Old 23rd May 2017, 10:13   #7981  |  Link
Ghitulescu
Ghitulescu's Avatar
1440x1080 is a perfectly valid BD resolution.
Therefore all editing and authoring suites MUST support it, even more when it's also a standard format, HDV; and not whatever downloaded one (Youtube or other sources, grey to dark )
Born in the USB (not USA)
Old 23rd May 2017, 12:31   #7982  |  Link
Music Fan
If you have only one title and don't need menus, tsMuxer is good too (multiAVCHD actually uses it for muxing).
Music Fan is offline   Reply With Quote
Old 23rd May 2017, 17:59   #7983  |  Link
rs008f
mutliavchd crashes when I try to author M2T files.
rs008f is offline   Reply With Quote
Old 23rd May 2017, 20:18   #7984  |  Link
Music Fan
Try to mux them first with tsMuxer.
Old 23rd May 2017, 21:57   #7985  |  Link
rs008f
tsMuxer doesn't support M2T files, it reports can't detect stream type.
Is there a Windows software similar to this Mac software ClipWrap? http://www.divergentmedia.com/clipwrap
Old 23rd May 2017, 22:20   #7986  |  Link
Music Fan
And if you change the extension (to ts or m2ts) before opening it ?
Probably FFmpeg (in command line).
Old 23rd May 2017, 22:21   #7987  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
It depends on whether the .mts file contains the appropriate stream meta-data...
Do you have a sample?
Old 23rd May 2017, 22:32   #7988  |  Link
rs008f
Changing to TS works. Although PowerDVD 13 can't play the 1 minute video Bluray folder created. Fortunately, the one multiAVCHD creates plays fine.
What would the commands for FFMPEG to rewrap M2T files to MOV/MP4 files without re-encoding/transcoding?
Edit: I found one through googling.
ffmpeg -i "input.mts" -vcodec copy -acodec pcm_s16le "output.mov"
Old 3rd April 2018, 13:34   #7989  |  Link
MB2
Hi all,
Recently upgraded my pc, new install etc.
I had been using BD-RE Builder to make 12gb files to make "multi" film discs using MultiAVCHD, but after the rebuild, when i click make menu in MultiAVCHD, i get this error
[13:29:39] Avisynth is not working properly! Menu will not available!
[13:29:39] Re/Install Avisynth 2.58, ffdshow, haali splitter.
I have installed all these, from the BD-RE Builder links (Avisynth 0.60) etc...
MultiAVCHD used to work on the "old PC". Not sure what is going on but any help appreciated.
I've tried reinstalling ffdshow and haali splitter too. Which actually resulted in BD-RE Builder creating back ups out of sync... so reinstalled all again, and BD-RE Builder works fine again... just not MultiAVCHD.
Desperate for this to work please
MB2 is offline   Reply With Quote
Old 29th August 2018, 15:48   #7990  |  Link
bananenmann
Originally Posted by alimao View Post
Title movie search movie database offiline ? Any possible solution ?
That's my problem, too. Is there a possibility to enter somewhere in the program a new link to a new database, so that this feature will work again?
Second Question:
Three custom templates are integrated. Does someone have more than that or knows, where I can download some?
Third Question:
The default Backround sound sample is nice, but after using it for years, I can't hear it anymore. Does someone have some other loop-samples with that duration of 32 seconds?
Thanks in advance!!!
P.s.:
Please Dean, continue your great work on this program. Although it is old, it is still the best one for creating AVCHDs and Blurays. Unfortunately it is still buggy. If you would continue I would even buy it, because it's great.
bananenmann is offline   Reply With Quote
Old 29th August 2018, 19:16   #7991  |  Link
MrVideo
MrVideo's Avatar
I'm a little confused. BDRB can be used to make a disc with multiple items on the menu. I use it to make BDs of TV show episodes. So, if you have more than one movie you want to fit on a BD-25, or BD-50, BDRB will do that just fine.
My Total Eclipse 2017 Photos
Old 27th September 2018, 09:07   #7992  |  Link
Flanker-B
Doesn't work for me in windows 10 any more. it launches but as soon as i load a file in it (mkv for example) it suddenly reduces it's window size and becomes this weird small blank window.
Flanker-B is offline   Reply With Quote
Old 7th November 2018, 20:06   #7993  |  Link
nikknightt
When I play back an authored AVCHD or BD on my xbox one it locks up on the menu. I've tried slide,carousel & xmb.. Is there a setting to make it play correctly? The same content is fine on a PS3 or stand alone player.. discs created with tsmuxer work fine on the xbox. thanks..
nikknightt is offline   Reply With Quote
Old 19th December 2018, 11:07   #7994  |  Link
jetro75
TSMuxeR error
Hello Guys need some help here, I start to use MultiAVCHD to convert MKV videos 8 years ago, every things fine but lately it give me some errors like this:
multiAVCHD.dat version: [04010767]
[11:26:28] Subtitle track #4 name: [forced]
[11:26:33] [AUTO-FIT]: Title#01 2755 kbps, 1920x1080 -> 1280x720 -> 1280x720
[11:26:38] Checking for available space and drive types (FAT32/NTFS)...
[11:26:39] Destination [E:]: NTFS, 3803302.6 MiB (3714.163 GiB) free space
[11:26:39] Temp folder [c:]: NTFS, 489123.37 MiB (477.66 GiB) free space
[11:26:39] Log started for multiAVCHD v4.1 (build 771)
[11:26:39] Selected output mode: Panasonic Viera TV / Camcoder (SDHC) (NTSC)
[11:26:39] Processing one title...
[11:26:39] Existing E:\Fantastici\AVCHD\ cannot be used as destination folder!
[11:26:39] Output will be written to: E:\Fantastici\AVCHD-20181219-112639
[11:26:41] Processing (F:\torrent\Harry Potter And The Deathly Hallows Part 1 2010 BDRip 1080p Ita Eng X265-NAHOM\Harry Potter And The Deathly Hallows Part 1.mkv)...
[11:26:41] This title is marked for reencoding / uncropping...
[11:26:41] Encoding process may take 10 min to 10 hours, so be patient...
[11:26:41] *** Initiating video encoding:
[11:26:41] *** Original : 1920x1080
[11:26:41] *** Crop : 0
[11:26:41] *** Resize : 1280x720
[11:26:41] *** Uncrop to : 1280x720
[11:26:41] *** Sharpen : 0
[11:26:41] *** Bitrate : 2755 kbps
[11:26:41] *** Frame rate: Original (23.976)
[11:26:41] *** Level : 4
[11:26:41] *** Quality : One pass (insane)
[11:26:41] *** SAR : 1:1
[11:26:41] *** DAR : 1280x720
[11:26:41] *** Profile : Blu-ray
[11:26:41] *** Stand-by for indexing (ffms2)...
[11:26:41] *** Encoding : One pass - content: [02:25:56]
[11:26:41] *** Encoding : x264 options: --preset ultrafast -B 2755 -I 48 --level 4 -i 24 -b 3 -m 0 -r 4 --ipratio 1.4 --vbv-bufsize 15000 --vbv-maxrate 14000 --qcomp 0.5 --threads auto --thread-input --aud --nal-hrd vbr --sar 1:1 --me dia --b-pyramid strict --slices 0 --weightp 0 --rc-lookahead 0 -o "c:\multiAVCHD\_TEMP\multiTEMP-20181219\Harry Potter And The Deathly Hallows Part 1.[1280x720-23.976].264" "c:\multiAVCHD\_TEMP\multiTEMP-20181219\20181219-112641-uncrop-running.avs"
[11:27:51] *** Speed : 2964.85 fps (elapsed: 00:01:10 - Realtime x 123.66)
[11:27:51] *** Transcoding failed!
[11:27:51] *** Check ffdshow/avisynth/haali (reinstall)!
[11:27:51] >>> Download links: http://multiforum.deanbg.com/viewtopic.php?f=7&t=17
[11:27:51] *** DEBUG: Try to play [c:\multiAVCHD\_TEMP\multiTEMP-20181219\20181219-112641-uncrop-running.avs] in MPC or other player, which supports AviSynth scripts and report the error to the author!
[11:27:51] tsMuxeR failed to process [F:\torrent\Harry Potter And The Deathly Hallows Part 1 2010 BDRip 1080p Ita Eng X265-NAHOM\Harry Potter And The Deathly Hallows Part 1.mkv]...
here avisynth script:
loadplugin("C:\multiAVCHD\tools\ffms2.dll")
filename="F:\torrent\Harry Potter And The Deathly Hallows Part 1 2010 BDRip 1080p Ita Eng X265-NAHOM\Harry Potter And The Deathly Hallows Part 1.mkv"
b = FFVideoSource(filename).LanczosResize( 1280,720)
#bordersizeX=int((1280-width(b))/2)
#bordersizeY=int((720-height(b))/2)
#AddBorders(b, bordersizeX, bordersizeY, bordersizeX, bordersizeY)
#b=last
b=b
return b.ConvertToYV12()
It say me: Check ffdshow/avisynth/haali (reinstall)!
I've reinstalled every thing bu errors still occurs sometimes with some video.
I've run Multitest it say all ok.
Any help would be apppreciated ty.
jetro75 is offline   Reply With Quote
Old 20th December 2018, 07:10   #7995  |  Link
manolito
manolito's Avatar
You will not get any help here for conversions of files downloaded from a torrent...
Old 20th December 2018, 10:41   #7996  |  Link
jetro75
Really? and where i could get some help?
Old 20th December 2018, 12:10   #7997  |  Link
SeeMoreDigital
Forum rule 6 clearly states:
"No warez, cracks, serials or illegally obtained copyrighted content! Links to content of a questionable nature (e.g. anything you don't own and/or have downloaded), asking for, offering, or asking for help/helping to process such content in any way or form is not tolerated."
You are on your own!
Old 8th January 2019, 06:55   #7998  |  Link
Avalokitesvara
Hello !
I have exactly the same problem. My Blu-Ray burned with MultiAVCHD works on a computer but not on XBOX ONE. The menu launches properly, the background music too, but impossible to navigate the menu. No button on the remote control responds. Is there a solution ? I search with BDEdit but the software is complex and although I think I have identified where the "navigation" part of the menu, I do not know what to change for it to work...
I know that MultiAVCHD will not have any more updates, but I should be able to do something... No?
Thank you to the entire community and happy new year !
Avalokitesvara is offline   Reply With Quote
Old 15th January 2019, 16:59   #7999  |  Link
mariner
You could try using a chaep blu-ray player like the versatile sony x700. It even plays 4k L5.1AVC 'blu-ray" disc.
mariner is offline   Reply With Quote
Old 16th January 2019, 08:27   #8000  |  Link
Avalokitesvara
Thank you for your answer, but it was not really the question ... Yes, the Blu-Ray works without problems on other players, but my question was whether it is possible to play Blu-Ray with functional menus on XBOX ONE.
avchd, blu-ray hd-dvd, mkv, multiavchd, re-author
