Old 5th March 2019, 13:26   #14781  |  Link
asarian
That sample is 1080p60.
Yikes, I linked the wrong sample. Here is the real one: proper sample
asarian is offline
Old 5th March 2019, 13:37   #14782  |  Link
sneaker_ger
Progressive 1080p25 encoded as interlaced.
sneaker_ger is offline
Old 5th March 2019, 13:41   #14783  |  Link
asarian
That's what I thought.
asarian is offline
Old 5th March 2019, 17:28   #14784  |  Link
mkver
That's not the whole story. It's MBAFF with pic_struct SEIs declaring every coded frame to be progressive; furthermore, bottom_field_pic_order_in_frame_present_flag is set to zero (meaning that the top and bottom fields of the coded frames have the same pic order count and even in the absence of a pic_struct SEI the coded frames should be considered progressive*). But it also has ct_type equal to 1 which means that the original source material is interlaced; furthermore the specs contain the clause that "Two consecutive fields in output order shall have different values of clockTimestamp when the value of ct_type for either field is 1 (interlaced)." This means that this stream is simply out-of-spec!
The reason that this particular sample is treated as interlaced is that FFmpeg uses the ct-type to override the pic_struct (notice that ct_type isn't simply the value read from the bitstream). So changing the ct_type is one way of fixing this.
Notice that ffmpeg has a bug because it always flags MBAFF as interlaced in the absence of SEI (see here) regardless of the pic order count of the fields involved. This means that simply deleting the SEI would not change the behaviour of FFmpeg based players unless FFmpeg is fixed, too (and the player updated).
*: From the semantics of pic_struct:
"NOTE 6 – When pic_struct_present_flag is equal to 0, then in many cases default values may be inferred. In the absence of other indications of the intended display type of a picture, the decoder should infer the value of pic_struct as follows:
– If field_pic_flag is equal to 1, pic_struct should be inferred to be equal to (1 + bottom_field_flag).
– Otherwise, if TopFieldOrderCnt is equal to BottomFieldOrderCnt, pic_struct should be inferred to be equal to 0 [progressive frame].
– Otherwise, if TopFieldOrderCnt is less than BottomFieldOrderCnt, pic_struct should be inferred to be equal to 3 [TFF].
– Otherwise (field_pic_flag is equal to 0 and TopFieldOrderCnt is greater than BottomFieldOrderCnt), pic_struct should be
inferred to be equal to 4 [BFF]."
mkver is offline
Old 5th March 2019, 17:46   #14785  |  Link
sneaker_ger
I always wonder what the guys writing MPEG specs are smoking.
Old 5th March 2019, 21:19   #14786  |  Link
asarian
@mkver, wow, that's a complicated story!
That might explain why tsMuxer totally tripped on it (badly broken and jittery output). I was able to extract the main stream correctly with eac3to.
There's some visual evidence for that too; darn if I can find one now, but earlier, I saw a few frames with your typical interlaced 'stripes' artifacts in them (as if badly deinterlaced). It's this way on the original .m2ts blu-ray too (so it's not an eac3to extract thing).
asarian is offline
Old 1st April 2019, 23:35   #14787  |  Link
Xor
Please simply help, i formatted and reinstall last version of eac3to 334 (also the surcode suite)
Test result
H:\eac3to334>EAC3TO -TEST
eac3to (v3.34) is up to date
Nero Audio Decoder (Nero 6 or older) doesn't seem to be installed
  http://www.nero.com/eng/store-blu-ray.html
  CAUTION: You need Nero 7. Nero 8 won't work with eac3to.
ArcSoft DTS Decoder doesn't seem to be installed
  http://www.arcsoft.com/products/totalmediatheatre
Sonic Audio Decoder (3.34.0.0) doesn't seem to be installed
Haali Matroska Muxer doesn't seem to be installed
  http://haali.net/mkv
Nero AAC Encoder (1.5.4.0) is installed
Surcode DTS Encoder (1.0.29.0) is installed
I tried to convert a DTS track to AC3, for DEcoding using other tool (Decoding with libDcaDec DTS Decoder...)
H:\eac3to334>eac3to Test.dts Test.ac3 -640
DTS, 5.1 channels, 1:53:27, 1509kbps, 48kHz
Remapping channels...
Encoding AC3 <640kbps> with libAften...
Creating file "Test.ac3"...
eac3to processing took 0 minute, 41 seconds.
Done.
Surcode DTS Encoder (1.0.29.0) include DECODER or not ?
Thank's
Xor is offline
Old 1st April 2019, 23:57   #14788  |  Link
No, the SurCode DTS encoder is an encoder only. But libavcodec in eac3to has a free DTS decoder, no need for additional software.
LigH is offline
Old 7th April 2019, 16:30   #14789  |  Link
asarian
Another quick extension question. I extracted a TrueHD stream to a .thd file. So far so good. Is there a way I can get tsMuxer to accept it, though?
asarian is offline
Old 8th April 2019, 00:53   #14790  |  Link
tebasuna51
tebasuna51's Avatar
tsMuxeR only accept tracks .thd+ac3
Extract the full TrueHD track like thd+ac3 or convert the .thd stream to .thd+ac3 with eac3to.
tebasuna51 is offline
Old 8th April 2019, 01:44   #14791  |  Link
asarian
Oops! Guess that's what I did wrong: I assumed (like with DTS-MA and .dts), that .thd would include the .ac3 sub-core.
asarian is offline
Old 8th April 2019, 20:10   #14792  |  Link
Xor
d:\eac3to334>eac3to t1.dts t1_768.dts -768
DTS, 5.1 channels, 2:34:09, 1509kbps, 48kHz
Writing WAVs...
Creating file "t1_768.L.wav"...
Creating file "t1_768.R.wav"...
Creating file "t1_768.LFE.wav"...
Creating file "t1_768.C.wav"...
Creating file "t1_768.SR.wav"...
Creating file "t1_768.SL.wav"...
Encoding DTS <768kbps> with Surcode...
Surcode DTS Encoder doesn't seem to be installed.
Please show me an alternative encoder (to Minnetonka Surcode DTS) can support ENCODE DTSHD (@ 1509kbps) ????
Xor is offline
Old 8th April 2019, 23:35   #14793  |  Link
filler56789
SuperVirus
filler56789's Avatar
Writing WAVs...
ffdcaenc-2 doesn't support DTSHD, only ordinary DCA, cannot be used by eac3to, but it is free.
The Master Audio Suite supports all types of DTS, including pure lossless DTSHD, but it's not free and cannot be used by eac3to.
filler56789 is offline
Old 9th April 2019, 08:11   #14794  |  Link
I didn't expect you want to encode to DTS instead of AC3; eac3to has a (DCA Core) DTS decoder with libav (libdcadec), and an AC3 encoder with libav (ffmpeg AC3). For this task, my remark "no need for additional software" is valid. I did not mean to extend it to encoding to DTS, that's a different topic.
Lossy DTS (DCA Core) with high bitrate, compatible to DVD Video discs (1509.75 kbps), is not the lossless "DTS-HD", compatible to Blu-ray discs.
LigH is offline
Old 9th April 2019, 10:24   #14795  |  Link
tebasuna51
tebasuna51's Avatar
Only 2 points:
It can be used with 'pipe':
eac3to INPUT stdout.wav | ffdcaenc -i - -o output.dts -l -b 1509.75
eac3to can't use libav (ffmpeg), it use libAften.dll (obsolete). But also can use ffmpeg with 'pipe':
eac3to INPUT stdout.w64 | ffmpeg -i - -c:a ac3 -b:a 640k -center_mixlev 0.707 output.ac3
Old 14th April 2019, 22:04   #14796  |  Link
Xor
I have installed "Suite Surcode 1.0.23", work fine on ENcoding DTS.
But this version support DEcoding DTSHD ?
If Yes, how to force eac3to to use surcode for deconding dtshd (not use libDcaDec free ) ????
Thank's
Xor is offline
Old 14th April 2019, 22:18   #14797  |  Link
Thank's
There is no reason to even entertain such a thought, because libdcadec supports full and flawless DTS-HD decoding. You don't need any external software for DTS-HD decoding.
nevcairiel is offline
Old 15th April 2019, 09:19   #14798  |  Link
tebasuna51
tebasuna51's Avatar
Like nevcairiel say there is no reason to eac3to use other decoder than libdcadec, btw eac3to can use other decoders than defaults like is explained in the first post of this thread.
To decode DTS-HD can't use Surcode but yes ArcSoft or Sonic (if installed), to override default decoders can be used parameters like:
-arcsoft
-sonic
-nero
Old 15th April 2019, 16:13   #14799  |  Link
Bandits
Request explanation of the following audio output.
Audio_3_English DELAY -17ms.THD+AC3
Does the "DELAY -17ms" mean:
A delay of -17ms on the audio needs to be applied when remuxing?
A delay of -17ms was applied to the audio output and nothing has to be done when remuxing?
If the delay was applied to the audio output, is there a way to turn off the creation of the filename with "DELAY -17ms" in it? Even when I specify a filename for the output eac3to still changes it when it wants a DELAY in the filename.
Blu-Ray Ripper 0.112c/0.21a
Bandits is offline
Old 15th April 2019, 21:59   #14800  |  Link
tebasuna51
tebasuna51's Avatar
eac3to can't apply delay's to thd streams.
eac3to
