Old 17th November 2013, 14:12   #18361  |  Link
soneca
Amen to that. I've never had much of a problem from viruses... but I've had lots of issues caused by antivirus software. I have to disable it whenever I'm doing anything productive locally (like backups) because it slows the system down so terribly.
Off:
jdobbs, you can tell which is the antivirus you use?
For years I did not have this problem of slowness using Nod32. From time to time do testing with leading antivirus market and none has the lightness(less impact on the system)of Eset, which even protects very well.
Old 17th November 2013, 14:38   #18362  |  Link
mparade
Originally Posted by HWK View Post
Which antivirus you are using, I recently had case where program was being blocked by AV and all I had to do was turn of AV shield and BD-RB was able to make change.
I hate it when AV suppose to protect computer, instead the make user life miserable.
Eset Endpoint Antivirus. I disabled it, but the situation is exact the same as I wrote in my last letter. I tried to run it without AV enabled both from my own and from my admin profile with the same results......I think I have to turn to some win7 expert or search in google for a solution. Anyway, thank all of you for the help.
Old 17th November 2013, 14:41   #18363  |  Link
Sharc
Well, that's the result of another one of those "this won't hurt anything" last minute changes before release. You think I'd learn. I've fixed it. The CERTIFICATE thing was fixed as well (there was two changes that needed to be made -- I'd only changed one).
Good news that you could nail it down. Thanks.
Old 17th November 2013, 14:51   #18364  |  Link
Originally Posted by soneca View Post
Off:
I've gone through several. My criteria for "best" now is the one that is easiest to turn off/on. I'm currently using AVG.
Based on my experience ALL antivirus packages slow your system down without exception. Some may be better than others, but they all have a significant impact when enabled.
Old 17th November 2013, 15:53   #18365  |  Link
gonca
rendez2k
Do you have MIN_M2TS_SIZE set to anything but default
Old 17th November 2013, 15:56   #18366  |  Link
rendez2k
rendez2k's Avatar
The only thing I changed thats different is in Import/QP settings, minimums changed to 10 & 5.
rendez2k is offline   Reply With Quote
Old 17th November 2013, 16:02   #18367  |  Link
gonca
Can you post your INI file
Old 17th November 2013, 16:03   #18368  |  Link
rendez2k
rendez2k's Avatar
[Options]
VERSION=0.45.0.4
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
MENU_BACKGROUND=C:\Program Files (x86)\BD_Rebuilder\misc\menuback.jpg
IMPORT_THRESHOLD=10
QUICK_PLAY_THRESHOLD=5
MENU_AUTO_BACKGROUND=1
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
AUTO_BURN=2
TARGET_SIZE=23500
[Paths]
WORKING_PATH=G:\TEMP\
Old 17th November 2013, 17:05   #18369  |  Link
gonca
@jdobbs--@rendez2k
Pacific Rim
[11/17/13] BD Rebuilder v0.45.04 (beta)
[09:21:35] Source:  PACIFIC_RIM
  - Input BD size: 41.60 GB
  - Approximate total content: [03:13:42.986]
  - Target BD size: 22.95 GB
  - Windows Version: 6.1 [7601]
  - Quick-Play Reauthoring mode enabled
  - Resize SD to HD 720p enabled
  - Quality: Good (Very Fast), ABR
[09:21:35] PHASE ONE, Encoding
 - [09:21:35] Processing: VID_00002 (1 of 14)
 - [09:21:35] Extracting A/V streams [VID_00002]
 - [09:21:42] Reencoding video [VID_00002]
   - Rate/Length: 23.976fps, 6,889 frames
   - Bitrate: 7,257 Kbs
 - [09:21:42] Reencoding: VID_00002, Pass 1 of 1
 - [09:22:23] Video Encode complete
 - [09:22:23] Processing audio tracks
 - [09:22:23] Multiplexing M2TS
 - [09:22:26] Processing: VID_00011 (2 of 14)
 - [09:22:26] Extracting A/V streams [VID_00011]
 - [09:24:24] Reencoding video [VID_00011]
   - Rate/Length: 23.976fps, 188,857 frames
   - Bitrate: 17,834 Kbs
 - [09:24:24] Reencoding: VID_00011, Pass 1 of 1
 - [09:47:01] Video Encode complete
 - [09:47:01] Processing audio tracks
 - [09:47:01] Multiplexing M2TS
 - [09:48:25] Processing: VID_00013 (3 of 14)
 - [09:48:25] Extracting A/V streams [VID_00013]
 - [09:48:31] Reencoding video [VID_00013]
   - Rate/Length: 23.976fps, 7,029 frames
   - Bitrate: 7,330 Kbs
 - [09:48:31] Reencoding: VID_00013, Pass 1 of 1
 - [09:49:11] Video Encode complete
 - [09:49:11] Processing audio tracks
 - [09:49:11] Multiplexing M2TS
 - [09:49:15] Processing: VID_00014 (4 of 14)
 - [09:49:15] Extracting A/V streams [VID_00014]
 - [09:49:21] Reencoding video [VID_00014]
   - Rate/Length: 23.976fps, 6,491 frames
   - Bitrate: 7,725 Kbs
 - [09:49:21] Reencoding: VID_00014, Pass 1 of 1
 - [09:50:05] Video Encode complete
 - [09:50:05] Processing audio tracks
 - [09:50:05] Multiplexing M2TS
 - [09:50:09] Processing: VID_00015 (5 of 14)
 - [09:50:09] Extracting A/V streams [VID_00015]
 - [09:50:16] Reencoding video [VID_00015]
   - Rate/Length: 23.976fps, 8,281 frames
   - Bitrate: 7,250 Kbs
 - [09:50:16] Reencoding: VID_00015, Pass 1 of 1
 - [09:51:05] Video Encode complete
 - [09:51:05] Processing audio tracks
 - [09:51:05] Multiplexing M2TS
 - [09:51:08] Processing: VID_00016 (6 of 14)
 - [09:51:08] Extracting A/V streams [VID_00016]
 - [09:51:15] Reencoding video [VID_00016]
   - Rate/Length: 23.976fps, 8,150 frames
   - Bitrate: 7,300 Kbs
 - [09:51:15] Reencoding: VID_00016, Pass 1 of 1
 - [09:52:03] Video Encode complete
 - [09:52:03] Processing audio tracks
 - [09:52:03] Multiplexing M2TS
 - [09:52:07] Processing: VID_00017 (7 of 14)
 - [09:52:07] Extracting A/V streams [VID_00017]
 - [09:52:12] Reencoding video [VID_00017]
   - Rate/Length: 23.976fps, 5,785 frames
   - Bitrate: 7,277 Kbs
 - [09:52:12] Reencoding: VID_00017, Pass 1 of 1
 - [09:52:46] Video Encode complete
 - [09:52:46] Processing audio tracks
 - [09:52:46] Multiplexing M2TS
 - [09:52:50] Processing: VID_00018 (8 of 14)
 - [09:52:50] Extracting A/V streams [VID_00018]
 - [09:52:56] Reencoding video [VID_00018]
   - Rate/Length: 23.976fps, 6,625 frames
   - Bitrate: 7,309 Kbs
 - [09:52:56] Reencoding: VID_00018, Pass 1 of 1
 - [09:53:34] Video Encode complete
 - [09:53:34] Processing audio tracks
 - [09:53:34] Multiplexing M2TS
 - [09:53:38] Processing: VID_00020 (9 of 14)
 - [09:53:38] Extracting A/V streams [VID_00020]
 - [09:53:44] Reencoding video [VID_00020]
   - Rate/Length: 23.976fps, 5,977 frames
   - Bitrate: 7,181 Kbs
 - [09:53:44] Reencoding: VID_00020, Pass 1 of 1
 - [09:54:17] Video Encode complete
 - [09:54:17] Processing audio tracks
 - [09:54:17] Multiplexing M2TS
 - [09:54:21] Processing: VID_00026 (10 of 14)
 - [09:54:21] Extracting A/V streams [VID_00026]
 - [09:54:27] Reencoding video [VID_00026]
   - Rate/Length: 23.976fps, 6,697 frames
 - [09:54:27] Reencoding: VID_00026, Pass 1 of 1
 - [09:55:06] Video Encode complete
 - [09:55:06] Processing audio tracks
 - [09:55:06] Multiplexing M2TS
 - [09:55:10] Processing: VID_00027 (11 of 14)
 - [09:55:10] Extracting A/V streams [VID_00027]
 - [09:55:19] Reencoding video [VID_00027]
   - Rate/Length: 23.976fps, 12,817 frames
   - Bitrate: 7,291 Kbs
 - [09:55:19] Reencoding: VID_00027, Pass 1 of 1
 - [09:56:33] Video Encode complete
 - [09:56:33] Processing audio tracks
 - [09:56:33] Multiplexing M2TS
 - [09:56:37] Processing: VID_00028 (12 of 14)
 - [09:56:37] Extracting A/V streams [VID_00028]
 - [09:56:43] Reencoding video [VID_00028]
   - Rate/Length: 23.976fps, 4,489 frames
   - Bitrate: 7,253 Kbs
 - [09:56:43] Reencoding: VID_00028, Pass 1 of 1
 - [09:57:09] Video Encode complete
 - [09:57:09] Processing audio tracks
 - [09:57:09] Multiplexing M2TS
 - [09:57:13] Processing: VID_00029 (13 of 14)
 - [09:57:13] Extracting A/V streams [VID_00029]
 - [09:57:19] Reencoding video [VID_00029]
   - Rate/Length: 23.976fps, 4,729 frames
   - Bitrate: 7,242 Kbs
 - [09:57:19] Reencoding: VID_00029, Pass 1 of 1
 - [09:57:47] Video Encode complete
 - [09:57:47] Processing audio tracks
 - [09:57:47] Multiplexing M2TS
 - [09:57:51] Processing: VID_00030 (14 of 14)
 - [09:57:51] Extracting A/V streams [VID_00030]
 - [09:57:57] Reencoding video [VID_00030]
   - Rate/Length: 23.976fps, 5,857 frames
   - Bitrate: 7,258 Kbs
 - [09:57:57] Reencoding: VID_00030, Pass 1 of 1
 - [09:58:31] Video Encode complete
 - [09:58:31] Processing audio tracks
 - [09:58:31] Multiplexing M2TS
[09:58:34]PHASE ONE complete
[09:58:34]PHASE TWO - Rebuild Started
 - [09:58:34] Rebuilding BD file Structure
 - [09:58:34] Creating Quick-Play Menu...
   - Encoding menu background...
   - Building menu structure...
[09:58:37] - Encode and Rebuild complete
[09:58:37] Writing BD structure to ISO file
 - ImgBurn completed successfully
[10:01:46] JOB: PACIFIC_RIM finished.
[Options]
VERSION=0.45.0.4
MODE=2
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=0
TARGET_SIZE=23500
AUTO_BURN=2
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=
SD_CONVERT=1
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=1
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
DGDECNV=0
OUTPUT_3D=0
NEROAAC=0
SUPTITLE=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23500
IMPORT_THRESHOLD=5
QUICK_PLAY_THRESHOLD=10
[Paths]
WORKING_PATH=W:\HD\
SOURCE_PATH=I:\PACIFIC_RIM\
Folder structure
TMT 6 -- hangs as usual
PDVD13 -- works fine
BD-R
TMT 6 -- hangs
Sony BDP-S550 -- works fine --standalone
Old 17th November 2013, 17:06   #18370  |  Link
rendez2k
rendez2k's Avatar
Wow! You must have a fast PC. Mine is still encoding my second attempt!
Worrying yours works though?
Old 17th November 2013, 17:17   #18371  |  Link
gonca
BD-R disc works on SONY and PDVD13, FOLDER works on PDVD13
Old 17th November 2013, 17:41   #18372  |  Link
[Options]
VERSION=0.45.0.4
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
IMPORT_THRESHOLD=10
AUTO_BURN=2
TARGET_SIZE=23500
[Paths]
You have to be consistent with your reporting. The INI above isn't the settings used in the bug report:
- Input BD size: 41.77 GB
- Approximate total content: [03:19:23.284]
- Windows Version: 6.2 [9200]
Old 17th November 2013, 17:43   #18373  |  Link
rendez2k
rendez2k's Avatar
Well, the issue is that I removed Windows 8 after the encode yesterday. Due to too many issues and put Win 7 back-on. I'll be re-running the test after the disc I'm currently doing. But, Rim has failed twice under Windows 8.
Old 17th November 2013, 18:25   #18374  |  Link
tn jim
This is my second attempt with latest beta, first one on another BD movie was fine. Second attempt on another movie aborted. AnyDVD HD did it's thing without problems. Is this a bug or a problem with the original disc?
Log file below:
[11:59:13] Source: 94623009_THE_QUEEN_00000
- Input BD size: 19.71 GB
- Approximate total content: [01:43:22.154]
- MOVIE-ONLY mode enabled
[11:59:14] PHASE ONE, Encoding
- [11:59:14] Processing: VID_00009 (1 of 1)
- [11:59:14] Extracting A/V streams [VID_00009]
- Error in attempt to extract audio/subs.
- AV frame too large (65303 bytes). Increase AV buffer.
[12:04:16] - Failed to retrieve audio, aborted
tn jim is offline   Reply With Quote
Old 17th November 2013, 18:33   #18375  |  Link
rendez2k
rendez2k's Avatar
Tried a second disc, burnt to BD-RE again. Works fine on PDVD13 but all I get on the Sony is the background image and music. No buttons!
Edit: reburnt to standard BD-R still won't work. Happy to test anything further. Assume my Sony standalone isn't conforming to a certain spec?
Old 17th November 2013, 18:35   #18376  |  Link
HWK
HWK's Avatar
Log file below:
This error message is coming from tsmuxer, not BD-RB and it is caused by bad rip. Re-rip original disc with anydvd and see what happens. Make sure to use anydvd default setting as well.
Old 17th November 2013, 22:24   #18377  |  Link
tn jim
Ok, I did a do over without any changes to any of my setups and it worked fine?
Old 17th November 2013, 22:27   #18378  |  Link
soneca
The Nod32 causes much less impact on the system and protects more compared to AVG. If you want to test and the like Nod32, I paid the license for you!
Old 18th November 2013, 00:29   #18379  |  Link
mparade
Just to inform those who experienced similar problems like I did recently, finally done it with Win7DSFilterTweaker within less than 1 minute, so now my inspect.exe tells:
- FFDSHOW: [4504], Ok
- AnyDVD settings check: Ok.
- BD Rebuilder v0.45.0.4, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
Old 18th November 2013, 00:36   #18380  |  Link
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
Great. I would have suggested that to you -- but I'd forgotten the name.
