Old 10th November 2021, 17:19   #1  |  Link
YaBoyShredderson
What happens when my video exceeds the maximum bitrate of the tier and level?
Im using staxrip to encode using x265, and havent left the tier on auto and high on undefined. Its a 4k60 video, and staxrip automatically chose level 5.0 main tier, but its bitrate came out at 65mbits, using crf 18. How does that work? Should i define a tier and?
YaBoyShredderson is offline   Reply With Quote
Old 11th November 2021, 04:53   #2  |  Link
RanmaCanada
CRF will use as much bitrate as it deems fit. If you want a lower bitrate, you are going to have to tell it so. There were some posts talking about this in the sub.
RanmaCanada is offline   Reply With Quote
Old 15th November 2021, 05:57   #3  |  Link
benwaggoner
If you don't specify a level, x265 will default to the lowest level that is compatible with your frame size and fps, and then set --vbv-bufsize and --vbv-maxrate as appropriate (and other parameters).
If your bitrate exceeds main tier, perhaps it will increase it to high tier if you didn't specify that.
If you know what decoders you are targeting, it's better to specify that actual level. And I'd be careful about specifying High Tier for much of anything consumer-oriented. UHD Blu-ray is one exception, as it supports a much higher bitrate than Level 5.1.
Ben Waggoner
My Compression Book
Old 15th November 2021, 08:59   #4  |  Link
excellentswordfight
Lost my old account :(
Not sure if you have experience with any custom builds, but for me x265 has never set --vbv-bufsize and --vbv-maxrate when level is auto selected, its only set when level is manually specified. It will also default to high tier (if available) when level is specified & tier is not.
Whats a bit odd for TS though that it used level 5 for 2160p60, I didnt think that was valid for level 5. Did you check the encoded file as well TS? Maybe thats just an UI bug in staxrip.
excellentswordfight is offline   Reply With Quote
Old 15th November 2021, 10:24   #5  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Interesting. Yeah, I think 5.0 is limited to 30fps only and you gotta go to 5.1 for 50fps and 60fps. Does x265 actually allow people to encode it that way? O_O
Old 15th November 2021, 16:01   #6  |  Link
excellentswordfight
No, normally it doesnt, encoding fails and exits when using an level that isnt valid for that framesize/rate
Old 16th November 2021, 18:09   #7  |  Link
benwaggoner
Perhaps an issue with the custom build build being used?
Mainline x265 has always failed or reduced parameters if I asked it to violate profile @ level @ tier restrictions.
Ben Waggoner
My Compression Book
Old 16th November 2021, 18:49   #8  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Yeah that's what I thought
Must be a custom_build issue then. I would have been surprised if the mainline x265 actually allowed to encode such a stream eheheheh
Old 29th November 2021, 16:04   #9  |  Link
Balling
But nvenc does not. LOL. https://trac.ffmpeg.org/ticket/6476#comment:12
Balling is offline   Reply With Quote
bitrate, level, staxrip, tier, x265
