Old 3rd December 2017, 19:09   #381  |  Link
Glarioo
MeGui 2798: Everything works fine now. Thanks!
Old 20th January 2018, 14:55   #382  |  Link
tormento
Acid fr0g
tormento's Avatar
Is there a way to process multiple audio tracks from a mkv file without having to extract them?
If not, could it be added?
I am getting better results with ffmpeg rather than with eac.
@turment on Telegram
Old 21st January 2018, 11:47   #383  |  Link
tebasuna51
tebasuna51's Avatar
- Using eac3to with Tools -> HD Stream Extractor you can process multiple audio tracks from a mkv. But offer a limited use off eac3to (unless you add many parameters in '+ options' box).
You can use my GUI UsEac3to better than HDStreamExtractor and you can encode also with ffmpeg.
- Using AviSynth decoders, with 'Audio encoding' in main 'Input' tab, you can only process the first audio from a mkv with LWLibavAudioSource.
Using BeHapy you can select the audio track desired adding the desired stream_index to decoder, for instance:
LWLibavAudioSource("INPUT.mkv", stream_index=2)
Maybe that can be implemented in MeGUI
BTW I'm not sure if that method is better:
Extract and recode 2 tracks from a mkv: 51 sec.
Recode the 2 tracks without extract: 53 sec.
(I supose eac is eac3to)
If you are talking about AC3 encoding, yes the default eac3to encoder Aften is deprecated and ffmpeg must be used.
Old 22nd January 2018, 12:16   #384  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks for your kind reply, however I intended with MeGUI tool
I can convert audio from tool but one track at a time and only if already extracted.
I would like to feed a mkv and get a minimal GUI to transcode the audio tracks only into whatever I want with FFMpeg
Old 28th January 2018, 16:55   #385  |  Link
Zathor
The best option for you is OneClick. You can select the input file and the audio encodings for each track and do all in once. Not sure if this is what you are searching for.
Old 28th January 2018, 19:11   #386  |  Link
Bexley
DLL download link is broken.
Bexley is offline   Reply With Quote
Old 28th January 2018, 19:21   #387  |  Link
Zathor
Done (see first post)
Old 28th January 2018, 19:31   #388  |  Link
Bexley
Many thanks.
Old 28th January 2018, 20:39   #389  |  Link
Bexley
I'm getting a crash when encoding to x264 that I do not get with Megui x32 using the exact same config. I'm ripping DVDs and encoding to x264 for my media server. If I download, unzip, run AVS script creator, and encode with the default x264 scratchpad settings it works perfectly. But the minute I change my x264 settings for 480i source, x264 crashes when the encode starts.
LoadPlugin("C:\MeGUI-2808-64\tools\dgindex\DGDecode.dll")
DGDecode_mpeg2source("C:\E4190\VIDEO_TS\VTS_03_1.d2v", info=3)
LoadPlugin("C:\MeGUI-2808-64\tools\avisynth_plugin\ColorMatrix.dll")
ColorMatrix(hints=true, threads=0)
#deinterlace
#crop
#resize
#denoise
Default scratchpad settings runs like a raped ape at 300fps, it's awesome. When I load my NTSC 480i preset (this is true video) I get a crash as soon as x264 loads.
program --level 4.1 --bluray-compat --preset veryslow --tune film --crf 20 --keyint 30 --open-gop --slices 4
--vbv-bufsize 30000 --vbv-maxrate 40000 --tff --colorprim smpte170m --transfer smpte170m --colormatrix smpte170m
--sar 10:11 --output "output" "input"
--[Information] [1/28/2018 1:12:54 PM] Started handling job
--[Information] [1/28/2018 1:12:55 PM] Preprocessing
--[Information] [1/28/2018 1:12:55 PM] AviSynth input script
---[NoImage] LoadPlugin("C:\MeGUI-2808-64\tools\dgindex\DGDecode.dll")
---[NoImage] DGDecode_mpeg2source("C:\E4190\VIDEO_TS\VTS_03_1.d2v", info=3)
---[NoImage] LoadPlugin("C:\MeGUI-2808-64\tools\avisynth_plugin\ColorMatrix.dll")
---[NoImage] ColorMatrix(hints=true, threads=0)
---[NoImage] #deinterlace
---[NoImage] #crop
---[NoImage] #resize
---[NoImage] #denoise
--[Information] [1/28/2018 1:12:55 PM] resolution: 720x480
--[Information] [1/28/2018 1:12:55 PM] frame rate: 30000/1001
--[Information] [1/28/2018 1:12:55 PM] frames: 44311
--[Information] [1/28/2018 1:12:55 PM] aspect ratio: 3:2 (1.500)
--[Information] [1/28/2018 1:12:55 PM] target device selected: Blu-ray
--[Information] [1/28/2018 1:12:55 PM] changing --keyint to 30 as required for the selected device
--[Information] [1/28/2018 1:12:55 PM] Job command line: "C:\MeGUI-2808-64\tools\x264\x264.exe" --level 4.1 --bluray-compat \
 --preset veryslow --tune film --crf 20 --keyint 30 --open-gop --slices \
 4 --vbv-bufsize 30000 --vbv-maxrate 40000 --tff --colorprim \
smpte170m --transfer smpte170m --colormatrix smpte170m --sar \
10:11 --output "C:\E4190\VIDEO_TS\VTS_03_1.264" "C:\E4190\VIDEO_TS\VTS_03_1.avs"
--[Information] [1/28/2018 1:12:55 PM] Process started
--[Information] [1/28/2018 1:12:55 PM] Standard output stream
--[Information] [1/28/2018 1:12:55 PM] Standard error stream
--[Error] [1/28/2018 1:12:57 PM] Process exits with error: 0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819)
--[Information] [1/28/2018 1:12:57 PM] Job completed
I do not get this crash using MeGui x32 with the same preset. Only the x64 version. Any thoughts?
Old 28th January 2018, 22:11   #390  |  Link
Groucho2004
@Bexley
Run the script with AVSMeter64 to see if this crashes. I vaguely remember that DGDecode 64 bit is not very stable so this could be the problem.
Groucho's Avisynth Stuff
Old 28th January 2018, 22:27   #391  |  Link
Bexley
@Bexley
The script itself runs like a champ all day long. I can load it up in VDub or AVSmeter and do whatever, output to any format. I can also feed it to x264 with no parameters i.e., program --output "output" "input" and it works fine. It's only when I change any x264 parameters that it crashes. Something is happening when MeGui hands it off that's causing x264 to throw up. I'm playing with settings now to try and narrow down which one is causing the problem.
I can confirm that changing the AVC level from unrestricted to 4.1 causes a crash, but I don't know what else might be at play.
Old 28th January 2018, 23:08   #392  |  Link
Bexley
It's definitely AVC level 4.1 that's causing it. It works fine with all the other options as long as I leave that unrestricted. I'm encoding for Bluray compatibility and it calls for 4.1, so leaving it unrestricted is an option but not a very good one.
Old 18th February 2018, 04:43   #393  |  Link
Bexley
New build 2824 seems to fix this. Thanks.
Old 22nd February 2018, 22:47   #394  |  Link
Morku
I have some strange issue with MeGUI 64 Bit, when I want encode 10-Bit input encode with x264 with 8-Bit output.
The created file is distorted (double resolution, everything is green) and handled like without "--input-depth 10".
Thats the AviSynth script I use
LoadPlugin("LSMASHSource.dll")
LSMASHVideoSource("test2.mov", format="YUV420P10")
Here the x264 parameter
program --output-depth 8 --input-depth 10 --output "output" "input"
The thing is, when I use MeGUI 32-Bit the result is fine!
It can't be a x264.exe issue, because both version using the same 64-Bit x264.exe file.
It also can't be LSMASH 32/64-Bit issue, because when I use x265 in MeGUI 64 Bit with --input-depth 10 --profile main, the result is also fine.
The only difference is, that MeGUI 32-Bit is additional using avs4x26x.exe.
That's the log for MeGUI 64-Bit:
https://pastebin.com/NRZZUH4V
and here for 32-Bit:
https://pastebin.com/9WhmL5ki
What's the cause? Is there a solution for it?
Morku is offline   Reply With Quote
Old 22nd February 2018, 23:00   #395  |  Link
sneaker_ger
L-Smash doesn't know native AviSynth+ formats >8 bit, only hacked formats. Either use ffms or try:
For 8 bit output simply:
LSMASHVideoSource("test2.mov", format="YUV420P8")
x264 --input-depth 8 --output-depth 8 "input.avs" -o "output.264"
For 10 bit pipe/output:
LSMASHVideoSource("test2.mov")
ConvertFromDoubleWidth(bits=10)
ConvertBits(16)
x264 --input-depth 16 --output-depth 10 "input.avs" -o "output.264"
Old 25th February 2018, 15:11   #396  |  Link
Gser
ConvertBits(16)
L-Smash does know Avisynth+ formats, he just has to set stacked=false.
Gser is offline   Reply With Quote
Old 25th February 2018, 15:17   #397  |  Link
sneaker_ger
Wrong.
He didn't set stacked=true. (stacked=false is the default)
stacked=false only means that it is using the "interleaved" hacked format, not the "stacked" hacked format.
Old 26th February 2018, 14:33   #398  |  Link
Gser
Wrong.
LWLibavVideoSource
Avisynthplus color formats
I've done many 10 bit x265 encodes with this, it works fine. Only problem I have is that not many filters support the format.
I just noticed he was using x264. Maybe it only supports stacked 10-bit? Perhaps he could dither it to 8 bits with a filter instead of feeding 10 bits to x264.
There is something weird going on I do have to admit, using Convertbits(8), doesn't convert the bit depth which I believe is its primary function. Also trying to resize with internal filters results in a mess.
Old 26th February 2018, 15:56   #399  |  Link
sneaker_ger
It's because L-Smash doesn't support the native high bitdepth formats of AviSynth+. You can tell L-Smash to output format="yuv420p16" but that will not be the native format. Just 16 bit hacked into AviSynth's 8 bit format as double width (interleaved) or double height (stacked). Filters will treat it as 8 bit and produce garbage results unless you either convert it into native format or have a filter that supports hacked input (often via "lsb_in" parameter).
If you put info() behind L-Smash you can see that AviSynth+ will always report 8 bits per component. This isn't the case for ffms2 because that actually does support the native formats >8 bit.
Old 26th February 2018, 20:37   #400  |  Link
Gser
Thanks for the info, I've been struggling with this for the past year now. I'm guessing I have to use the C-plugin version of ffms2 for the high bit depth support.
