5th May 2008, 13:10 | #4621 | Link |
The Machinist HD DVD:
3: h264/AVC, 1080p24 /1.001 (16:9) with pulldown flags This title does not appear to have pulldown flags. Video is destroyed when removing pulldown with h264info and plays fine at 23.976 fps without. |
5th May 2008, 15:52 | #4622 | Link |
Thanks for your new eac3to version.
You includes the -extensible parameter to output wav with the WAVE_FORMAT_EXTENSIBLE header (henceforth WFE). I like this improvement but I have some comments: - When use WFE header is mandatory a fix channel order. - The most useful new data (maybe the unique) is the Channel Mask to specify the channels present in the audiodata. - When is unknown the channels present in the source is recommended use a default Channel Mask based in the number of channels. - When we know the source channels the channel mask must be set in accord. 1) ABOUT DEFAULTS I think the default used in eac3to for 4 channels (0x000F = FL FR FC LF) must be changed for 0x0033 = FL FR BL BR (Quadro) more usual and compatible with Flac/Ogg multichannel. A WFE wav with maskchannel 0x000F is rejected by flac. The default used for 8 channel (0x00FF = FL FR FC LF BL BR FLC FRC) is not usual, maybe the default can be 0x063F = FL FR FC LF BL BR SL SR When I try know the default for 7 channels using a 3/3.1 wav file: Code:
eac3to v2.45 command line: "D:\Test\AudioN\eac3to\eac3to.exe" "E:\Test\7_61.wav" "E:\Test\z331.wav" -extensible ------------------------------------------------------------------------------ WAV, 6.1 channels, 0:00:20, 16 bits, 48khz Doubling 7th channel... Reading WAV... Writing WAV... Creating file "E:\Test\z331.wav"... eac3to processing took 1 second. Done. Maybe the default for 7 channel can be: 0x013F = FL FR FC LF BL BR BC 2) ABOUT KNOW SOURCE AC3 At least with ac3 source we can obtain perfect WFE wav output: Code:
acmod.lfe ac3 channels Mask and MS channels ordered Detect-MaskCh eac3to libav remap ------------------------- --------------------------------- --------------------- ------------ 1 1/0.0 C 0x0004 FC 1.0 0x0004 ok not needed 1 1/0.1 C LFE 0x000C FC LF 1.1 0x0003 (1)(2) not needed 2 2/0.0 L R 0x0003 FL FR 2.0 0x0003 ok not needed 2 2/0.1 L R LFE 0x000B FL FR LF 2.1 0x0007 (2) not needed 4 2/1.0 L R S 0x0103 FL FR BC 2/1 0x0007 (2) not needed 4 2/1.1 L R S LFE 0x010B FL FR LF BC 2/1.1 0x000F (2)(3) -0,1,3,2,4,5 6 2/2.0 L R SL SR 0x0033 FL FR BL BR 2/2 0x000F (2) not needed 6 2/2.1 L R SL SR LFE 0x003B FL FR LF BL BR 2/2.1 0x0037 (2)(3) -0,1,4,2,3,5 3 3/0.0 L C R 0x0007 FL FR FC 3/0 0x0007 (3) -0,2,1,3,4,5 3 3/0.1 L C R LFE 0x000F FL FR FC LF 3/0.1 0x000F (3) -0,2,1,3,4,5 5 3/1.0 L C R S 0x0107 FL FR FC BC 3/1 0x000F (2)(3) -0,2,1,3,4,5 5 3/1.1 L C R S LFE 0x010F FL FR FC LF BC 3/1.1 0x0037 (2)(3) -0,2,1,4,3,5 7 3/2.0 L C R SL SR 0x0037 FL FR FC BL BR 5.0 0x0037 (3) -0,2,1,3,4,5 7 3/2.1 L C R SL SR LFE 0x003F FL FR FC LF BL BR 5.1 0x003F ok already done (2) Default mask for channel number, the correct mask can be easyly put based in detection (3) When decoded with libav need remapping channels. (1) Wrong detection, must be 1.1 (not important because mono + LFE is really strange). But is my fault, eac3to detect 1.1 correctly Last edited by tebasuna51; 11th May 2008 at 22:14. |
5th May 2008, 18:26 | #4624 | Link |
I seem to have run into a consistent problem with certain DVDs that are 480i60. The following is an example:
eac3to v2.45 command line: eac3to vts_01_1.vob+vts_01_2.vob+vts_01_3.vob+vts_01_4.vob t.mkv ------------------------------------------------------------------------------ VOB, 1 video track, 3 audio tracks, 3 subtitle tracks, 1:53:11 1: Joined VOB file 2: MPEG2, 480i60 /1.001 (16:9) 3: AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -26dB 4: AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -25dB 5: AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -23dB 6: Subtitle 7: Subtitle 8: Subtitle [v02] Extracting video track number 2... [a04] Extracting audio track number 4... [a05] Extracting audio track number 5... [v02] Muxing video to Matroska... [a03] Extracting audio track number 3... [a05] Removing dialog normalization... [a04] Removing dialog normalization... [a03] Removing dialog normalization... [v02] The MPEG2 stream changed from 60000i to 48000i at runtime 0:00:02. [s07] Extracting subtitle track number 7... [s08] Extracting subtitle track number 8... [s06] Extracting subtitle track number 6... [a03] Creating file "t - 3 - AC3, 2.0 channels, 192kbps, 48khz.ac3"... [a04] Creating file "t - 4 - AC3, 2.0 channels, 192kbps, 48khz.ac3"... [a05] Creating file "t - 5 - AC3, 2.0 channels, 192kbps, 48khz.ac3"... [s08] Creating file "t - 5 - Subtitle.sup"... [s06] Creating file "t - 3 - Subtitle.sup"... [s07] Creating file "t - 4 - Subtitle.sup"... Added fps value to MKV header. Video track 2 contains 162910 frames. eac3to processing took 1 minute, 50 seconds. Done. The "stream changed from 60000i to 48000i " is the consistancy. The mkv file produced is jerky during playback and this happens to all that I try to convert where this exact stream change occurs. Is there an option on eac3to that will solve this or is this a bug?
zap |
5th May 2008, 21:08 | #4625 | Link |
Madashi,
Next time I get a Bluray in with LCPM audio, and a DTS-HD track, I will do more testing. But for now, your assumption is incorrect. All the tracks I am converting are from full length feature films. The TrueHD, DTS-HD, and DD+ tracks come out roughly the same size, between 1 and 3gb depending on movie length. Once uncompressed to WAV, all files are > 4gb, even the TrueHD. My question is, why do the LPCM tracks that ship with the Blurays work perfectly, while ones converted using eac3to don't? What is difference between the LPCM provided by the movie studio, and the one your program is making? Is there some kind of program I can use to analyze the two LPCM files? Bascially, I wan't to do something similar listed in this thread: http://forum.doom9.org/showthread.ph...533#post968533 But I want to go from DTS-HD/TrueHD/DD+ to LPCM. Would I use the RAW output option on eac3to, and map the channels like it says in that thread? Last edited by jchappo; 5th May 2008 at 21:23. |
5th May 2008, 21:24 | #4626 | Link | |
5th May 2008, 21:44 | #4627 | Link |
Madshi,
When converting a TrueHD track to a DTS track with a multiparts seamless branching .m2ts file, are two passes really needed? In my example I try to extract two tracks: an AC3 track and a TrueHD track (converted to DTS). Overlap is only detected on the AC3 track, is this normal? If so, could you automate the two passes to avoid calling surcode twice ? In fact, if the second pass was handled directly by EAC3TO you could save a lot of time since the demuxing has been already done. Thanks for your great tool! |
5th May 2008, 21:45 | #4628 | Link | |
The wav file >4GB have a field to inform about the length than must be wrong because have only 4 bytes and the max number is 2^32. There are soft to manage these big wave files, you can encode to ac3 with Aften -readtoeof 1, or to mp4 with Neroaacenc -ignorelength. You can split, change bitdepth, samplerate, ... with WaveWizard. An also can be managed in AviSynth (BeHappy, SoundOut, Wavi) if you open the file with RaWavSource() method. You can also convert (SoundOut) the header to w64 (Sonic Foundry, now acquired by Sony) format with fields than support until 2^64 filelength, but not all soft can accept this format. |
5th May 2008, 22:12 | #4629 | Link | |
Even if you needed 2 passes in your case, to avoid calling surcode twice (it is very slow), i suggest converting truehd (or whatever) to wav, do the 2nd pass (if needed) and then run a simple command to make the wav 2 dts encoding. This is what i always do when i want to encode to dts. Another good reason for feeding surcode direclty with wav files is to avoid the "surcode button didn't seem to work" error when you specify long filenames/paths as inputs. In that case you won't need to decode the source track twice. Last edited by nautilus7; 5th May 2008 at 22:17. |
5th May 2008, 22:34 | #4631 | Link | |
The 5.1 channels are automatically remapped from LPCM/DTS-HD/TrueHD/DD+ The RAW is the same than the wav if you delete the first 44 bytes. |
5th May 2008, 23:14 | #4632 | Link |
Let me fully explain the problem I have so everyone can understand it better.
The Popcorn hour A-100, is a network media player which can play uncompressed Bluray audio/video. It will accept a M2TS stream and passthrough the LPCM audio to my receiver. Some Bluray movies come with an LPCM audio stream already on them, some do not. For the ones that do not, I want to use eac3to to convert the TrueHD/DTS-HD/DD+ to LCPM so the A-100 can play it. But, I have only been successful with TrueHD so far, both DTS-HD and DD+ produce files that are garbage after the first 20-30% of the movie. This is the problem. My question is, why can't eac3to produce LPCM files like that ones the movie studio includes on some discs? If I could produce those exact files, then that would be awesome and everything would just work. I am trying to figure out why eac3to is not producing these same files, and how to fix it. |
5th May 2008, 23:40 | #4634 | Link |
You keep saying your "problem", but you didn't listen to what madshi already said.
Do a simple test: Instead of making multi channel wav files make mono wavs. (eac3to input.thd/dtshd/eac3/etc output.wavs). Then check the center channel of all tracks. I bet every single one would be fine. |
6th May 2008, 00:40 | #4635 | Link |
I have the same problem with lpcm as the above poster. What we really need is a program that can accept wavs not an interleaved wav file and mux that with video like scenarist. That way the audio track will be under 4 gigs. either that or maybe madshi could add an option to split the demuxed video and audio file every 30 mins. That way we maybe able to use tsmuxer and append the file and the sound may be correct.
6th May 2008, 02:20 | #4636 | Link |
nautilis7,
I tried what you said and you are correct. If by dump luck, the TrueHD stream decoded into a working WAV, then why can't I edit the value in the WAV header to make it always work? I'm just trying to get a working solution to producing working LPCM files. |
6th May 2008, 02:25 | #4637 | Link | |
6th May 2008, 08:30 | #4638 | Link | |
b4k3d
eac3to.exe source.m2ts destination.wavs then use another encoder to make the multi channel PCM/WAV? But, what encoder and what settings and how do we ensure proper LPCM channel configuration? |
6th May 2008, 08:41 | #4640 | Link | |||||||||
The VOB format allows to have language identifiers inside the VOB stream. If there are any, eac3to will read them and display them. I do have some DVDs where language detection works. However, there are many DVDs where the language information is not contained in the VOB itself, but in the other files (*.IFO, I believe). eac3to currently doesn't parse these files, so the language cannot be displayed in such cases. Quote:
Can you upload a little sample which works with v1.16 but not with v2.45? Quote:
I've already thought about this. Maybe I will. Quote:
eac3to |
