Old 25th March 2020, 16:59   #981  |  Link
poisondeathray
Not sure, think not a bug, was just not supported back then, Shekh & Pinterf got together and arranged for joint support.
Nice!
I wonder if this can be extended to avs+ script in avfs since it's vfw based??
Maybe it's the wrong place to ask, but vapoursynth's enable_v210 = True emulates v210, so the virtual AVI looks like v210 (e.g. other programs and mediainfo identifies it as v210)
But avs+'s global OPT_Enable_V210 = true still identified as p210 when sent through avfs
Old 29th March 2020, 00:54   #982  |  Link
lansing
I'm having problem displaying blu-ray m2ts file, where any random seek will result in blocky gray images for about 10 frames, then it became normal again. And the issue doesn't end there. When I apply Neatvideo, a temporal denoising filter, the problem goes 5-6 good frames -> 15 blocky gray frames -> 5-6 good frames and repeat.
Old 29th March 2020, 13:11   #983  |  Link
Sharc
With a random seek we will get garbled frames until we hit the next I frame in the stream (GOP start for correct decoding).
Old 29th March 2020, 14:39   #984  |  Link
videoh
Useful n00b
Instead of opening the M2TS directly, make an avs script with frame-accurate seeking and then open that in VirtualDub2.
I don't know what VirtualDub2 is using to open M2TS files.
Old 29th March 2020, 16:15   #985  |  Link
shekh
I agree. Reliability of seek in VD2 depends on FFMpeg API which is not sufficient for some formats (like m2ts)
VirtualDub2
Old 29th March 2020, 16:29   #986  |  Link
StainlessS
StainlessS's Avatar
I'm sure that VH knows this already but DGIndex has these available as file extension filters in DGIndex:
vob, mpg, mpeg, m1v, m2v, mpv, tp, ts, trp, m2t, m2ts, pva, vro
I sometimes post sober.
Old 29th March 2020, 17:00   #987  |  Link
videoh
Useful n00b
Quite right, SS. but remember DGIndex is MPG2 only. DGIndexNV can handle the other formats. I think ffms2 would be fine also. Don't like to push my stuff to avoid triggering some members.
Old 29th March 2020, 17:13   #988  |  Link
StainlessS
StainlessS's Avatar
Arh yes, did not see the Blu-Ray thing.
Old 29th March 2020, 18:07   #989  |  Link
lansing
Alright, I was trying to do some quick tweaking with VD on the fly and don't want to go through "opening the video in a script and then loading the script" for every single video. I guess the long route is still inevitable.
Old 29th March 2020, 18:12   #990  |  Link
videoh
Useful n00b
My new abbreviation for you is now SssS. Reminds me of Windows SxS stuff.
Old 29th March 2020, 18:24   #991  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
How about SßS
Old 29th March 2020, 20:52   #992  |  Link
videoh
Useful n00b
That works! But how to type that funny B? I don't seem to have one on my keyboard.
Old 29th March 2020, 21:36   #993  |  Link
Groucho2004
This German grapheme is largely extinct now. Just use a double s.
Groucho's Avisynth Stuff
Old 29th March 2020, 21:44   #994  |  Link
SeeMoreDigital
Nein!!!!!!!!!!!!!!!!!!!!
Old 29th March 2020, 21:55   #995  |  Link
qyot27
qyot27's Avatar
Alt+0223 is the combo for the Eszett.
Old 29th March 2020, 22:11   #996  |  Link
Groucho2004
OK. According to this, there are still some uses for that relic.
@vh
If you really have to mutilate Stainless' moniker, use SssS.
Old 30th March 2020, 00:01   #997  |  Link
StainlessS
StainlessS's Avatar
Common guys, keep on topic.
ssS
Old 30th March 2020, 03:16   #998  |  Link
videoh
Useful n00b
@vh
Umm:
https://forum.doom9.org/showthread.p...58#post1905458
Old 30th March 2020, 12:39   #999  |  Link
Groucho2004
Yeah, I know it's your creation. I probably should have phrased it differently.
Old 13th April 2020, 16:40   #1000  |  Link
nji
Display pane, zoom - suggestion
As probably most VD2's users I take VD2 for enhancing movies.
For that I have to assess the exact look of the orig movie
and the effect of the filters ... in VD2's display panes.
Just recently I realized that when doing this
... by zooming with context menu ...
the shown zoom is NOT the actual content,
but what the interpolation alg does from it.
Choosing the alg (to "pixel" = orig.) is only possible
by disabling DirectX in "Options / Preferences / Display",
or by enabling OpenGL.
So my suggestion/ question:
To disable DirectX at that point by default.
(If it doesn't have any other disadvantages I don't know about).
nji is offline   Reply With Quote
