Old 28th May 2021, 14:10   #21  |  Link
pinterf
Originally Posted by Dogway View Post
That makes sense now. I thought it only was the convolution types. I also noticed chaining removegrain (or Dither_boxfilter) is very fast, whereas Expr() suffers a lot, probably due what you explained. So processing in 32-bit float would tell another story.
These masktools2 filters has no simd versions, probably because they do generic stuff.
mt_convolution, mt_gradient, mt_mappedblur, mt_hysteresis
pinterf is offline   Reply With Quote
Old 28th May 2021, 14:16   #22  |  Link
GMJCZP
GMJCZP's Avatar
I am trying to substitute Overlay for ex_blend in my RescueFrame script, and regardless of whether I use 8 bits or not, I am getting the following error message:
"Expr: All inputs must have the same number of planes and the same dimensions, subsampling included."
If I use the only ConverttoYv12 that works I only get a black image.
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 28th May 2021, 14:40   #23  |  Link
Dogway
@pinterf: mt_hysteresis was one I doubted to include or not. I will have a look.
@GMJCZP: I checked it but what is it blending? it looks like blending with opacity of 1.0, basically frame replacing. There are tools already for that like ReplaceFramesSimple or Prune by StainlessS. ex_blend needs clips a and b to be the same format or it will error out.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 28th May 2021, 18:04   #24  |  Link
GMJCZP
GMJCZP's Avatar
Don't Overlay and ex_blend have identical behavior?
By law and justice!
GMJCZP's Arsenal
Old 30th May 2021, 19:49   #25  |  Link
Dogway
Updated ExTools to improve performance for ex_xxpand() by decoupling the thresholding (now just 6% shy from mt_expand() and with only SSSE3!!!) .
Also improved ex_blur() performance when rad>1 by precomputing final pixel weights.
Finally added the LUT expr family for easier porting the code and UV plane handling.
I also had time to sanitize SMDegrain, still not complete sanitation but near (v3.2.0d RC1). Removed old avs, Dither and YUY2 support. Ported masktools2 to ExTools in a "MIX" fashion and fixed a few small issues. Finally updated code to new avs+ grammar and properly formatted it.
By the way, Transforms Pack is also near to v1.0 final, it's advancing nice, 32-bit support, 2020CL and NCL conversion, and bugfixes.
Old 31st May 2021, 00:09   #26  |  Link
kedautinh12
Old 31st May 2021, 09:45   #27  |  Link
tormento
Acid fr0g
tormento's Avatar
Wow!
Considering it is just the script I use plain always, big thanks!
@turment on Telegram
Old 31st May 2021, 13:17   #28  |  Link
Dogway
Yes, it should be a bit faster. In my tests (check post#2) it performs 0.150fps better which translates into shaving 30 mins in encoding speed for a full feature. In any case the major bottleneck in SMDegrain is mvtools itself. I also plan to add an UHD mode, to try to make it faster in such cases.
Old 31st May 2021, 14:33   #29  |  Link
GMJCZP
GMJCZP's Avatar
Your function does not accept ConvertToYuv24(), which does accept Overlay, and could help mitigate at least the effects of conversions.
By law and justice!
GMJCZP's Arsenal
Old 31st May 2021, 15:08   #30  |  Link
Dogway
Sorry I don't understand well. It works with YV24 on my side, how is your script?
It's not a 1:1 port of Overlay(), my blending modes matches Photoshop's.
Old 31st May 2021, 16:48   #31  |  Link
GMJCZP
GMJCZP's Avatar
In my signature.
Therein lies the problem, I cannot achieve 100% emulation. RescueFrame calls Overlay to replace one or a group of frames with an image and so far I have not succeeded with Ex_blend.
By law and justice!
GMJCZP's Arsenal
Old 2nd June 2021, 10:57   #32  |  Link
tormento
Acid fr0g
tormento's Avatar
As I wrote in other thread, I dream of MVTools2 on CUDA.
Old 2nd June 2021, 16:48   #33  |  Link
tormento
Acid fr0g
tormento's Avatar
My current syntax with realfinder version is
SMDegrain (tr=4, thSAD=400, refinemotion=false, n16_out=true, mode=0, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true)
to have a 16 bit output from 8 bit input.
Do you plan to introduce a similar flag or is it sufficient to delete it and add ConvertBits(16) before SMDegrain?
There is mode=0 too, about dithering, that is useless if working with a 16 bit chain. Have I to ignore it or simply use -1 as argument?
Old 2nd June 2021, 17:16   #34  |  Link
Dogway
Yes, ConvertBits(16) beforehand for 16-bits.
I had a look at SVPFlow but it only supports 1 frame delta, also it was slower in my tests... Maybe when mvtools2 from Neo gets ported back, but pinterf said he isn't doing it so someone else needs to be up for the task.
I'm currently working on further SMDegrain cleanup, in my internal version mode is removed also, might upload today or tomorrow since I added quite a few changes.
On another note, I have been advancing with Transforms Pack, now in RC8. Internally I also added linear_in and linear_out arguments (when dealing with linear rgb image sequences for example) and a convert format only option, so you can convert from YUV420 to YV444 without any gamma nor gamut processing, it also uses a lazy mode input, so easy to use.
Old 2nd June 2021, 17:31   #35  |  Link
tormento
Acid fr0g
tormento's Avatar
Would it be possible to introduce some depan/stabilize while denoising? We already have some vectors ready, perhaps it could be almost computation free.
Old 2nd June 2021, 17:58   #36  |  Link
Dogway
Normally you want to denoise after stabilization not the other way around, in any case Stab() uses DepanEstimate for the vectors. What are you using that uses MAnalyse mv?
Old 2nd June 2021, 18:22   #37  |  Link
tormento
Acid fr0g
tormento's Avatar
Nothing, I think
I did some real world benchmarks.
SMDegrain-3.1.2·111~realfinder.avsi with script:
PHP Code:
SetMemoryMax()
SetFilterMTMode("DEFAULT_MT_MODE"2)
LoadPlugin("D:\Eseguibili\Media\DGDecNV\DGDecodeNV.dll")
DGSource("F:\In\2_00 13 assassini\assassini.dgi",ct=140,cb=140,cl=0,cr=0)
CompTest24(1)
SMDegrain (tr=4thSAD=400refinemotion=falsen16_out=truemode=0contrasharp=falsePreFilter=4truemotion=trueplane=4chroma=true)
Prefetch(6
SMDegrain-3.2.0d~Dogway.avsi with script:
PHP Code:
SetMemoryMax()
ConvertBits(16)
CompTest24(1)
SMDegrain (tr=4thSAD=400refinemotion=falsecontrasharp=falsePreFilter=4truemotion=trueplane=4chroma=true)
Prefetch(6
x264.exe --crf 20 --preset slow --aq-mode 2 --colorprim bt709 --colormatrix bt709 --transfer bt709 --range tv --input-depth 16 --output "F:\In\2_00 13 assassini\assassini_4_400_temp\assassini_4_400_out.h264" "F:\In\2_00 13 assassini\assassini_4_400_temp\assassini_4_400.avs"
realfinder: encoded 3624 frames, 10.39 fps, 2904.75 kb/s, 50.20 MB
Dogway: encoded 3624 frames, 13.36 fps, 2903.99 kb/s, 50.18 MB
x265.exe --crf 22 --preset slow --output-depth 10 --colorprim bt709 --colormatrix bt709 --transfer bt709 --range limited --input-depth 16 --dither --output "F:\In\2_00 13 assassini\assassini_4_400_temp\assassini_4_400_out.hevc" "F:\In\2_00 13 assassini\assassini_4_400_temp\assassini_4_400.avs"
realfinder: encoded 3624 frames in 968.31s (3.74 fps), 1740.06 kb/s, Avg QP:25.89
Dogway: encoded 3624 frames in 986.45s (3.67 fps), 1739.71 kb/s, Avg QP:25.90
The speed increase in x264 encoding is massive. I hope there aren't some tradeoffs.
Old 2nd June 2021, 18:49   #38  |  Link
Dogway
Wow 13fps, what CPU do you have? I always use Refinemotion though, would also like to have a variable blocksize option in mvtools like in BM3D.
Normally I see a 4% to 5% speed increase, I swapped masktools2 calls with Expr() based ex_tools calls which run faster for HBD, also replaced removegrain blurs with faster alternatives, and process the motion vectors in 8-bit. And expression optimization in luma_rebuild.
Currently I'm trying to optimize for UHD by serving a half size pelclip to MSuper, for that I'm setting pel=1, it runs but I'm not sure if this is correct code-wise maybe if someone can confirm.
Also found that SimpleResize is faster than bilinear for downscaling, so I might use that but doesn't support HBD though.
Old 3rd June 2021, 10:03   #39  |  Link
tormento
Acid fr0g
tormento's Avatar
i7-2600k @ 4.6 GHz
I have found that working with 16bit in AVS+ script and leaving all the dithering to x264 (proper HBD aware build from jpsdr) gives a lot of speed increase and better visual results too.
Unfortunately my CPU hasn't enough cores to use AVS+ script plus x265 efficiently.
Can you confirm me that your revised version of SMDegrain is bitdepth transparent, i.e. the output has the same bitplane of the input at any stage of the avsi?
Old 10th June 2021, 20:24   #40  |  Link
Dogway
Ok, seems that converting vector bitdepth back to input bitdepth was strangely not ideal (defaults back to mode=1). In any case client filters can work with vectors of different bitdepth as declared in 2.7.25 of the changelog and also first line of 2.7.19.22.
With the new mvtools2 version DCT is now much faster, so I defaulted DCT to 5, if everyone agrees.
@Tormento, only 8-bit is used for motion vectors, MDegrain uses a MSuper of original bitdepth, and everything else is processed in original bitdepth.
avisynth, dogway, filters, hbd, packs
