Old 2nd December 2016, 23:39   #81  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffhevc 3.0.6 and ffx264 3.2.2
* Merged the output code for the batch mode with that for single file input
* Fixed an issue where remuxing to MP4 may fail in case the user chooses FLAC audio
* Renamed variable $extracon to $remuxcon and $econ to $rcon
* Made strict option "global" so I won't have to worry about adding experimental audio codecs support in the future
* Clean ups to the FPS conversion menu
Old 4th January 2017, 13:58   #82  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.0.7 and ffx264 3.2.3
* Use readlink to get the full path to the cover art image. Fixes an issue when running in batch mode
Old 5th January 2017, 12:32   #83  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.0.8 and ffx264 3.2.4
* Support per-file auto-cropping when running in batch mode
* Use internally full paths for input and output
* Add a test case for output directory to the script that gets sourced for encoding
Old 6th January 2017, 11:48   #84  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.0.9 and ffx264 3.2.5
* Bugfix: default output directory wasn't made when running in batch mode
* Display found per-file crop values when running in batch mode
Old 8th January 2017, 12:21   #85  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.1.0 and ffx264 3.2.6
* Support SMPTE-2084 transfer characteristics
* Placed the video post-processing filters in their own sub-menu
* Some small changes to the FPS conversion code
Old 9th January 2017, 13:41   #86  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.1.1 and ffx264 3.2.7
* Fix a possible issue when detecting the FPS value that occurs with some files
* Expand directory path internally instead of exporting the dirname command to the file that gets sourced for encoding
* Use 'bc' for calculating the detected FPS value
* Only use fractions internally for FPS values. The user should be presented with the floating point value
Old 12th January 2017, 01:23   #87  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.1.2 and ffx264 3.2.8
* Added support for pixel format conversion
* Added support for colorspace conversion
Old 13th January 2017, 12:39   #88  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.1.3 and ffx264 3.2.9
* Support 50 <-> 60/59.940 FPS conversions
* Use upper-case words for the color primaries/transfers/matrices and pixel formats
* Support 4.0 audio channel layout in addition to Quad
Old 15th January 2017, 12:39   #89  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.1.4 and ffx264 3.3.0
* Support ALAC audio encoding
* Some small improvements to the audio code
* A few variable renamings, mostly in the case statements
Old 18th January 2017, 15:02   #90  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.1.5 and ffx264 3.3.1
* Check channel amount for the libfdk_aac encoder and warn and exit on 7 channels as it doesn't support it
* Use range=tv instead of range=mpeg for the color conversion filter
* Bugfix: return value of variable autocrop wasn't checked when running in batch mode resulting in always cropping the input files
* Bugfix in the $OUTPUT variable when running in batch mode
* Removed readlink from the batch mode variables as it's no longer needed
Old 20th January 2017, 14:35   #91  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.1.6 and ffx264 3.3.2
* Fixed a small issue in the output for batch mode
Old 24th January 2017, 17:16   #92  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.1.7 and ffx264 3.3.3
* Removed one of the OUTPUT variables for batch mode. It is no longer needed
* Rewrote the audio channel layout code. It is now based on per-codec encoder support
* Repositioned the audio channel checking code
Old 6th February 2017, 21:39   #93  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.1.9 and ffx264 3.3.5
* Support the framestep filter for FPS conversion
* Support halving the frame rate. Only supported for 50/59.940/60 FPS input
Old 22nd February 2017, 16:14   #94  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.2.0 and ffx264 3.3.6
* Support high FPS -> low FPS conversions
* Bugfix: missing options in FPS conversion menu
Old 6th March 2017, 22:28   #95  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.2.1
* Update audio compression level values
* Initial support for HDR VUI signaling
Old 18th March 2017, 22:56   #96  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.2.2 and ffx264 3.3.7
* Update audio compression level values (ffx264 only)
* Update colorspace entry for NTSC video
* Fixed bug in the video_colorspace_func() values
Old 28th March 2017, 20:01   #97  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.2.3
* Update to the default encoding options
Old 3rd April 2017, 20:01   #98  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.2.4 and ffx264 3.3.8
* Support setting the input/output color range
Old 13th May 2017, 19:00   #99  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.2.5 and ffx264 3.3.9
* Support accurate rounding for the software scalers
* Support full chroma interpolation for the software scalers
* Use the flags option of the scale option instead of -sws_flags to set scaler and its options
Old 14th May 2017, 10:33   #100  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.2.6 and ffx264 3.4.0
* Bugfix in the software scale code. Use an if conditional to check for an y/n answer
