26th September 2008, 04:44 | #21 | Link |
No suggestions, ok, staying with VFAPI (also trying makeAvis but it seems as I'm hitting limits - on this installation/OS at least - which VFAPI doesn't have).
I'm making tests (and will search and possibly start a thread) on a workflow like this: preprocessingFrameserving-NLE/compositing-postprocessingFrameserving-compression and use of NVidia hardware mpeg2 compression. |
10th January 2009, 09:12 | #22 | Link |
Well , I think that Teriffic tool, like Asynther with many more options. Also, it's not just for Avisynth scripts. I use it for batch scripting with FFMpeg and a few other CLI tools. Saves me a lot of cutting and pasteing. A few minor "gotchas" (minimal editing features, besides the intellisence, and a little cumbersome to find the "scan" folders) but overall I find it very useful.
27th February 2009, 22:21 | #23 | Link |
Is there a command-line tool for getting information from an AVS file. Currently, the only way I know of is to open the AVS file in Virtual Dub, choose "File Information" and write it down. What I am looking for is something like:
avs_info -duration source.avs To get the length in time avs_info -width -height source.avs To get the width and height of the frame etc. |
28th February 2009, 06:08 | #24 | Link | |
You could write Avisynth functions. Look at: http://avisynth.org/mediawiki/Clip_properties http://avisynth.org/mediawiki/WriteFile http://avisynth.org/mediawiki/ConditionalFilter http://avisynth.org/mediawiki/Import e.g. Code:
Import("MYAVS.avs") filename = "info.txt" WriteFile(filename, """ "Width: " """, "width") WriteFile(filename, """ "Frames: " """, "FrameCount") Last edited by AlanHK; 28th February 2009 at 06:10. |
1st March 2009, 13:26 | #25 | Link | |
Avisynth language lover
Use WriteFileStart instead, as the data you want are video, not frame, properties. To get video duration, use Code:
WriteFileStart(filename, """ "Duration (secs): " """, "FrameCount/FrameRate") |
3rd March 2009, 20:00 | #27 | Link |
AVS Info
Gavino, AlanHK, thanks. I had known about the "WriteFileStart" command but had not really played around with it, as I had thought that once I had opened VDub, I would then have to manually close it up again. Basically, I've got a bunch of AVS files in a directory and would like to get general video information from them. But I did find that if get_info.avs is ...
Import("source.AVS") filename = "info.txt" WriteFileStart(filename, """ "Duration (secs): " """, "FrameCount/FrameRate") Code:
VirtualDub /x get_info.avs I thank you for the help, it has gotten me a lot farther down the road toward what I would realy like to see, which would be a command-line utility that writes to STDOUT, so that it's output could be redirected. |
2nd December 2009, 10:29 | #29 | Link | |
HDConvertToX author
and the same result could be get with avisynth_mt + avs2yuv BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
11th January 2010, 07:39 | #30 | Link |
Apply Replaygain to AVS
A batch script using Wavi and a modified version of Wavegain to apply Replaygain to an AVS file, by adding an AmplifydB line: Code:
@echo off ::AVSGain: apply Replaygain to AVS files if %1X==X goto ALL :LOOP for %%I in (%1) do ( echo Applying replaygain to %%I echo.>>%%~fsI wavi %%I - | wavegain2 - -e echo AmplifydB^(%%TRACK_GAIN%%^) ^>^> %%~fsI ) SHIFT @if %1X==X goto END @goto LOOP :ALL for /f "delims=" %%I in ('dir *.avs /b') do ( echo Applying replaygain to %%I echo.>>%%~fsI wavi %%I - | wavegain2 - -e echo AmplifydB^(%%TRACK_GAIN%%^) ^>^> %%~fsI ) :END The original version of Wavegain doesn't work properly with piped input, the modded version fixes this. Wavegain and Wavi must be in the search path, or give the full path to each executable. I don't use spaces in my filenames, you may need to wrap the filenames in quotes if you do. Last edited by AlanHK; 17th January 2010 at 18:51. |
18th April 2013, 17:16 | #31 | Link |
BatchWizardMod - application that generate a special template from a VirtualDub/AviSynth script
file and apply this template for any number of specified files. For VirtualDub - creates one script that process all specified files. For AviSynth - creates .avs for each specified file. BatchWizardMod |
15th December 2014, 09:45 | #32 | Link |
AVFS and Pismo file mount
http://www.turtlewar.org/avfs/
Nice tool that allows mount a virtual folder with uncompressed avi and wav files that resul from avs file interpretation. |
15th December 2014, 22:03 | #33 | Link |
Avisynthesizer_MOD batch creator: http://forum.doom9.org/showthread.php?t=166820
A SendTo App that allows Windows Explorer selection of video files and fills in a user supplied Template with the filenames. Can concatenate (join/splice) selected files (default as original non mod version) and create a single output AVS file OR, batch create multiple AVS files, one for each input source file (MOD version only). Has a GUI to select required template and sort input files if multiple input files selected. Dont miss the above previous post "AVFS and Pismo file mount" also posted today.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th December 2014 at 23:22. |
22nd May 2020, 20:50 | #34 | Link |
AVISYNTH-BATCH.zip (required FFmpeg) at https://www.mediafire.com/folder/wrpd1f5ayoavb/SHARED . Edit TEMPLATE-1.txt and TEMPLATE-2.txt, drag and drop mediafile or folder on "generate-avs-encode-drag-and-drop.bat" script and encoding will start.
