Old 9th February 2011, 03:38   #11201  |  Link
Giddeon
RE: Afterlife 'Undead Vision' problems
I have searched on this thread for this problem and cannot find it, so here it is.
I ripped the complete Resident Evil: Afterlife Blu-Ray to a directory. I then put it through BD Rebuilder with the BD25 size selected, all the extras and just english audio and subtitles (allowing for more than one stream of a language). Everything seems fine except the resultant BD25 sized version has no audio on the Picture in Picture commentary called 'Undead Vision'.
After about 3 hours faffing about getting PDVD to play an iso image i made of the original files (just to check see if it's in there) it played with sound just fine. So it's definately BD Rebuilder thats skipping the sound.
When i look at the list of tracks BD Rebuilder has detected, there is always one audio track that it refuses to tick, even with me changing the audio options in the settings to all languages, no reencoding etc etc.
Can someone help me? I cant figure out how to get the sound on this extra feature and i suspect its that stubborn track that i cant enable.
Apreciate the time jdobbs, been using your program now for a looong time
Giddeon is offline   Reply With Quote
Old 9th February 2011, 03:49   #11202  |  Link
dfsooner
This won't resolve any BD_RB problem, but you can always use tsmuxer to add the audio stream back in from the original. That would solve your immediate problem with this movie.
dfsooner is offline   Reply With Quote
Old 9th February 2011, 03:50   #11203  |  Link
dfsooner
Of course you will have to determine which .m2ts file contains the audio in the original.
Old 9th February 2011, 05:12   #11204  |  Link
@jdobbs
Based on the fact that you've reponded to all subsequent reports, I'm guessing that my post #11180 "fell down a crack" and eluded what has to be your very tired eyes ;>}
I didn't miss it, I guess I just forgot to respond. I ordered "Centurion" online -- and expect it to be delivered tomorrow.
jdobbs.softworks@gmail.com
Old 9th February 2011, 05:15   #11205  |  Link
Originally Posted by Giddeon View Post
If it is DTS Express, it is a known issue (you'll see numerous posts on it here in this thread) and it isn't supported by any of the helper apps. I'm trying to create a workaround... I've been at the 90% complete level for a while now (experienced programmers will laugh when they hear that one ) -- but I'm having playback/timing issues still.
Old 9th February 2011, 05:16   #11206  |  Link
I suspect it is a DTS Express stream -- which isn't supported by TSMUXER.
Old 9th February 2011, 05:45   #11207  |  Link
Capsbackup
Suspicion correct!
Old 9th February 2011, 07:18   #11208  |  Link
dfsooner
Please don't do this.
I am testing for a custom size larger than DVD-9 (11000 to be exact). If it works for that, I'll be a happy camper. Besides my menus are not motion, so I don't anticipate any problems of that nature. I'll know in a few hours and will post the results.
Just for the record, I don't use DVD-9 size much any more because I no longer trust double layer DVD media. I have opted for 110000 for most of my rebuilds because it still gives me pretty good PQ and allows enough room to retain the HD audio (which BD-RB apparently allows for anything larger than [BD-9] - thanks for that, by the way - I wish it were optional for any size).
Rebuilt one of my TMPgenc-authored BDs with v0.37.04 at a custom size of 11000 and the menu works perfectly.
Old 9th February 2011, 18:23   #11209  |  Link
AndyP
Hi
Having a problem with Avatar (PAL) Extended edition.
Trying to build as DVD-5. Movie only, alternate movie mode DVD5, other movie (playlist number 3 from the list) Fails with FAILED to rebuild.
Settings
[Options]
MODE=1
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=0
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23450
TARGET_SIZE=23500
VERSION=0.37.0.4
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
OPEN_GOP=0
DEINTERLACE=0
SD_TO_1080=0
CONVERT_WIDE=0
AC3_192=0
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=0
MOVIEONLY_TYPE=1
ALTCRF=20
ALTMETHOD=0
[Paths]
SOURCE_PATH=E:\AVATAR_CE_D1\
WORKING_PATH=E:\DVD\
Log
[11:22:14] BD Rebuilder v0.37.04 (beta)
  - Source:  AVATAR_CE_D1
  - Input BD size: 39.85 GB
  - Approximate total content: [02:58:09.470]
  - Windows Version: 6.1 [7600]
  - Mode: DVD-5, 720x480/576, AC3 Audio
  - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[11:22:14] PHASE ONE, Encoding
 - [11:22:14] Extracting A/V streams [VID_00049]
 - [11:32:36] Reencoding: VID_00049 (1 of 33)
 - [11:32:36] Collecting video information
   - Rate/Length: 23.976fps, 14,972 frames
   - Bitrate: 2,944 Kbs
 - [11:42:27] Video Encode complete
 - [11:42:27] Reencoding audio tracks (if req'd)
 - [11:50:11] Multiplexing M2TS
 - [11:50:11] Extracting A/V streams [VID_00002]
 - [11:52:48] Reencoding: VID_00002 (2 of 33)
 - [11:52:48] Collecting video information
   - Rate/Length: 23.976fps, 25,559 frames
   - Bitrate: 2,527 Kbs
 - [12:42:05] Video Encode complete
 - [12:42:05] Multiplexing M2TS
 - [12:42:05] Extracting A/V streams [VID_00034]
 - [12:42:17] Reencoding: VID_00034 (3 of 33)
 - [12:42:17] Collecting video information
   - Rate/Length: 23.976fps, 1,003 frames
   - Bitrate: 3,749 Kbs
 - [12:45:03] Video Encode complete
 - [12:45:03] Multiplexing M2TS
 - [12:45:03] Extracting A/V streams [VID_00004]
 - [12:45:31] Reencoding: VID_00004 (4 of 33)
 - [12:45:31] Collecting video information
   - Rate/Length: 23.976fps, 2,113 frames
   - Bitrate: 3,495 Kbs
 - [12:48:46] Video Encode complete
 - [12:48:46] Multiplexing M2TS
 - [12:48:46] Extracting A/V streams [VID_00035]
 - [12:49:08] Reencoding: VID_00035 (5 of 33)
 - [12:49:08] Collecting video information
   - Rate/Length: 23.976fps, 3,056 frames
   - Bitrate: 3,243 Kbs
 - [12:50:55] Video Encode complete
 - [12:50:55] Multiplexing M2TS
 - [12:50:55] Extracting A/V streams [VID_00006]
 - [12:52:59] Reencoding: VID_00006 (6 of 33)
 - [12:52:59] Collecting video information
   - Rate/Length: 23.976fps, 21,792 frames
   - Bitrate: 3,226 Kbs
 - [12:53:00] Reencoding: VID_00006
 - [13:08:36] Video Encode complete
 - [13:08:36] Multiplexing M2TS
 - [13:08:36] Extracting A/V streams [VID_00036]
 - [13:08:50] Reencoding: VID_00036 (7 of 33)
 - [13:08:50] Collecting video information
   - Rate/Length: 23.976fps, 727 frames
   - Bitrate: 4,056 Kbs
 - [13:08:51] Reencoding: VID_00036
 - [13:11:21] Video Encode complete
 - [13:11:21] Multiplexing M2TS
 - [13:11:21] Extracting A/V streams [VID_00008]
 - [13:12:20] Reencoding: VID_00008 (8 of 33)
 - [13:12:20] Collecting video information
   - Rate/Length: 23.976fps, 7,831 frames
   - Bitrate: 2,509 Kbs
 - [13:27:54] Video Encode complete
 - [13:27:54] Multiplexing M2TS
 - [13:27:54] Extracting A/V streams [VID_00037]
 - [13:28:02] Reencoding: VID_00037 (9 of 33)
 - [13:28:02] Collecting video information
   - Rate/Length: 23.976fps, 960 frames
   - Bitrate: 2,462 Kbs
 - [13:31:24] Video Encode complete
 - [13:31:24] Multiplexing M2TS
 - [13:31:24] Extracting A/V streams [VID_00010]
 - [13:32:08] Reencoding: VID_00010 (10 of 33)
 - [13:32:08] Collecting video information
   - Rate/Length: 23.976fps, 5,135 frames
   - Bitrate: 2,457 Kbs
 - [13:42:26] Video Encode complete
 - [13:42:26] Multiplexing M2TS
 - [13:42:26] Extracting A/V streams [VID_00050]
 - [13:42:40] Reencoding: VID_00050 (11 of 33)
 - [13:42:40] Collecting video information
   - Rate/Length: 23.976fps, 1,057 frames
   - Bitrate: 2,424 Kbs
 - [13:44:32] Video Encode complete
 - [13:44:32] Multiplexing M2TS
 - [13:44:32] Extracting A/V streams [VID_00012]
 - [13:45:28] Reencoding: VID_00012 (12 of 33)
 - [13:45:28] Collecting video information
   - Rate/Length: 23.976fps, 6,760 frames
   - Bitrate: 2,884 Kbs
 - [14:04:04] Video Encode complete
 - [14:04:04] Multiplexing M2TS
 - [14:04:04] Extracting A/V streams [VID_00038]
 - [14:04:12] Reencoding: VID_00038 (13 of 33)
 - [14:04:12] Collecting video information
   - Rate/Length: 23.976fps, 1,036 frames
   - Bitrate: 3,270 Kbs
 - [14:08:35] Video Encode complete
 - [14:08:35] Multiplexing M2TS
 - [14:08:35] Extracting A/V streams [VID_00014]
 - [14:09:40] Reencoding: VID_00014 (14 of 33)
 - [14:09:40] Collecting video information
   - Rate/Length: 23.976fps, 8,633 frames
   - Bitrate: 3,089 Kbs
 - [14:15:07] Video Encode complete
 - [14:15:07] Multiplexing M2TS
 - [14:15:07] Extracting A/V streams [VID_00051]
 - [14:15:45] Reencoding: VID_00051 (15 of 33)
 - [14:15:45] Collecting video information
   - Rate/Length: 23.976fps, 8,548 frames
   - Bitrate: 2,431 Kbs
 - [14:21:39] Video Encode complete
 - [14:21:39] Multiplexing M2TS
 - [14:21:39] Extracting A/V streams [VID_00016]
 - [14:21:49] Reencoding: VID_00016 (16 of 33)
 - [14:21:49] Collecting video information
   - Rate/Length: 23.976fps, 2,482 frames
   - Bitrate: 2,387 Kbs
 - [14:23:07] Video Encode complete
 - [14:23:07] Multiplexing M2TS
 - [14:23:07] Extracting A/V streams [VID_00040]
 - [14:23:11] Reencoding: VID_00040 (17 of 33)
 - [14:23:11] Collecting video information
   - Rate/Length: 23.976fps, 605 frames
   - Bitrate: 4,115 Kbs
 - [14:23:34] Video Encode complete
 - [14:23:34] Multiplexing M2TS
 - [14:23:34] Extracting A/V streams [VID_00018]
 - [14:24:32] Reencoding: VID_00018 (18 of 33)
 - [14:24:32] Collecting video information
   - Rate/Length: 23.976fps, 11,310 frames
   - Bitrate: 2,966 Kbs
 - [14:30:40] Video Encode complete
 - [14:30:40] Multiplexing M2TS
 - [14:30:40] Extracting A/V streams [VID_00041]
 - [14:31:01] Reencoding: VID_00041 (19 of 33)
 - [14:31:01] Collecting video information
   - Rate/Length: 23.976fps, 3,014 frames
   - Bitrate: 3,936 Kbs
 - [14:32:48] Video Encode complete
 - [14:32:48] Multiplexing M2TS
 - [14:32:48] Extracting A/V streams [VID_00020]
 - [14:33:40] Reencoding: VID_00020 (20 of 33)
 - [14:33:40] Collecting video information
   - Rate/Length: 23.976fps, 11,158 frames
   - Bitrate: 2,708 Kbs
 - [14:39:47] Video Encode complete
 - [14:39:47] Multiplexing M2TS
 - [14:39:47] Extracting A/V streams [VID_00042]
 - [14:39:56] Reencoding: VID_00042 (21 of 33)
 - [14:39:56] Collecting video information
   - Rate/Length: 23.976fps, 2,528 frames
   - Bitrate: 2,468 Kbs
 - [14:41:19] Video Encode complete
 - [14:41:19] Multiplexing M2TS
 - [14:41:19] Extracting A/V streams [VID_00022]
 - [14:42:26] Reencoding: VID_00022 (22 of 33)
 - [14:42:26] Collecting video information
   - Rate/Length: 23.976fps, 13,448 frames
   - Bitrate: 2,838 Kbs
 - [14:49:40] Video Encode complete
 - [14:49:40] Multiplexing M2TS
 - [14:49:40] Extracting A/V streams [VID_00052]
 - [14:49:51] Reencoding: VID_00052 (23 of 33)
 - [14:49:51] Collecting video information
   - Rate/Length: 23.976fps, 3,033 frames
   - Bitrate: 2,504 Kbs
 - [14:51:31] Video Encode complete
 - [14:51:31] Multiplexing M2TS
 - [14:51:31] Extracting A/V streams [VID_00024]
 - [14:57:16] Reencoding: VID_00024 (24 of 33)
 - [14:57:16] Collecting video information
   - Rate/Length: 23.976fps, 62,869 frames
   - Bitrate: 3,104 Kbs
 - [15:31:02] Video Encode complete
 - [15:31:02] Multiplexing M2TS
 - [15:31:02] Extracting A/V streams [VID_00044]
 - [15:31:07] Reencoding: VID_00044 (25 of 33)
 - [15:31:07] Collecting video information
   - Rate/Length: 23.976fps, 899 frames
   - Bitrate: 3,500 Kbs
 - [15:31:37] Video Encode complete
 - [15:31:37] Multiplexing M2TS
 - [15:31:37] Extracting A/V streams [VID_00026]
 - [15:31:51] Reencoding: VID_00026 (26 of 33)
 - [15:31:51] Collecting video information
   - Rate/Length: 23.976fps, 2,814 frames
   - Bitrate: 3,376 Kbs
 - [15:33:20] Video Encode complete
 - [15:33:20] Multiplexing M2TS
 - [15:33:20] Extracting A/V streams [VID_00045]
 - [15:33:23] Reencoding: VID_00045 (27 of 33)
 - [15:33:23] Collecting video information
   - Rate/Length: 23.976fps, 608 frames
   - Bitrate: 4,064 Kbs
 - [15:33:45] Video Encode complete
 - [15:33:45] Multiplexing M2TS
 - [15:33:45] Extracting A/V streams [VID_00028]
 - [15:34:28] Reencoding: VID_00028 (28 of 33)
 - [15:34:28] Collecting video information
   - Rate/Length: 23.976fps, 7,431 frames
   - Bitrate: 3,918 Kbs
 - [15:38:28] Video Encode complete
 - [15:38:28] Multiplexing M2TS
 - [15:38:28] Extracting A/V streams [VID_00046]
 - [15:38:31] Reencoding: VID_00046 (29 of 33)
 - [15:38:31] Collecting video information
   - Rate/Length: 23.976fps, 380 frames
   - Bitrate: 4,005 Kbs
 - [15:38:45] Video Encode complete
 - [15:38:45] Multiplexing M2TS
 - [15:38:45] Extracting A/V streams [VID_00030]
 - [15:39:29] Reencoding: VID_00030 (30 of 33)
 - [15:39:29] Collecting video information
   - Rate/Length: 23.976fps, 7,929 frames
   - Bitrate: 3,689 Kbs
 - [15:43:42] Video Encode complete
 - [15:43:42] Multiplexing M2TS
 - [15:43:42] Extracting A/V streams [VID_00047]
 - [15:44:02] Reencoding: VID_00047 (31 of 33)
 - [15:44:02] Collecting video information
   - Rate/Length: 23.976fps, 3,806 frames
   - Bitrate: 3,236 Kbs
 - [15:46:02] Video Encode complete
 - [15:46:02] Multiplexing M2TS
 - [15:46:02] Extracting A/V streams [VID_00032]
 - [15:46:25] Reencoding: VID_00032 (32 of 33)
 - [15:46:25] Collecting video information
   - Rate/Length: 23.976fps, 5,610 frames
   - Bitrate: 2,631 Kbs
 - [15:49:15] Video Encode complete
 - [15:49:15] Multiplexing M2TS
 - [15:49:15] Extracting A/V streams [VID_00048]
 - [15:49:28] Reencoding: VID_00048 (33 of 33)
 - [15:49:28] Collecting video information
   - Rate/Length: 23.976fps, 7,185 frames
   - Bitrate: 1,107 Kbs
 - [15:52:47] Video Encode complete
 - [15:52:47] Multiplexing M2TS
[15:52:47]PHASE ONE complete
[15:52:47]PHASE TWO - Rebuild Started
 - [15:52:47] Rebuilding stream 00049 [1 of 33]
 - [15:52:47] Rebuilding stream 00002 [2 of 33]
 - [15:52:47] Rebuilding stream 00034 [3 of 33]
 - [15:52:47] Rebuilding stream 00004 [4 of 33]
 - [15:52:47] Rebuilding stream 00035 [5 of 33]
 - [15:52:47] Rebuilding stream 00006 [6 of 33]
 - [15:52:47] Rebuilding stream 00036 [7 of 33]
 - [15:52:47] Rebuilding stream 00008 [8 of 33]
 - [15:52:47] Rebuilding stream 00037 [9 of 33]
 - [15:52:47] Rebuilding stream 00010 [10 of 33]
 - [15:52:47] Rebuilding stream 00050 [11 of 33]
 - [15:52:47] Rebuilding stream 00012 [12 of 33]
 - [15:52:47] Rebuilding stream 00038 [13 of 33]
 - [15:52:47] Rebuilding stream 00014 [14 of 33]
 - [15:52:47] Rebuilding stream 00051 [15 of 33]
 - [15:52:47] Rebuilding stream 00016 [16 of 33]
 - [15:52:47] Rebuilding stream 00040 [17 of 33]
 - [15:52:47] Rebuilding stream 00018 [18 of 33]
 - [15:52:47] Rebuilding stream 00041 [19 of 33]
 - [15:52:47] Rebuilding stream 00020 [20 of 33]
 - [15:52:47] Rebuilding stream 00042 [21 of 33]
 - [15:52:47] Rebuilding stream 00022 [22 of 33]
 - [15:52:47] Rebuilding stream 00052 [23 of 33]
 - [15:52:47] Rebuilding stream 00024 [24 of 33]
 - [15:52:47] Rebuilding stream 00044 [25 of 33]
 - [15:52:47] Rebuilding stream 00026 [26 of 33]
 - [15:52:47] Rebuilding stream 00045 [27 of 33]
 - [15:52:47] Rebuilding stream 00028 [28 of 33]
 - [15:52:47] Rebuilding stream 00046 [29 of 33]
 - [15:52:47] Rebuilding stream 00030 [30 of 33]
 - [15:52:47] Rebuilding stream 00047 [31 of 33]
 - [15:52:47] Rebuilding stream 00032 [32 of 33]
 - [15:52:47] Rebuilding stream 00048 [33 of 33]
 - [15:52:47] Building ALTERNATE OUTPUT Structure
 - [15:56:13] Starting MPLEX.
[15:56:13] - Failed to REBUILD
Thanks for any advice.
Cheers,
Andy
AndyP is offline   Reply With Quote
Old 9th February 2011, 19:41   #11210  |  Link
Giddeon
Well well well, i went to check after reading your reply (thanks for that btw) and guess what.. DTS Express. You really do know your sh*t
Well thanks for the effort your making to sort that out, i've got faith enough to leave the bugger on my drive till you do. I'll be watching the latest updates with great interest.
Excellent work dood, you rock
Old 9th February 2011, 23:37   #11211  |  Link
@jdobbs
I just did a full disc conversion of "Centurion" to BD9, using "Good" (Very fast) and "One-pass (CRF) settings - audio encoding options were left untouched, so that BD-RB performed a downconversion of the audio to 5.1AC3 640kbps.
While the original 7.1 DTS(MA) audio had (per tsMuxeR) an audio delay of 18,393ms, this delay disappeared somewhere in the downconversion, so that the playback was grossly (18+ seconds) out of synch.
The proof in the pudding was that using tsMuxeR to add a delay of 18,393ms to the primary audio of the main compressed .M2TS file eliminated the problem.
The reason for the original delay appears to be due to an initial rather mysterious SILENT 18 second static display regarding "Technicolor Services" and details of the video and audio formats.
Reminiscent, if I remember correctly, of the structure of, "The Girl With The Dragon Tattoo". Back in September, in your post #9531, you stated:
But the "Tatoo" problem only affected the "movie-only" version, so perhaps this is something different...
I fixed this one for the next release. BD-RB was experiencing a PTS/DTS overflow (if you look at the times for the feature with BDEdit, you'll see that the start/stop times are all huge -- it starts at 10 hours). I corrected a section of my code that had attempted to use a 32 bit integer to temporarily hold the PTS value. As a result, BD-RB didn't catch the 18 second difference between the first audio and video PTS values. Obviously there aren't many discs out there with DTS/PTS values that large -- explaining why this hasn't been an issue before.
Old 10th February 2011, 04:19   #11212  |  Link
Capsbackup
This is a good find / fix! I agree there probably are very few discs authored this way, but for those that are it will be dealt with.
Interesting that I thought BD-RB would pull the delay value from the mpls that tsMuxeR reads upon remux, so as to avoid the potential audio delay causing the async.
Will this correction apply to secondary audio as well, since there was another report of the main audio being in sync but the secondary audio was not?
Old 10th February 2011, 07:28   #11213  |  Link
setarip_old
setarip_old's Avatar
@jdobbs
Glad to hear that you were able to address this so quickly.
Now, when one of the 10,000 (it seems) heads gets lopped off, you'll hear "Thump, thump, thump" as it hits the ground - and not, "Sire, may I peel you a grape?" ;>}
Old 10th February 2011, 13:42   #11214  |  Link
Jake802
Question
Hey guys I am having problems making a backup of Case 39. Here is the log.....
[07:35:50] BD Rebuilder v0.37.04 (beta)
- Source: CASE_39_AC
- Input BD size: 35.49 GB
- Approximate total content: [02:44:02.565]
- Target BD size: 22.90 GB
- Quality: Highest (Very Slow), Two Pass
[07:35:50] PHASE ONE, Encoding
- [07:35:50] Extracting A/V streams [VID_00019]
- [07:35:58] Reencoding: VID_00019 (1 of 23)
- [07:35:58] Collecting video information
- Source Video: MPEG-2, 720x480
- Rate/Length: 29.970fps, 958 frames
- [07:35:58] Reencoding: VID_00019, Pass 1 of 1
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.37.04 (beta)
- HAALI Splitter: Isn't recommended version
- FFDSHOW: , not recommended version
- FFDSHOW VC-1 set incorrectly: [0]
- FFDSHOW MPEG2 set incorrectly: [0]
- FFDSHOW AVC set incorrectly: [0]
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[07:36:02] - Failed video encode, aborted
I realize the following are wrong according to the log:
But I just got done doing a backup of The Lovely Bones with no issues. I am guessing the two discs have different Video File types,and this is why I am encountering the issue?
Jake
Sorry I left out I have my VC1 set to wmv9,I thought thats what were supposed to set it to in windows 7?
Jake
Jake802 is offline   Reply With Quote
Old 10th February 2011, 13:50   #11215  |  Link
Jake802
Ok I got the movie backup to work but not full backup!
Old 10th February 2011, 15:14   #11216  |  Link
drmih
Strangely enough I have my system setup correctly and Case 39 works fine. Just an idea, but have you thought about installing the recommended software correctly?
Old 10th February 2011, 15:29   #11217  |  Link
Jake802
That's why I asked the question, The only settings I have touched in FFDShow is to make sure the VC1 is set to WMV9. I dont have a clue as to what the others should be. I just know I havent touched them and I havent had any issues in a long time!
Old 10th February 2011, 15:36   #11218  |  Link
I don't think there is a way you can reliably get the delay from the MPLS. You have to look at the start PTS times of the audio in the M2TS. I'm pretty sure that's how TSMUXER does it also -- since it can find it without an MPLS. BD Rebuilder looks for the PTS of all the audio streams directly from the M2TS. All the streams don't necessarily have to have the same start PTS, though... so one might have a delay while another does not. You also have to remember that the secondary audio stream is synced to the secondary video, not the primary. Even the multiple video streams may not have the same start PTS (although they usually do). I don't trust another app to catch all that.
I don't remember the other report you mentioned -- but the odds are low that there is a connection.
Old 10th February 2011, 15:44   #11219  |  Link
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Jake
Jake
That's undoubtedly the issue. You may think you have VC-1 set to wmv9 -- but BD Rebuilder is looking directly at the registry, and it isn't set.
You need to follow the directions in the first post of this thread exactly. You aren't set up correctly. Any one of those incorrect values I see can result in failure -- and you have several wrong.
Old 10th February 2011, 15:50   #11220  |  Link
Jake802
You need to follow the directions in the first post of this thread exactly. You aren't set up correctly. Any one of those incorrect values can result in failure -- and you have several wrong.
Thanks JDobbs!
Question my video decoder configuration says vc1 wmv9,how else do i fix it,should I uninstall everything and reinstall it? I just found it odd because I have been making backups for months now with no issues? So Uninstall everything and reinstall after a fresh reboot?
Jake
