Old 20th November 2012, 02:00   #41  |  Link
I've had my say, you've had yours. When you have something working along the lines you describe, I suppose you'll let us all know. I won't be holding my breath.
And BTW, please stop the profanity per forum rule 4. Thank you. I have edited your post.
Old 20th November 2012, 03:10   #42  |  Link
Daemon404
I'll write something this week or next, and maybe add support to VIVTC (we'll see... scary tritical code port), and publish it along with a few other things. I never did say I wouldn't write something to handle it separately (but perhaps bundled).
Anyway, there's no compelling reason to couple the two, since you usually do want the unprocessed video, and VapourSynth has this nice frame metadata (as opposed to *bleck* AVS's hinting).
If anyone has any particularly bad samples, feel free to post them, and I will test them while I write it. I'd appreciate it.
I'm rather surprised people have only been mentioning this sort of thing, instead of the much larger and obvious problem of leading B frames, which I can't seem to stab libavcodec to handle in a nice way no matter what I do, seemingly. Yes, I've tried implementing something similar to what DGDecode does, but libavcodec is having none of that. Help or suggestions are VERY welcome with regards to this.
BTW, perhaps you could be a little less condescending with your posts in the future.
Daemon404 is offline   Reply With Quote
Old 20th November 2012, 04:15   #43  |  Link
Maybe when you stop referring to my work as 'cruft'.
You can't move pulldown handling out of the source filter, because the source filter must randomly access and display a numbered frame in the pulled-down stream. I'd be interested to hear if you have a solution for that, maybe you haven't thought it through?
You can accomplish the job with libavcodec; I have done that several times. What problem are you running into with libavcodec? There are some streams it may struggle with, but for most stuff it works just fine. You just have to know what it does when you feed it nondecodable frames.
Old 20th November 2012, 09:50   #44  |  Link
06_taro
soy sauce buyer
A souce filter is supposed to preserve whatever exists in the souce and convert it into a structure that the downstream filter can handle. If d2vsouce does put those flags as per-frame properties without loosing anything useful or even normally useless (you never know what weird souces may be and what weird things others may want to do, so a normally useless things may accidentally be useful in some cases), and there are filters knowing how to handle them and convert the clips into different forms according to different purposes in a user-friendly way , then everything is fine. Otherwise we cannot leave those flags to a condition in which it is a pain to deal with.
06_taro is offline   Reply With Quote
Old 20th November 2012, 10:14   #45  |  Link
Revgen
1) I've had TS captures in the past that contained TFF and BFF frames. Why? I don't know, but that's how it was captured through the Firewire port. DGIndex and DGMPEGDec's ability to tell which frames were TFF and BFF by reading the RFF flags helped me tremendously to deinterlace the video. I've yet to capture such a file for awhile now, but I never know when it might happen again.
2)Also, I've had to encode silent movie captures that contained different framerates. Parts of the silent movie were 20fps, some were 22fps, and some were 24fps. These movies were originally broadcasted hard-telecined to handle the different framerates. And for good reason. It's a hellava lot easier than using RFF flags. I had to IVTC and use RFF flags for each section (via DGPulldown) and join them together in order for the whole movie to play progressively while keeping the same audio soundtrack. If I ever decided to rip these movies from my DVD-R's again and back them up to a different format, I'd need to have those multiple RFF flags read in order to process the video correctly.
I hope the metadata solution works for these issues.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 20th November 2012, 15:14   #46  |  Link
Daemon404
It's not strictly needed in the source filter. You can frame accurately seek within the coded picture, which is indeed what you way want.
Per-frame metadata mat not be entirely sufficient in this case, actually, so what I'm thinking it something like this:
import vapoursynth as vs
core = vs.Core()
ret = core.d2v.Source(input=r'C:\somefile.d2v', nocrop=True)
ret = core.d2v.ApplyRFF(ret, d2v=r'C:\somefile.d2v')
last = ret
This would nicely decouple the two, while allowing you to apply a d2v's RFF flags to an arbitrary clip (useful if you mess up or something). The other option is to use whole-clip metadata, when it is added to VapourSynth (Myrsloik says it's coming!).
Also, to clarify, ApplyRFF would be akin to honoring the RFF flags. I still do not intend to implement Force FILM.
In my case, when I tried returning the first decodable frame in place of all the leading non-decodable frames, the entire clip ended up being shorter than it was supposed to be, since it was missing 2-3 frames still, somehow. My general method was to still start at the beginning of the first GOP, and decode until frame N, where N is the first decodable frame, and return that in place of the first N frames.
Can you perhaps elaborate on your strategy?
The d2v file stashes TFF/BFF info, so that is easy to expose.
I'd be grateful if you could supply a sample for testing when I implement this.
Old 20th November 2012, 16:00   #47  |  Link
last = ret
I don't see what you gain from "nicely decoupling" the two, but hey go for it if it pleases you. Having to load a separate plugin, coordinate the D2V filename between them, etc., appears pointless to me and introduces unnecessary complications. The fact is you need that code somewhere, and it is definitely not cruft.
Why not? It's proven to be quite useful for several types of streams.
It's no different from what you described. Have you determined where the missing frames are? You may be missing some at the end.
Old 20th November 2012, 16:12   #48  |  Link
Daemon404
I don't see what you gain from "nicely decoupling" the two, but hey go for it if it pleases you. Having to load a separate plugin, etc., appears pointless to me. The fact is you need that code somewhere, and it is definitely not cruft.
Maintainability. And the idea is to have it in the same plugin (dll/so), and in the same namespace (core.d2v), but a different function name. It's the "VapourSynth Way" to do things. Here's a lazy wrapper:
core.std.LoadPlugin(r'C:\d2vsource.dll')
def betterD2VSource(path):
    ret = core.d2v.Source(input=path)
    ret = core.d2v.ApplyRFF(ret, d2v=path)
    return ret
Maybe I'll even bundle it!
It doesn't seem like anything but a convenience thing to me. Even the most basic IVTC plugin could do this given proper metadata. And that what this is: IVTC. IIRC, TIVTC even supports doing this in AviSynth (by pointing it at a d2v).
They're missing at the beginning on the stream I tested, which DGDecode handles correctly. I might try and read avconv.c/ffmpeg.c to see what they do, but they're also kind of weird on these cases, I think. I haven't tested FFMS2.
Old 9th December 2012, 02:38   #49  |  Link
Daemon404
Just posted Beta4.
Quick summary of things:
  • 4:2:2 Support
  • MPEG Transport Stream PID Support (Multi-stream)
  • RFF Support (See README)
  • Bug Fixes!
Full changelog here.
At some point I plan to enable sliced threading for the MPEG1/2 decoding, and frame threading for RFF application.
URLs in OP.
Old 9th December 2012, 04:43   #50  |  Link
Revgen
Good news. The RFF flags seem to be working. I tried one of my silent movies with 20fps and 24fps sections and the pulldown flags are being properly honored.
Bad news. The GCC Beta4 build seems to be broken. It just hangs when I try to load it. MSVC Beta4 build works fine.
Moe: Why?
Old 9th December 2012, 05:20   #51  |  Link
Daemon404
I asked someone else to build it this time, as my usual box I build the MinGW stuff on was down. I'll rebuild it / test on Monday.
Old 11th December 2012, 04:12   #52  |  Link
Daemon404
New MinGW binary up in OP, with a critical bug too.
I've tested this binary to work on Windows 7.
Not going to bother posting Visual Studio builds now, as theyre a fair bit slower than MinGW builds (even though they're ~2.5x smaller).
Old 13th January 2013, 23:16   #53  |  Link
mikewando
It might be worth noting which version of libavcodec this requires (especially in the configure script) since Ubuntu 12.10's libavcodec-dev is evidently too old.
For others trying to compile on 12.10 I grabbed the 9.1 tarball from http://libav.org/download.html and that worked for me, but I had to add --enable-pic to my configure line when building libavcodec; d2vsource complained otherwise.
Edit: Tried it out and it seems to work fine for my purposes. Thanks a lot for the work! Looking forward to a future where I can keep my whole workflow in 64bit Linux.
mikewando is offline   Reply With Quote
Old 14th January 2013, 00:29   #54  |  Link
Daemon404
I generally follow git master. As for --enable-pic, I figured that was common knowledge, since PIC is kind of required for Linux shared libraries. I suppose I could note it.
Old 14th January 2013, 00:58   #55  |  Link
mikewando
Of course PIC makes sense, but I didn't know libavcodec builds without -fpic by default. I'm not sure how common that is; I try to generally avoid building my own libraries as much as possible. I also wanted to note it for other people who may have no idea what the error message is really telling them.
At any rate I think the most helpful thing would just to have the configure script spit out that it requires libavcodec >= 0.9.0, or whatever its current requirement is, since it's entirely possible for libavcodec/avcodec.h to exist and have been found and still fail the configure check.
Old 26th February 2013, 16:55   #56  |  Link
Daemon404
Beta5 Released: http://chromashift.org/vs/d2vsource_beta5.zip
ChangeLog here.
Highlights: Open GOP seeking now works properly in all cases!
Sure.
Old 26th February 2013, 17:05   #57  |  Link
paradoxical
Thanks for this! Quick question: Have you fixed the limitation about last frame not decoded? If not check out this starting at line 417. Or I can probably try to make a patch for you.
Old 26th February 2013, 17:18   #58  |  Link
Daemon404
I know. I've just been too lazy to deal with libavcodec's tomfoolery...
Old 26th February 2013, 17:37   #59  |  Link
paradoxical
Well, I think I know where the fix needs to be. Testing now and if it works I'll send you a patch shortly.
Old 26th February 2013, 19:02   #60  |  Link
paradoxical
So this is odd. The fix I made works for certain clips to get all frames whereas others crash when reading the last frame. Continuing to debug it.
d2v, dgindex, vapoursynth
