#10221 | Link |
Maybe I used the wrong words. Correctly said:
I don't know if the audio tracks are present after the encode. I definitely know that I am not able to select them in the language menu of the disc on my Panasonic BD60, FW 2.5, when they where not selected in the setup menu. |
#10222 | Link |
![]() Join Date: Oct 2001
What I was asking was for you to look in the folder and see if it was there. That would at least clear up whether it was an issue with the command, or with the reencode itself.
jdobbs.softworks@gmail.com |
#10224 | Link |
If you mean Inspect ?, just look inside the folder that has BD-RB, you will see a file named Inspect. Open that file and click Inspect, and it will tell you if all the associated programs for BD-RB are correctly installed.
#10225 | Link | |
@omegaman7
Hi! Quote:
#10226 | Link |
BD Rebuilder v0.36.03 (beta)
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.36.03). Changes for this version:
- Added a new hidden option for specifying the HC Encoder profile to use for movie-only DVD output. The quality of the encode (highest being slowest) can be set by adding "HC_PROFILE=s" to the config (INI) file with "s" being set to "FAST", "NORMAL", or "BEST". The default setting is "NORMAL". - Corrected a syntax error on command lines that could cause encoding failure for DVD output when an audio delay is required. - Corrected an error in which an unmatched language setting (BD to DVD) could cause a build failure when outputting to ALTERNATE/DVD. - Fixed a regression in which ALTERNATE/MKV audio output was always incorrectly being reencoded to DD 2.0 (rather than DD 5.1 when available). - Corrected an error in which audio streams that contained delays, and were not in the initial (SETUP defined) list of selections, could (if later selected from the streams list) be muxed out-of-sync. - Updated the included version of X264.EXE to the latest release (r1772). - Updated the included version of X264-64.EXE to the latest release (r1772). - Other minor corrections and cosmetic fixes.
#10227 | Link | |
thank you i will test rebuild the movie with this new version and check if everything goes well thantks |
#10228 | Link | |
#10229 | Link |
Hello everyone! i am using BD-rebuilder since a month, thank you to create thatīs wonderful program.
This week i was rebuilding spartacus disc 2 and i have 3 times this problem - [20:24:10] Reencoding: VID_00001, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.36.02 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - FFDSHOW_RAW_AUDIO: Not recommended setting - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [16:47:58] - Failed video encode, aborted And i donīt find the solution, the three times the same error in the same part of the rebuild, the interesting thing itīs that the log show "- FFDSHOW_RAW_AUDIO: Not recommended setting" but if i do the inspect show "- FFDSHOW: 3326, Ok - FFDSHOW_RAW_AUDIO: Set to "All Supported", Ok" could you know what itīs happening? Thank very much for your work jdobbs! |
#10230 | Link |
Tried the batch mode last night(0.35.01 I've since updated). Unfortunately, a bug incurred in the first job(Toy Story 3), which apparently aborts all jobs. This is unfortunate eh? For a measly audio problem, which may not exist in following jobs. Error 75 which apparently suggests rebuilder was trying to reference audio that doesn't exist. Not sure how that happened. I did click on audio streams in the streams section. I'm rerunning the job on default settings to see what happens. I only ripped the disc using anydvd. No other processing other than Bd Rebuilder.
[02:10:17] BD Rebuilder v0.35.01 (beta) [02:10:18] BEGIN - BATCH SEQUENCE ========================== ----------------------- [02:10:18] PROCESSING BATCH FILE [1] ----------------------- [02:10:19] BD Rebuilder v0.35.01 (beta) - Source: TOY_STORY_3_DISC_1 - Input BD size: 44.41 GB - Approximate total content: [03:03:18.611] - Target BD size: 22.90 GB - Windows Version: 6.1 [7600] - Quality: High Quality (Default), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [02:10:19] PHASE ONE, Encoding - [02:10:19] Extracting A/V streams [VID_00472] - [02:10:19] Reencoding: VID_00472 (1 of 113) - [02:10:19] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 167 frames - [02:10:19] Reencoding: VID_00472, Pass 1 of 1 - [02:10:22] Video Encode complete - [02:10:22] Reencoding audio tracks (if req'd) - [02:10:22] Multiplexing M2TS - [02:10:23] Extracting A/V streams [VID_00469] - [02:10:23] Reencoding: VID_00469 (2 of 113) - [02:10:23] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 108 frames - [02:10:23] Reencoding: VID_00469, Pass 1 of 1 - [02:10:25] Video Encode complete - [02:10:25] Reencoding audio tracks (if req'd) - [02:10:25] Multiplexing M2TS - [02:10:26] Extracting A/V streams [VID_00465] - [02:10:26] Reencoding: VID_00465 (3 of 113) - [02:10:26] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 168 frames - [02:10:26] Reencoding: VID_00465, Pass 1 of 1 - [02:10:29] Video Encode complete - [02:10:29] Reencoding audio tracks (if req'd) - [02:10:29] Multiplexing M2TS - [02:10:30] Extracting A/V streams [VID_00466] - [02:10:30] Reencoding: VID_00466 (4 of 113) - [02:10:30] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 168 frames - [02:10:30] Reencoding: VID_00466, Pass 1 of 1 - [02:10:33] Video Encode complete - [02:10:33] Reencoding audio tracks (if req'd) - [02:10:33] Multiplexing M2TS - [02:10:34] Extracting A/V streams [VID_00459] - [02:10:34] Reencoding: VID_00459 (5 of 113) - [02:10:34] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 191 frames - [02:10:34] Reencoding: VID_00459, Pass 1 of 1 - [02:10:37] Video Encode complete - [02:10:37] Reencoding audio tracks (if req'd) - [02:10:37] Multiplexing M2TS - [02:10:38] Extracting A/V streams [VID_00401] - [02:10:39] Reencoding: VID_00401 (6 of 113) - [02:10:39] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 308 frames - [02:10:39] Reencoding: VID_00401, Pass 1 of 1 - [02:10:49] Video Encode complete - [02:10:49] Reencoding audio tracks (if req'd) - [02:10:50] Multiplexing M2TS - [02:10:50] Extracting A/V streams [VID_00463] - [02:10:52] Reencoding: VID_00463 (7 of 113) - [02:10:52] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 840 frames - [02:10:52] Reencoding: VID_00463, Pass 1 of 1 - [02:11:05] Video Encode complete - [02:11:05] Reencoding audio tracks (if req'd) - [02:11:06] Multiplexing M2TS - [02:11:08] Extracting A/V streams [VID_00322] - [02:11:10] Reencoding: VID_00322 (8 of 113) - [02:11:10] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 302 frames - Bitrate: 21,156 Kbs - [02:11:10] Reencoding: VID_00322, Pass 1 of 1 - [02:11:42] Video Encode complete - [02:11:42] Reencoding audio tracks (if req'd) - [02:11:42] Multiplexing M2TS - [02:11:45] Extracting A/V streams [VID_00346] - [02:11:47] Reencoding: VID_00346 (9 of 113) - [02:11:47] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 302 frames - [02:11:47] Reencoding: VID_00346, Pass 1 of 1 - [02:11:56] Video Encode complete - [02:11:56] Reencoding audio tracks (if req'd) - [02:11:57] Multiplexing M2TS - [02:11:58] Extracting A/V streams [VID_00359] - [02:12:00] Reencoding: VID_00359 (10 of 113) - [02:12:00] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 302 frames - [02:12:00] Reencoding: VID_00359, Pass 1 of 1 - [02:12:10] Video Encode complete - [02:12:10] Reencoding audio tracks (if req'd) - [02:12:10] Multiplexing M2TS - [02:12:11] Extracting A/V streams [VID_00345] - [02:12:14] Reencoding: VID_00345 (11 of 113) - [02:12:14] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 447 frames - [02:12:14] Reencoding: VID_00345, Pass 1 of 1 - [02:12:26] Video Encode complete - [02:12:26] Reencoding audio tracks (if req'd) - [02:12:27] Multiplexing M2TS - [02:12:28] Extracting A/V streams [VID_00358] - [02:12:31] Reencoding: VID_00358 (12 of 113) - [02:12:31] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 447 frames - [02:12:31] Reencoding: VID_00358, Pass 1 of 1 - [02:12:43] Video Encode complete - [02:12:43] Reencoding audio tracks (if req'd) - [02:12:43] Multiplexing M2TS - [02:12:45] Extracting A/V streams [VID_00321] - [02:12:49] Reencoding: VID_00321 (13 of 113) - [02:12:49] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 447 frames - Bitrate: 18,425 Kbs - [02:12:49] Reencoding: VID_00321, Pass 1 of 1 - [02:13:35] Video Encode complete - [02:13:35] Reencoding audio tracks (if req'd) - [02:13:36] Multiplexing M2TS - [02:13:37] Extracting A/V streams [VID_00382] - [02:13:40] Reencoding: VID_00382 (14 of 113) - [02:13:40] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 547 frames - [02:13:40] Reencoding: VID_00382, Pass 1 of 1 - [02:13:54] Video Encode complete - [02:13:54] Reencoding audio tracks (if req'd) - [02:13:55] Multiplexing M2TS - [02:13:57] Extracting A/V streams [VID_00372] - [02:14:01] Reencoding: VID_00372 (15 of 113) - [02:14:01] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 547 frames - [02:14:01] Reencoding: VID_00372, Pass 1 of 1 - [02:14:15] Video Encode complete - [02:14:15] Reencoding audio tracks (if req'd) - [02:14:16] Multiplexing M2TS - [02:14:17] Extracting A/V streams [VID_00349] - [02:14:21] Reencoding: VID_00349 (16 of 113) - [02:14:21] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 523 frames - [02:14:21] Reencoding: VID_00349, Pass 1 of 1 - [02:14:35] Video Encode complete - [02:14:35] Reencoding audio tracks (if req'd) - [02:14:36] Multiplexing M2TS - [02:14:37] Extracting A/V streams [VID_00362] - [02:14:42] Reencoding: VID_00362 (17 of 113) - [02:14:42] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 523 frames - [02:14:42] Reencoding: VID_00362, Pass 1 of 1 - [02:14:56] Video Encode complete - [02:14:56] Reencoding audio tracks (if req'd) - [02:14:57] Multiplexing M2TS - [02:14:58] Extracting A/V streams [VID_00378] - [02:15:04] Reencoding: VID_00378 (18 of 113) - [02:15:04] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 570 frames - [02:15:04] Reencoding: VID_00378, Pass 1 of 1 - [02:15:17] Video Encode complete - [02:15:17] Reencoding audio tracks (if req'd) - [02:15:19] Multiplexing M2TS - [02:15:20] Extracting A/V streams [VID_00388] - [02:15:24] Reencoding: VID_00388 (19 of 113) - [02:15:24] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 570 frames - [02:15:24] Reencoding: VID_00388, Pass 1 of 1 - [02:15:38] Video Encode complete - [02:15:38] Reencoding audio tracks (if req'd) - [02:15:39] Multiplexing M2TS - [06:31:39] Video Encode complete - [06:31:39] Reencoding audio tracks (if req'd) - [06:31:40] ReencodeAudio() 00075 1801 [09:43:56] - Failed to reencode audio, aborted [09:43:56] BATCH ABORTED... |
#10231 | Link |
Possible undersize?
Re-encoded a Blu-ray to BD-25 keeping audio untouched (DTS-HDMA + AC3 2.0 commentary), 2 pass encode:
[13:33:05] BD Rebuilder v0.36.03 (beta) - Source: THE_THIN_RED_LINE - Input BD size: 34,73 GB - Approximate total content: [02:50:47.070] - Target BD size: 22,95 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [13:33:05] PHASE ONE, Encoding - [13:33:05] Extracting A/V streams [VID_00274] - [13:51:44] Reencoding: VID_00274 (1 of 1) - [13:51:44] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 245.684 frames - Bitrate: 12.953 Kbs - [13:51:44] Reencoding: VID_00274, Pass 1 of 2 - [15:58:51] Reencoding: VID_00274, Pass 2 of 2 - [22:04:44] Video Encode complete - [22:04:45] Reencoding audio tracks (if req'd) - [22:04:45] Multiplexing M2TS [22:11:50]PHASE ONE complete [22:11:50]PHASE TWO - Rebuild Started - [22:11:50] Rebuilding BD file Structure [22:25:16] - Encode and Rebuild complete [22:25:16]JOB: THE_THIN_RED_LINE finished. ![]() |
#10232 | Link |
I found problem. I want to reencode ac3 640kbs to ac3 448kbs.
I goto setting select reencode ac3 to 448kbs. When rencode finnish i use bdinfo check but ac3 still 640kbs same before reencode. i have to do. sorry i'm englise is not good. thank you. |
#10233 | Link | |
I'm still making adjustments to the sizing during beta testing. So I'd expect it to be more accurate by the time I get to v1.00. You can always set a custom target size (see SETUP) that is closer to a full disc -- but right now I don't want to risk oversizing because that requires a complete redo. There wouldn't be any likely visible difference in the output with that small amount of undersizing. I'm not one of the folks who subscribes to the "fill to the edge of the disc" philosophy. But over time it'll get closer.
jdobbs.softworks@gmail.com Last edited by jdobbs; 19th November 2010 at 01:25. |
#10234 | Link |
I re-ripped Cars and ran it through the newest version of DVD-RB. I still get the same error. Here is the log:
----------------------- [13:47:02] BD Rebuilder v0.36.03 (beta) - Source: CARS - Input BD size: 38.53 GB - Approximate total content: [03:35:49.536] - Target BD size: 22.95 GB - Windows Version: 5.1 [2600] - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [13:47:02] PHASE ONE, Encoding - [13:47:02] Extracting A/V streams [VID_00015] - [13:47:10] Reencoding: VID_00015 (1 of 34) - [13:47:10] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 847 frames - Bitrate: 9,545 Kbs - [13:47:10] Reencoding: VID_00015, Pass 1 of 1 - [13:47:20] Video Encode complete - [13:47:20] Reencoding audio tracks (if req'd) - [13:47:20] Multiplexing M2TS - [13:47:22] Extracting A/V streams [VID_00016] - [13:47:25] Reencoding: VID_00016 (2 of 34) - [13:47:25] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 239 frames - Bitrate: 10,398 Kbs - [13:47:25] Reencoding: VID_00016, Pass 1 of 1 - [13:47:28] Video Encode complete - [13:47:28] Reencoding audio tracks (if req'd) - [13:47:28] Multiplexing M2TS - [13:47:29] Extracting A/V streams [VID_00023] - [13:47:36] Reencoding: VID_00023 (3 of 34) - [13:47:36] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 720 frames - Bitrate: 8,856 Kbs - [13:47:36] Reencoding: VID_00023, Pass 1 of 1 - [13:47:44] Video Encode complete - [13:47:44] Reencoding audio tracks (if req'd) - [13:47:44] Multiplexing M2TS - [13:47:46] Extracting A/V streams [VID_00024] - [13:47:53] Reencoding: VID_00024 (4 of 34) - [13:47:53] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 720 frames - Bitrate: 9,076 Kbs - [13:47:53] Reencoding: VID_00024, Pass 1 of 1 - [13:48:00] Video Encode complete - [13:48:00] Reencoding audio tracks (if req'd) - [13:48:00] Multiplexing M2TS - [13:48:02] Extracting A/V streams [VID_00025] - [13:48:08] Reencoding: VID_00025 (5 of 34) - [13:48:08] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 720 frames - Bitrate: 8,881 Kbs - [13:48:08] Reencoding: VID_00025, Pass 1 of 1 - [13:48:16] Video Encode complete - [13:48:16] Reencoding audio tracks (if req'd) - [13:48:16] Multiplexing M2TS - [13:48:19] Extracting A/V streams [VID_00026] - [13:48:25] Reencoding: VID_00026 (6 of 34) - [13:48:25] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 720 frames - Bitrate: 8,981 Kbs - [13:48:25] Reencoding: VID_00026, Pass 1 of 1 - [13:48:32] Video Encode complete - [13:48:32] Reencoding audio tracks (if req'd) - [13:48:32] Multiplexing M2TS - [13:48:35] Extracting A/V streams [VID_00027] - [13:48:42] Reencoding: VID_00027 (7 of 34) - [13:48:42] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 720 frames - Bitrate: 8,901 Kbs - [13:48:42] Reencoding: VID_00027, Pass 1 of 1 - [13:48:49] Video Encode complete - [13:48:49] Reencoding audio tracks (if req'd) - [13:48:49] Multiplexing M2TS - [13:48:52] Extracting A/V streams [VID_00028] - [13:48:58] Reencoding: VID_00028 (8 of 34) - [13:48:58] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 720 frames - Bitrate: 8,907 Kbs - [13:48:58] Reencoding: VID_00028, Pass 1 of 1 - [13:49:06] Video Encode complete - [13:49:06] Reencoding audio tracks (if req'd) - [13:49:06] Multiplexing M2TS - [13:49:08] Extracting A/V streams [VID_00029] - [13:49:14] Reencoding: VID_00029 (9 of 34) - [13:49:14] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 720 frames - Bitrate: 8,849 Kbs - [13:49:14] Reencoding: VID_00029, Pass 1 of 1 - [13:49:22] Video Encode complete - [13:49:22] Reencoding audio tracks (if req'd) - [13:49:22] Multiplexing M2TS - [13:49:24] Extracting A/V streams [VID_00030] - [13:49:30] Reencoding: VID_00030 (10 of 34) - [13:49:30] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 720 frames - Bitrate: 8,973 Kbs - [13:49:30] Reencoding: VID_00030, Pass 1 of 1 - [13:49:38] Video Encode complete - [13:49:38] Reencoding audio tracks (if req'd) - [13:49:38] Multiplexing M2TS - [13:49:40] Extracting A/V streams [VID_00036] - [13:51:04] Reencoding: VID_00036 (11 of 34) - [13:51:04] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 10,297 frames - Bitrate: 9,628 Kbs - [13:51:04] Reencoding: VID_00036, Pass 1 of 1 - [13:54:01] Video Encode complete - [13:54:01] Reencoding audio tracks (if req'd) - [13:54:01] Multiplexing M2TS - [13:54:25] Extracting A/V streams [VID_00037] - [13:55:19] Reencoding: VID_00037 (12 of 34) - [13:55:19] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 6,557 frames - Bitrate: 9,502 Kbs - [13:55:19] Reencoding: VID_00037, Pass 1 of 1 - [13:57:03] Video Encode complete - [13:57:03] Reencoding audio tracks (if req'd) - [13:57:03] Multiplexing M2TS - [13:57:19] Extracting A/V streams [VID_00038] - [13:58:10] Reencoding: VID_00038 (13 of 34) - [13:58:10] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 6,248 frames - Bitrate: 8,999 Kbs - [13:58:10] Reencoding: VID_00038, Pass 1 of 1 - [13:59:56] Video Encode complete - [13:59:56] Reencoding audio tracks (if req'd) - [13:59:56] Multiplexing M2TS - [14:00:10] Extracting A/V streams [VID_00039] - [14:01:13] Reencoding: VID_00039 (14 of 34) - [14:01:13] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 28,860 frames - Bitrate: 3,131 Kbs - [14:01:13] Reencoding: VID_00039, Pass 1 of 1 - [14:02:39] Video Encode complete - [14:02:39] Reencoding audio tracks (if req'd) - [14:02:39] Multiplexing M2TS - [14:02:57] Extracting A/V streams [VID_00040] - [14:03:20] Reencoding: VID_00040 (15 of 34) - [14:03:20] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 9,770 frames - Bitrate: 3,106 Kbs - [14:03:20] Reencoding: VID_00040, Pass 1 of 1 - [14:03:48] Video Encode complete - [14:03:48] Reencoding audio tracks (if req'd) - [14:03:48] Multiplexing M2TS - [14:03:56] Extracting A/V streams [VID_00041] - [14:04:17] Reencoding: VID_00041 (16 of 34) - [14:04:17] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 9,900 frames - Bitrate: 3,122 Kbs - [14:04:17] Reencoding: VID_00041, Pass 1 of 1 - [14:04:47] Video Encode complete - [14:04:47] Reencoding audio tracks (if req'd) - [14:04:47] Multiplexing M2TS - [14:04:54] Extracting A/V streams [VID_00042] - [14:05:15] Reencoding: VID_00042 (17 of 34) - [14:05:15] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 9,500 frames - Bitrate: 3,047 Kbs - [14:05:15] Reencoding: VID_00042, Pass 1 of 1 - [14:05:42] Video Encode complete - [14:05:42] Reencoding audio tracks (if req'd) - [14:05:42] Multiplexing M2TS - [14:05:49] Extracting A/V streams [VID_00043] - [14:06:12] Reencoding: VID_00043 (18 of 34) - [14:06:12] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 10,980 frames - Bitrate: 3,064 Kbs - [14:06:12] Reencoding: VID_00043, Pass 1 of 1 - [14:06:40] Video Encode complete - [14:06:40] Reencoding audio tracks (if req'd) - [14:06:40] Multiplexing M2TS - [14:06:48] Extracting A/V streams [VID_00044] - [14:06:59] Reencoding: VID_00044 (19 of 34) - [14:06:59] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 4,930 frames - Bitrate: 3,135 Kbs - [14:06:59] Reencoding: VID_00044, Pass 1 of 1 - [14:07:14] Video Encode complete - [14:07:14] Reencoding audio tracks (if req'd) - [14:07:14] Multiplexing M2TS - [14:07:17] Extracting A/V streams [VID_00045] - [14:07:33] Reencoding: VID_00045 (20 of 34) - [14:07:33] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 6,420 frames - Bitrate: 3,057 Kbs - [14:07:33] Reencoding: VID_00045, Pass 1 of 1 - [14:07:49] Video Encode complete - [14:07:49] Reencoding audio tracks (if req'd) - [14:07:49] Multiplexing M2TS - [14:07:54] Extracting A/V streams [VID_00046] - [14:08:24] Reencoding: VID_00046 (21 of 34) - [14:08:24] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 13,003 frames - Bitrate: 3,147 Kbs - [14:08:24] Reencoding: VID_00046, Pass 1 of 1 - [14:09:02] Video Encode complete - [14:09:02] Reencoding audio tracks (if req'd) - [14:09:02] Multiplexing M2TS - [14:09:11] Extracting A/V streams [VID_00047] - [14:09:25] Reencoding: VID_00047 (22 of 34) - [14:09:25] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 6,930 frames - Bitrate: 2,860 Kbs - [14:09:25] Reencoding: VID_00047, Pass 1 of 1 - [14:09:39] Video Encode complete - [14:09:39] Reencoding audio tracks (if req'd) - [14:09:39] Multiplexing M2TS - [14:09:44] Extracting A/V streams [VID_00048] - [14:09:51] Reencoding: VID_00048 (23 of 34) - [14:09:51] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 3,120 frames - Bitrate: 2,870 Kbs - [14:09:51] Reencoding: VID_00048, Pass 1 of 1 - [14:09:58] Video Encode complete - [14:09:58] Reencoding audio tracks (if req'd) - [14:09:58] Multiplexing M2TS - [14:10:00] Extracting A/V streams [VID_00049] - [14:10:12] Reencoding: VID_00049 (24 of 34) - [14:10:12] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 5,850 frames - Bitrate: 2,840 Kbs - [14:10:12] Reencoding: VID_00049, Pass 1 of 1 - [14:10:23] Video Encode complete - [14:10:23] Reencoding audio tracks (if req'd) - [14:10:23] Multiplexing M2TS - [14:10:28] Extracting A/V streams [VID_00050] - [14:10:35] Reencoding: VID_00050 (25 of 34) - [14:10:35] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 3,090 frames - Bitrate: 2,848 Kbs - [14:10:35] Reencoding: VID_00050, Pass 1 of 1 - [14:10:42] Video Encode complete - [14:10:42] Reencoding audio tracks (if req'd) - [14:10:42] Multiplexing M2TS - [14:10:44] Extracting A/V streams [VID_00051] - [14:10:57] Reencoding: VID_00051 (26 of 34) - [14:10:57] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 6,210 frames - Bitrate: 2,834 Kbs - [14:10:57] Reencoding: VID_00051, Pass 1 of 1 - [14:11:09] Video Encode complete - [14:11:09] Reencoding audio tracks (if req'd) - [14:11:09] Multiplexing M2TS - [14:11:14] Extracting A/V streams [VID_00053] - [14:12:02] Reencoding: VID_00053 (27 of 34) - [14:12:02] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 3,608 frames - Bitrate: 16,245 Kbs - [14:12:02] Reencoding: VID_00053, Pass 1 of 1 - [14:12:58] Video Encode complete - [14:12:58] Reencoding audio tracks (if req'd) - [14:12:58] Multiplexing M2TS - [14:13:11] Extracting A/V streams [VID_00054] - [14:13:32] Reencoding: VID_00054 (28 of 34) - [14:13:32] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 2,307 frames - Bitrate: 9,857 Kbs - [14:13:32] Reencoding: VID_00054, Pass 1 of 1 - [14:14:00] Video Encode complete - [14:14:00] Reencoding audio tracks (if req'd) - [14:14:00] Multiplexing M2TS - [14:14:07] Extracting A/V streams [VID_00055] - [14:14:39] Reencoding: VID_00055 (29 of 34) - [14:14:39] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 3,563 frames - Bitrate: 10,078 Kbs - [14:14:39] Reencoding: VID_00055, Pass 1 of 1 - [14:15:29] Video Encode complete - [14:15:29] Reencoding audio tracks (if req'd) - [14:15:29] Multiplexing M2TS - [14:15:38] Extracting A/V streams [VID_00060] - [14:54:49] Reencoding: VID_00060 (30 of 34) - [14:54:49] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 167,736 frames - Bitrate: 8,049 Kbs - [14:54:49] Reencoding: VID_00060, Pass 1 of 1 - [15:52:35] Video Encode complete - [15:52:35] Reencoding audio tracks (if req'd) - [15:52:35] Multiplexing M2TS - Error in attempt to multiplex: MUX_00060.meta - Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed. [16:00:48] - Failed to build structure, aborted Thanks. Later. acerjen Last edited by jdobbs; 19th November 2010 at 19:15. |
#10235 | Link |
Second attempt of Toy Story 3 went well. This time I didn't fiddle with the audio streams. Sure wish I had a freak processor to eat up this processing job. I'd run a lot more tests
#10236 | Link |
A rare but potential bug surfaced regarding mixed audio bitrates within a "Play All" bonus feature for the movie Predators. The bonus feature is 40:12, Evolution of the Species. It is broken up into 8 seperate .m2ts files, with 7 of the files having 448kbps, 6 channel AC3 audio, but one has 224kbps, 2 channel AC3 audio.
The full movie backup completes correctly, as BD-RB keeps the original structure intact and preserves the 8 individual files. However, if movie only is selected, and this .mpls is selected from the other Movie-Only playlist choices, the problem occurs. Since BD-RB attempts to join the 8 seperate m2ts files into one m2ts, and the lone 224kbps 2 channel AC3 is different from the rest, there is a problem. I have never experienced this before, probably very uncommon, but does provide another consideration for joining multi-part m2ts files into one. ![]() |
#10237 | Link | |
#10238 | Link | |
As I said, BD-RB reencodes this Blu-ray correctly if I choose full backup. It maintains the same structure. Only when I select movie only in BD-RB, and choose the associated .mpls, which BD-RB has as an available option to select from does the problem arise. Perhaps if BD-RB read the contents of this mpls, it would detect that the audio streams of each m2ts are not the same and refuse to continue to attempt to join them? I know this is extremely rare, and I really don't have an issue with it. ![]() I just wanted to share an experience that could allow BD-RB to make a movie only option that has audio sync or missing audio for a multi-part movie clip. ![]() Last edited by Capsbackup; 19th November 2010 at 17:13. |
#10239 | Link | |
BD-RB already reads the MPLS and each of the CLPI files... but all the audio encoding has to be done together. I could reject is sure... but then I'd get even more bug reports because of the missing segment. What I worry about is that if I start looking for ways to fix things that are out-of-spec, there would be no end to it.
jdobbs.softworks@gmail.com Last edited by jdobbs; 19th November 2010 at 19:15. |
#10240 | Link |
Rewording Suggestion To Avoid Confusion
@jdobbs
Maybe in the next program version, and on post #1, you could do some re-phrasing that would avoid confusing newbies, et al: The Matroska splitter is not mentioned in the actual program - instead being referred to as Haali splitter. So if BDRB reports an incorrect Haali splitter during a failed encode, users will go looking for it in post #1 and not find it.... ...maybe reword post #1 to include ..."Matroska", formerly known as... anyway, thought it might help. |
