Old 19th December 2019, 16:22   #21  |  Link
StainlessS
StainlessS's Avatar
Wait, does that mean plugins which make use of arrays won't work on recent versions of AviSynth? What makes it incompatible?
I believe they may be commented out in avs+ source [not sure], but only for script, not plugins.
[ie arrays not yet implemented for scripts, you is ok for plugs, they have always worked, cannot be implemented for script so long as v2.5 interface is supported for plugins (or something like that)]
Some Links (Search on "array", in Avisynth Devs forum, user Pinterf, posts only):-
(in reverse order as they appear in search)
http://forum.doom9.org/showthread.ph...58#post1860458
http://forum.doom9.org/showthread.ph...60#post1824560
remove script array (new AVSValue schema) feature, cannot make it compatible with Invoke from v2.5 plugins until I figure out a workaround or such plugins would slowly distinct. <sniff> <sniff>
http://forum.doom9.org/showthread.ph...25#post1789325
http://forum.doom9.org/showthread.ph...32#post1788632
http://forum.doom9.org/showthread.ph...29#post1788529
http://forum.doom9.org/showthread.ph...18#post1785318
http://forum.doom9.org/showthread.ph...53#post1785253
http://forum.doom9.org/showthread.ph...79#post1784879
http://forum.doom9.org/showthread.ph...19#post1784619
http://forum.doom9.org/showthread.ph...32#post1784532
http://forum.doom9.org/showthread.ph...81#post1784081
It turned out that it is a filter using avisynth 2.5 plugin interface.
I'm not happy, now I have a deeper clue about the caveats of keeping the backward compatibility with that what is called "baked code".
In its current form I am not able to keep the compatibility between avisynth 2.5 interface and my new AVSValue handling schema. The problem affects arrays (and such, the filter parameter passing). Although the array creation is transparent when 2.6 interface is used and automatically uses the new mechanism for creating and copying AVSValue types, but plugins using "baked code" avs 2.5 interface are not knowing about the feature and use the array creation codes hardcoded in the 2.5 interface.
And since I simply not able to check, what kind of interface made a call to ScriptEnvironment::Invoke, I have to revert that array feature. O.K. having script arrays are only a nice addition to the language but there was quite a bit of work with this feature.
So it seems that I have to revert my nice new array mechanism, even from the dev version of my builds. As there are still some plugins out there with the 2.5 interface, I cannot make avs+ incompatible with them and cause users inconveniance.
http://forum.doom9.org/showthread.ph...52#post1789252
Above links may or may not be relevant [I skipped a few links that seemed not relevant].
I sometimes post sober.
Old 20th December 2019, 12:18   #22  |  Link
vcmohan
Originally Posted by wonkey_monkey View Post
They can if a variable of another type appears between them. I did this on my ColourWarp plugin so you can specify non-clip-specific points first, then the clips, then the clip-specific points.
I am under the impression that since the default input clip is 'last', it always must be specified first. still can a string like
.*c.+[dat]i.*
be used?
mohan
my plugins are now hosted here
vcmohan is offline   Reply With Quote
Old 20th December 2019, 12:28   #23  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Not sure about that. I would expect the "last" clip to be matched on the ".*", not on the "c". In fact everything will probably end up in the first array until it encounters a named parameter.
My filter still uses the default first input clip, but it allows you to specify further clips as colour sources. I probably did something like
ci*c*i*
Old 20th December 2019, 12:42   #24  |  Link
pinterf
Arrays, as they appear for plugin writers are working fine, no change in them. Some years ago I was experimenting, made an attempt to support arrays in the script level as well. e.g.
color = [255, 233, 101]
or
values = [[0,"black"],[255,"white"]]
color = values[0,0]
But it broke compatibility (=crashed ) - I think plugins using avs 2.5 "baked code" concept and even avspmod was not compatible with it. The remnants are still there in my source under NEW_AVSVALUE define.
pinterf is offline   Reply With Quote
Old 20th December 2019, 12:42   #25  |  Link
StainlessS
StainlessS's Avatar
ci*c*i*
+1, yes.
EDIT: [After seeing Pinterf post above] Perhaps v2.5 support should be dropped soon/immediately. [I would be happy to do same].
Old 20th December 2019, 12:48   #26  |  Link
Groucho2004
Seriously? Can you imagine the scream of a million voices of those who use 2.5 plugs? Me included?
Groucho's Avisynth Stuff
Old 20th December 2019, 12:50   #27  |  Link
StainlessS
StainlessS's Avatar
Who cares bout them, or you !
EDIT: Can still provide v2.5 plug, and separate v2.6 plug, v2.58 will still be able to use existing 2.5 plugs.
That there bullet will one day need biting. [whenever you do it, some will not like it]
Old 20th December 2019, 13:05   #28  |  Link
Groucho2004
1. I don't want to use 2.5.8, I want to use AVS+.
2. There are 2.5 plugs for which there is no source code.
Old 20th December 2019, 13:05   #29  |  Link
StainlessS
StainlessS's Avatar
We need a list of 'invaluable' v2.5 plugins that are not yet converted to v2.6 interface, and some that will take on conversions, I am prepared to help in this where I am able.
And list of v2.5 invaluable plugs for which there is no source. [Some/Most LaTo will likely be in this list]
EDIT: Entire Gavino Grunt compatibility in avs+ would be a good idea (where not already implemented).
Both Grunt and GScript should have been adopted way back in Avs v2.60 Standard, as suggested by some.
Old 20th December 2019, 16:03   #30  |  Link
real.finder
or
color = values[0,0]
can it be like http://avisynth.nl/index.php/RemapFrames#Usage_5 to fix this?
edit: or the same way that used to load 2.0 plugins in avs 2.5 (by LoadPluginEx.dll, so it will be LoadPlugin25.dll or something)?
+ aside from that, still waiting for expr changes
See My Avisynth Stuff
Old 20th December 2019, 17:00   #31  |  Link
qyot27
qyot27's Avatar
'Remnants' meaning that it was just shuffled behind the define so it wouldn't cause compatibility issues, or that even if it is active, it's incomplete (per 2.6+, where it would presumably work)?
I ask, because I actually was considering having NEW_AVSVALUE active for Linux/OSX builds (at least once I actually get libavisynth.so in a working* state). We don't have to worry about retaining compatibility with 2.5 plugins on those platforms because there's practically none that were ported while AvxSynth was a thing. Like, there's maybe 5 in total.
*it builds, but because of some of the Win32-specific things that had to be disabled on non-Windows, it currently fails to load. And I haven't reconciled the changes enough so that it doesn't impede MSVC's ability to build the codebase on Windows.
