Old 20th June 2012, 20:38   #15281  |  Link
johnnytav
New Version 0.40.10 Runs Slow
Originally Posted by RobertM View Post
Are you sure you are using the same quality setting as before. Go to the "Menu>Settings>Encoder settings" screen and make sure you have selected the same quality level. If you were running "better" before and "highest" now you would see a significantly longer process.
I checked a few of the older versions .ini files to see setting and adjusted to Auto Quality.
Works as the older versions did.
Keep up the Good Work
JohnnyJT
johnnytav is offline   Reply With Quote
Old 23rd June 2012, 12:24   #15282  |  Link
k-c-ksum
As I mentioned earlier, I did numerous tests against VC-1 PiP sources -- and they came out correct (480p), even when I used your (k-c-ksum) settings. I have to believe there is something odd about that particular disc.
I'll look for Mummy-2 and see what I can find.
i'll try Pitch Black as thats a vc1 movie/pip disc
k-c-ksum
k-c-ksum is offline   Reply With Quote
Old 24th June 2012, 15:07   #15283  |  Link
k-c-ksum
Pitch Black is the same vc1 480p in. avc 480i out
k-c-ksum
Old 24th June 2012, 15:37   #15284  |  Link
What are you using to check the output? I've done at least 20 discs in testing and they are all 480p. I have another one (Harry Potter 6) going right now.
Old 24th June 2012, 15:57   #15285  |  Link
This one came out 480p also... so I've done lots and lots of discs -- even using your settings -- and they all have correctly reencoded correctly to 480p. I confirm it by opening the output with BD-RB, TSMUXER, and BD-INFO. I don't know what else I can do.
Old 24th June 2012, 16:36   #15286  |  Link
k-c-ksum
i open the backup in bdrb and click on secondary tab and it shows its interlaced
it may or may not be happening to others but they arnt aware of it?
is there anyway to force progressive encoding of secondary streams regardless of what its flagged as.? What determins if x264 encodes it as interlaced or progressive?
checked installed software and all is OK
 Windows Version: 6.1 [7601]
- FFDSHOW: [3882], Ok
- WIN7 preferred AVC CODEC:  Ok
- WIN7 preferred VC-1 CODEC:  Ok
- WIN7 preferred MPEG2 CODEC:  Ok
- FFDSHOW MPEG2 set to "libavcodec":  Ok
- FFDSHOW AVC set to "libavcodec":  Ok
- AnyDVD settings check: Ok.
- BD Rebuilder v0.40.0.10, Ok
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
k-c-ksum
Old 24th June 2012, 16:57   #15287  |  Link
Not likely.. it definitely isn't happening to me, and there have only been two people report it. My guess is that something odd is happening in your instances alone. Right now I don't know what that is.
In order to reencode these as interlaced, a special setting has to be added to the encoding command line. Can you run it again, and while the secondary is being encoded, open LASTCMD.TXT (in the BD-RB installation folder)? Copy and paste the command line here so I can look at it. Also post the contents of the secondary file's AVS. It will look something like this: "VID_00000_2.AVS" -- the "_2" indicates it is a secondary.
Old 24th June 2012, 17:09   #15288  |  Link
I've reloaded your settings and I'm trying "Harry Potter 6" again.
Old 24th June 2012, 19:04   #15289  |  Link
k-c-ksum
heres the avs
#Created by BD Rebuilder - v0.40.10 (beta)
DirectshowSource("E:\TEMP\BLU_RE-ENCODES\WORKFILES\00037.track_6912.mkv", fps=23.976, framecount=155870, audio=false)
ConvertToYV12().AssumeFPS(24000,1001)
LASTCMD.TXT
"E:\BD_Rebuilder\tools\x264.exe" "E:\TEMP\BLU_RE-ENCODES\WORKFILES\VID_00037_2.AVS" --preset ultrafast --cabac --bframes 3 --b-pyramid none --qpmin=0 --slow-firstpass
 --crf 25 --level 3.2 --sar 10:11 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 12000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 7000 --fake-interlaced --
threads auto --thread-input --stats "E:\TEMP\BLU_RE-ENCODES\WORKFILES\VID_00037_2.AVS.264.stats" --pass 1 --output "E:\TEMP\BLU_RE-ENCODES\WORKFILES\VID_00037_2.AVS.264"
k-c-ksum
Old 25th June 2012, 18:53   #15290  |  Link
Thanks. Can you post your log for that job. I've done a couple more encodes since -- and they have also come out correctly. I want to see if it's possible that the "--fake-interlaced" setting is coming from a previous encode and is not being reset for some reason.
[Edit] I think I may have it. It may be possible that if the previously encoded stream was interlaced, and you have deinterlacing set, the "--fake-interlacing" setting gets carried over. None of the discs I've tested seem to match that scenario. I'll do some testing.
Old 26th June 2012, 15:57   #15291  |  Link
k-c-ksum
does the log get saved anywhere? reopened BDRB but log staus is empty. I have Deinterlace ticked. I'll run it again with it unchecked
unchecked deinterlace
 "E:\BD_Rebuilder\BD_Rebuilder\BD_Rebuilder\tools\x264.exe" "E:\TEMP\BLU_RE-ENCODES\WORKFILES\VID_00037_2.AVS" --preset ultrafast --cabac --bframes 3
 --b-pyramid none --qpmin=0 --slow-firstpass --crf 25 --level 3.2 --sar 10:11 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 12000 --keyint 24 --min-keyint 1 --ipratio 1.1
 --pbratio 1.1 --vbv-maxrate 7000 --tff --threads auto --thread-input --stats "E:\TEMP\BLU_RE-ENCODES\WORKFILES\VID_00037_2.AVS.264.stats" --pass 1
just opened the re-encode VID_00037_2.AVS.264 file in ts muxer and it reports it as interlaced
k-c-ksum
Old 27th June 2012, 01:49   #15292  |  Link
That's consistent with the problem... it isn't really the "deinterlace" setting. It is the fact that the previous encode is interlaced.
The log (BDREBUILDER.LOG) is in the working folder. It's a text file and can be opened with NOTEPAD.
Old 27th June 2012, 16:02   #15293  |  Link
k-c-ksum
06/26/12] BD Rebuilder v0.40.10 (beta)
[15:59:07] Source:  PITCH_BLACK_G51
  - Input BD size: 34.59 GB
  - Approximate total content: [02:56:10.475]
  - Target BD size: 23.24 GB
  - Windows Version: 6.1 [7601]
  - Quality: Good (Very Fast), ABR
[15:59:09] PHASE ONE, Encoding
 - [15:59:09] Processing: VID_00166 (1 of 9)
 - [15:59:09] Extracting A/V streams [VID_00166]
 - [15:59:16] Reencoding video [VID_00166]
   - Rate/Length: 23.976fps, 1,465 frames
 - [15:59:16] Reencoding: VID_00166, Pass 1 of 1
 - [16:00:02] Video Encode complete
 - [16:00:02] Processing audio tracks
 - [16:00:02] Multiplexing M2TS
 - [16:00:08] Processing: VID_00203 (2 of 9)
 - [16:00:08] Extracting A/V streams [VID_00203]
 - [16:00:17] Reencoding video [VID_00203]
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29.970fps, 4,370 frames
 - [16:00:17] Reencoding: VID_00203, Pass 1 of 1
 - [16:00:44] Video Encode complete
 - [16:00:44] Processing audio tracks
 - [16:00:44] Multiplexing M2TS
 - [16:00:49] Processing: VID_00012 (3 of 9)
 - [16:00:50] Extracting A/V streams [VID_00012]
 - [16:00:59] Reencoding video [VID_00012]
   - Rate/Length: 23.976fps, 1,572 frames
 - [16:00:59] Reencoding: VID_00012, Pass 1 of 1
 - [16:01:54] Video Encode complete
 - [16:01:54] Processing audio tracks
 - [16:01:54] Multiplexing M2TS
 - [16:02:00] Processing: VID_00246 (4 of 9)
 - [16:02:00] Extracting A/V streams [VID_00246]
 - [16:02:15] Reencoding video [VID_00246]
   - Rate/Length: 29.970fps, 7,400 frames
 - [16:02:15] Reencoding: VID_00246, Pass 1 of 1
 - [16:02:56] Video Encode complete
 - [16:02:56] Processing audio tracks
 - [16:02:56] Multiplexing M2TS
 - [16:03:01] Processing: VID_00169 (5 of 9)
 - [16:03:01] Extracting A/V streams [VID_00169]
 - [16:03:08] Reencoding video [VID_00169]
   - Rate/Length: 23.976fps, 7,200 frames
 - [16:03:08] Reencoding: VID_00169, Pass 1 of 1
 - [16:05:34] Video Encode complete
 - [16:05:34] Processing audio tracks
 - [16:05:34] Multiplexing M2TS
 - [16:05:41] Processing: VID_00252 (6 of 9)
 - [16:05:41] Extracting A/V streams [VID_00252]
 - [16:05:47] Reencoding video [VID_00252]
 - [16:05:48] Reencoding: VID_00252, Pass 1 of 1
 - [16:08:15] Video Encode complete
 - [16:08:15] Processing audio tracks
 - [16:08:16] Multiplexing M2TS
 - [16:08:21] Processing: VID_00185 (7 of 9)
 - [16:08:21] Extracting A/V streams [VID_00185]
 - [16:08:35] Reencoding video [VID_00185]
   - Rate/Length: 29.970fps, 8,535 frames
 - [16:08:36] Reencoding: VID_00185, Pass 1 of 1
 - [16:09:33] Video Encode complete
 - [16:09:33] Processing audio tracks
 - [16:09:33] Multiplexing M2TS
 - [16:09:39] Processing: VID_00188 (8 of 9)
 - [16:09:39] Extracting A/V streams [VID_00188]
 - [16:10:53] Reencoding video [VID_00188]
   - Rate/Length: 29.970fps, 37,125 frames
 - [16:10:54] Reencoding: VID_00188, Pass 1 of 1
 - [16:15:27] Video Encode complete
 - [16:15:27] Processing audio tracks
 - [16:15:27] Multiplexing M2TS
 - [16:15:47] Processing: VID_00037 (9 of 9)
 - [16:15:47] Extracting A/V streams [VID_00037]
 - [16:26:38] Reencoding video [VID_00037]
 - [16:26:38] Reencoding secondary video [TRK_02]
   - Rate/Length: 23.976fps, 155,870 frames
   - Bitrate: 23,871 Kbs
 - [16:45:42] Reencoding: VID_00037, Pass 1 of 1
[16:56:53]PHASE ONE aborted by user request
k-c-ksum
Old 27th June 2012, 18:05   #15294  |  Link
Thanks. I think I have it now. The "interlaced" setting is being carried over from the previous encode (VID_00188). I was having trouble finding it, because none of my test discs have an interlaced stream immediately preceding the secondary encode. Good find. I'll have it fixed for the next release.
Old 27th June 2012, 20:53   #15295  |  Link
bbcby
Selected source is not BD Format
This always occurs (in my case), if the film (time code) does not start from 00:00:00:00
bbcby is offline   Reply With Quote
Old 28th June 2012, 01:24   #15296  |  Link
That can't be an accurate statement. There are almost no discs that begin with that time code. In fact I don't think I have ever seen one that does. But even with that said, the timecode also has no bearing on that message. That message generally occurs when either the disc directory format is not correct, or one of the MPLS or CLPI files doesn't have the correct header information. In other words, the disc isn't compliant with the BD standard.
Old 28th June 2012, 05:12   #15297  |  Link
omegaman7
omegaman7's Avatar
Selected source not BD format
I had that error every time I'd load files over a network. I no longer employ more than one PC at the moment. So I haven't been able to localize the problem. It probably was the way I was configured.
Old 28th June 2012, 17:15   #15298  |  Link
meadrocks
I have Chinatown that Anydvd is giving me a read error on. Typically I use the "Save to HD" Anydvd option & it reads & saves the entire disk to the HD. Is there a way to just read the movie, since all i want is to make a mkv of the movie? Do I have to retain some BD file structure for BD-RB ro read it correctly? Are there other files that I'll need to copy?
meadrocks is offline   Reply With Quote
Old 28th June 2012, 20:00   #15299  |  Link
bbcby
Sorry for my English...
These discs are very much. For example "Yellow Submarine". Many times come across the opera / ballet (Deutsche Grammophon, Opus Arte).
Here's an example, I do demux Blu-ray with BD Reauthor, open it in the Scenarist BD (5.1.3/5.7) and immediately muxing do not make any changes.
Then open it in BD_Rebuilder and immediately get an error. Selected source is not BD Format.
Can we say that Scenarist does not correct disks?
Then I reset timecode in Scenarist to 00:00:00:00, muxing and open to the BD_Rebuilder... and there is no error.
See Attachments pictures.
Old 28th June 2012, 20:25   #15300  |  Link
You could try copying the largest M2TS to your hard drive and creating a movie-only source using TSMUXER. But if that file is where the read error is (very likely) you'll have the same problem.
