13th June 2012, 22:20 | #15241 | Link | |
In BD Rebuilder (the subject of this thread) it's pretty easy. Just select "Convert SD to 720p" or "Convert SD to 1080p" in the SETUP dialog. You can use multiAVCHD to convert a DVD to BD pretty easily -- and use that as the source for BD-RB. There are several other ways to do it also. Last edited by jdobbs; 13th June 2012 at 22:25. |
14th June 2012, 16:40 | #15243 | Link | |
Note, even though it'll keep the dts express the dts express sound might still not work. I have this issue myself and jdobbs is aware that certain players will read the encode and other ones won't. He'll eventually figure it out! He's a smart fella! Jdobbs, I have some questions for you. I'm doing a complete disc encode of an episode disc of a tv series and the original disc is 43.2GB with a bdrebuilder output of 22.4GB. Taking a look at one episode using bdinfo and MPC the original bitrate is ~14,000 Kb/s and the bdrebuilder bitrate is ~4,500 Kb/s. From my reading it seems like this bitrate is far too low for 1080p? Would it be best to convert it to 720p? Also, I don't want to do this with these discs but for future reference could I blank half the episodes and putting them on one bluray disc with the other half on another bluray? I thought about doing this but it would take too many bluray discs and cost too much. Thank you for your continued support on a great program! |
14th June 2012, 20:05 | #15244 | Link | |
Yes, you could make a backup in the way you describe. You could, for instance on a disc that had 8 episodes, blank the second 4 on the first backup and blank the first 4 on the second. |
14th June 2012, 21:36 | #15245 | Link |
First of all, does blanking a title just produce a blank (black?) video of low bitrate to save space or eliminate the title from the disc? I've never used blanking before so I don't know.
I didn't expect such a quick response... I just read that if your bitrate is around 4,000Kb/s it's better to go for 720p as they'll be more information per frame since it's a lower resolution. I did a bdrebuilder encode of 1080p and 720p. I'm currently deciding which one to burn. Whichever one I go with I'll do the rest that way. I even looked at only keeping the DTS core and not the full DTS-HD.MA but that'll only gain me 1GB per eposide so I didn't think that i'll gain that much in picture quality so I kept the high def audio. The discs are Star Trek The Original Series and each episode is 50 mins long. I've only touched one disc so far and it has four episodes on it. I'm pretty sure that the rest of the discs will have 4 episodes as well. Each episode has an original unmastered video and a digitally mastered one so that the viewer can switch between the two and see how it originally aired. Some episodes also have pip of commentary and stuff but I don't think that i'm going to be able to hear the audio since it's DTS Express. It took me 10 hours to encode this bad boy at the settings below!!! Code:
[22:46:22] Source: STAR_TREK_SEASON_2__DISC_1 - Input BD size: 43.28 GB - Approximate total content: [04:49:35.632] - Target BD size: 23.54 GB - Windows Version: 6.1 [7601] - SHUTDOWN at completion enabled - Quality: High Quality (Default), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 BTW, I just scanned all episodes with BDinfo and the originals were all around 14,000 Kb/s and the encode were around 4,900 Kb/s. |
14th June 2012, 22:37 | #15246 | Link |
You can't use bitrate as a finite "if then else" decision parameter. It isn't something that functions on its own, it depends on other factors as well (like source complexity and encoding bells-and-whistles used). I've done a lot of encoding at lower bitrates with much success. You'll also find a lot of high quality MKV & MP4 files floating around that look good with a lot less...
Blanking replaces the original video with a short (~.5 second) blank video. Not sure how halving the size of the disc cuts the bitrate by that much? There must be a huge portion that is kept intact? Last edited by jdobbs; 14th June 2012 at 22:39. |
15th June 2012, 00:17 | #15247 | Link | |
Out of all the files that make up the four episodes there are: (2x) 4.5GB, (2x) 3.5GB, (2x) 2.5GB, (2x) 1.5GB, and the rest are below 1GB. Bdrebuilders log shows that it encoded 91 files. A majority of the files for the episodes are below 1GB. I know some of the files are menus and other things so it looks like it encoded everything correctly. As you can see from the beginning of the log in the previous post that there was almost 5 hours of 1080p video on this one disc! That pretty much explains why the original is only 14,000Kb/s. Any higher and they'd have to put less episodes on each disc. If you think about it though it's 1960's Star Trek! Even if you had a higher bitrate it wouldn't make the video quality any better. BTW, what would I look for in the 1080p encode to see if it's bad? Pixelization? Every encode that i've done with x264 no matter how low the bitrate gets looks fine to me but then again my tv is a 60" 720p so that could explain why i've never seen bad video since it's not full 1080p. Last edited by Audiophile1178; 15th June 2012 at 00:23. |
15th June 2012, 00:46 | #15248 | Link | |
I know I have the first season of Star Trek (TOS), but can't remember if I have all the seasons. If I do, I'll test that disc. They did a really good job with those discs. They went back to the original film prints and created HD from them. They also give you the option of using newer (more up-to-date) graphics (on the space scenes and the bridge's "big screen"). It is really impressive. They'll be coming out with TNG in HD using the same concepts this year (season one in July)... can't wait. I got the preview disc w/three episodes on it -- looks pretty good. It's a little disconcerting, though, to think that after I paid for all 7 seasons on DVD, I may have to do the same on BD... Last edited by jdobbs; 15th June 2012 at 00:50. |
15th June 2012, 04:19 | #15249 | Link |
I have followed strictly the instruction on the first page, but still got error on converting my adele concert blu-ray disc to 25gb discs, the following is the log
[06/15/12] BD Rebuilder v0.40.10 (beta) [10:57:54] Source: ADELE - Input BD size: 26.40 GB - Approximate total content: [02:00:05.331] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [10:57:54] PHASE ONE, Encoding - [10:57:54] Processing: VID_00000 (1 of 3) - [10:57:54] Extracting A/V streams [VID_00000] - [11:15:48] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 178,602 frames - Bitrate: 23,493 Kbs - [11:15:48] Reencoding: VID_00000, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.40.10 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [11:15:49] - Failed video encode, aborted My computer configuration: Intel Core i7 2600 8gb ram win7 64 bit ultimate Will it be the bug of the software? |
16th June 2012, 12:43 | #15251 | Link | |
Planning to try other softwares Any way thanks! |
16th June 2012, 16:24 | #15252 | Link |
Hi, I know this is my fault but I left BD Rebuilder to encode to a BD25 size and I ran out of disk space. I just checked the progress and it had come up with an error that it couldn't rebuild because it couldn't find 00102.m2ts. It is there so I cleared some hard drive space and resumed the job but come up with another error. I've changed the encode step to 4 which is the step before 00102.m2ts and deleted the log from 00102.m2ts in the INI. Do I need to move the m2ts files and the clpi files back to the WORKFILES folder to get it to rebuild properly? They're just short videos to encode now.
16th June 2012, 18:24 | #15253 | Link |
I would strongly suggest that, given the errors that you are seeing, you should just begin again from scratch. Making sure, of course, that you have sufficient disc space this time, and that means MORE than 25GB (since BDRB has to create working files before writing to the target files).
16th June 2012, 18:36 | #15254 | Link |
@ Jonaldinho RE:BD25 size and I ran out of disk space.
This has probably happened to all of us at one time or another. After you make enough room to finish the encode and rebuild (usually at least twice the size of the original BD), you restart BD_Rebuilder and make sure that you have the EXACT SAME setting's that you made the FIRST TIME (playlists, audio and subs and still have the same size output), then you are good to go. BD_Rebuilder will pickup where it left off and rebuild the Bluray structure, if it is only on the re-encoding step it will restart what ever step it was on before it crashed (ie: pass 1 or 2). Good Luck, worknstiff |
16th June 2012, 18:54 | #15255 | Link |
Thanks, I deleted the main movie encoded .264 file because it had already been muxed into an m2ts file, I always do this and it always works but because there was an error I think I need it now. I'll keep it in future to be safe if there's an error again. So now i've made space by deleting files that aren't related to the project. I have moved all the newly created m2ts files into the STREAM folder. There's the same amount as the original so I just need it to be rebuilt into a Blu-ray file structure. I have copyied everything to the new workpath except the original STREAM folder and I know that at least the clpi files need to be changed so I tried inputting the new structure into BD Rebuilder hoping it would remux and change the clpi files to be compatible but it didn't work because it's expecting other audio streams. Would changing the hidden option 'FIX_MOVIEONLY' to 0 fix this. If not I would start from scratch.
16th June 2012, 21:56 | #15256 | Link | |
16th June 2012, 23:49 | #15257 | Link | |
17th June 2012, 19:21 | #15258 | Link |
been a while since i backed anything up, any way, noticed you have dts express support so i dug out and old favorite. The Fast and the Furious. It uses VC1 for the main movie and 2 PIP secondary tracks. After RB has done its thing and created the backup (Slow 2 pass for the main video, 1 pass CRF for the extras) i opened it in cyberlink powerdvd 11. All worked well apart from the dts express audio couldnt be heard. Reading back i see it works on some players and not on others. Curiously i opened the backup in RB and noticed the secondary tracks are flagged as 480i 23.976 were as the original rip is flagged as 480p vc1. Maybe this is causing the player to get confused and subsequently not playing the audio as its expecting the secondary video to be progressive?
k-c-ksum Last edited by k-c-ksum; 17th June 2012 at 19:24. |
18th June 2012, 02:56 | #15259 | Link | |
