15th September 2010, 01:05 | #81 | Link |
This disc can not be played!
I'm using DVDRebuilder Pro 1.28.2 rebuilding from a rip created using AnyDVD, and then using that rebuild in ImgBurn to create an ISO file to burn a DVD +R. I get the message on my Samsung BD-P4600: "This disc can not be played!" I can play the disc fine using my computer's DVD Drive, as well as a Yamaha standalone DVD drive, but it won't play on my fancy new Samsung Bluray drive. The Samsung will play regular DVDs, BDs, and even backup BDs created using BDRebuilder. But it won't play the backups created using DVDRebuilder.
I'm wondering why not, and is there a parameter that I could set in DVD Rebuilder Pro that would work around this problem? |
15th September 2010, 01:46 | #82 | Link | |
15th September 2010, 03:33 | #83 | Link | |
When I created the ISO image of the BD disc (after using BDRebuilder) I used UDF 2.5, and the media I used was Verbatim DVD+R DL 8X. The DVDs play in every DVD player I have, even an old Plextor drive that's about 8 years old. But they won't play in that fancy Samsung. The BDs do, though. Strange. |
15th September 2010, 06:48 | #84 | Link | |
19th December 2010, 00:24 | #86 | Link | |
Look at this thread and search for "targetsectors" in the DVD Rebuilder sub-forum and you'll find lots of information. If you're using a media player you may also want to consider "Mobile Output" options. Last edited by jdobbs; 19th December 2010 at 00:27. |
23rd January 2011, 22:20 | #87 | Link |
When I was encoding a dvd the compression was all complete but I got an error during the muxing stage and realized I ran out of harddrive space. Is it possible to have dvd rebuilder pick up where it left off since I still have the working folder saved?
23rd January 2011, 22:33 | #88 | Link |
If you mean the rebuild stage of the process, then you should be able to click rebuild, once there is space on the output drive
If you were in "one click mode" to begin with, I'm afraid I can't help you. I prefer 3 clicks myself |
24th January 2011, 01:07 | #90 | Link |
3 click mode is highly beneficial. You might consider leaving it there. Especially if you like the following ability:
Once you've prepared the files, you can open this editor. There I suspect you will see the benefits |
11th June 2011, 18:14 | #93 | Link |
Hi jdobbs
Whilst I've got you on the line, can I ask you a question. At present I use a pc with an Intel E8400 cpu (3Ghz dual core) to run BD RB however I have seen some an Intel Q9300 (2.5GHz Quad core) cpu's at reasonable prices... So the question is, if I buy and install a Q9300 cpu instead will this intern run BD RB at a faster rate because it will be using four cores, or not..?? Many Thanks |
12th June 2011, 02:46 | #95 | Link |
Excuse me guys, but the last few posts are OT.
This thread is about DVD-Rebuilder, not BD-Rebuilder. It was suggested a couple of times in the past to make a separate section for BD-Rebuilder, but so far nothing happened. Time to rethink this decision? Cheers manolito |
12th June 2011, 02:58 | #96 | Link | |
12th June 2011, 04:13 | #97 | Link | |
It's hard for some folks to distinguish the difference between a "Frequently Asked Question" and "a question". Last edited by jdobbs; 12th June 2011 at 04:16. |
15th August 2011, 00:26 | #99 | Link |
No one is pulling anything apart, we were just asking to separate the topics. Jdobbs has done a terrific job, no one says otherwise. I bought DVDRB years ago and have contributed 3 times to BDRB so he can continue his great work, but the DVDRB FAQ had more questions about BDRB than the former. I use both all of the time.
16th December 2011, 17:01 | #100 | Link |
NickSteel
Force Film
With DVD Rebuilder Pro and film source, is Force Film logic (like in DGIndex) utilized for FILM to reduce file size?
In the past, I would: Dvdfab main movie DGIndex (force film, if FILM) Resize in avs to crop top and bottom encode with HCEnc as 3:2 pulldown |
