Old 1st November 2017, 11:53   #14421  |  Link
tebasuna51
tebasuna51's Avatar
Yes, you must use the 00004.m2ts (I do not expect problems with audio sync).
If you try extract tracks from the mpls eac3to crash because no audio in first m2ts.
The mpls is only usefull to extract the chapters, but you need correct the times with the duration of first m2ts.
tebasuna51 is offline
Old 1st November 2017, 12:03   #14422  |  Link
hubblec4
Matroska find' ich toll
Originally Posted by pstn View Post
Could anyone explain what is going on with this pls?
1) 00003.mpls, 00009.m2ts+00004.m2ts, 1:51:42
- Chapters, 12 chapters
- h264/AVC, 1080i50 (16:9)
- DTS Master Audio, Norwegian, multi-channel, 48kHz
- DTS Master Audio, French, multi-channel, 48kHz
since the 00009.m2ts file is a 10frame (1/2 second) black screen with no audio track, followed by the movie, should I be doing the demuxing directly on the 00004.m2ts (the actual movie) file instead?
thanks
I don't know what your aim is.
But you could try my chapterEditor.
Such disturbing m2ts can be ignored/removed and the chapter times will be recalculated automatically.
hubblec4 is offline
Old 1st November 2017, 14:15   #14423  |  Link
mini-moose
Interesting, didn't know that's a feature in CE!
Please see pm hubblec4.
mini-moose is offline
Old 2nd November 2017, 21:03   #14424  |  Link
pcroland
Originally Posted by eac3to
D:\_encode\s09
λ eac3to.exe 00.eac3 00_hd.eac3 -6006ms
E-AC3, 2.0 channels, 0:23:43, 224kbps, 48kHz, dialnorm: -24dB
Removing E-AC3 dialog normalization...
Applying (E-)AC3 delay...
A remaining delay of +10ms could not be fixed.
Creating file "00_hd.eac3"...
eac3to processing took 1 second.
Originally Posted by MediaInfo
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 spf)
With 187.5 fps the length of one frame is 5.33ms, not 32ms, isn't it? So the "remaining delay" that "cannot be fixed" should be less than 3ms (2.66ms) in the worst case with E-AC3 (that has 256spf).
pcroland is offline
Old 2nd November 2017, 23:52   #14425  |  Link
kron
Warning message
Hi, friends,
is it a problem? I used the version 31 and everything was ok, but now using v32 shows this:
eac3to v3.32
command line: "C:\Program Files\eac3to\eac3to.exe" "C:\Users\Desktop\Audio HD\Overdrive.2017.BluRay.1080p.DTS-HD.MA.5.1.AVC.REMUX-FraMeSToR_track2_eng.dts" "C:\Users\Desktop\Audio HD\Overdrive.2017.BluRay.1080p.DTS-HD.MA.5.1.AVC.REMUX-FraMeSToR_track2_eng.dts_.flac" -progressnumbers -log="C:\Program Files\eac3to\UsEac3To.log"
DTS Master Audio, 5.1 channels, 24 bits, 48kHz
(core: DTS, 5.1 channels, 1509kbps, 48kHz)
Decoding with libDcaDec DTS Decoder...
libDcaDec reported the warning "XLL output not lossless". <WARNING>
Encoding FLAC with libFlac...
Creating file "C:\Users\Desktop\Audio HD\Overdrive.2017.BluRay.1080p.DTS-HD.MA.5.1.AVC.REMUX-FraMeSToR_track2_eng.dts_.flac"...
The original audio track has a constant bit depth of 24 bits.
eac3to processing took 10 minutes, 51 seconds.
Done.
Thanks for helping.
kron is offline
Old 3rd November 2017, 00:15   #14426  |  Link
Forum attachments take a while to get approved. Could you please use an image hoster, or simply quote full CLI parameters and the error message from the console?
As uncomplicated image hoster, I would recommend e.g. https://frupic.frubar.net; and for screenshots from a console window, I would prefer PNG over JPG.
LigH is offline
Old 3rd November 2017, 00:51   #14427  |  Link
tebasuna51
tebasuna51's Avatar
It's not a problem.
That was repported before with previous eac3to versions.
Sometimes libdcadec show that WARNING, I suspect is when a DTS frame don't need extra info to convert in lossless (like silent frames).
Old 3rd November 2017, 01:22   #14428  |  Link
kron
Thanks for answering, I'll remember this.
It's not a problem.
Reading some posts back, I've seen it was corrected in v31, do you think it will be also done in this 32?
BTW, do you friends still use Arcsoft to convert DTS to flac or have just forget it?
Sorry for so many questions, but I believe in the good will here.
Thanks for the attention.
kron is offline
Old 3rd November 2017, 08:51   #14429  |  Link
If there is no "regression" (accidental loss), then all the fixes introduced in v31 should persist in v32.
The Arcsoft decoder is commercial (and of course not shipped together with eac3to), and the free libavcodec decoder is just as good (can be bit-exact as well where possible, or at least with negligible difference), so I believe there is little reason today to insist in Arcsoft. I believe it also had some issues providing different feature sets per version... but I never used it.
LigH is offline
Old 3rd November 2017, 10:02   #14430  |  Link
mtamimi
Guys, any update on that issue with some decrypted UHD discs?!
Thnx
mtamimi is offline
Old 3rd November 2017, 11:24   #14431  |  Link
tebasuna51
tebasuna51's Avatar
You are right, sometimes there are a little diference (last bit +- 1, some rounding error) between ArcSoft and libdcadec decoders.
But in my tests always the decoded with libdcadec are bitexact with the source wav, and the decoded with ArcSoft is the unexact.
Now ArcSoft is only necessary to decode DTS-Express, not supported in last libdcadec.dll. But you can use ffmpeg than now include a more recent libdcadec.
@kron
Use the 'Save Log' button in UsEac3to and attach the log file here.
More easy, and save space in forum, instead a image capture sometimes incomplete.
Old 3rd November 2017, 12:00   #14432  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Not directly eac3to-related but what kind of commandline should be used for ffmpeg when piping from eac3to in case of DTS-Express to WAV?
Boulder is offline
Old 3rd November 2017, 16:35   #14433  |  Link
sneaker_ger
Piping from eac3to implies eac3to has to decode DTS-Express. Which it can't. You need to open the file directly with ffmpeg.
sneaker_ger is offline
Old 3rd November 2017, 16:45   #14434  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Can't you pipe the extracted DTS file? Otherwise it's two passes (extract core, decode file with ffmpeg) at least if the playlist has multiple m2ts files.
Boulder is offline
Old 3rd November 2017, 17:09   #14435  |  Link
tebasuna51
tebasuna51's Avatar
Yep, you need two passes with multiple m2ts
Old 4th November 2017, 01:00   #14436  |  Link
kron
Hi, guys, sorry for the mistakes, let's see if I did right this time.
eac3to v3.32
Done.
Thanks for the patience.
kron is offline
Old 4th November 2017, 11:22   #14437  |  Link
mtamimi
I need your help regarding this a BD that I have...
1. Listing the playlist works...But it reports 2 similar playlists, the 2nd one is the correct one since the stream 9031 is the beginning of the movie...
eac3to.exe E:\
1) 00108.mpls, 1:29:23
[14993+4761+6837+15438+15239+17347+25303+268+23180+16207+86+15862+1470+6953+15999+12333+23096+24749+21465+25620+13396+29818+20351+8413+12583+20631+21951+25683+21820+23783+10226+6888+29843+12750+13212+0+14298+20771+9415+21118+23276+8535+14235+18830+138+14053+17728+30132+14167+14332+18422+31252+3096+26217+21108+18946+17707+7113+13953+22220+9031].m2ts
- Chapters, 10 chapters
- h264/AVC, 1080p24 /1.001 (16:9)
- DTS Master Audio, English, multi-channel, 48kHz
- AC3, English, stereo, 48kHz
2) 01002.mpls, 1:29:23
[9031+22220+13953+7113+17707+18946+21108+26217+3096+31252+18422+14332+14167+30132+17728+14053+138+18830+14235+8535+23276+21118+9415+20771+14298+0+13212+12750+29843+6888+10226+23783+21820+25683+21951+20631+12583+8413+20351+29818+13396+25620+21465+24749+23096+12333+15999+6953+1470+15862+86+16207+23180+268+25303+17347+15239+15438+6837+4761+14993].m2ts
2. Selecting the 2nd playlist reports this
eac3to.exe E:\ 2)
M2TS, 1 video track, 2 audio tracks, 1 subtitle track, 1:29:19, 24p /1.001
1: Chapters, 10 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz
4: AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
5: Subtitle (PGS), English
3. Encoding the audio to DD 5.1 @ 640 fails with error...Can you guys help?!
eac3to.exe E:\ 2) 3:Audio.ac3 -640
a03 Extracting audio track number 3...
a03 Decoding with libDcaDec DTS Decoder...
a03 libDcaDec reported the warning "XLL output not lossless".
a03 Remapping channels...
a03 Encoding AC3 <640kbps> with libAften...
a03 Creating file "Audio.ac3"...
a03 0:06:26 The pes parser received incomplete data.
a03 0:06:26 Skipping dirty PES bytes...
a03 This track is not clean.
a03 libDcaDec reported the error "Invalid bitstream format".
Aborted at file position 1655990272.
P.S. Handbrake handles this disc w/o issues at all. It can encodes both the audio and video w/o issues...
mtamimi is offline
Old 4th November 2017, 13:32   #14438  |  Link
tebasuna51
tebasuna51's Avatar
I never see that, 2 mpls with the same m2ts just in reverse order.
The problem seems located at time 0:06:26
You can load each m2ts in [9031+22220+13953+7113+17707+18946...] until reach that point.
Maybe is a corrupt m2ts or without the same audio stream than crash eac3to.
I don't know for what Handbrake work, maybe skip the problems without crash.
Are audio/video in sync after the point 0:06:26?
Old 4th November 2017, 15:26   #14439  |  Link
hubblec4
A more strange Bluray for such behaviour is: BASTILLE_DAY.
There are more then 500 playlists with the same m2ts files in different orders.
@mtamimi
Looks like the m2ts files are corrupt.
hubblec4 is offline
Old 4th November 2017, 15:52   #14440  |  Link
Boulder
Pig on the wing
Boulder's Avatar
They're not strange, that's a form of copy protection.
Boulder is offline
eac3to
