Old 26th November 2010, 21:12   #10301  |  Link
Originally Posted by micflair View Post
I cant find anything in my temp or bd-rebuilder install folder called .inf or with the extension of .inf.. am I having a blonde moment here guys..
The INI is in the BD Rebuilder folder. The INF is in the working folder. It's gotta' be there (unless it was deleted) -- BD Rebuilder won't work without it.
Old 26th November 2010, 22:39   #10302  |  Link
micflair
ok im with it now.. heres the inf..
[Status]
LABEL=AN_IDIOT_ABROAD_D1
VERSION=v0.36.04 (beta)
SOURCE_SIZE=43187173778
SOURCE_VIDEO_SIZE=43060180992
TARGET_SIZE=24641536000
REDUCTION=.569308875375012
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
QUICK=0
ENCODE_STEP=0
COMPLETED=7
REBUILD_COMPLETE=1
[00000]
AUDIO=1
PGS=1
M2TS_TARGET=5451307410
RATE=15251
NSTART=27000000
NEND=144449280
NSIZE=5258207232
FLINK=-1
MLINK=0
[00001]
AUDIO=1
PGS=1
M2TS_TARGET=5426777102
RATE=15250
NSTART=27000000
NEND=143926560
NSIZE=5225508864
FLINK=-1
MLINK=0
[00002]
AUDIO=1
PGS=1
M2TS_TARGET=5393295837
RATE=15269
NSTART=27000000
NEND=143032320
NSIZE=5212084224
FLINK=-1
MLINK=0
[00003]
AUDIO=1
PGS=1
M2TS_TARGET=5406328766
RATE=15252
NSTART=27000000
NEND=143468640
NSIZE=5228132352
FLINK=0
MLINK=0
[00006]
AUDIO=1
PGS=1
M2TS_TARGET=289792027
RATE=17122
NSTART=27000000
NEND=32594400
NSIZE=286212096
FLINK=0
MLINK=0
[00012]
AUDIO=1
PGS=1
M2TS_TARGET=69946181
RATE=17086
NSTART=27000000
NEND=28351800
NSIZE=70311936
FLINK=0
MLINK=0
[00018]
AUDIO=1
PGS=1
M2TS_TARGET=2477095891
RATE=13166
NSTART=27000000
NEND=88551360
NSIZE=2409492480
FLINK=0
MLINK=0
looks like its written in russian to me.. lol
micflair is offline   Reply With Quote
Old 26th November 2010, 23:07   #10303  |  Link
micflair
and heres the other..
[Options]
VERSION=0.36.0.4
MODE=0
ENCODE_QUALITY=5
ONEPASS_ENCODING=2
AUTO_QUALITY=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=1
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23450
TARGET_SIZE=23500
PRIORITY_CLASS=0
QUICK_EXTRAS=0
[Paths]
WORKING_PATH=M:\BD\
SOURCE_PATH=E:\
Old 26th November 2010, 23:15   #10304  |  Link
Capsbackup
@micflair;
This is not present in your log above, as you stated it was earlier, which is why your backup keeps reencoding the menu files and anything below 600MB.
Originally Posted by Capsbackup View Post
You need to make sure you put the wording in correctly and in the right place. Example:
Below [Options]
MIN_M2TS_SIZE=600
If you check BD-RB files to reencode from the list, the files less than this size will not be present.
So copy: MIN_M2TS_SIZE=600 just below the [Options] file and save it, then start BD-RB again. You should see less files to reencode in the BD-RB list.
Old 27th November 2010, 02:05   #10305  |  Link
worknstiff
I was just wondering if anyone else has run into this prob. I recently got a new Bluray player BDT350 and it plays most of my backup BD_RB disks just fine, but not all. It seems it does not like any of the disks that were created using BD_Rebuilder from about 6 months ago to over a year ago. They play on the BDT350 but don't have any video output, but they play just fine on my old DMP-BD35. There is really no rhyme or reason I can come up with that makes one disk play and the other one not unless there is something in the different versions of BD_RD that has changed. (I have the Startrek movies and none of the 1to6 older disks play but the Next Generation ones do and all were done around the same time.) I am doing a replacement encode now to see if I can use the new index structure to fix the disk and make it playable.
Old 27th November 2010, 10:53   #10306  |  Link
rilopes
Use the defaults, they are set as "default" precisely because they are the best settings to use.
Thanks jdobbs !
I tried default settings, but changed a little bit...and it worked ( logs attached ). Burned to a BD-RE and played in my Samsung BD-3600 player.
Toy Story 3 movie has some frames which are specific for each language. So, every time these frames are shown, the image pauses ( not sound ) and is played again seconds later from exactly same point.
I remember some Disney DVD's where it happened too.
May be a BD-rebuilder bug ?
rilopes is offline   Reply With Quote
Old 27th November 2010, 18:27   #10307  |  Link
omegaman7
omegaman7's Avatar
Just encoded "The expendables"(BD-25) yesterday. Longest encode thus far. 13+ hours at High quality (Default) with quick encode for extras. I have a feeling it's gonna be a while before we tame that down to under an hour average :S
Jdobbs, you said you have a quad, I'm curious how yours fairs? My Phenom 940 @3.5Ghz is my X264 slave How long did your backup of "The Expendables" take? I'm planning a new build in february. Wondering if it's really worth it...
Last edited by omegaman7; 27th November 2010 at 18:44. Reason: additional explanation
Old 27th November 2010, 18:41   #10308  |  Link
DrKajun
Whats the "FULL_AVCHD" switch in the INI do? If I set this to 1, will it do a Full Backup with strict AVCHD?
DrKajun is offline   Reply With Quote
Old 28th November 2010, 00:23   #10309  |  Link
??? There is no switch called "FULL_AVCHD"...
Old 28th November 2010, 00:24   #10310  |  Link
I haven't done "The Expendables" yet. When I do it, I'll let you know how long it took.
Old 28th November 2010, 02:31   #10311  |  Link
Capsbackup
I think DrKajun might be refering to the BDREBUILDER configuration settings. From my BD-RB folder:
[Options]
MIN_M2TS_SIZE=100
KEEP_MBTREE=1
MODE=0
ENCODE_QUALITY=2
ONEPASS_ENCODING=2
AUTO_QUALITY=0
QUICK_EXTRAS=0
TARGET_SIZE=4500
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DEINTERLACE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=0
REMOVE_WORKFILES=0
FULL_AVCHD=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=4525
REMOVE_OUTPUT=0
OPEN_GOP=1
USE_FILTERS=0
MOVIE_ONLY_LOOP=1
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=0
VERSION=0.36.0.4
ASSUME_DVD_PAL=0
[Paths]
SOURCE_PATH=G:\BD RIPS\
WORKING_PATH=G:\
Old 28th November 2010, 02:58   #10312  |  Link
setarip_old
setarip_old's Avatar
@omegaman7
Hi!
I believe that the reason "The Expendables" takes so long to process is that it contains an ENTIRE second copy of the movie as the "BonusView", modified for PIP with commentary (Does not appear to use seamless branching), as well as extensive commentary and a good number of extras.
{My guess is, that when the producers realized how poor the actual movie is, they tried to add as many distractions as possible ;>})
Old 28th November 2010, 04:24   #10313  |  Link
I see why it takes so long -- there's 5 1/2 hours of video on that disc... I'm doing it now -- I'll let you know how long it takes.
Old 28th November 2010, 04:29   #10314  |  Link
@Capsbackup
??? That's probably something left over from early testing. But it certainly has no affect now. BD Rebuilder never reads the value.
Old 28th November 2010, 05:14   #10315  |  Link
audit13
Sound is out of sync with picture
I just want to start off by saying this is an awesome program.
I compressed Splice and English Patient (movie only, dvd-9, default settings) and the audio was out of sync with the video at the end of the compression process. There seems to be no rhyme or reason because other movies that were compressed with the same settings were perfect.
I recompressed Splice using the same settings and it turned out fine. I'm inthe process of re-compressing English Patient.
Both movies had DTS-HD soundtracks.
Any ideas as to why this sometimes happens?
audit13 is offline   Reply With Quote
Old 28th November 2010, 05:48   #10316  |  Link
DrKajun
[Options]
FULL_AVCHD=0
Correct, was wonder what this switch in the INI does?
Old 28th November 2010, 05:52   #10317  |  Link
Capsbackup
What are you playing the backups with, software player or standalone?
Old 28th November 2010, 07:06   #10318  |  Link
It's never happened to me... but if you did it with a version prior to 36.3 it could be this:
- Corrected an error in which audio streams that
  contained delays, and were not in the initial
  (SETUP defined) list of selections, could (if
  later selected from the streams list) be muxed
  out-of-sync.
Old 28th November 2010, 15:22   #10319  |  Link
I'm running a Phenom II X4 945 overclocked to 3.4Ghz running on an older AMD2+ MB with 8GB of DDR2 memory. It took 7 hrs and 4 min to complete "The Expendables".
Not bad, actually, for a disc with 5 1/2 hours of content.
Old 28th November 2010, 15:23   #10320  |  Link
worknstiff
FYI: Regarding my Panasonic DMP-BDT350 (Quote: Bluray player BDT350 plays most of my backup BD_RB disks just fine, but not all.) Don't know if there is an easy fix for this but just in case anyone else has this problem, the difference between the unplayable disks and the newest disks processed by BD_Rebuilder are that they are High Profile 4.0 instead of High Profile 4.1 that was used earlier. I wonder when this was changed and why? I wonder why my older BD35 can play both and the BDT-350 plays it but with no video output. It is weird because you would think the BDT350 would like the higher bitrate allowed by the 4.1 profile, but I'm sure jdobbs must have had a good reason to go back to 4.0 from the older 4.1 profile. I wish there was an easy fix to make these older disks playable without recoding and burning all of them. At any rate thanks jdobbs for the great program, even if there are a few glitches here and there. It is a work in progress after all.
