26th October 2018, 21:28 | #3222 | Link | |
Release 2.0
26th October 2018, 21:30 | #3223 | Link |
Hello everyone !!!
I have a "weird" problem...I'm trying to convert HDR to SDR winth avisynth/Hable method,and at the end of demuxing.starting to encode,staxrip crashes with this error: "Win32Exception (1.9.0.0) The resource loader failed to find MUI file System.ComponentModel.Win32Exception (0x80004005): The resource loader failed to find MUI file at StaxRip.Proc.Start() in C:\Users\Revan\Desktop\staxrip-1.8.2.0\General\Proc.vb:line 327 at StaxRip.x265Enc.Encode(String passName, String commandLine, ProcessPriorityClass priority) in C:\Users\Revan\Desktop\staxrip-1.8.2.0\Encoding\x265Enc.vb:line 65 at StaxRip.x265Enc.Encode() in C:\Users\Revan\Desktop\staxrip-1.8.2.0\Encoding\x265Enc.vb:line 41 at StaxRip.GlobalClass.ProcessVideo() in C:\Users\Revan\Desktop\staxrip-1.8.2.0\General\GlobalClass.vb:line 231 at System.Threading.Tasks.Parallel.<>c__DisplayClass4_0.<Invoke>b__0() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at StaxRip.GlobalClass.ProcessJob(String jobPath) in C:\Users\Revan\Desktop\staxrip-1.8.2.0\General\GlobalClass.vb:line 138 at StaxRip.GlobalClass.ProcessJobs() in C:\Users\Revan\Desktop\staxrip-1.8.2.0\General\GlobalClass.vb:line 37" I know it's weird because it refers to staxrip 1.8.2.0 (and i use 1.9.0.0),and to some strange path users\Revan\desktop. No previous staxrip installations.Do i have to install other programs/dependencies ? Any help is highly appreciated!!! |
26th October 2018, 21:57 | #3224 | Link | |
32Bit is not supported, only x64, make sure your not running it as 32Bit. MUI File - is Something that should be installed already, Which is installed by Windows. Only files that are required by AVS is Avisynth+ and MS runtimes if there not already installed and sometimes dotnet 4.7(Should already be installed if your using Windows 10). Last edited by Revan654; 26th October 2018 at 21:59. |
26th October 2018, 23:50 | #3225 | Link |
thanks for the update!!
is it possible to encode a 422 avi source to 420 using vapoursynth? it keep crashing saying i cant. It works fine with Avisynth but never worked with VS on any staxrip version. ------------------- Video encoding using x265 2.9+2 ------------------- "C:\Program Files (x86)\VapourSynth\core64\vspipe.exe" C:\temp\staxrip\hcidfgdfgp-001_temp\hcidfgdfgp-001_new.vpy - --y4m | D:\2.0.0.0.x64\Apps\x265\x265.exe --crf 17 --preset slow --profile main10 --level-idc 5.1 --output-depth 10 --vbv-bufsize 160000 --vbv-maxrate 160000 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,50)" --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --max-luma 1023 --hdr --hdr-opt --repeat-headers --hrd --aud --vui-timing-info --vui-hrd-info --min-keyint 24 --keyint 240 --no-open-gop --deblock -3:-3 --no-sao --no-strong-intra-smoothing --chromaloc 2 --sar 1 --frames 720 --y4m --output C:\temp\staxrip\hcidfgdfgp-001_temp\hcidfgdfgp-001_new_out.hevc - x265 [error]: main10 profile not compatible with i422 input chroma subsampling. Error: fwrite() call failed when writing frame: 0, plane: 0, errno: 32 Output 29 frames in 1.22 seconds (23.71 fps) obalClass.vb:ligne 138 Last edited by imhh11; 26th October 2018 at 23:54. |
27th October 2018, 00:17 | #3226 | Link | |
For VS It has to be converted to proper Pixel Format first before it can be feed into the encoder. see fmtconv docs for proper layout and code. |
27th October 2018, 08:27 | #3227 | Link | |
Thanks for the update.
27th October 2018, 12:13 | #3228 | Link |
Starfish
I always make a new folder for StaxRip. So I copied my templates to the 2.0 settings folder.
I wanted to encode a video file with x264 which resulted in an error. Code:
x264 [error]: main profile doesn't support a bit depth of 10 Error: fwrite() call failed when writing frame: 0, plane: 0, errno: 22 Output 9 frames in 0.46 seconds (19.70 fps) |
27th October 2018, 16:23 | #3229 | Link |
thanks for this release.
there's one thing which prevents me from switching to this staxrip: HDR metadata is not appended to x265 command line. import vui metadata setting is enabled. it only works on old staxrip 1.7.0.6 is this a known problem? anyone knows a fix? thanks |
27th October 2018, 18:19 | #3230 | Link | |
27th October 2018, 18:24 | #3231 | Link | |
They keep simplifying the read out. It went from the entire color coordinates now it only shows colorspace. FYI, 1.7.0.6 + MediaInfo does have some bad ColorSpace values. Which was only fixed recently. It showed BT.709 instead of showing BT.2020. |
27th October 2018, 19:17 | #3232 | Link | |
are values like Mastering display luminance even necessary to correctly encode hdr10 content? Last edited by RieGo; 27th October 2018 at 19:20. |
27th October 2018, 21:00 | #3233 | Link | |
You are also missing the HDR10 feature I added in with 1.9, which adds the remaining HDR metadata into the video. ------ MediaInfo, There is no perfect version. Older versions report incorrect ColorSpaces, But contains Color Coordinates. New Version contains Correct ColorSpaces but doesn't contain Color Coordinates. Your going have to pick what you want. As long as your HDR source is True Rec.2020 the VUI will be import. The issue is some studios forget to switch display monitor settings from P3 to Rec.2020. Not even HDR service/applications accepts P3 as a acceptable HDR colorSpace. Even YoutubeHDR rejects P3. -------- You can use the PowerShell Scripts I've Created, Which will add 95% of all HDR Flags needed for encoding(Which contains the Master-Display data). |
28th October 2018, 00:59 | #3235 | Link |
Raven,
I'm not sure if this has been reported already. I can't add more jobs while another video is being encoded. The app just quits. Present job encoding is not affected though. v1.8.2 and below does not have this problem
28th October 2018, 08:20 | #3237 | Link |
So i looked into the HDR scripts - "HDR to 10bit 1000nits(Rec.2100)AVS.ps1".
it basically just adds static metadata (color coordinates), but not the data which is in the source (i compared with older HDR files i encoded). shouldn't this produce wrong results? is this because we have no way to read out color coordinates without a proper mediainfo? actually i think i found an answer to this question here: https://github.com/SK-Hardwired/nv_h...tcher/issues/9 so these values are indeed always the same, no matter which hdr source you have, right? in this case i assume it would be enough to save those values in a staxrip template Last edited by RieGo; 28th October 2018 at 14:51. |
28th October 2018, 18:05 | #3238 | Link | |
29th October 2018, 00:02 | #3239 | Link |
Thanks revan. FYI, I can no longer add any jobs now. The window just closes without showing the encoding template
30th October 2018, 16:19 | #3240 | Link |
Ever since I tried to use Version 1.8 and above I get the following error:
"---------------- Error Video encoding using NVEnc 4.20 ---------------- Video encoding using NVEnc 4.20 failed with exit code: 1 (0x1) The exit code might be a system error code: STATUS_WAIT_1 The exit code might be a system error code: Unzulässige Funktion. ------------------- Video encoding using NVEnc 4.20 ------------------- C:\Portable\StaxRip2.0.0.0.x64\Apps\NVEnc\NVEncC64.exe --cqp 18:20:22 --preset quality -i D:\Torrent\Snow.White.and.the.Three.Stooges.1961.1080p.AMZN.WEBRip.DDP2.0.x264-ABM\Snow.White.and.the.Th..._temp\Snow.White.and.the.Three.Stooges.1961.1080p.AMZN.WEB-DL.DDP2.0.x264-ABM_new.avs -o D:\Torrent\Snow.White.and.the.Three.Stooges.1961.1080p.AMZN.WEBRip.DDP2.0.x264-ABM\Snow.White.and.the.Th..._temp\Snow.White.and.the.Three.Stooges.1961.1080p.AMZN.WEB-DL.DDP2.0.x264-ABM_new_out.h264 Error on nvEncGetEncodePresetConfig: 15 (NVENC indicates that an invalid struct version was used by the client) Error on nvEncGetEncodePresetConfig: 15 (NVENC indicates that an invalid struct version was used by the client) Failed to Initialize the encoder .: 15 (NVENC indicates that an invalid struct version was used by the client) ------------------- Video encoding using NVEnc 4.20 ------------------- C:\Portable\StaxRip2.0.0.0.x64\Apps\NVEnc\NVEncC64.exe --cqp 18:20:22 --preset quality -i D:\Torrent\Snow.White.and.the.Three.Stooges.1961.1080p.AMZN.WEBRip.DDP2.0.x264-ABM\Snow.White.and.the.Th..._temp\Snow.White.and.the.Three.Stooges.1961.1080p.AMZN.WEB-DL.DDP2.0.x264-ABM_new.avs -o D:\Torrent\Snow.White.and.the.Three.Stooges.1961.1080p.AMZN.WEBRip.DDP2.0.x264-ABM\Snow.White.and.the.Th..._temp\Snow.White.and.the.Three.Stooges.1961.1080p.AMZN.WEB-DL.DDP2.0.x264-ABM_new_out.h264 Error on nvEncGetEncodePresetConfig: 15 (NVENC indicates that an invalid struct version was used by the client) Error on nvEncGetEncodePresetConfig: 15 (NVENC indicates that an invalid struct version was used by the client) Failed to Initialize the encoder .: 15 (NVENC indicates that an invalid struct version was used by the client)" Can anybody help? Edit: Problem solved, I installed the latest NVidia Grafic Driver Last edited by Lupissimo; 30th October 2018 at 16:55. |
