Old 25th December 2008, 11:14   #41  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
This is fixed and a new version is available...
Now MKV -> AVCHD support is functional.
Move instead of copy will be added as an option later.
* Update check and info added in log tab
* Author messages added in log tab
* mkvinfo & tsmuxer used for mkv->avchd conversion, so download again the full package
I will open a new thread for my program to avoid confusion with kaid's perl script.
Dean
Old 25th December 2008, 18:03   #42  |  Link
Deepstar
can you add jddobs fixclpi Tool? This were great.
An idea: if you already create a avchd dir with your Tool. An option that you add another avchd dir. Without add the menufiles.
In the moment there is an error. Because the the Tool think the menufiles is an movie.
You did a great job
Deepstar is offline   Reply With Quote
Old 26th December 2008, 09:13   #43  |  Link
deank
deank's Avatar
So it is done. Test it.
I searched the forum, but couldn't find the thread with fixcli.exe.
Can you help with that?
And what exactly does it fix?
The thread of multiAVCHD is http://forum.doom9.org/showthread.ph...44#post1228044.
Please post your further questions/reports there.
Old 26th December 2008, 09:54   #44  |  Link
nosnoop
Here's the post by jdobbs with his fixclpi utility:
http://forum.doom9.org/showthread.ph...92#post1207492
And his description of tsMuxeR's bug:
TSMUXER seems to have a small bug that causes fast-forward, rewind, and seeking issues when creating Blu-ray output.
It appears as though the COARSE/FINE table relationship in the .CLPI file isn't being structured properly. The program correctly creates a new COARSE entry with the PTS rolls over (the LSBs contained in the FINE table get to a point where they will require an increment in the COARSE table). But it appears it doesn't do so (at least not always) when the same thing happens to the COARSE/FINE SPN. As a result, you have combined SPN pointers that suddenly drop to very small values (at least until the next COARSE reference)...
causing glitches in rewind and forwarding video.
nosnoop is offline   Reply With Quote
Old 29th December 2008, 21:06   #45  |  Link
deank
deank's Avatar
It is added in multiAVCHD (yet not visible) but when applied, the tool always says: "Not a valid CLPI file..." or something alike...
Strange...
avchd, menu, mkv, ps3, tsmuxer
