Old 16th January 2013, 20:51   #16501  |  Link
setarip_old
setarip_old's Avatar
@unrox
Hi!
Tsmuxer
Just installed the new version, also re-installed the components. It will start to copy and after about 2 minutes get the error message "tsmuxer has stopped", tried on two computers same result.
Please clarify, you just installed the new version of what? (There hasn't been a new version of tsMuxeR in more than two years)
What original, commercial Blu-ray discs are you trying to process?
Old 17th January 2013, 01:43   #16502  |  Link
ChldsPlay
I can't get Total Recall to fit onto a BD-25. The output is always too large. I do not have this problem with any other title. I have tried changing the output from BD-25 to a custom size, but it didn't change anything.
[Status]
LABEL=TOTAL_RECALL_2012
VERSION=v0.42.08 (beta)
SOURCE_SIZE=49780247220
SOURCE_VIDEO_SIZE=49477294080
TARGET_SIZE=24641536000
REDUCTION=.491914186346708
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;enm;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
QUICK=0
ENCODE_STEP=0
COMPLETED=118
REBUILD_COMPLETE=1
ChldsPlay is offline   Reply With Quote
Old 17th January 2013, 05:39   #16503  |  Link
omegaman7
omegaman7's Avatar
I'll run Total Recall 2012 tonight. Now I have a reason to run it I'll post around 8Am regarding my results. Looks like my current version just expired. Better update to 42.08 I see that you have.
Old 17th January 2013, 15:50   #16504  |  Link
Capsbackup
Has anyone else been confronted by this? If so, how did you overcome this?
I was only sharing my experience to this question.
The bug report is noted though.
Old 17th January 2013, 16:01   #16505  |  Link
Prz
I just installed the new beta of BDR and have experienced a "failed video encoding .... aborted". Tried running another title which encoded correctly in prior release. Any ideas as to whats wrong? Messages below.
[01/17/13] BD Rebuilder v0.42.08 (beta)
- Input BD size: 22.28 GB
- Approximate total content: [01:53:04.819]
- Target BD size: 7.84 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- Auto Quality: Good (Very Fast), Two Pass
[09:52:03] PHASE ONE, Encoding
- [09:52:03] Processing: VID_00058 (1 of 1)
- [09:52:03] Extracting A/V streams [VID_00058]
- [09:56:12] Reencoding video [VID_00058]
- Rate/Length: 23.976fps, 162,673 frames
- Bitrate: 8,459 Kbs
- [09:56:12] Reencoding: VID_00058, Pass 1 of 2
- Encode failed. Aborting.
- BD-Rebuilder v0.42.08 (beta)
- FFDSHOW: 3882, Ok
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[09:56:12] - Failed video encode, aborted
Prz is offline   Reply With Quote
Old 17th January 2013, 16:13   #16506  |  Link
Ch3vr0n
Seems like you edited the logfile. Where's the source volume name? don't edit logfile contents
Old 17th January 2013, 16:21   #16507  |  Link
Prz
Here it is.
[09:52:00] Source: DARK_SHADOWS_00100
- FFDSHOW: 3882, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Old 17th January 2013, 16:49   #16508  |  Link
omegaman7
omegaman7's Avatar
@ChldsPlay
I use a custom size of 23500 for the output size. Generally, the size averages 22 - 22.5Gb. However in this case (Total Recall 2012) it ended up at 23.1Gb. Looks like I'll be running it again. Because while that fits on a single layer BD, That's getting awfully close to the outer edge. I prefer hang around 22 - 22.5Gb. It's been my experience, that most burn errors occur at the very end of the disc.
Old 17th January 2013, 17:03   #16509  |  Link
Ch3vr0n
what's the volume name in full disc mode? Something's not right, may be a corrupt rip
Old 17th January 2013, 17:31   #16510  |  Link
Prz
Here's the log file in full backup mode. Tried another title which was a know "good rip" and got the same result but will try to re-rip and attempt again.
[11:29:18] Source: DARK_SHADOWS
- Input BD size: 23.82 GB
- Approximate total content: [02:18:35.390]
- Auto Quality: Better (Faster), Two Pass
[11:29:22] PHASE ONE, Encoding
- [11:29:22] Processing: VID_00002 (1 of 16)
- [11:29:22] Extracting A/V streams [VID_00002]
- [11:29:26] Reencoding video [VID_00002]
- Rate/Length: 23.976fps, 287 frames
- Bitrate: 2,938 Kbs
- [11:29:26] Reencoding: VID_00002, Pass 1 of 2
- FFDSHOW: 3882, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[11:29:26] - Failed video encode, aborted
Old 17th January 2013, 18:40   #16511  |  Link
HatchetMan
HD=1, doesn't that mean you are retaining HD audio? Which is like an extra 6 or 7GB over DTS core?
@Prz - If that's the case, you may be leaving only about 1GB or even less for the video since you are trying to fit it on dual layer dvd (Target BD size: 7.84 GB)
Maybe it fails because it can't squeeze the video in that size at full resolution 1920x1080?? Or of course maybe a bad rip, happens to me from time to time. But not on this title, I had no problem taking movie only down to that size by getting rid of HD audio (set to AC3 @ 448kbps instead). The 1920x1080 video ended up looking as good as orig, in my eyes, audio pretty much the same as source, to my ears (using audio amplify = 1.1, which is a 10% increase in gain).
HatchetMan is offline   Reply With Quote
Old 17th January 2013, 18:47   #16512  |  Link
HatchetMan
@setarip_old
In case you never get Ted working, because I had issues with it and BDRB as well, here is another option to backing it up. Take your full disc anydvd hd rip and run it through makemkv selecting only the unrated version (based on listed runtimes). There it is in full HD glory movie only MKV format. But to shrink it down some, now run that file through Handbrake. That is how I got my backup done anyways, had to do the same with Green Lantern extended, I could get get a folder backup using BDRB, but always and mysteriously failed when trying to make the mkv structure, go figure...
Old 17th January 2013, 19:08   #16513  |  Link
Prz
@HatchetMan ... Removed the HD audio with same results....any other suggestions?
Old 17th January 2013, 20:51   #16514  |  Link
Prz
Looks like by BDR suspected failure was self inflicted as I chose the BD 9 rather than BD 25 option. Its rebuilding now. Thanks Chevron and HatchetMan for your attempts to help.
Old 17th January 2013, 22:39   #16515  |  Link
ChldsPlay
Originally Posted by omegaman7 View Post
@ChldsPlay
That is what I used for custom settings and 23.1 GB is what I get using bd-25 or custom output. It doesn't fit on the discs I have (by maybe half a gig or so).
Old 17th January 2013, 23:06   #16516  |  Link
RobertM
The BD-25 preset sets the target size to about 23,500 MB, so that might explain why you get the same result with a custom target of 23,500 MB. Why don't you try a custom setting of 22,500 MB and see if that gets it to fit?
Old 18th January 2013, 00:22   #16517  |  Link
omegaman7
omegaman7's Avatar
I set it for 23000 and ended up with an output size of 22.6Gb. That's close enough. However, I also chose the Default (High Quality setting). Most the time now, I use the slowest quality setting. It's become clear, that the quality setting will affect the overall output size. I started using the slowest setting, because I've been noticing that while using DGDecNV, the video quality isn't as good as it could be. I think I understand why. Would be difficult to explain though :S I've also started using X264/LAVF again. I haven't had time to REALLY compare the two frameservers.
Essentially though, I believe DGDecNV is like hardware acceleration. In which the video frames are over simplified in some cases. I've certainly seen that when playing back backups, and using hardware acceleration.
Old 18th January 2013, 22:08   #16518  |  Link
setarip_old
Further re:"Ted" movie only out of sync
@jdobbs and others
The curious world of BD backups continues.
I exchanged my "Ted" BD for a new replacement and all sync problems disappeared ;>}
Old 18th January 2013, 22:35   #16519  |  Link
RobertM
Did you happen to keep the rip from the first disc? It would be interesting to see what the differences are in the STREAM folder.
Old 18th January 2013, 23:57   #16520  |  Link
setarip_old
Sorry, no I didn't...
