Old 31st January 2014, 20:15   #19021  |  Link
Originally Posted by omegaman7 View Post
My first attempt of 3DMKV(1/2 SBS) to 3DBD appeared to work. But I never saw anything about using FRIM. It used X264. And there was no "SSIF" data. So perhaps I'm confused as to the 3DBD standard. The resulting file stays in SBS? I won't be trying again, until I have my 3D display in a week or two. Though BDrebuilder seemed to acknowledge that everything 3D was kosher, regarding the input.
You're doing something wrong. If you have a pseudo structure source that was created by importing a SBS source, and you choose movie-only output, and not ALTERNATE (it HAS to be movie-only, because BD-RB only supports BD3D for movie-only) -- FRIM will be used and you will get a full BD3D compliant structure after the encode. FRIM is the only way to do MVC encoding with BD-RB, X264 can't do it.
Keeping it SBS would defeat the whole purpose.
Old 31st January 2014, 20:17   #19022  |  Link
omegaman7
omegaman7's Avatar
You're doing something wrong. If you have a pseudo structure source that was created by importing a SBS source, and you choose movie-only output (it HAS to be movie-only, because BD-RB only supports BD3D for movie-only) -- FRIM will be used and you will get a full BD3D compliant structure after the encode.
Thanks JD. I'll likely try again today
"Keeping it in sbs would defeat the purpose"
I had a thought about that. That's why I posted. I'll try again.
Old 31st January 2014, 20:17   #19023  |  Link
pididdi
pididdi's Avatar
so itīs done, the bd-25 source of "odd thomas" (reencoded from the original source) did the job well. the dvd9 sized output looks great. here is the OT_DVD9_LASTCMD.TXT:
"C:\video\BD_Rebuilder\tools\x264.exe" "C:\VIDEO\FILM\WORKFILES\VID_00000.AVS" --preset medium --bluray-compat --b-pyramid none --weightp 1 --qpmin=0 --bitrate 7625 --level 4.0 --qpfile "C:\VIDEO\FILM\WORKFILES\VID_00000.CHP" --sar 1:1 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 13000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 15000 --threads auto --thread-input --stats "C:\VIDEO\FILM\WORKFILES\VID_00000.AVS.264.stats" --pass 2 --output "C:\VIDEO\FILM\WORKFILES\VID_00000.AVS.264"
now i will reencode the bd-25 source to dvd5 size with 1440x1080 resolution and dts-reencoding to ac3 (what was the my first problem in question), but i cannot reencode the original source main movie to dvd5 size with 1440x1080 resolution in one step (i only have the mainmovie "odd thomas" riped from the original bluray)!
pididdi is offline   Reply With Quote
Old 31st January 2014, 20:19   #19024  |  Link
Are you posting for the fun of it, or are we actually trying to accomplish something here? You seem to spend your time posting, but don't take the time to read responses. This is a bug reporting thread after all.
Old 31st January 2014, 20:28   #19025  |  Link
Originally Posted by rendez2k View Post
Hmmmm, well I had a line in my config about MVC so I removed it. Encoding has now started. I think I had to add MVC from a different package,something to do with the 3D side of things? Do I need it?
BD-RB no longer uses any MVC decoder from any other package. I don't see how that could affect it...
Old 31st January 2014, 20:29   #19026  |  Link
rendez2k
rendez2k's Avatar
Well, I currently have this so I assume its encoding OK?
- Input BD size: 5.85 GB
- Approximate total content: [01:34:50.726]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7601]
- Warning: SBS 3D source indicated.
[18:54:14] PHASE ONE, Encoding
- [18:54:14] Processing: VID_00000 (1 of 1)
- [18:54:14] Extracting A/V streams [VID_00000]
- [18:57:42] Reencoding video [VID_00000]
- Rate/Length: 23.976fps, 136,441 frames
- Bitrate: 30,562 Kbs
- [18:57:42] Reencoding: VID_00000, Pass 1 of 1
rendez2k is offline   Reply With Quote
Old 31st January 2014, 20:33   #19027  |  Link
omegaman7
omegaman7's Avatar
I really should have heeded the warning.
"- Warning: SBS 3D source indicated."
By selecting movie only output, all appears to be well so far.
Rendez2k, are you setup for movie only ouput? Because apparently that's necessary.
Perhaps when importing a single title, full backup can be grayed out, and not possible.
Old 31st January 2014, 20:35   #19028  |  Link
rendez2k
rendez2k's Avatar
Bugger. Nope, it was on full disc. Will have to try again tomorrow now!
Old 31st January 2014, 20:40   #19029  |  Link
Yeah, I should probably do something to steer the process in the right direction. Maybe automatically select MOVIE-ONLY when the import is complete... I hate to block full backup completely , because there might be someone who wants to keep SBS output to BD. Although I admit that is probably rare.
Old 31st January 2014, 20:48   #19030  |  Link
pididdi
pididdi's Avatar
i think it is a bug when bd-rebuilder isnīt able to rebuild a movie only source from "odd thomas" (man, other bdīs work fine), to dvd5 size with 1440x1080 resolution in one step! the result was a very uggly videoquality with blocks out of order! but i will stop writing posts now. i have helped myself and i have what i wanted! the trick to rebuild the original to bd-25 size seems to work.
Old 31st January 2014, 20:51   #19031  |  Link
omegaman7
omegaman7's Avatar
All decoders fail, and no encode initiates.
[11:24:54] Importing MKV: SURFING3D
  - Collecting audio/video streams from source...
  - Building pseudo-BD source structure...
[11:28:25] Video import completed successfully.
[01/31/14] BD Rebuilder v0.46.07 (beta)
[11:31:06] Source:  SURFING3D_00000
  - Input BD size: 9.35 GB
  - Approximate total content: [01:40:16.009]
  - MOVIE-ONLY mode enabled
  - Converting SBS source to 3D-BD format
  - Quality: High Quality (Default), ABR
  - MVC 3D Output Mode enabled
  - Decoding/Frame serving: DGDecNV
  - Audio Settings: AC3=0 DTS=1 HD=1 Kbs=640
[11:31:06] PHASE ONE, Encoding
 - [11:31:06] Processing: VID_00000 (1 of 1)
 - [11:31:06] Extracting A/V streams [VID_00000]
 - [11:32:48] Reencoding video [VID_00000]
   - Rate/Length: 23.976fps, 144,240 frames
   - Bitrate: 24,998 Kbs
   - Using FRIMEncoder for MVC reencoding
 - [11:32:48] Reencoding: VID_00000, Pass 1 of 1
[11:32:48] - Failed video encode, aborted
[11:38:06] Source:  SURFING3D_00000
[11:38:07] PHASE ONE, Encoding
 - [11:38:07] Processing: VID_00000 (1 of 1)
 - [11:38:07] Extracting A/V streams [VID_00000]
 - [11:39:51] Reencoding video [VID_00000]
 - [11:39:51] Reencoding: VID_00000, Pass 1 of 1
[11:39:52] - Failed video encode, aborted
[11:41:13] Source:  SURFING3D_00000
[11:41:17] PHASE ONE, Encoding
 - [11:41:17] Processing: VID_00000 (1 of 1)
 - [11:41:17] Extracting A/V streams [VID_00000]
 - [11:43:02] Reencoding video [VID_00000]
 - [11:43:02] Reencoding: VID_00000, Pass 1 of 1
[11:43:03] - Failed video encode, aborted
"INF"
[Status]
LABEL=SURFING3D
VERSION=v0.46.07 (beta)
SOURCE_SIZE=10039357440
SOURCE_VIDEO_SIZE=10039357440
TARGET_SIZE=24641536000
REDUCTION=2.454493342554
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=1.5
[00000]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=24641536000
RATE=24998
Old 31st January 2014, 20:56   #19032  |  Link
Can you post the AVS file so I can see if it looks correct?
Old 31st January 2014, 20:56   #19033  |  Link
omegaman7
omegaman7's Avatar
This?
#Created by BD Rebuilder - v0.46.07 (beta)
DirectshowSource("R:\IMPORTS\SURFING3D\BDMV\STREAM\00000.m2ts", fps=23.976, framecount=144240, audio=false)
Spline16Resize(3840,1080)
ConvertToYV12().AssumeFPS(24000,1001)
Old 31st January 2014, 20:58   #19034  |  Link
This?
Yeah, and it looks right. I hope I haven't done something to screw up the FRIMEncode command line.
Old 31st January 2014, 21:00   #19035  |  Link
omegaman7
omegaman7's Avatar
Unfortunately, I didn't keep the last two versions to compare :S
I'm patient. As I said, my display is a week or more out. I've been buying the combo packs, and playing around ahead of time.
Old 31st January 2014, 21:05   #19036  |  Link
This?
Ahhh... I think I may know what it is.
1. Click on the start button and select FFDSHOW from "All Programs"
2. Select VFW configuration.
3. On the Decoder tab, go down to "Raw Video", and select "All Supported".
Let me know if that works -- and I'll update to a new version that does this automatically at encode time.
Old 31st January 2014, 21:13   #19037  |  Link
omegaman7
omegaman7's Avatar
Appears to be running now Thanks!
@ ~8hrs to go :S
Old 31st January 2014, 21:31   #19038  |  Link
@ ~8hrs to go :S
Great to see its working.
Yeah, MVC encoding is anything but fast. But I notice on my system that my processor time is nowhere near 100%. I need to find a way to multiprocess when using FRIMEncode. On my system I think I could probably double the speed.
Old 31st January 2014, 21:36   #19039  |  Link
omegaman7
omegaman7's Avatar
Yeah, mine fluctuates around 60%. Pretty soon, and my computer will run off a self sustained generator. And wattage be damned
No, it's closer to 50%.
Old 31st January 2014, 22:43   #19040  |  Link
pididdi
pididdi's Avatar
only two sentences! it plays back on my blu-ray player with a very good image! good job, jdoobs!
