2nd May 2012, 21:58 | #15062 | Link | |
under windows 7 64bit, i find that non-LAVF is often faster in any case with a 6core AMD CPU. i'd suggest trying an encode both ways and see which is faster on your particular system. |
4th May 2012, 03:48 | #15063 | Link |
Okay, I turned LAVF on and timed a rebuild of Limitless. x264-64.exe was running at 99%. It took 4.18 hours including time to create an ISO.
Then I unchecked the LAVF option and let it run again. However, x264-64.exe STILL ran at 99%. Not the *32 version as before. This time it took 5.13 hours including time to create an ISO. I'm also running and AMD 6 core CPU. Obviously I want to enable the LAVF option in the future. It seems there is some latch function that only wants to run the 64 bit version now, with or without the LAVF option. |
4th May 2012, 10:05 | #15064 | Link |
I tried 2 movies yesterday Alien 3 and Alien 4. Before that I successfully reencoded Alien and Aliens 2, but these 2 I got video aborted, can it be the new X264?
========================== [17:57:38] BD Rebuilder v0.40.09 (beta) [17:57:38] BEGIN - BATCH SEQUENCE ========================== ----------------------- [17:57:38] PROCESSING BATCH FILE [23] ---------------------- [05-03-12] BD Rebuilder v0.40.09 (beta) [17:57:39] Source: ALIEN_3 - Input BD size: 25,51 GB - Approximate total content: [02:24:52.641] - Target BD size: 22,95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [17:57:40] PHASE ONE, Encoding - [17:57:40] Processing: VID_00750 (1 of 27) - [17:57:40] Extracting A/V streams [VID_00750] - [18:05:39] Reencoding video [VID_00750] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5.029 frames - Bitrate: 16.275 Kbs - [18:05:39] Reencoding: VID_00750, Pass 1 of 2 - [18:07:14] Reencoding: VID_00750, Pass 2 of 2 - [18:10:05] Video Encode complete - [18:10:05] Processing audio tracks - Track 4352 (eng): Keeping original audio - [18:10:05] Processing: VID_00752 (2 of 27) - [18:10:05] Extracting A/V streams [VID_00752] - [18:11:02] Reencoding video [VID_00752] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 16.081 frames - Bitrate: 16.469 Kbs - [18:11:02] Reencoding: VID_00752, Pass 1 of 2 - [18:15:24] Reencoding: VID_00752, Pass 2 of 2 - [18:26:44] Video Encode complete - [18:26:44] Processing: VID_00753 (3 of 27) - [18:26:44] Extracting A/V streams [VID_00753] - [18:26:54] Reencoding video [VID_00753] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.334 frames - Bitrate: 16.554 Kbs - [18:26:54] Reencoding: VID_00753, Pass 1 of 2 - [18:27:32] Reencoding: VID_00753, Pass 2 of 2 - [18:29:16] Video Encode complete - [18:29:16] Processing: VID_00754 (4 of 27) - [18:29:16] Extracting A/V streams [VID_00754] - [18:29:27] Reencoding video [VID_00754] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.355 frames - Bitrate: 16.291 Kbs - [18:29:27] Reencoding: VID_00754, Pass 1 of 2 - [18:30:05] Reencoding: VID_00754, Pass 2 of 2 - [18:31:46] Video Encode complete - [18:31:46] Processing: VID_00755 (5 of 27) - [18:31:46] Extracting A/V streams [VID_00755] - [18:32:20] Reencoding video [VID_00755] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 9.314 frames - Bitrate: 16.293 Kbs - [18:32:20] Reencoding: VID_00755, Pass 1 of 2 - [18:34:55] Reencoding: VID_00755, Pass 2 of 2 - [18:41:33] Video Encode complete - [18:41:33] Processing: VID_00756 (6 of 27) - [18:41:33] Extracting A/V streams [VID_00756] - [18:42:45] Reencoding video [VID_00756] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 19.151 frames - Bitrate: 16.341 Kbs - [18:42:45] Reencoding: VID_00756, Pass 1 of 2 - [18:48:13] Reencoding: VID_00756, Pass 2 of 2 - [19:01:51] Video Encode complete - [19:01:51] Processing: VID_00757 (7 of 27) - [19:01:51] Extracting A/V streams [VID_00757] - [19:02:01] Reencoding video [VID_00757] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.053 frames - Bitrate: 16.568 Kbs - [19:02:01] Reencoding: VID_00757, Pass 1 of 2 - [19:02:36] Reencoding: VID_00757, Pass 2 of 2 - [19:04:03] Video Encode complete - [19:04:03] Processing: VID_00758 (8 of 27) - [19:04:03] Extracting A/V streams [VID_00758] - [19:04:17] Reencoding video [VID_00758] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3.281 frames - Bitrate: 16.140 Kbs - [19:04:17] Reencoding: VID_00758, Pass 1 of 2 - [19:05:14] Reencoding: VID_00758, Pass 2 of 2 - [19:07:35] Video Encode complete - [19:07:35] Processing: VID_00759 (9 of 27) - [19:07:35] Extracting A/V streams [VID_00759] - [19:07:53] Reencoding video [VID_00759] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3.243 frames - Bitrate: 16.237 Kbs - [19:07:53] Reencoding: VID_00759, Pass 1 of 2 - [19:08:51] Reencoding: VID_00759, Pass 2 of 2 - [19:11:07] Video Encode complete - [19:11:07] Processing: VID_00760 (10 of 27) - [19:11:07] Extracting A/V streams [VID_00760] - [19:11:47] Reencoding video [VID_00760] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 12.286 frames - Bitrate: 16.383 Kbs - [19:11:47] Reencoding: VID_00760, Pass 1 of 2 - [19:15:11] Reencoding: VID_00760, Pass 2 of 2 - [19:24:00] Video Encode complete - [19:24:00] Processing: VID_00761 (11 of 27) - [19:24:00] Extracting A/V streams [VID_00761] - [19:24:24] Reencoding video [VID_00761] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 6.950 frames - Bitrate: 16.468 Kbs - [19:24:24] Reencoding: VID_00761, Pass 1 of 2 - [19:26:22] Reencoding: VID_00761, Pass 2 of 2 - [19:31:32] Video Encode complete - [19:31:32] Processing: VID_00762 (12 of 27) - [19:31:32] Extracting A/V streams [VID_00762] - [19:31:47] Reencoding video [VID_00762] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3.597 frames - Bitrate: 16.348 Kbs - [19:31:47] Reencoding: VID_00762, Pass 1 of 2 - Encode failed. Aborting. - BD-Rebuilder v0.40.09 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [19:56:45] - Failed video encode, aborted ----------------------- [19:56:45] PROCESSING BATCH FILE [24] ---------------------- [05-03-12] BD Rebuilder v0.40.09 (beta) [19:56:53] Source: ALIEN_RESURRECTION - Input BD size: 29,41 GB - Approximate total content: [01:56:08.669] - Target BD size: 22,95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [19:56:54] PHASE ONE, Encoding - [19:56:54] Processing: VID_00750 (1 of 13) - [19:56:54] Extracting A/V streams [VID_00750] [19:59:00]PHASE ONE aborted by user request [19:59:00] BATCH ABORTED... ========================== [19:59:00] END - BATCH SEQUENCE ========================== ---------------------- [05-03-12] BD Rebuilder v0.40.09 (beta) [19:59:32] Source: ALIEN_3 - Input BD size: 25,51 GB - Approximate total content: [02:24:52.641] - Target BD size: 22,95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [19:59:33] PHASE ONE, Encoding - [19:59:33] Processing: VID_00762 (12 of 27) - [19:59:33] Reencoding video [VID_00762] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3.597 frames - Bitrate: 21.015 Kbs - [19:59:33] Reencoding: VID_00762, Pass 1 of 2 - Encode failed. Aborting. - BD-Rebuilder v0.40.09 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [19:59:34] - Failed video encode, aborted ---------------------- [05-03-12] BD Rebuilder v0.40.09 (beta) [20:01:57] Source: ALIEN_RESURRECTION - Input BD size: 29,41 GB - Approximate total content: [01:56:08.669] - Target BD size: 22,95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:02:01] PHASE ONE, Encoding - [20:02:01] Processing: VID_00750 (1 of 13) - [20:02:01] Extracting A/V streams [VID_00750] - [20:09:46] Reencoding video [VID_00750] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 6.779 frames - Bitrate: 21.469 Kbs - [20:09:46] Reencoding: VID_00750, Pass 1 of 2 - [20:11:42] Reencoding: VID_00750, Pass 2 of 2 - [20:17:06] Video Encode complete - [20:17:07] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:17:07] Processing: VID_00701 (2 of 13) - [20:17:07] Extracting A/V streams [VID_00701] - [20:17:20] Reencoding video [VID_00701] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.085 frames - Bitrate: 21.283 Kbs - [20:17:20] Reencoding: VID_00701, Pass 1 of 2 - [20:18:01] Reencoding: VID_00701, Pass 2 of 2 - [20:19:42] Video Encode complete - [20:19:42] Processing: VID_00751 (3 of 13) - [20:19:42] Extracting A/V streams [VID_00751] - [20:21:51] Reencoding video [VID_00751] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 25.970 frames - Bitrate: 21.229 Kbs - [20:21:51] Reencoding: VID_00751, Pass 1 of 2 - [20:29:40] Reencoding: VID_00751, Pass 2 of 2 - Encode failed. Aborting. - BD-Rebuilder v0.40.09 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [20:59:03] - Failed video encode, aborted |
6th May 2012, 13:27 | #15067 | Link |
@hifreak
I'd take a look at any/all system stability factors. The fact that several AVC sources have successfully encoded before having issues leads one to believe it isn't configuration related. Check out anything that might lead to overheating. |
6th May 2012, 14:43 | #15068 | Link |
BD-Rebuilder works great 99.99% of the time for me on full backup BD's, but every once in a while I hit a brick wall and the "Chinatown" Blu-ray is one of them. Burned the backup only to find out later when watching that at around 1:29:00 into the movie, the audio synch goes out by about 500ms (audio is before the video - corresponding video is around 500ms late) and it stays that way from around 1:29:00 to the end of the film. Audio sync is fine from the beginning up to that point. I'm going on my 7th re-encode trying to figure out what's going on and every single re-encode has that late timing at the same mark.
All BD-Rebuilder system programs are compliant/set correctly using Inspect.exe BD-Rebuilder encoder settings are Good (Very Fast) - One Pass (ABR) Encoding Movie is one .m2ts file (00800.m2ts) MPEG-4 (AVC). The original .m2ts file plays fine on my PC via MPC as well as the original Blu-ray disc on a stand-alone Sony BDP-S480. Out-of-sync re-encodes are confirmed on my PC using either MPC or VLC. After the 1st bad encode, ripped the original disc a 2nd time using AnyDVDHD 7.0.4.0 Both the original 5.1 main audio and (mono) tracks are TRUE-HD. Initial encode was set to "do not convert/reencode" checked (default) to extract cores. Commentary track is 2-channel AC3 and ironically the only one that stays in sync from beginning to end With "do not convert/reencode" checked, tried "Keeping the HD audio..." checked. That's worked before on "multi"-.m2ts movies where I would hear audio interruptions at file transitions on my Sony BDP-S480 when HD audio was down-converted - didn't work here. Tried just keeping the (mono) TRUE-HD audio track - still the same Tried substituting the x264.exe converter from the previous version of BD-Rebuilder (BD-RBV04008 - x264 - v2164), but still the same thing. Tried the newest x264 version (2197) - still the same After one of the encodes, tried extracting the original main TRUE-HD 5.1 track via tsMuxeR 1.10.6, down-converted to AC3, demuxed the re-encode and replaced/muxed to .m2ts with the original down-converted extraction - still the same. Things I haven't tried yet are movie-only and "do not convert/reencode" unchecked, which I figured was pointless since the core is at 640kbps anyway and that the tsMuxeR 1.10.6 experiment didn't work. If anyone has a clue Thanks... |
6th May 2012, 16:09 | #15069 | Link |
Still looking into this "Chinatown" thing and not sure how much of a bearing it has, but when looking at the various files using MediaInfo in PBCore 1.2 view:
00800.m2ts (original file) - <formatDuration>02:10:32.520</formatDuration> 00800.m2ts (re-encoded file) - <formatDuration>02:10:31.782</formatDuration> with the re-encoded .m2ts file being slightly longer by 262ms In BDeditv0.17b (not that familiar with how to read BDedit info. - from the playlist tab for 00800.mpls): 00800.m2ts (original file) - 02:10:32.824 00800.m2ts (re-encoded file) - 02:10:31.782 The corresponding extracted AC3 core files in the WORKFILES folder of my latest re-encode in MediaInfo: 00800.track_4352.ac3 (main movie track) - <formatDuration>02:10:31.328</formatDuration> 00800.track_4357.ac3 (commentary track) - <formatDuration>02:10:31.808</formatDuration> where the audio file lengths are different - by right around the amount I've been guesstimating - 480ms Maybe I'll try ditching the audio commentary track. |
6th May 2012, 18:03 | #15071 | Link |
Hi Guys,
I tried the movie Immortals (Krieg der Götter) in German. Got this error. ---------------------- [05.06.12] BD Rebuilder v0.40.09 (beta) [12:40:49] Source: KRIEG_DER_GOETTER - Input BD size: 18,97 GB - Approximate total content: [01:50:43.678] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, 640Kbs DD5.1 - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=448 [12:40:50] PHASE ONE, Encoding - [12:40:50] Processing: VID_00084 (1 of 2) - [12:40:50] Extracting A/V streams [VID_00084] - [13:04:05] Reencoding video [VID_00084] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 159.264 frames - Bitrate: 4.848 Kbs - [13:04:05] Reencoding: VID_00084, Pass 1 of 2 - [14:44:39] Reencoding: VID_00084, Pass 2 of 2 - [18:32:02] Video Encode complete - [18:32:03] Processing audio tracks - Track 4352 (deu): Reencoding audio to AC3... - [18:32:04] Processing audio tracks - Track 4352 (deu): Reencoding audio to AC3... - ERROR in attempt to reencode audio (AFTEN) [AUD_00084_4352.AVS] [18:32:05] - Failed to reencode audio, aborted Who can help? |
6th May 2012, 20:02 | #15072 | Link |
Having Trouble with Backing up my 3D Blurays
I've used BD-Rebuilder for quite some time and really never had an issue......Unitl recently I've never really gotten an error that I couldn't figure out. I've been backing up my collection of Blurays for a while now (whenever I get a chance) and have always been realitvely successful. However using the latest Beta Ver. 40.09 I'm unable to successfully back up my 3D versions of my collection. Here's basically what happens:
I put my original in and run AnyDvd/HD and it will play (do this to test). I then rip the entire disc to an ISO. I then mount the ISO and run it again (while AnyDvd/HD is in the background) and play it to again make sure it plays while mounted in the ISO format. I then turnoff AnyDvd/HD and run BD-Rebuilder. The software see's the movie and I check off the few options like 25GB file and turn into an ISO using Image Burn........... Here's where the mystery comes. It does everything like normal, doesn't come up with any errors and then creates an ISO via Image Burn........However when I either burn to a Disc or Mount it as an Image when it has been compressed under 25GB the image will not play either in my PS3 (under a year old with newest firmware) or on my media PC using PowerDVD 11 (latest update). In the PC it tries to load forever and on the Media PC running PowerDVD 11 Ultra it says that "Cyberlink Power DVD could not read a file on this disc, playback will stop" Any other Bluray I back up in my collection will playback fine. It is only the 3D blurays that are having the error/problems. Any Ideas.........? Rig Specs: Bluray Burner: LG GBW-H20L Processor FX-8120 Hard Drives 128GB Kingston SSD & Hitachi 1TB Sata II ATA Memory: 16GB Dual Channel |
6th May 2012, 20:11 | #15073 | Link | |
I had exactly the same problem at exactly the same place. If you watch the movie carefully at that point in the movie, there is a very slight freeze in the video but the audio is not effected. So...from that point on the audio leads the video. I was able to finally get the movie to backup without the problem (after many tries with various audio settings.) I used BDRB directly on the original BluRay disc. I loaded AnyDVD and did movie only build directly from the BluRay. It took a bit longer but it did work. Not too sure why. HTH. Last edited by CV91913; 6th May 2012 at 23:41. Reason: Responded to wrong person...included origninal quote |
6th May 2012, 22:24 | #15074 | Link | |
7th May 2012, 05:49 | #15076 | Link | |
Thanks... |
8th May 2012, 16:09 | #15077 | Link | |
11th May 2012, 23:13 | #15079 | Link |
I know this is gonna sound weird, but hear me out. I know we can convert the DTS streams to AC3 and whatnot. Do we have options to convert to PCM? I've converted my audio to PCM and when i mux back into my m2ts file, the audio doesn't play. I know there's more to it, changing mpls files or whatever, just looking for some help.
[SLiM] |
12th May 2012, 06:10 | #15080 | Link | |
