Old 9th November 2007, 22:08   #221  |  Link
trott
ah, I thought that was what I was doing. I of course do not want them encoded in the video...
I'll extract them manually; however it would be nice if your tool could mux the subpicture streams into the container; both mp4 and mkv support this.
trott is offline   Reply With Quote
Old 9th November 2007, 22:17   #222  |  Link
I use subrip to convert subtitles to text files. However after conversion I always leave them in separate files instead of muxing.
Old 10th November 2007, 00:23   #223  |  Link
Topher
newbie working with vobs
I've been using AutoGK for a couple of years to create xvids from my ripped dvds. I want to try x.264 encodes but I'm not sure what I need to do.
I've ripped a dvd in file mode & in Ripbot, I select the first vob file. Will ripbot select the subsequent vobs? I see that once it's demuxed & indexed the audio, the duration is the length of the first vob. Should I rip in IFO mode instead?
Do I need to demux them into an mpeg file first? Is there freeware to do this?
Sorry if the questions are pretty basic, but like I said, I've been using AutoGK & it doesn't require much thinking.
Topher is offline   Reply With Quote
Old 10th November 2007, 13:15   #224  |  Link
You have to select manually all vobs you want to encode.
for example: VTS_01_1.VOB , VTS_01_2.VOB , VTS_01_3.VOB ...
Old 11th November 2007, 01:21   #225  |  Link
mutha88
I have a question. Can a MPEG-4 files output be read from a regular DVD player? I mean the kind, that RipBot uses?
Another question. Is there more audio profiles to add? Or can you? Congratulations for this good proggy...i've been using Staxxrip quite for a while, but i think, that this is better for batch encoding
mutha88 is offline   Reply With Quote
Old 11th November 2007, 02:10   #226  |  Link
deets
nope ripbot264 outputs h.264 compliant files which no regular dvd player can read
deets is offline   Reply With Quote
Old 11th November 2007, 22:47   #227  |  Link
Topher
Thanks! Worked great. Now I just need a faster computer.
Old 11th November 2007, 23:54   #228  |  Link
Miryan
I also have a question. If I select the vobs, the program itself (or windows?) change the order, and the files comes like this: VTS_01_4.VOB,VTS_01_1.VOB,VTS_01_2.VOB,VTS_01_3.VOB.
So, RipBot 'knows' the real order, like 1-2-3-4, or it will code like 4, 1, 2 and 3?
Miryan is offline   Reply With Quote
Old 12th November 2007, 12:25   #229  |  Link
Selected files VTS_01_4.VOB,VTS_01_1.VOB,VTS_01_2.VOB,VTS_01_3.VOB
are indexed in 4, 1, 2 and 3 order.
Old 12th November 2007, 12:32   #230  |  Link
Miryan
I see, thanks!
Old 14th November 2007, 15:59   #231  |  Link
PSPNut
I have been using Ripbot for some time for encoding to PSP and it has been working great. Recently, I bought an iPhone (which unfortunately doesn't work with Floola), and have ran into issue with the audio encoding. iTunes fails silently during import and QuickTime gives an error -2041.
If I extract the audio manually and transcode it using iTunes and then remux it back using mp4box, it works great.
Is there is way to make the iPhone profile create an audio track that can be directly imported via iTunes?
PSPNut is offline   Reply With Quote
Old 17th November 2007, 17:27   #232  |  Link
Jerry_Sm@rt
@Atak_Snajpera
I really like your gui ,very easy to use for batch encoding.
It would be better if u add surport for nero aac encoder
and make the audio profile editable(like the video part) .
Jerry_Sm@rt is offline   Reply With Quote
Old 17th November 2007, 23:34   #233  |  Link
Why do you guys like nero encoder so much? I made many quality test using Sennheiser headphones and I didn't hear any differences.
Why? What is missing?
Old 18th November 2007, 01:23   #234  |  Link
Mtz
Mtz's Avatar
I used for the first time this program today. Some things regarding iPhone profile as an example when choosing [ level 3.0 ] iPOD Touch & iPhone:
- mkv output to be greyed
- the audio must to stay under "2.0 AAC LC 128kbps" and no other option to be available. Best is to be autoset as "2.0 AAC LC 96kbps" as default.
- the video must to stay under 640x480 and no other option to be available for resize and max. bitrate 1500 kbps.
Request: when adding subtitles to be possible to add black bars, keeping correct aspect ratio and the subtitles to be placed at the bottom of the video. The reason is because the display is 4:3 and if encoding some 16:9 movie with subtitles the player will add black bars and the subtitles will be not very readable if them are in the video as opposed to be on the black bars. Also for srt subtitles the font, size cannot be choosed by the users and I consider for iPhone the default font is too small. User needs to learn how to make better ssa subtitles. I don't know if you can add an option for font, size, position of subtitles but I hope to add something simple when adding subtitles like: WideScreen (16:9) or LetterBoxed (16:9 in a 4:3 frame with black borders).
enjoy,
Mtz
Mtz is offline   Reply With Quote
Old 18th November 2007, 04:59   #235  |  Link
Jerry_Sm@rt
Coz nero's faster.
For example, people may need 48 kbps he+ps aac for some animation title or high bitrate 5.1 aac...
Old 18th November 2007, 23:47   #236  |  Link
Coz nero's faster.
I don't think so
My system: Core 2 Duo@2.8Ghz
conversion 1h:52m mp3 to 128 kbps CT-AAC took 2m:30s / ND-AAC SSE took 4m:10s
HE+parametric stereo sucks!
320 kbps is a maximum for 6 channels. There is nothing above that.
Old 20th November 2007, 00:20   #237  |  Link
mrpijey
OK, here are two stupid questions for you....:
1: How do I make ripbot264 accept my DTS-encoded x264-streams? When I open up a .mkv-file that has its audio encoded with DTS i get a "Audio properties returned by AviSynth are incorrect" error, displaying Audiorate, AudioChannels and AudioLength to 0. It's something with my codecs, but what? What should I use? I can playback the files with audio properly, but ripbot264 won't swallow it.
2: AC3 encoded x264-streams show up in ripbot264 as 2 channels only. Even if I know they are 6 channels they only show 2. With MPEG2's (DVD source) it works with 6 chan.Trying to convert 1080/720p streams into lower resolution.
I prolly missed something quite obvious, but I can't see the solution... any ideas?
mrpijey is offline   Reply With Quote
Old 20th November 2007, 16:28   #238  |  Link
Jerry_Sm@rt
I don't think so
Maybe I jump to that speed conclusion too hurry,I'll do some more test myself.
Lowrate heaacv2 may sound bad for u , but it's popular in tv animation archive.
I know 256k is good for 5.1 lc aac,but there's no 5.1 audio profile now in your gui.
So maybe u could think about split audio option to 3 part :encoder vorbis/lcaac/heaac/heaacv2;channels 2.0/5.1 ;bitrate xxx.Or simply add more audio profiles.
Old 20th November 2007, 18:07   #239  |  Link
Send me small sample
Disable Mixer in FFDShow Audio Configuration
What are you talking about???
Old 20th November 2007, 18:41   #240  |  Link
Mtz
Mtz's Avatar
Can you reply at my previous post? The most interesting si regarding WideScreen and Letterboxed thing.
10x!
enjoy,
Mtz
