10th June 2012, 02:05 | #15221 | Link | |
10th June 2012, 06:00 | #15222 | Link |
I used tsmuxer and deselected the audio stream. However, it created a .wav file during the process that I plugged back into the compressed version of the m2ts, also using tsmuxer. That was on a version compressed to 21000.
Interestingly, when I did the same thing to a version compressed to 6500, tsmuxer failed when trying to insert the LPCM stream. I expected either both to succeed or both to fail. Not sure what is going on. Still trying to get another copy of the disc, however to try a distinctly different rip. I'm hoping to pin it down to either a bad disc or a problem with my original drive. |
10th June 2012, 11:30 | #15223 | Link | |
Sorry, my bad, I'm sure.
I corrected the problem by making a copy of 4352.ac3 (which BD-RB had successfully created) and renaming it 4353.ac3, then resuming BD-RB. Everything I did and posted about after that was to test & prove that 00043.m2ts does in fact contain two PCM tracks. I ran TSMUXER, dropped 00043.m2ts into it, selected both PCM tracks, chose Demux as output and tsmuxer extracted two PCM tracks. In other words, tsmuxer failed to extract one of the two PCM tracks during BD-RB operation -- but extracted both fine when I operated tsmuxer as a stand-alone app. |
11th June 2012, 17:06 | #15224 | Link |
Hi i am poiting this question to Jdobbs i got 1st time ever problem with lastest Rebuilder. Since this version my reencoding is finishing @ 25,5 GB (27 451 559 936)
doesnt matter if i choose target 25GB or manuall it ends @27GB. Even after removing LPCM audio still same. Best way its to use 2 previous versions but as usuall expired |
11th June 2012, 17:50 | #15225 | Link |
With this version my encodings seem to finish between 0.5 and 1.5Gb smaller (depending on the size of the original movie - the larger it is the bigger the difference is between target size and actual size BDRebuilder produces) than what I specify in the Custom Target Size option. This was not the case with previous versions. If a log is needed I'll do another back up and will provide it. I did Transformers 3 (original size just over 38Gb) and set the Custom target size to 20Gb. The eventual back up was 18.5Gb. Next I did Planet Earth disk 1 (original size just over 22Gb) and set the Custom target size to 16.1Gb the eventual back up ended up 15.6Gb. The settings were Two Pass, High Quality, keeping original HD Audio.
12th June 2012, 01:29 | #15226 | Link |
@asiafan
@Yordan5 Nothing has changed in this version that affects sizing in any way (except possibly the new version of X264 -- but that is very, very unlikely). I would suggest you uninstall/reinstall FFDSHOW, HAALI, and AVISYNTH. |
12th June 2012, 04:53 | #15227 | Link | |
I have now ripped this 5 times with two different original discs on three different blu-ray drives from two different manufacturers. I get exactly the same error in every case. Because the error is generated from tsmuxer, I have to assume that either there is a bug in tsmuxer or an authoring anomaly in the title itself. Not sure there is any way around it at this point. I even tried converting the LPCM track to AC3 using Audacity but had some sound gaps that made it unusable. Ideas anyone? |
12th June 2012, 10:46 | #15228 | Link | |
i will be reencoding few others BDs so i will inform you if this is just matter or single BD or matter of x264 version this last BD was 27GB so i done quickly BD25 fast two pass mode + DTS HD => ac3 . PS can i put x264 files older to new version or its pointless? |
12th June 2012, 13:06 | #15229 | Link | |
Aging Video Hobbyist
12th June 2012, 19:47 | #15231 | Link |
Bumped into a peculiar disc: Thin Ice (http://www.amazon.com/Thin-Ice-Blu-r.../dp/B007RKFY0W). It's 46GB in total and contains two large .m2ts files. 00000.m2ts is 18.9GB and 00034.m2ts is 21GB. The latter, when played in MPC-HC, has a running time of 109 minutes. 00000.m2ts, while a smaller file, has a running time of more than 200 minutes -- but when one tries to skip ahead, MPC-HC crashes.
I tried to create a full backup of the disc while blanking 00034.m2ts (and trailers): Code:
[06.12.12] BD Rebuilder v0.40.10 (beta) [19:23:51] Source: THIN_ICE - Input BD size: 23,35 GB - Approximate total content: [04:15:08.634] - Target BD size: 23,78 GB - Windows Version: 6.1 [7601] - Quality: Highest (Very Slow), Two Pass - X264 Tweak(s) enabled - Decoding/Frame serving: DGDecNV - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [19:23:53] PHASE ONE, Encoding - [19:23:53] Processing: VID_00000 (1 of 28) - [19:23:53] Extracting A/V streams [VID_00000] - [19:29:32] Reencoding video [VID_00000] - [19:29:32] Keeping original video (no reencode) - [19:29:32] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:29:32] Multiplexing M2TS - [19:29:38] Processing: VID_00024 (2 of 28) - [19:29:38] Extracting A/V streams [VID_00024] - [19:29:49] Reencoding video [VID_00024] - [19:29:49] Keeping original video (no reencode) - [19:29:49] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:29:49] Multiplexing M2TS - [19:29:54] Processing: VID_00025 (3 of 28) - [19:29:54] Extracting A/V streams [VID_00025] - [19:30:02] Reencoding video [VID_00025] - [19:30:02] Keeping original video (no reencode) - [19:30:02] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:30:02] Multiplexing M2TS - [19:30:06] Blanking: VID_00026 (4 of 28) - [19:30:06] Blanking: VID_00034 (5 of 28) - [19:30:06] Processing: VID_00035 (6 of 28) - [19:30:06] Extracting A/V streams [VID_00035] - [19:30:15] Reencoding video [VID_00035] - [19:30:15] Keeping original video (no reencode) - [19:30:15] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:30:15] Multiplexing M2TS - [19:30:19] Processing: VID_00101 (7 of 28) - [19:30:19] Extracting A/V streams [VID_00101] - [19:32:53] Reencoding video [VID_00101] - [19:32:53] Keeping original video (no reencode) - [19:32:53] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:32:53] Multiplexing M2TS - [19:34:20] Processing: VID_00102 (8 of 28) - [19:34:20] Extracting A/V streams [VID_00102] - [19:35:42] Reencoding video [VID_00102] - [19:35:42] Keeping original video (no reencode) - [19:35:42] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:35:42] Multiplexing M2TS - [19:35:56] Processing: VID_00104 (9 of 28) - [19:35:56] Extracting A/V streams [VID_00104] - [19:36:16] Reencoding video [VID_00104] - [19:36:16] Keeping original video (no reencode) - [19:36:16] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:36:16] Multiplexing M2TS - [19:36:27] Processing: VID_00105 (10 of 28) - [19:36:27] Extracting A/V streams [VID_00105] - [19:36:39] Reencoding video [VID_00105] - [19:36:39] Keeping original video (no reencode) - [19:36:39] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:36:39] Multiplexing M2TS - [19:36:44] Processing: VID_00106 (11 of 28) - [19:36:44] Extracting A/V streams [VID_00106] - [19:36:58] Reencoding video [VID_00106] - [19:36:58] Keeping original video (no reencode) - [19:36:58] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:36:58] Multiplexing M2TS - [19:37:03] Processing: VID_00107 (12 of 28) - [19:37:03] Extracting A/V streams [VID_00107] - [19:37:15] Reencoding video [VID_00107] - [19:37:15] Keeping original video (no reencode) - [19:37:15] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:37:15] Multiplexing M2TS - [19:37:20] Processing: VID_00108 (13 of 28) - [19:37:20] Extracting A/V streams [VID_00108] - [19:37:32] Reencoding video [VID_00108] - [19:37:32] Keeping original video (no reencode) - [19:37:32] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:37:32] Multiplexing M2TS - [19:37:38] Processing: VID_00109 (14 of 28) - [19:37:38] Extracting A/V streams [VID_00109] - [19:37:49] Reencoding video [VID_00109] - [19:37:49] Keeping original video (no reencode) - [19:37:49] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:37:49] Multiplexing M2TS - [19:37:54] Processing: VID_00110 (15 of 28) - [19:37:54] Extracting A/V streams [VID_00110] - [19:38:05] Reencoding video [VID_00110] - [19:38:05] Keeping original video (no reencode) - [19:38:05] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:38:05] Multiplexing M2TS - [19:38:11] Processing: VID_00111 (16 of 28) - [19:38:11] Extracting A/V streams [VID_00111] - [19:38:24] Reencoding video [VID_00111] - [19:38:24] Keeping original video (no reencode) - [19:38:24] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:38:24] Multiplexing M2TS - [19:38:31] Processing: VID_00112 (17 of 28) - [19:38:31] Extracting A/V streams [VID_00112] - [19:38:43] Reencoding video [VID_00112] - [19:38:43] Keeping original video (no reencode) - [19:38:43] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:38:43] Multiplexing M2TS - [19:38:48] Processing: VID_00113 (18 of 28) - [19:38:48] Extracting A/V streams [VID_00113] - [19:39:00] Reencoding video [VID_00113] - [19:39:00] Keeping original video (no reencode) - [19:39:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:39:00] Multiplexing M2TS - [19:39:05] Processing: VID_00114 (19 of 28) - [19:39:05] Extracting A/V streams [VID_00114] - [19:39:19] Reencoding video [VID_00114] - [19:39:19] Keeping original video (no reencode) - [19:39:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:39:19] Multiplexing M2TS - [19:39:24] Processing: VID_00115 (20 of 28) - [19:39:24] Extracting A/V streams [VID_00115] - [19:39:37] Reencoding video [VID_00115] - [19:39:37] Keeping original video (no reencode) - [19:39:38] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:39:38] Multiplexing M2TS - [19:39:43] Processing: VID_00116 (21 of 28) - [19:39:43] Extracting A/V streams [VID_00116] - [19:40:01] Reencoding video [VID_00116] - [19:40:01] Keeping original video (no reencode) - [19:40:01] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:40:01] Multiplexing M2TS - [19:40:10] Processing: VID_00318 (22 of 28) - [19:40:10] Extracting A/V streams [VID_00318] - [19:40:23] Reencoding video [VID_00318] - [19:40:23] Keeping original video (no reencode) - [19:40:23] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:40:23] Multiplexing M2TS - [19:40:29] Blanking: VID_00325 (23 of 28) - [19:40:29] Blanking: VID_00326 (24 of 28) - [19:40:29] Blanking: VID_00327 (25 of 28) - [19:40:29] Blanking: VID_00328 (26 of 28) - [19:40:29] Processing: VID_00340 (27 of 28) - [19:40:29] Extracting A/V streams [VID_00340] - [19:40:41] Reencoding video [VID_00340] - [19:40:41] Keeping original video (no reencode) - [19:40:41] Processing audio tracks - [19:40:41] Multiplexing M2TS - [19:40:46] Processing: VID_00343 (28 of 28) - [19:40:46] Extracting A/V streams [VID_00343] - [19:40:57] Reencoding video [VID_00343] - [19:40:57] Keeping original video (no reencode) - [19:40:57] Processing audio tracks - [19:40:57] Multiplexing M2TS [19:41:02]PHASE ONE complete [19:41:02]PHASE TWO - Rebuild Started - [19:41:02] Rebuilding BD file Structure [19:41:37] - Encode and Rebuild complete [19:41:37] JOB: THIN_ICE finished. Here's where things go weird: 00000.m2ts and 00034.m2ts are not in the same playlist, so BD-RB lets me blank 00034.m2ts -- and you can see from the log BD-RB processes 00000.m2ts by keeping original video and audio -- but the final output is less than 5GB in size. Yes, I'm using custom size but I don't think this is related to that. Just a guess, mind you Last edited by colinhunt; 12th June 2012 at 19:49. |
12th June 2012, 21:00 | #15233 | Link | |
13th June 2012, 18:48 | #15239 | Link |
I'm not that familiar wiht Virtu, but CUDA is supported through DGDecNV decoding, assuming you have it installed (see the SETUP dialog). As some point in the future it might also be available through support of LAV filters.
