Old 4th June 2010, 03:38   #8501  |  Link
snakeman
I'm using the supplied MP4BOX on Windows 7 32 bit -- no problems.
I'm going to try a fresh download and see what happens.
snakeman
snakeman is offline   Reply With Quote
Old 4th June 2010, 04:09   #8502  |  Link
Originally Posted by bassnut View Post
Well of the 3 systems I have used BD Rebuilder on .....
Sys 1 - AMD Athlon X25200+ @ 2.8GHZ with 4 gig PC400 ram Vista Ultimate 64 would take me about 24 to 28 Hrs when I first started to use BD Rebuilder about 10 months ago. Processor pegged 100% all the way.
Sys 2 - AMD PhenomX4 940 @ 3.2GHZ 4 GIG DDR2 1066 Ram Vista Ultimate 64 would take about 12 Hrs about 8 months ago ..... could shave off an easy hour by over clocking it to 3.7GHZ. Processor wouild run about 90% on first pass and peg at 100% for second pass.
SYS 3 - AMD PhenomX4 965 @ 3.2GHZ DDR3 1600 Ram Windows 7 Pro 64 takes about 5 hours with Auto Settings and I can shave off about 1.5 Hrs with it over clocked to 3.9GHZ and about 6 hrs with High quality settings. Processor wouild run about 90% on first pass and peg at 100% for second pass. Depending on the movie I get about 75fps first pass and about 15 -21 fps Second pass the odd movie would get down to about 12 fps but not too often.
The Processor does make a big diference.
Wow. I'm jealous. Oh, well... I'm gonna' get one of those high-end computers when I grow up.
Old 4th June 2010, 09:20   #8503  |  Link
bassnut
Keeps me out of trouble in the winter time
bassnut is offline   Reply With Quote
Old 4th June 2010, 12:16   #8504  |  Link
DK
DK's Avatar
@ bassnut: don't get me wrong but it looks you're comparing apples to oranges
a x4 940 @ 3.2ghz and a x4 965 @ 3.2ghz (the clock speed of the 964 should be 3.4) will not result in 12 vs 5 hrs.
the used settings (you mention auto in the case of the 965) and the length of your movie are what matters.
but i do agree that a quadcore makes a huge difference.
before BD RB i used a x2 6000 (2x 3ghz) for conversions but i ended up with the usual 20+ hrs conversion time.
then i bought a x4 945 which now runs @ 3.45ghz and encoding times vary from 1-10hrs depending on quality setting used and number of frames to encode.
Old 4th June 2010, 14:19   #8505  |  Link
hasaro
First of all, thank you for this excellent software.
My case is with the movie THE HANGOVER REGION A. I do a BD25 full backup, but the UNRATED VERSION has the audio desync. The teatrical version does not present any problem. I tried all the versions of BD-rebuilder for the last two months. But every backup has the same problem.
[Status]
LABEL=THE_HANGOVER
VERSION=v0.34.02 (beta)
SOURCE_SIZE=40152130398
SOURCE_VIDEO_SIZE=39101546496
TARGET_SIZE=24326963200
REDUCTION=.595280273642914
RESIZE_1080=0
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=18
REBUILD_COMPLETE=1
[00000]
AUDIO=11111
PGS=1111111
M2TS_TARGET=10924506167
RATE=7666
NSIZE=10537648128
FLINK=0
MLINK=0
[00001]
AUDIO=11
PGS=1111
M2TS_TARGET=10176417504
RATE=7958
NSIZE=9745987584
FLINK=0
MLINK=0
[00004]
AUDIO=1
PGS=1111
M2TS_TARGET=67226706
RATE=6597
NSIZE=63264768
FLINK=0
MLINK=0
[00005]
AUDIO=1
PGS=1111
M2TS_TARGET=424313493
RATE=5969
NSIZE=416944128
FLINK=0
MLINK=0
[00006]
AUDIO=1
PGS=1111
M2TS_TARGET=408879257
RATE=5956
NSIZE=406775808
FLINK=0
MLINK=0
[00007]
AUDIO=1
PGS=1111
M2TS_TARGET=71970357
RATE=5946
NSIZE=68376576
FLINK=0
MLINK=0
[00010]
AUDIO=11
PGS=
M2TS_TARGET=137485399
RATE=1320
NSIZE=141121536
FLINK=0
MLINK=0
[00012]
AUDIO=1
PGS=1111
M2TS_TARGET=93040650
RATE=6164
NSIZE=88891392
FLINK=0
MLINK=0
[00013]
AUDIO=1
PGS=1111
M2TS_TARGET=64933515
RATE=6260
NSIZE=60420096
FLINK=0
MLINK=0
[00015]
AUDIO=1
PGS=1111
M2TS_TARGET=100227444
RATE=6128
NSIZE=96380928
FLINK=0
MLINK=0
[00016]
AUDIO=1
PGS=1111
M2TS_TARGET=91255837
RATE=6496
NSIZE=84805632
FLINK=0
MLINK=0
[00017]
AUDIO=1
PGS=1111
M2TS_TARGET=82313489
RATE=6045
NSIZE=79601664
FLINK=0
MLINK=0
[00020]
AUDIO=1
PGS=1111
M2TS_TARGET=98373142
RATE=5591
NSIZE=97105920
FLINK=0
MLINK=0
[00026]
AUDIO=1
PGS=
M2TS_TARGET=127237358
RATE=6379
NSIZE=123217920
FLINK=0
MLINK=0
[00027]
AUDIO=1
PGS=
M2TS_TARGET=126871618
RATE=6330
NSIZE=120809472
FLINK=0
MLINK=0
[00028]
AUDIO=1
PGS=
M2TS_TARGET=120730840
RATE=6291
NSIZE=117086208
FLINK=0
MLINK=0
[00029]
AUDIO=1
PGS=
M2TS_TARGET=42623363
RATE=6470
NSIZE=42860544
FLINK=0
MLINK=0
[00030]
AUDIO=1
PGS=
M2TS_TARGET=117973159
RATE=7043
NSIZE=116121600
FLINK=0
MLINK=0
[15:16:08] BD Rebuilder v0.34.02 (beta)
  - Source:  THE_HANGOVER
  - Input BD size: 37,39 GB
  - Approximate total content: [04:16:27.622]
  - Target BD size: 22,66 GB
  - Windows Version: 6.0 [6001]
  - Auto Quality: Good (Very Fast), One Pass
[15:16:08] PHASE ONE, Encoding
 - [15:16:08] Extracting A/V streams [VID_00000]
 - [15:21:58] Reencoding: VID_00000 (1 of 18)
 - [15:21:58] Reencoding secondary video [TRK_02]
 - [15:42:24] Collecting video information
   - Rate/Length: 23,976fps, 143.521 frames
   - Bitrate: 7.666 Kbs
 - [15:42:24] Reencoding: VID_00000, Pass 1 of 1
 - [17:00:31] Video Encode complete
 - [17:00:31] Reencoding audio tracks (if req'd)
 - [17:00:31] Multiplexing M2TS
 - [17:07:16] Extracting A/V streams [VID_00001]
 - [17:11:58] Reencoding: VID_00001 (2 of 18)
 - [17:11:58] Collecting video information
   - Rate/Length: 23,976fps, 155.209 frames
   - Bitrate: 7.958 Kbs
 - [17:11:58] Reencoding: VID_00001, Pass 1 of 1
 - [18:36:07] Video Encode complete
 - [18:36:07] Reencoding audio tracks (if req'd)
 - [18:36:07] Multiplexing M2TS
 - [18:42:46] Extracting A/V streams [VID_00004]
 - [18:42:49] Reencoding: VID_00004 (3 of 18)
 - [18:42:49] Collecting video information
   - Rate/Length: 23,976fps, 1.705 frames
   - Bitrate: 6.597 Kbs
 - [18:42:49] Reencoding: VID_00004, Pass 1 of 1
 - [18:43:45] Video Encode complete
 - [18:43:45] Reencoding audio tracks (if req'd)
 - [18:43:45] Multiplexing M2TS
 - [18:43:47] Extracting A/V streams [VID_00005]
 - [18:43:59] Reencoding: VID_00005 (4 of 18)
 - [18:43:59] Collecting video information
   - Rate/Length: 23,976fps, 11.898 frames
   - Bitrate: 5.969 Kbs
 - [18:43:59] Reencoding: VID_00005, Pass 1 of 1
 - [18:49:52] Video Encode complete
 - [18:49:52] Reencoding audio tracks (if req'd)
 - [18:49:52] Multiplexing M2TS
 - [18:50:06] Extracting A/V streams [VID_00006]
 - [18:50:18] Reencoding: VID_00006 (5 of 18)
 - [18:50:18] Collecting video information
   - Rate/Length: 23,976fps, 11.419 frames
   - Bitrate: 5.956 Kbs
 - [18:50:18] Reencoding: VID_00006, Pass 1 of 1
 - [18:56:09] Video Encode complete
 - [18:56:09] Reencoding audio tracks (if req'd)
 - [18:56:09] Multiplexing M2TS
 - [18:56:21] Extracting A/V streams [VID_00007]
 - [18:56:24] Reencoding: VID_00007 (6 of 18)
 - [18:56:24] Collecting video information
   - Rate/Length: 23,976fps, 2.005 frames
   - Bitrate: 5.946 Kbs
 - [18:56:24] Reencoding: VID_00007, Pass 1 of 1
 - [18:57:26] Video Encode complete
 - [18:57:26] Reencoding audio tracks (if req'd)
 - [18:57:26] Multiplexing M2TS
 - [18:57:28] Extracting A/V streams [VID_00010]
 - [18:57:39] Reencoding: VID_00010 (7 of 18)
 - [18:57:39] Reencoding secondary video [TRK_02]
 - [18:58:29] Collecting video information
   - Rate/Length: 23,976fps, 14.498 frames
   - Bitrate: 1.320 Kbs
 - [18:58:29] Reencoding: VID_00010, Pass 1 of 1
 - [19:04:04] Video Encode complete
 - [19:04:04] Reencoding audio tracks (if req'd)
 - [19:04:04] Multiplexing M2TS
 - [19:04:09] Extracting A/V streams [VID_00012]
 - [19:04:12] Reencoding: VID_00012 (8 of 18)
 - [19:04:12] Collecting video information
   - Rate/Length: 23,976fps, 2.511 frames
   - Bitrate: 6.164 Kbs
 - [19:04:12] Reencoding: VID_00012, Pass 1 of 1
 - [19:05:37] Video Encode complete
 - [19:05:37] Reencoding audio tracks (if req'd)
 - [19:05:37] Multiplexing M2TS
 - [19:05:39] Extracting A/V streams [VID_00013]
 - [19:05:42] Reencoding: VID_00013 (9 of 18)
 - [19:05:42] Collecting video information
   - Rate/Length: 23,976fps, 1.729 frames
   - Bitrate: 6.260 Kbs
 - [19:05:42] Reencoding: VID_00013, Pass 1 of 1
 - [19:06:38] Video Encode complete
 - [19:06:38] Reencoding audio tracks (if req'd)
 - [19:06:38] Multiplexing M2TS
 - [19:06:40] Extracting A/V streams [VID_00015]
 - [19:06:43] Reencoding: VID_00015 (10 of 18)
 - [19:06:43] Collecting video information
   - Rate/Length: 23,976fps, 2.714 frames
   - Bitrate: 6.128 Kbs
 - [19:06:43] Reencoding: VID_00015, Pass 1 of 1
 - [19:08:12] Video Encode complete
 - [19:08:12] Reencoding audio tracks (if req'd)
 - [19:08:12] Multiplexing M2TS
 - [19:08:14] Extracting A/V streams [VID_00016]
 - [19:08:17] Reencoding: VID_00016 (11 of 18)
 - [19:08:17] Collecting video information
   - Rate/Length: 23,976fps, 2.320 frames
   - Bitrate: 6.496 Kbs
 - [19:08:17] Reencoding: VID_00016, Pass 1 of 1
 - [19:09:31] Video Encode complete
 - [19:09:31] Reencoding audio tracks (if req'd)
 - [19:09:31] Multiplexing M2TS
 - [19:09:33] Extracting A/V streams [VID_00017]
 - [19:09:36] Reencoding: VID_00017 (12 of 18)
 - [19:09:36] Collecting video information
   - Rate/Length: 23,976fps, 2.233 frames
   - Bitrate: 6.045 Kbs
 - [19:09:36] Reencoding: VID_00017, Pass 1 of 1
 - [19:10:53] Video Encode complete
 - [19:10:53] Reencoding audio tracks (if req'd)
 - [19:10:53] Multiplexing M2TS
 - [19:10:55] Extracting A/V streams [VID_00020]
 - [19:10:59] Reencoding: VID_00020 (13 of 18)
 - [19:10:59] Collecting video information
   - Rate/Length: 23,976fps, 2.917 frames
   - Bitrate: 5.591 Kbs
 - [19:10:59] Reencoding: VID_00020, Pass 1 of 1
 - [19:12:14] Video Encode complete
 - [19:12:14] Reencoding audio tracks (if req'd)
 - [19:12:14] Multiplexing M2TS
 - [19:12:16] Extracting A/V streams [VID_00026]
 - [19:12:20] Reencoding: VID_00026 (14 of 18)
 - [19:12:20] Collecting video information
   - Rate/Length: 23,976fps, 3.444 frames
   - Bitrate: 6.379 Kbs
 - [19:12:20] Reencoding: VID_00026, Pass 1 of 1
 - [19:14:05] Video Encode complete
 - [19:14:05] Reencoding audio tracks (if req'd)
 - [19:14:05] Multiplexing M2TS
 - [19:14:08] Extracting A/V streams [VID_00027]
 - [19:14:12] Reencoding: VID_00027 (15 of 18)
 - [19:14:12] Collecting video information
   - Rate/Length: 23,976fps, 3.460 frames
   - Bitrate: 6.330 Kbs
 - [19:14:12] Reencoding: VID_00027, Pass 1 of 1
 - [19:16:09] Video Encode complete
 - [19:16:09] Reencoding audio tracks (if req'd)
 - [19:16:10] Multiplexing M2TS
 - [19:16:13] Extracting A/V streams [VID_00028]
 - [19:16:17] Reencoding: VID_00028 (16 of 18)
 - [19:16:17] Collecting video information
   - Rate/Length: 23,976fps, 3.312 frames
   - Bitrate: 6.291 Kbs
 - [19:16:17] Reencoding: VID_00028, Pass 1 of 1
 - [19:18:02] Video Encode complete
 - [19:18:02] Reencoding audio tracks (if req'd)
 - [19:18:02] Multiplexing M2TS
 - [19:18:06] Extracting A/V streams [VID_00029]
 - [19:18:07] Reencoding: VID_00029 (17 of 18)
 - [19:18:07] Collecting video information
   - Rate/Length: 23,976fps, 1.138 frames
   - Bitrate: 6.470 Kbs
 - [19:18:07] Reencoding: VID_00029, Pass 1 of 1
 - [19:18:42] Video Encode complete
 - [19:18:42] Reencoding audio tracks (if req'd)
 - [19:18:42] Multiplexing M2TS
 - [19:18:44] Extracting A/V streams [VID_00030]
 - [19:18:48] Reencoding: VID_00030 (18 of 18)
 - [19:18:48] Collecting video information
   - Rate/Length: 23,976fps, 2.901 frames
   - Bitrate: 7.043 Kbs
 - [19:18:48] Reencoding: VID_00030, Pass 1 of 1
 - [19:20:21] Video Encode complete
 - [19:20:21] Reencoding audio tracks (if req'd)
 - [19:20:21] Multiplexing M2TS
[19:20:24]PHASE ONE complete
[19:20:24]PHASE TWO - Rebuild Started
 - [19:20:24] Rebuilding BD file Structure
[19:20:47] - Encode and Rebuild complete
 - WORKFILES folder removed.
[19:20:47]JOB: THE_HANGOVER finished.
hasaro is offline   Reply With Quote
Old 4th June 2010, 14:29   #8506  |  Link
@hasaro
Please run INSPECT.EXE and post the results.
Old 4th June 2010, 14:45   #8507  |  Link
Capsbackup
I have one, got old, but refuse to grow up!
Old 4th June 2010, 15:28   #8508  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
I posted some time ago here that I'll create a small tool to check user PC Directshow capabilities of decoding AVC/H.264, MPEG-2 and VC-1, so here it is:
Download link (3MB) (self-extractable 7z exe)
Contains:
.\multiTEST\multiTEST.exe - main executable
.\multiTEST\calclib.dll
.\multiTEST\testdata\test_H264.m2ts
.\multiTEST\testdata\test_MPEG2.m2ts
.\multiTEST\testdata\test_VC1.m2ts
.\multiTEST\testdata\x264.exe
Old 4th June 2010, 15:52   #8509  |  Link
hasaro
This is the report
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3133, Ok
- BD Rebuilder v0.34.0.2, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Old 4th June 2010, 17:14   #8510  |  Link
bassnut
When I was using the PII 940 the settings with BD Rebuilder were allot different then now as they would compare to the High Quality Settings which takes about 8 hrs with the PII 965. I could run a quick run with the PII 940 to see what difference the settings make now with a recode but don't see the point unless someone would like to know what the difference is. The clock speed for my 965 was just a typo yes stock is 3.4GHZ though I am running that at 3.9GHZ now.
Old 4th June 2010, 21:32   #8511  |  Link
DGenerateKane
Former Kanenite
Originally Posted by DarWun View Post
I believe BD-REs that are version 2.0 or greater will play back in the PS3. The PS3 will not recognize version 1.0 BD-RE disks.
I've tried a both a 2.1 Verbatim and now this 2.1 Sony to no avail.
DGenerateKane is offline   Reply With Quote
Old 5th June 2010, 00:35   #8512  |  Link
Did you do a full reformat? I had to with my discs...
Old 5th June 2010, 08:42   #8513  |  Link
tyler durdan
Hi jdobbs,
Wonder if you would let me know what I need to to fix the issue below.
It is on the full disc backup of Bee Movie
"Error in attempt to MKVMERGE.
[16:48:48] - Failed to retrieve audio, aborted"
Damien
tyler durdan is offline   Reply With Quote
Old 5th June 2010, 14:03   #8514  |  Link
Originally Posted by tyler durdan View Post
Hi jdobbs,
Damien
Error messages aren't of much use out-of-context. Can you provide the entire log and also the results of INSPECT.EXE?
Old 5th June 2010, 14:19   #8515  |  Link
tyler durdan
I tried to post the entire log bit it exceeded the amount of characters available.
I see that others have posted a type of insert that allows you to scroll up and down within the post.
Can someone let me know how to do this?
Old 5th June 2010, 14:28   #8516  |  Link
Just put CODE tags around it. See the "#" at the top of the dialog when you are entering text.
Old 5th June 2010, 14:54   #8517  |  Link
tyler durdan
Here we are
- Windows Version: 6.0 [6002]
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[09:06:26] BD Rebuilder v0.34.02 (beta)
  - Source:  BEE_MOVIE
  - Input BD size: 45.93 GB
  - Approximate total content: [03:23:03.904]
  - Target BD size: 24.02 GB
[09:06:26] PHASE ONE, Encoding
 - [09:06:26] Extracting A/V streams [VID_00001]
 - [09:08:12] Reencoding: VID_00001 (1 of 74)
 - [09:08:12] Collecting video information
   - Rate/Length: 29.970fps, 26,405 frames
   - Bitrate: 8,727 Kbs
 - [09:08:12] Reencoding: VID_00001, Pass 1 of 2
 - [09:25:00] Reencoding: VID_00001, Pass 2 of 2
 - [10:17:56] Video Encode complete
 - [10:17:56] Reencoding audio tracks (if req'd)
 - [10:17:56] Multiplexing M2TS
 - [10:18:19] Extracting A/V streams [VID_00002]
 - [10:18:53] Reencoding: VID_00002 (2 of 74)
 - [10:18:53] Collecting video information
   - Rate/Length: 29.970fps, 5,485 frames
   - Bitrate: 9,679 Kbs
 - [10:18:53] Reencoding: VID_00002, Pass 1 of 2
 - [10:22:23] Reencoding: VID_00002, Pass 2 of 2
 - [10:36:42] Video Encode complete
 - [10:36:42] Reencoding audio tracks (if req'd)
 - [10:36:42] Multiplexing M2TS
 - [10:36:47] Extracting A/V streams [VID_00003]
 - [10:37:47] Reencoding: VID_00003 (3 of 74)
 - [10:37:47] Collecting video information
   - Rate/Length: 29.970fps, 13,599 frames
   - Bitrate: 9,685 Kbs
 - [10:37:47] Reencoding: VID_00003, Pass 1 of 2
 - [10:46:55] Reencoding: VID_00003, Pass 2 of 2
 - [11:16:39] Video Encode complete
 - [11:16:39] Reencoding audio tracks (if req'd)
 - [11:16:39] Multiplexing M2TS
 - [11:16:47] Extracting A/V streams [VID_00004]
 - [11:16:58] Reencoding: VID_00004 (4 of 74)
 - [11:16:58] Collecting video information
   - Rate/Length: 29.970fps, 3,987 frames
   - Bitrate: 9,545 Kbs
 - [11:16:58] Reencoding: VID_00004, Pass 1 of 2
 - [11:19:19] Reencoding: VID_00004, Pass 2 of 2
 - [11:28:20] Video Encode complete
 - [11:28:20] Reencoding audio tracks (if req'd)
 - [11:28:20] Multiplexing M2TS
 - [11:28:23] Extracting A/V streams [VID_00005]
 - [11:28:33] Reencoding: VID_00005 (5 of 74)
 - [11:28:33] Collecting video information
   - Rate/Length: 29.970fps, 3,775 frames
   - Bitrate: 9,653 Kbs
 - [11:28:33] Reencoding: VID_00005, Pass 1 of 2
 - [11:30:29] Reencoding: VID_00005, Pass 2 of 2
 - [11:35:08] Video Encode complete
 - [11:35:08] Reencoding audio tracks (if req'd)
 - [11:35:08] Multiplexing M2TS
 - [11:35:10] Extracting A/V streams [VID_00006]
 - [11:35:21] Reencoding: VID_00006 (6 of 74)
 - [11:35:21] Collecting video information
   - Rate/Length: 29.970fps, 3,059 frames
   - Bitrate: 9,675 Kbs
 - [11:35:21] Reencoding: VID_00006, Pass 1 of 2
 - [11:36:54] Reencoding: VID_00006, Pass 2 of 2
 - [11:40:34] Video Encode complete
 - [11:40:34] Reencoding audio tracks (if req'd)
 - [11:40:34] Multiplexing M2TS
 - [11:40:36] Extracting A/V streams [VID_00007]
 - [11:40:42] Reencoding: VID_00007 (7 of 74)
 - [11:40:42] Collecting video information
   - Rate/Length: 29.970fps, 1,992 frames
   - Bitrate: 9,648 Kbs
 - [11:40:42] Reencoding: VID_00007, Pass 1 of 2
 - [11:41:42] Reencoding: VID_00007, Pass 2 of 2
 - [11:43:59] Video Encode complete
 - [11:43:59] Reencoding audio tracks (if req'd)
 - [11:43:59] Multiplexing M2TS
 - [11:44:00] Extracting A/V streams [VID_00008]
 - [11:44:01] Reencoding: VID_00008 (8 of 74)
 - [11:44:01] Collecting video information
   - Rate/Length: 29.970fps, 193 frames
   - Bitrate: 9,526 Kbs
 - [11:44:01] Reencoding: VID_00008, Pass 1 of 2
 - [11:44:08] Reencoding: VID_00008, Pass 2 of 2
 - [11:44:22] Video Encode complete
 - [11:44:22] Reencoding audio tracks (if req'd)
 - [11:44:22] Multiplexing M2TS
 - [11:44:23] Extracting A/V streams [VID_00009]
 - [11:44:35] Reencoding: VID_00009 (9 of 74)
 - [11:44:35] Collecting video information
   - Rate/Length: 29.970fps, 4,707 frames
   - Bitrate: 9,666 Kbs
 - [11:44:35] Reencoding: VID_00009, Pass 1 of 2
 - [11:46:51] Reencoding: VID_00009, Pass 2 of 2
 - [11:52:08] Video Encode complete
 - [11:52:08] Reencoding audio tracks (if req'd)
 - [11:52:08] Multiplexing M2TS
 - [11:52:11] Extracting A/V streams [VID_00010]
 - [11:52:18] Reencoding: VID_00010 (10 of 74)
 - [11:52:18] Collecting video information
   - Rate/Length: 29.970fps, 2,637 frames
   - Bitrate: 9,638 Kbs
 - [11:52:18] Reencoding: VID_00010, Pass 1 of 2
 - [11:53:33] Reencoding: VID_00010, Pass 2 of 2
 - [11:56:31] Video Encode complete
 - [11:56:31] Reencoding audio tracks (if req'd)
 - [11:56:31] Multiplexing M2TS
 - [11:56:32] Extracting A/V streams [VID_00011]
 - [11:56:44] Reencoding: VID_00011 (11 of 74)
 - [11:56:44] Collecting video information
   - Rate/Length: 29.970fps, 4,813 frames
   - Bitrate: 9,610 Kbs
 - [11:56:44] Reencoding: VID_00011, Pass 1 of 2
 - [11:59:00] Reencoding: VID_00011, Pass 2 of 2
 - [12:04:05] Video Encode complete
 - [12:04:05] Reencoding audio tracks (if req'd)
 - [12:04:05] Multiplexing M2TS
 - [12:04:08] Extracting A/V streams [VID_00012]
 - [12:04:30] Reencoding: VID_00012 (12 of 74)
 - [12:04:30] Collecting video information
   - Rate/Length: 29.970fps, 6,774 frames
   - Bitrate: 9,649 Kbs
 - [12:04:30] Reencoding: VID_00012, Pass 1 of 2
 - [12:07:41] Reencoding: VID_00012, Pass 2 of 2
 - [12:14:57] Video Encode complete
 - [12:14:57] Reencoding audio tracks (if req'd)
 - [12:14:57] Multiplexing M2TS
 - [12:15:01] Extracting A/V streams [VID_00013]
 - [12:15:11] Reencoding: VID_00013 (13 of 74)
 - [12:15:11] Collecting video information
   - Rate/Length: 29.970fps, 3,920 frames
   - Bitrate: 9,634 Kbs
 - [12:15:11] Reencoding: VID_00013, Pass 1 of 2
 - [12:17:05] Reencoding: VID_00013, Pass 2 of 2
 - [12:21:25] Video Encode complete
 - [12:21:25] Reencoding audio tracks (if req'd)
 - [12:21:25] Multiplexing M2TS
 - [12:21:27] Extracting A/V streams [VID_00014]
 - [12:21:37] Reencoding: VID_00014 (14 of 74)
 - [12:21:37] Collecting video information
   - Rate/Length: 29.970fps, 3,319 frames
   - Bitrate: 9,620 Kbs
 - [12:21:37] Reencoding: VID_00014, Pass 1 of 2
 - [12:23:11] Reencoding: VID_00014, Pass 2 of 2
 - [12:27:08] Video Encode complete
 - [12:27:08] Reencoding audio tracks (if req'd)
 - [12:27:08] Multiplexing M2TS
 - [12:27:10] Extracting A/V streams [VID_00015]
 - [12:27:10] Reencoding: VID_00015 (15 of 74)
 - [12:27:10] Collecting video information
   - Rate/Length: 29.970fps, 181 frames
   - Bitrate: 629 Kbs
 - [12:27:10] Reencoding: VID_00015, Pass 1 of 2
 - [12:27:15] Reencoding: VID_00015, Pass 2 of 2
 - [12:27:19] Video Encode complete
 - [12:27:19] Reencoding audio tracks (if req'd)
 - [12:27:19] Multiplexing M2TS
 - [12:27:19] Extracting A/V streams [VID_00016]
 - [12:27:26] Reencoding: VID_00016 (16 of 74)
 - [12:27:26] Collecting video information
   - Rate/Length: 29.970fps, 2,743 frames
   - Bitrate: 9,701 Kbs
 - [12:27:26] Reencoding: VID_00016, Pass 1 of 2
 - [12:28:56] Reencoding: VID_00016, Pass 2 of 2
 - [12:35:17] Video Encode complete
 - [12:35:17] Reencoding audio tracks (if req'd)
 - [12:35:17] Multiplexing M2TS
 - [12:35:18] Extracting A/V streams [VID_00017]
 - [12:35:25] Reencoding: VID_00017 (17 of 74)
 - [12:35:25] Collecting video information
   - Rate/Length: 29.970fps, 2,372 frames
   - Bitrate: 9,665 Kbs
 - [12:35:25] Reencoding: VID_00017, Pass 1 of 2
 - [12:36:47] Reencoding: VID_00017, Pass 2 of 2
 - [12:41:51] Video Encode complete
 - [12:41:51] Reencoding audio tracks (if req'd)
 - [12:41:51] Multiplexing M2TS
 - [12:41:53] Extracting A/V streams [VID_00018]
 - [12:42:02] Reencoding: VID_00018 (18 of 74)
 - [12:42:02] Collecting video information
   - Rate/Length: 29.970fps, 2,525 frames
   - Bitrate: 9,680 Kbs
 - [12:42:02] Reencoding: VID_00018, Pass 1 of 2
 - [12:43:29] Reencoding: VID_00018, Pass 2 of 2
 - [12:49:39] Video Encode complete
 - [12:49:39] Reencoding audio tracks (if req'd)
 - [12:49:39] Multiplexing M2TS
 - [12:49:41] Extracting A/V streams [VID_00019]
 - [12:49:48] Reencoding: VID_00019 (19 of 74)
 - [12:49:48] Collecting video information
   - Rate/Length: 29.970fps, 2,746 frames
   - Bitrate: 9,672 Kbs
 - [12:49:48] Reencoding: VID_00019, Pass 1 of 2
 - [12:51:33] Reencoding: VID_00019, Pass 2 of 2
 - [12:58:10] Video Encode complete
 - [12:58:10] Reencoding audio tracks (if req'd)
 - [12:58:10] Multiplexing M2TS
 - [12:58:12] Extracting A/V streams [VID_00020]
 - [12:58:19] Reencoding: VID_00020 (20 of 74)
 - [12:58:19] Collecting video information
   - Rate/Length: 29.970fps, 2,759 frames
   - Bitrate: 9,633 Kbs
 - [12:58:19] Reencoding: VID_00020, Pass 1 of 2
 - [12:59:56] Reencoding: VID_00020, Pass 2 of 2
 - [13:06:38] Video Encode complete
 - [13:06:38] Reencoding audio tracks (if req'd)
 - [13:06:38] Multiplexing M2TS
 - [13:06:40] Extracting A/V streams [VID_00021]
 - [13:06:47] Reencoding: VID_00021 (21 of 74)
 - [13:06:47] Collecting video information
 - [13:06:47] Reencoding: VID_00021, Pass 1 of 2
 - [13:08:13] Reencoding: VID_00021, Pass 2 of 2
 - [13:15:01] Video Encode complete
 - [13:15:01] Reencoding audio tracks (if req'd)
 - [13:15:01] Multiplexing M2TS
 - [13:15:03] Extracting A/V streams [VID_00022]
 - [13:15:10] Reencoding: VID_00022 (22 of 74)
 - [13:15:10] Collecting video information
   - Rate/Length: 29.970fps, 2,400 frames
   - Bitrate: 9,639 Kbs
 - [13:15:10] Reencoding: VID_00022, Pass 1 of 2
 - [13:16:35] Reencoding: VID_00022, Pass 2 of 2
 - [13:20:51] Video Encode complete
 - [13:20:51] Reencoding audio tracks (if req'd)
 - [13:20:51] Multiplexing M2TS
 - [13:20:53] Extracting A/V streams [VID_00023]
 - [13:21:00] Reencoding: VID_00023 (23 of 74)
 - [13:21:00] Collecting video information
   - Rate/Length: 29.970fps, 2,550 frames
   - Bitrate: 9,661 Kbs
 - [13:21:00] Reencoding: VID_00023, Pass 1 of 2
 - [13:22:26] Reencoding: VID_00023, Pass 2 of 2
 - [13:26:41] Video Encode complete
 - [13:26:41] Reencoding audio tracks (if req'd)
 - [13:26:41] Multiplexing M2TS
 - [13:26:43] Extracting A/V streams [VID_00024]
 - [13:26:54] Reencoding: VID_00024 (24 of 74)
 - [13:26:54] Collecting video information
   - Rate/Length: 29.970fps, 2,423 frames
   - Bitrate: 9,621 Kbs
 - [13:26:54] Reencoding: VID_00024, Pass 1 of 2
 - [13:28:13] Reencoding: VID_00024, Pass 2 of 2
 - [13:32:26] Video Encode complete
 - [13:32:26] Reencoding audio tracks (if req'd)
 - [13:32:26] Multiplexing M2TS
      - [15:49:25] Extracting A/V streams [VID_00100]
 - [15:49:31] Reencoding: VID_00100 (66 of 74)
 - [15:49:31] Collecting video information
   - Rate/Length: 29.970fps, 1,765 frames
   - Bitrate: 8,930 Kbs
 - [15:49:31] Reencoding: VID_00100, Pass 1 of 2
 - [15:50:31] Reencoding: VID_00100, Pass 2 of 2
 - [15:54:18] Video Encode complete
 - [15:54:18] Reencoding audio tracks (if req'd)
 - [15:54:18] Multiplexing M2TS
 - [15:54:19] Extracting A/V streams [VID_00237]
 - [15:54:24] Reencoding: VID_00237 (67 of 74)
 - [15:54:24] Collecting video information
   - Source Video: MPEG-2, 1920x1080
   - Rate/Length: 23.976fps, 1,601 frames
   - Bitrate: 7,056 Kbs
 - [15:54:24] Reencoding: VID_00237, Pass 1 of 2
 - [15:55:07] Reencoding: VID_00237, Pass 2 of 2
 - [15:56:10] Video Encode complete
 - [15:56:10] Reencoding audio tracks (if req'd)
 - [15:56:10] Multiplexing M2TS
 - [15:56:11] Extracting A/V streams [VID_00238]
 - [15:56:11] Reencoding: VID_00238 (68 of 74)
 - [15:56:11] Collecting video information
   - Rate/Length: 23.976fps, 25 frames
   - Bitrate: 8,408 Kbs
 - [15:56:11] Reencoding: VID_00238, Pass 1 of 2
 - [15:56:13] Reencoding: VID_00238, Pass 2 of 2
 - [15:56:16] Video Encode complete
 - [15:56:16] Reencoding audio tracks (if req'd)
 - [15:56:16] Multiplexing M2TS
 - [15:56:16] Extracting A/V streams [VID_00239]
 - [15:56:20] Reencoding: VID_00239 (69 of 74)
 - [15:56:20] Collecting video information
   - Bitrate: 5,885 Kbs
 - [15:56:20] Reencoding: VID_00239, Pass 1 of 2
 - [15:57:03] Reencoding: VID_00239, Pass 2 of 2
 - [15:58:02] Video Encode complete
 - [15:58:02] Reencoding audio tracks (if req'd)
 - [15:58:02] Multiplexing M2TS
 - [15:58:03] Extracting A/V streams [VID_00240]
 - [15:58:04] Reencoding: VID_00240 (70 of 74)
 - [15:58:04] Collecting video information
   - Rate/Length: 23.976fps, 50 frames
   - Bitrate: 9,302 Kbs
 - [15:58:04] Reencoding: VID_00240, Pass 1 of 2
 - [15:58:06] Reencoding: VID_00240, Pass 2 of 2
 - [15:58:11] Video Encode complete
 - [15:58:11] Reencoding audio tracks (if req'd)
 - [15:58:11] Multiplexing M2TS
 - [15:58:12] Extracting A/V streams [VID_00241]
 - [15:58:16] Reencoding: VID_00241 (71 of 74)
 - [15:58:16] Collecting video information
   - Bitrate: 8,507 Kbs
 - [15:58:17] Reencoding: VID_00241, Pass 1 of 2
 - [15:59:03] Reencoding: VID_00241, Pass 2 of 2
 - [16:00:20] Video Encode complete
 - [16:00:20] Reencoding audio tracks (if req'd)
 - [16:00:20] Multiplexing M2TS
 - [16:00:21] Extracting A/V streams [VID_00243]
 - [16:00:54] Reencoding: VID_00243 (72 of 74)
 - [16:00:54] Collecting video information
   - Rate/Length: 29.970fps, 12,857 frames
   - Bitrate: 8,757 Kbs
 - [16:00:54] Reencoding: VID_00243, Pass 1 of 2
 - [16:08:34] Reencoding: VID_00243, Pass 2 of 2
 - [16:32:43] Video Encode complete
 - [16:32:43] Reencoding audio tracks (if req'd)
 - [16:32:43] Multiplexing M2TS
 - [16:32:50] Extracting A/V streams [VID_00244]
 - Error in attempt to MKVMERGE.
I still had to edit out some of the log(I had 35000 characters and they only allow 16000) but hopefully you get the idea
Thanks for your assistance
Old 5th June 2010, 18:01   #8518  |  Link
Race Guy
Also, (assuming you use ImgBurn) go to:
Tools >> Settings >> Write Page 1 & make sure these are checked:
DVD RAM/BD-RE Fast Write
Prefer Format With Full Cert
Prefer Format Without Spare Areas
Prefer Properly Formatted Discs
Prefer Format Size "Maximum"
I'm not sure how many of those are default? If you don't check "fast write", you'll only burn maybe 1x. With it checked, my LG burns at 2.3x. And, if you don't check "without spare areas" (& maybe "Maximum"??) you'll end up with a disc that is undersize (I think it was 1.5GB??) compared to a BD-R.
Race Guy is offline   Reply With Quote
Old 5th June 2010, 20:49   #8519  |  Link
8ternity
8ternity's Avatar
HI jdobbs:
Ohhh, i just saw updates! LOL. im with the version v33.07! Still having no troubles. I have installed ffdshow 3466 version becuase ripbot264 inspect for a newer version. If i have issues, i install recommanded version.
My post is about my system. I personally got an AMD Phenom II X4 940 3.01GHZ Black edition and also 8GB DDR2 dual channel installation (2x2GB DDR x2) and with windows 7 64bit edition, and it's rocks!!!!
If you take one quad-cores CPU, i recommand you to BUY an CORSAIR H50 Liquid serie CPU cooling for less that 100$ us and it make a huge difference for stability, lower tempeture, also i never reach max tempeture anymore. 10 degre celcious lower in 100% used, 4 cores at 100%!!
Your not obligated to purchass the newest processor! If you have an AM2+ motherboard, i recommand you to just change the processor. It's what i've done. I sell my AMD dual core 6400+ AM2 and my motherboard was compatible for AM2+ and AM3 new processor.
It's sure you can have an better processor, but it cost me just 145$ for a great upgrade! Newer processor their are all the time expensive.
Anyways, AMD will release Six-Cores soon. They are not accessible for now.
If you made the upgrade, you will never get unsatisfy! *sorry for my english*
Old 5th June 2010, 21:28   #8520  |  Link
chudm
in fact they are available, you can bought one of those x6 on amazon for only 200$ great little monster
chudm is offline   Reply With Quote
