Old 20th July 2019, 21:15   #6941  |  Link
mandarinka
mandarinka's Avatar
From the description, it looks both aqmode 3 and aqmode 4 are modifications of aqmode 2. Based on the descriptions, the first adds bias for darker scenes/parts and the second (#4) adds bias for detected(?) edges (to improve them?).
Old 21st July 2019, 10:31   #6942  |  Link
jlpsvk
But how... quality and speed impact??? I've done test on the whole 4K HDR movie. Same settings, one with AQ2, one with AQ4.
AQ2:
x265 [info]: HEVC encoder version 3.1+8-21db162c8622
x265 [info]: build info [Windows][GCC 9.1.0][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 AVX512
x265 [info]: Main 10 profile, Level-5.1 (High tier)
x265 [info]: Thread pool created using 28 threads
x265 [info]: Slices                              : 1
x265 [info]: frame threads / pool features       : 4 / wpp(25 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge         : star / 57 / 3 / 3
x265 [info]: Keyframe min / max / scenecut / bias: 24 / 240 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt        : 48 / 8 / 2
x265 [info]: b-pyramid / weightp / weightb       : 1 / 1 / 0
x265 [info]: References / ref-limit  cu / depth  : 4 / on / on
x265 [info]: AQ: mode / str / qg-size / cu-tree  : 2 / 1.0 / 8 / 1
x265 [info]: Rate Control / qCompress            : CRF-16.0 / 0.60
x265 [info]: VBV/HRD buffer / max-rate / init    : 160000 / 160000 / 0.900
x265 [info]: tools: rect amp limit-modes rd=4 psy-rd=2.00 rdoq=2 psy-rdoq=1.00
x265 [info]: tools: signhide tmvp lslices=4
x265 [info]: frame I:   1572, Avg QP:19.24  kb/s: 36306.92
x265 [info]: frame P:  31790, Avg QP:20.31  kb/s: 29999.39
x265 [info]: frame B: 120253, Avg QP:23.15  kb/s: 17831.23
x265 [info]: Weighted P-Frames: Y:9.7% UV:1.7%
x265 [info]: consecutive B-frames: 17.9% 9.6% 8.6% 19.1% 7.5% 10.0% 6.4% 9.3% 11.7%
encoded 153615 frames in 81511.10s (1.88 fps), 20538.46 kb/s, Avg QP:22.53
AQ4:
x265 [info]: AQ: mode / str / qg-size / cu-tree  : 4 / 1.0 / 8 / 1
x265 [info]: frame I:   1571, Avg QP:19.38  kb/s: 35277.33
x265 [info]: frame P:  31792, Avg QP:20.46  kb/s: 29185.39
x265 [info]: frame B: 120252, Avg QP:23.29  kb/s: 17402.88
x265 [info]: Weighted P-Frames: Y:9.6% UV:1.7%
x265 [info]: consecutive B-frames: 17.9% 9.6% 8.7% 19.1% 7.6% 10.0% 6.3% 9.3% 11.7%
encoded 153615 frames in 83129.38s (1.85 fps), 20024.18 kb/s, Avg QP:22.66
Core i9-7960X, 64GB DDR4, RTX 2070, 1TB NVMe SSD, 56TB NAS
jlpsvk is offline   Reply With Quote
Old 21st July 2019, 12:14   #6943  |  Link
Jamaika
I just found out that "aq-mode" parameters don't apply to frames I i.e. pictures. For qp on for frames P, aq-mode on. For qp off for frames I, aq-mode off.
Old 21st July 2019, 16:50   #6944  |  Link
vpupkind
Both hevc-aq and aq=4 try to take into account edges passing through the block.
vpupkind is offline   Reply With Quote
Old 21st July 2019, 21:11   #6945  |  Link
Jamaika
x265&svt-3.1+8
I don't know why no one adds x265 & svt. Is this a temporary fusion? I will risk something to write.
https://www.sendspace.com/file/mt3kue
Information about color space is also interesting. For SVT, this is currently the High Dymanic Range. For 8bit is Low Dynamic Range.
x265 [info]: SVT doesn't support input-csp param; Disabling it
x265 [info]: SVT doesn't support crf param; Disabling it
x265 [info]: SVT doesn't support info param; Disabling it
x265 [info]: SVT doesn't support aq-mode param; Disabling it
x265 [info]: SVT doesn't support colormatrix param; Disabling it
x265 [info]: SVT doesn't support colorprim param; Disabling it
x265 [info]: SVT doesn't support transfer param; Disabling it
x265 [info]: SVT doesn't support limit-refs param; Disabling it
x265 [info]: SVT doesn't support range param; Disabling it
if (params->color_space == BPG_CS_YCbCr_HDR) {
p->vui.matrixCoeffs = 9;
svtHevcParam->highDynamicRangeInput = 1;
if (params->bit_depth => 10) {
p->vui.bEnableVideoFullRangeFlag = 1;
} else {
p->vui.bEnableVideoFullRangeFlag = 0;
}// for 8bit is Low Dynamic Range
PS change files in x265
svt.h --> #define INPUT_SIZE_8K_TH 0xB71B00 // 12 Million
param.cpp --> svtHevcParam->vbvMaxrate = 0;
param.cpp --> svtHevcParam->vbvBufsize = 0;
param.cpp --> svtHevcParam->vbvBufInit = 90;
param.cpp --> svtHevcParam->hrdFlag = 0;
Old 22nd July 2019, 08:54   #6946  |  Link
DJATOM
DJATOM's Avatar
Can someone explain, what's the purpose of HME? Is it for better quality/accuracy of ME or just for making things faster?
Me on GitHub | My Telegram
DJATOM is offline   Reply With Quote
Old 22nd July 2019, 09:36   #6947  |  Link
froggy1
ffx264/ffhevc author
froggy1's Avatar
the former. it's for better quality/accuracy. Here's an article that explains it. It is also low computational but highly efficient
http://homepages.inf.ed.ac.uk/rbf/CV...stimation.html
ffx264--ffhevc--ffxvid
froggy1 is online now   Reply With Quote
Old 22nd July 2019, 19:19   #6948  |  Link
benwaggoner
So, it can make things faster at the same quality, higher quality at the same speed, or a mix of the two.
Ben Waggoner
My Compression Book
Old 24th July 2019, 12:46   #6949  |  Link
aegisofrime
Could you share your settings? By simply setting --hme, I'm seeing a reduction of around 40% in speed on my encodes. Thanks!
aegisofrime is offline   Reply With Quote
Old 24th July 2019, 13:12   #6950  |  Link
froggy1
froggy1's Avatar
I don't see such a high penalty on my i7 7700K processor. I use hme=1 and hme-search=umh,umh,umh
Old 24th July 2019, 15:16   #6951  |  Link
DJATOM
DJATOM's Avatar
My friend tried star,star,umh and caught a crash on frame 50, but umh,star,umh works fine (but slower).
Old 24th July 2019, 15:20   #6952  |  Link
froggy1
froggy1's Avatar
yes, I experienced the same crash when using star for all levels (L0,1,2) hme-search=star
I use umh because I find it preserves details better but is a bit slower than star
Old 24th July 2019, 18:20   #6953  |  Link
benwaggoner
Speculation: aq-mode 4 is the non-experimental implementation of --hevc-aq.
Ben Waggoner
My Compression Book
Old 24th July 2019, 21:00   #6954  |  Link
jlpsvk
@benwaggoner
i don't think so, as hevc-aq and aq-mode 4 coexists...
Old 24th July 2019, 22:41   #6955  |  Link
mandarinka
mandarinka's Avatar
I can confirm it doesn't like star on the first instance, I got crash right at start with merange 92 and 1440x1080 source.
To get higher speed, lower your merange. The value given is used as the distance of the first-stage search, so it is effectively quadrupled.
Old 25th July 2019, 06:28   #6956  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I'm currently using merange 32 for my 720p encodes (max CTU and TU is 32 for better CPU utilization). Would it make sense to lower the value for example to 16-20 and enable HME (with umh,umh,umh), or is the first stage range so important that it will start to affect the final result too much?
Old 25th July 2019, 06:55   #6957  |  Link
froggy1
froggy1's Avatar
I use as ME range a value of 26 for 1080p encodes (ctu is 32 too). ME range is calculated as follows:
ctu size - 4(luma) - 2(chroma) (- 1 if me=hex is used)
You can lower it to 26 and enable HME like I do. Here the performance penalty is very minor, also considering that HME, as explained in the article I linked to a few posts earlier, has computationally low complexity
I wonder what options the poster above uses to hit a 40% reduction in speed when HME is enabled
Old 25th July 2019, 10:17   #6958  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thanks, I need to test that change. I also noticed a severe slowdown when testing HME at its default values and with merange 32. This is with basically settings from preset 'slower' with only a few minor changes.
Old 25th July 2019, 11:55   #6959  |  Link
froggy1
froggy1's Avatar
I don't use presets but my own settings which I'm satisfied with. Here are my libx265 ffmpeg settings
X265PARAMS="ref=4:me=umh:hme=1:hme-search=umh,umh,umh:bframes=6:rd=4:subme=4:merange=26:strong-intra-smoothing=0:ctu=32:sao=0:cu-lossless=0:cutree=1:fades=1:tu-inter-depth=3:tu-intra-depth=3:rskip=1:max-merge=1:rc-lookahead=60:aq-mode=1:aq-strength=1.0:rdoq-level=1:psy-rdoq=1.5:psy-rd=2.3:limit-modes=1:limit-refs=3:limit-tu=1:rd-refine=0:deblock=-3,-3:weightb=1:weightp=1:rect=1:amp=0:wpp=1:pmode=0:pme=0:b-intra=1:b-adapt=2:b-pyramid=1:tskip-fast=0:fast-intra=0:early-skip=0:min-keyint=24:keyint=240"
Old 25th July 2019, 13:45   #6960  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Biggest differences seem to be ref=5, me star, rd=6, rd-refine, strong-intra-smoothing, max-merge=4 and amp in my settings. I don't think those should affect the search for motion though. I really need to test to get some rough values.
