26th February 2017, 20:12 | #4863 | Link |
Pig on the wing
Or leave the settings as they are and try --rskip. I could never tell if it was better on or off, but encoding is much faster enabled. It will probably increase the bitrate though.
26th February 2017, 20:18 | #4864 | Link |
x265.exe --crf 21 --aq-mode 1 --ctu 32 --qg-size 32 --deblock -3:-3 --me star --bframes 4 --rc-lookahead 60 --ref 5 --b-adapt 2 --tu-intra-depth 4 --tu-inter-depth 4 --merange 57 --weightp --weightb --scenecut 40 --rd 4 --limit-ref 3 --limit-modes --tskip --rect --amp --max-merge 5 --subme 5 --b-intra --no-rskip --no-sao --no-strong-intra-smoothing %1 -o %~n1.hevc
x265 [info]: HEVC encoder version 2.3+9-820f4327ddac x265 [info]: build info [Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2 x265 [info]: Main profile, Level-4 (Main tier) x265 [info]: Thread pool created using 8 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 3 / wpp(34 rows) x265 [info]: Coding QT: max CU size, min CU size : 32 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 4 inter / 4 intra x265 [info]: ME / range / subpel / merge : star / 57 / 5 / 5 x265 [info]: Keyframe min / max / scenecut / bias: 25 / 250 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 60 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 1 x265 [info]: References / ref-limit cu / depth : 5 / on / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-21.0 / 0.60 x265 [info]: tools: rect amp limit-modes rd=4 psy-rd=2.00 tskip signhide tmvp x265 [info]: tools: b-intra lslices=6 deblock(tC=-3:B=-3) x265 [info]: frame I: 3, Avg QP:22.55 kb/s: 28882.40 x265 [info]: frame P: 141, Avg QP:23.75 kb/s: 19287.13 x265 [info]: frame B: 456, Avg QP:28.23 kb/s: 6014.92 x265 [info]: Weighted P-Frames: Y:0.0% UV:0.0% x265 [info]: Weighted B-Frames: Y:0.0% UV:0.0% x265 [info]: consecutive B-frames: 0.7% 0.0% 0.0% 80.6% 18.8% encoded 600 frames in 264.24s (2.27 fps), 9248.22 kb/s, Avg QP:27.15 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 20s 0ms Bit rate : 9 071 Kbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.146 Stream size : 21.6 MiB (98%) Writing library : x265 2.3+9-820f4327ddac:[Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=4 / tu-intra-depth=4 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=5 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt Default : Yes Forced : No Gained a speed increase of 0.10 fps, resulted file 60KB smaller and saw no differences, these nasty blocks in the water are still there. Should I try with a -1:-1 deblocking value? |
26th February 2017, 20:23 | #4866 | Link | |
Source is YachtRide from here: http://ultravideo.cs.tut.fi/#testsequences |
26th February 2017, 20:53 | #4872 | Link |
yes, great for comparisons, I create a --lossless sample and a --crf16 sample and compare to the rip I am doing at the time.
Lol, your command line a few posts back is now virtually identical to mine. I use a slightly lower --merange for 1080p and --aq-mode 2, but apart from that, it is the same. Also for *some* ultra clean sources, even crf 22 suffices, and is virtually indistinguishable to the crf16 comparison, and not distinguishable at normal viewing distances (48 inch screen, 102 inch screen) Divxmaster |
26th February 2017, 21:38 | #4874 | Link |
Quite normal, yes. The HEVC algorithm as such has only a limited parallelizability. Parts of the encoding need to wait for other parts to finish first. This has been discussed many times before.
27th February 2017, 00:53 | #4877 | Link |
well primarily better quality. Although I haven't tried --aq 1 in recent versions of x265.
Ah, I see you do 8 bit encodes. I only do 10 bit encodes, but I see you use decoding hw that requires 8 bit. Also, add --no-open-gop, or you *may* have seeking issues. Cheers, Divxmaster |
27th February 2017, 18:32 | #4879 | Link | |
IIRC, the previous discussions were about 12/16 cores, or multiple CPUs not being fully utilized. @darksiderg : What CPU are you using? |
27th February 2017, 20:04 | #4880 | Link |
AQ 2 will decrease QP (increasing quality) in dark regions. This increases bitrate some, but helps the blocking-in-black issues, particularly on LCD displays will elevated blacks.
Note only for use with SDR gamma content. It's not appropriate for HDR PQ content, which has many more code values in dark, better matching human perception. |
