Old 13th April 2020, 07:03   #1  |  Link
PRAGMA
PD2V - A wrapper for dealing with scan, fields, VFR/CFR on MPEG sources
Released as part of pvsfunc
EDIT: This project has been reworked solely for MPEG-1/2 videos, and renamed to PD2V.
PD2V (class) is a convenience wrapper for loading MPEG-1/2 sources and dealing with scan, fields, deinterlacing, variable FPS, and such. Its unique feature is it can handle mixed scan-type videos. It will always return a progressive video, with the ability to convert VFR (variable frame rate) to CFR (constant frame rate) video. It's similar to a retail DVD player as it deinterlaces only if the frame is marked as interlaced, no metrics or guessing is involved.
Requirements:
- Python 3 (I recommend >= 3.8)
- DGIndex v1.5.8 or newer (please do not use D2VWitch e.t.c)
- MKVToolNix if you plan on using contained MPEG sources
- pvsfunc 3.1.1 or newer
- Optionally havsfunc for QTGMC (available on vsrepo for windows)
PRAGMA is offline   Reply With Quote
Old 14th April 2020, 02:32   #2  |  Link
sl1pkn07
Pajas Mentales...
windows centric is not cool
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline   Reply With Quote
Old 14th April 2020, 04:36   #3  |  Link
PRAGMA
? I actually use Linux lol
This is cross-os
Edit:
Fun fact, I use your amazing arch linux AUR repo's for VapourSynth stuff, and I appreciate them!
Old 15th April 2020, 13:45   #4  |  Link
sl1pkn07
Pajas Mentales...
what dgindex you use? through wine? or the modoki port (2010)
Old 15th April 2020, 17:00   #5  |  Link
PRAGMA
Wine v1.5.8
Old 15th April 2020, 22:53   #6  |  Link
sl1pkn07
Pajas Mentales...
thats why i mean is not cool xd
native is love, native is life
greethings and i'm glad you like my AUR (if you found a problem, please slaps me XD)
Old 15th April 2020, 23:15   #7  |  Link
videoh
Useful n00b
Maybe with CPUs so fast now, so that the ASM stuff could be eschewed, DGIndex could be natively ported. It shouldn't be too hard.
Old 16th April 2020, 09:59   #8  |  Link
PRAGMA
I'm having trouble getting it compiled on Visual Studio 2019, issues with the ASM files compiling causing problems it seems, it can't find NASM, though it can find MASM. Even if I take the BuildConfiguration files from VSNASM, they still have issues being compiled.
I pushed the DGIndex v1.5.8 (official) codebase to my GitHub as a mirror, with a ported readme in markdown. Feel free to try and upgrade it or make it compilable, the whole community could come together and get a nice port of this going.
Old 16th April 2020, 14:21   #9  |  Link
PRAGMA
greetings and I'm glad you like my AUR (if you found a problem, please slaps me XD)
Btw you can use this port if you wish, just understand the risks of it being inaccurate. D2VWitch I highly recommend to stay away from as it is definitely miles less accurate than DGIndex, way less configurability for my python script end too, so no way to even configure it to be more accurate.
Do note, that the script checks if the D2V was made by `DGIndexProjectFile16` which is v1.5.8 exactly, this is to make sure the script doesn't use outdated D2V files. If the port you want to use has good accuracy, and it's open-source, then link me to the source and download page and I can take a look and add a whitelist to its version magic if its different.
Old 16th April 2020, 15:24   #10  |  Link
videoh
Useful n00b
Looks like you just need NASM. I'd be happy to supply you with NASM or anything else you need. I can even send you a full VS 2019 project that builds fine. Send PM with email address and I'll get you everything right away.
Old 16th April 2020, 15:45   #11  |  Link
DJATOM
DJATOM's Avatar
There is also https://github.com/ShiftMediaProject/VSNASM, just plug-in into VS2019 and it should work. At least it worked with VS2017 in the past.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 17th April 2020, 13:05   #12  |  Link
videoh
Useful n00b
Here is DGMPGDec built with VS 2019 and including a Tools directory containing the assemblers you need. The project correctly references the Tools directory so things build right out of the box. Enjoy.
http://rationalqm.us/dgmpgdec/DGMPGDec_VS2019.rar
EDIT: Temporarily removed from site to check licensing issues for the assemblers.
Old 17th April 2020, 16:08   #13  |  Link
PRAGMA
<3 thanks!!!
Edit: Wouldnt it be a good idea to replace `dgmpgdec158.zip` with this one since its ultimately the same version and less people will run into compiling issues?
Old 17th April 2020, 16:18   #14  |  Link
videoh
Useful n00b
<3 thanks!!!
Great idea. I'll have to check on a few things to be sure I'm street legal with re-distributing the assemblers. Maybe should have thought of that before giving up this link.
EDIT: Temporarily removed the link to get street legal. OK, I can redistribute nasm as long as I include the license file. I cannot redistribute masm. Fortunately, you can download MASM 6.15 directly from Microsoft:
http://download.microsoft.com/downlo...N-US/vcpp5.exe
Extract ml.exe and ml.err and place them in the Tools folder.
Old 18th April 2020, 17:06   #15  |  Link
videoh
Useful n00b
Wouldn't it be a good idea to replace `dgmpgdec158.zip` with this one since its ultimately the same version and less people will run into compiling issues?
Done! My website now links a street legal 2019-buildable source distribution. The Tools directory contains a NASM executable and instructions to download MASM.
d2v, deinterlace, dvd, mpeg, vapoursynth
