Old 19th September 2018, 17:32   #52501  |  Link
mclingo
there is no such thing as max settings, there are too many variables, it will be the best performer, thats all that can be said,
Old 19th September 2018, 17:33   #52502  |  Link
Crimson Wolf
@Siso & @madhi
Nvidia control panel > display > change resolution :
My TV has desktop color depth, output color depth, output color format, output dynamic range connected with HDMI and OSD shows the information as stated in the changelog, but my other monitor which is connected with DVI and only shows desktop color depth shows refresh rate only on the OSD like the screenshot from Siso.
Crimson Wolf is offline   Reply With Quote
Old 19th September 2018, 17:34   #52503  |  Link
brazen1
Originally Posted by mrmojo666 View Post
do you know if there are video players that support HDR nativetly , without the need of madvr ?
thank you
Yes, DVDFab Media Player. I use it flawlessly for when I desire menus and it looks pretty good but prefer MPC players with madVR for main movie playback.
Old 19th September 2018, 17:35   #52504  |  Link
Siso
Soul Seeker
Siso's Avatar
Originally Posted by Crimson Wolf View Post
@Siso & @madhi
My monitor only allows me to select 32 bit color with DVI-D, the other options are available only if I use displayport or hdmi...
Old 19th September 2018, 17:45   #52505  |  Link
James Freeman
Thank you!
Old 19th September 2018, 17:46   #52506  |  Link
Razoola
'* added true GPU mode info (color format, bitdepth & dynamic range) to OSD (Nvidia only)'
Just wondering where in the OSD this info shows?
Razoola is offline   Reply With Quote
Old 19th September 2018, 18:08   #52507  |  Link
brazen1
I've been using madVR v0.92.14 with no problems. I just installed the new madVR v0.92.15 released today carrying over settings from v0.92.14. MPC-HC starts with a black screen and no OSD. I assume it is paused which it is and I press play even though there is no OSD. My display flashes into HDR mode. Audio begins and the picture is frozen on a single frame. If I navigate forward or reverse, the movie begins to play normally. So I start with MPC-BE instead and none of this funny business occurs. It just starts and plays like it should. Both MPC players use identical settings. I'm using the latest current nightly builds of each. Both players performed as expected before upgrading to v.0.92.15 fwiw.
Old 19th September 2018, 19:15   #52508  |  Link
as a blind shot try a different hardware decoder.
Old 19th September 2018, 19:29   #52509  |  Link
BetA13
cosmic entity
BetA13's Avatar
Originally Posted by Siso View Post
Yes, desktop PC, updated to 0.92.15, reset to default settings, same result.
i guess i have the same problem...
i see just the normal OSD stuff nothing new..
made a clean madvr install.
tested on 2 monitors, one with DVI - and one with VGA..(yes one monitor still has VGA)
and this is what i see:
dont mind my shaders down there..haha
Is there a screenshot somewhere to see how its supposed to look?
greetz
BetA13 is offline   Reply With Quote
Old 19th September 2018, 19:33   #52510  |  Link
brazen1
Good blind shot reco. Changed D3D11/automatic native to DXVA 2 copy back/my nvidia GPU. With MPC-HC video starts paused and pressing play it begins and all is well. Still, shouldn't start paused.
Will there be anything detrimental going from D3D11 to copyback considering my collection uses just about every various format and container offered SDR, HDR, 3D, 8 & 10bit, FSE for 3D and FS windowed for all others. Btw, thanks for the suggestion.
Old 19th September 2018, 19:39   #52511  |  Link
Grimsdyke
What SD-files green screen?
I have reported this already a while ago but you said back then that you had not the time to look more into it.
Setup:
MPC-BE + LAV + MadVR playing a SD-file.
Problem:
With SD activated in LAV Video the image is displayed only for a few seconds then the image turns completely green.
The video keeps playing and I can hear the sound.
(I first mentioned that to Nev but he said that is most likely a MadVR issue).
Thanks for the new version !!
Old 19th September 2018, 19:48   #52512  |  Link
Thunderbolt8
whats the reason for an option to use NGU with some added grain for taking screenshots? or why is this the default choice?
Old 19th September 2018, 19:52   #52513  |  Link
mclingo
new version of MADVR has fixed the 23,076 playback issue with MPC-HC, no longer hangs with black screen, wierd but great !
unfortunately I was hoping that maybe a combination of new AMD drivers and new MADVR would fix the blown out reds issue with AMD 23hz SDR playback, this really needs fixing, had this for months now with 3 different AMD cards and muliple sets of drivers and LAV / MADVR versions.
https://1drv.ms/u/s!AgvFafeelEBigP8JoUs9wKjRu8Ajjw
Just a reminder of the issue.
all 23,976 playback of any SDR material has blown out reds as shown in picture, but only with MADVR renderer.
• If If I turn off refresh rate switching and play in 60hz the problem goes away
• if I put my TV in PC mode the problem goes away (bluray mode used for access to TV processing)
• if I turn off use DIRECT3D for presentation in MADVR the problem goes
• if If set calibration to BT2020 in MADVR the problem goes away
• HDR material plays fine.
surely the way this problem manifests itself must ring a bell for someone?
Old 19th September 2018, 19:58   #52514  |  Link
mclingo
think I know what this is, untick delay playback until render q is full, this was unticked on my install of the latest version for some reason which is why i think it fixed my MPC-HC, with it back on, back to black screen, unticked, fixed again.
i was getting this on the old version as well though, must be a bug with HC on a windows update or something, had this for a while now.
Old 19th September 2018, 19:59   #52515  |  Link
Sunset1982
What movie (Star wars?) and Timestamp is this screenshot? I can check it with my setup...
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 19th September 2018, 20:05   #52516  |  Link
mclingo
all movies mate, its pretty obvious when you play the movie, phantom menace about 33 mins, it may only happen with setups very similar to mine though, see my SIG.
Old 19th September 2018, 20:12   #52517  |  Link
brazen1
I've never had a reason to enable that setting so there is nothing to untick but thanks anyway.
Old 19th September 2018, 20:49   #52518  |  Link
Crimson Wolf
On my TV, it shows refresh then (12bit, RGB, Full). On my DVI monitor, just shows refresh rate.
Old 19th September 2018, 20:59   #52519  |  Link
DVI is "always" 8 bit full range RGBA with consumer cards so there is nothing to report.
Old 19th September 2018, 21:37   #52520  |  Link
Ver Greeneyes
madshi, ever since updating to Windows 10 version 1803 I've been having an issue with madVR where my render queues seem "capped" in some way, maybe by GPU memory usage, and trying to use the more expensive algorithms leads to queues not filling up at all even though the render time is very low. I have a GeForce GTX 1080 and I never had problems before updating to Windows 10 version 1803, so I think Microsoft added some sort of new limitation.
I was briefly able to work around it by using FSE mode, but then that stopped working too, so I've fallen back to using extremely simple algorithms that don't hit the cap (even super-xbr is affected). I was hoping that new drivers or windows updates would fix the problem, but no luck so far. Unfortunately the new build of madvr doesn't fix it either. Let me know if there's anything I can do to help debug the issue.
