxing mode : zlib
Language : Thai
Text #30
Format : PGS
Muxing mode : zlib
Language : Turkish
Text #31
Format : PGS
Muxing mode : zlib
Language : Japanese
Text #32
Format : PGS
Muxing mode : zlib
Language : Russian
But the demuxed subtitles are named, I have marked the (XXXX) which is the correct subtitle name.
2_subtitles_English.sup
3_subtitles_English.sup
4_subtitles_English.sup
5_subtitles_English.sup
6_subtitles_Arabic.sup
7_subtitles_Undetermined.sup (Chinese)
8_subtitles_Undetermined.sup (Chinese)
9_subtitles_Undetermined.sup (CZech)
10_subtitles_Danish.sup
11_subtitles_Dutch.sup
12_subtitles_Finnish.sup
13_subtitles_French.sup
14_subtitles_German.sup
15_subtitles_Undetermined.sup (Greek)
16_subtitles_Hebrew.sup
17_subtitles_Hungarian.sup
18_subtitles_Indonesian.sup
19_subtitles_Italian.sup
20_subtitles_Japanese.sup
21_subtitles_Korean.sup
22_subtitles_Norwegian.sup
23_subtitles_Polish.sup
24_subtitles_Portuguese.sup
25_subtitles_Portuguese.sup
26_subtitles_Undetermined.sup (Slovak)
27_subtitles_Spanish.sup
28_subtitles_Spanish.sup
29_subtitles_Swedish.sup
30_subtitles_Thai.sup
31_subtitles_Turkish.sup
32_subtitles_Japanese.sup
33_subtitles_Russian.sup
Even if I import the files manually and want to set the names I cant find Greek, Chinese etc. on your list. The above is from a MKV demuxed by MakeMKV from a UHD disc I used as a source and where the names is correct.
GZZ is offline   Reply With Quote
Old 1st January 2018, 21:09   #15344  |  Link
GZZ
If I choose Denoise: "KNLMeansCL" and leave the Mono Noise at its default value: 0 it disables "KNLMeansCL" - Well I dont see any lines under Denoise in the avs script. But If I use value 2 and above it shows up in the avs script. What is the point in value 0 if it disabled itself ?
Also is there an explonation of Mono Noise. Its value is from 0..32 in increment of 2. But I have no idea is 2 is enough of I should use 32... A little hint box to explain would be helpful.
Old 1st January 2018, 21:17   #15345  |  Link
GZZ
If I use KNLMeansCL the Avs script give me this error: "KNLMeansCL: Only YUV444P10 is supported!"
Old 2nd January 2018, 11:26   #15346  |  Link
burt123
burt123's Avatar
Yee Ha...a new build for the new year v1.22.0....looks like a few little obvious changes, would be nice to know what WAS changed/improved ?!?
v1.22.0
Added: Support for UHD Blurays
Added: Automatic HDR information retention while encoding to HEVC format
Added: Automatic HDR to SDR tonemaping during conversion to AVC format
Added: Option to limit MT usage to specific filters only
Added: Custom Script option
Fixed: Various fixes and improvements
burt123 is offline   Reply With Quote
Old 2nd January 2018, 13:03   #15347  |  Link
https://forum.doom9.org/showthread.p...99#post1827599
Is that hard to click Preview Script and see what value works best for you???
Old 2nd January 2018, 17:39   #15348  |  Link
GZZ
Thanks for pointing it out, it obivous wasnt clear to me or else I would have used it. Thanks.
Old 3rd January 2018, 13:32   #15349  |  Link
GZZ
Another Question
When I choose to Copy Stream (TrueHD) then I see it runs an audio script in my Video avs script.
#AudioSource
Import("E:\Temp\RipBot264temp\job3\job3_a1.avs")
in this script it does a few things with the audio. What is the reason to do so when I choose to Copy stream and not reencode audio ?
Audio script
#AudioSource
LoadPlugin("D:\ChromeDownload\RipBot264v1.22.0\tools\AviSynth plugins\ffms\ffms_latest\x64\ffms2.dll")
audio=FFAudioSource("E:\Temp\RipBot264temp\job3\1_audio_English.dtsma")
audio=ConvertAudioToFloat(audio).ResampleAudio(48000)
#DownMix
#Delay
audio=DelayAudio(audio,0)
#Tempo
#Normalize
#AudioDub
audio=ConvertAudioTo16bit(audio)
AudioDub(video,audio)
Old 3rd January 2018, 13:47   #15350  |  Link
For Preview Script my friend...
Old 3rd January 2018, 21:29   #15351  |  Link
GZZ
Not trying to make your app look bad, just pointing out things that might not be correct.
The muxing of subtitles when doing a batch job is not muxed in the correct order
"D:\ChromeDownload\RipBot264v1.22.0\tools\mkvtoolnix\mkvmerge.exe" -o "E:\Encoding\Breaking_Bad_Season_2,_Disc_1_t04 EP 205 Breakage.mkv" --compression 0:none --title "Breaking_Bad_Season_2,_Disc_1_t04 EP 205 Breakage" --default-duration 0:24000/1001fps "E:\Temp\RipBot264temp\video.265" --compression 0:none --language 0:eng --sync 0:0 "E:\Temp\RipBot264temp\job7\1_audio_English.dtsma" --default-track 0:no --language 0:swe -s 0 -D -A "E:\Temp\RipBot264temp\job7\10_subtitles_Swedish.sup" --default-track 0:no --language 0:eng -s 0 -D -A "E:\Temp\RipBot264temp\job7\2_subtitles_English.sup" --default-track 0:no --language 0:eng -s 0 -D -A "E:\Temp\RipBot264temp\job7\3_subtitles_English.sup" --default-track 0:no --language 0:dan -s 0 -D -A "E:\Temp\RipBot264temp\job7\4_subtitles_Danish.sup" --default-track 0:no --language 0:fin -s 0 -D -A "E:\Temp\RipBot264temp\job7\5_subtitles_Finnish.sup" --default-track 0:no --language 0:ita -s 0 -D -A "E:\Temp\RipBot264temp\job7\6_subtitles_Italian.sup" --default-track 0:no --language 0:nor -s 0 -D -A "E:\Temp\RipBot264temp\job7\7_subtitles_Norwegian.sup" --default-track 0:no --language 0or -s 0 -D -A "E:\Temp\RipBot264temp\job7\8_subtitles_Portuguese.sup" --default-track 0:no --language 0:spa -s 0 -D -A "E:\Temp\RipBot264temp\job7\9_subtitles_Spanish.sup" --chapters "E:\Temp\RipBot264temp\job7\chapters.txt"
Subtitle 10 is treaded as number 1 (First subtitle). Can you change this to keep the order of the demuxed subtitle.
Old 3rd January 2018, 21:40   #15352  |  Link
I will take a look...
Old 4th January 2018, 11:50   #15353  |  Link
soneca
Since some versions RipBot264 does not recognize the media generated by Sony Vegas + Debugmode Frameserver.
Old 4th January 2018, 12:29   #15354  |  Link
Debugmode frameserver does not have working x64 version. Too bad that this plugin is no longer in development
Ripbot264 since 1.21.0 is using exclusively 64bit encoding chain.
Old 4th January 2018, 12:47   #15355  |  Link
soneca
What the hell! So I get the version 1.19.5 that works 100% here.
Old 4th January 2018, 15:31   #15356  |  Link
Danette
I'm converting many TV shows that are NTSC 29.97 fps MKV's. Of course, these need to be IVTC'd, which RipBot264 generally handles well. However, about half of them have vfr (variable frame rate) and RipBot264 makes a mess of them (out-of-sync audio and duplicated video at the end to fit the audio). If I demux the MKV's, RipBot264 will correctly process the the video-only files. Is there a solution for this?
Old 4th January 2018, 15:58   #15357  |  Link
squezer
Since ripbot264 v1.21 is impossible to convert DVD into mkv.
AviSynth preview is green, so is encoded video. (like in post 15342 )
Or it cannot load 32bit mpeg2 decoder ( same decoder error as in post 15353 )
v1.20 working fine though.
Could you please fix it?
squezer is offline   Reply With Quote
Old 4th January 2018, 16:23   #15358  |  Link
slalom
slalom's Avatar
You will find Greek as Ell (Ellinika, press e to navigate there), and Chinese as Zho
@Atak
Just a remind, I checked again some files with the version 1.22.0, and latest Avisynth+ r2580 (December 27, 2017)
I got these errors again
FFVideoSource: No video track found
FFAudioSource: No audio track found
and this
FFAudioSource: Audio format change detected. This is currently unsupported. Channels: 6 -> 6; Sample rate: 48000 -> 48000; Sample format: Unknown -> Unknown
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
Old 4th January 2018, 17:51   #15359  |  Link
whiskey
Drunken munky
I've updated to v1.22.0 by downloading the whole zip file and for some reason every time after demuxing audio and indexing I end up with "Decoding Error" window
whiskey is offline   Reply With Quote
Old 4th January 2018, 19:43   #15360  |  Link
Everything works on my Windows 7 x64 (source DVD Alien:Covenant )
Let me guess ,You are on that buggy win10?
Sorry but this kind of "bug report" is useless. How am I supposed to know what went wrong if you don't even bother to post whole error message?
@Slalom
You have corrupted files. I don't even want to know where you get those video files from.
Can you send me at least one of those problematic files?
