Old 4th October 2012, 05:17   #15901  |  Link
omegaman7
omegaman7's Avatar
Originally Posted by Ch3vr0n View Post
there are no issues with running any program like BDRB or another in the program files. I do, well not if u disable that stupid UAC like i did. Thats one of the first things i do after a windows install.
Me too. Pesky function In my opinion.
Old 4th October 2012, 08:57   #15902  |  Link
abbadon
any plan to make MULTIPROCESS work with IMPORT ? with my current Phenom II x4 940 it makes a 20% difference. I was planning on purchaching a 6 core Intel after extensive testing on such a machine, but my testing showed MULTIPROCESS gave an even greater boost from MULTIPROCESS (ca. 40%). Granted, I see myself doing VERY few imports, but is this conflict considered a bug-to-be-fixed ? or is there a manual workaround you can suggest?
Win7x64...I had to...
RIP WinXP
abbadon is offline   Reply With Quote
Old 4th October 2012, 14:31   #15903  |  Link
soneca
jdobbs,
All programs installed correctly, the windows registry was changed to allow me to use the revision(3882) of ffdshow with BD Rebuilder and RipBot264.
So it appears the 9999.
This time the conversion was completed but the BD Rebuilder is detecting bff as tff.
Bd Rebuilder should detect the correct order of the dominant field or the inclusion of the parameter "--bff" is always necessary?
I made another conversion including this parameter, and the video was processed correctly.
TWEAK_PASS_ONE=--tune film --bff
TWEAK_PASS_TWO=--tune film --bff
Old 4th October 2012, 15:03   #15904  |  Link
mercadonegro
mercadonegro
Originally Posted by jwjohnson View Post
mercadonegro
Do you have BD-RB installed in the Program Files or the Program Files (x86) folders?
Windows 7 doesn't always play nice with BD-RB if you put it there.
Hello jwjohnson
BD-RB I have not installed in the Program Files or Program Files (x86)
I have it installed on another hard drive.
E: \ Mercadonegro \ in process \ Compression \ BD_Rebuilder
But when I choose to keep the DTS audio, I have no problem ...
mercadonegro is offline   Reply With Quote
Old 4th October 2012, 15:04   #15905  |  Link
mercadonegro
mercadonegro
@mercadonegro
Error 00070 is "Permission Denied" -- you have a permissions issue with either the application or the folder where it is attempting to write.
I'd right-click on the files AFTEN.EXE and WAVI.EXE in the BD-RB tools folder and see if there is some rights issue against one of them.
Hi jdobbs
OK. I right click on AFTEN.EXE and WAVI.EXE, on the Details tab, but no rights issue
My English is not good. Apologies.
Old 4th October 2012, 15:11   #15906  |  Link
Originally Posted by mercadonegro View Post
Hi jdobbs
The conversion is run as a batch job (in order to redirect the output of WAVI into AFTEN). So that might be another place to look. Unfortunately this is definitely a rights/privilege issue, which is specific to your system. It's tough to debug one of those on a forum, there are lots of possibilities.
Old 4th October 2012, 15:19   #15907  |  Link
aneurysm
hi,
this is not a bug .. but something I haven't found yet.
is there an option to select to which language audio or subs are changed ?
for instance .. a disc with 20 different subs. I have standard selected to keep ENG & DUT subs.
After the rebuild, all the subs that are gone are replaced by ENG (So I have 19 ENG subs & 1 DUT sub). But what if I would like them to all be replaced by DUT (19 DUT subs & 1 ENG sub)?
tnx in advance
aneurysm is offline   Reply With Quote
Old 4th October 2012, 15:59   #15908  |  Link
Originally Posted by aneurysm View Post
hi,
tnx in advance
Currently the languages that are not kept are modified to point to the first of the languages that are. So if ENG is first on the list of selected languages, the track id for all the removed languages are changed to point to ENG. If the first was DUT, then they'd point to DUT. I could probably add a hidden parameter that gives precedence to some other language.
Old 4th October 2012, 16:05   #15909  |  Link
aneurysm
Currently the languages that are not kept point are modified to point to the first of the languages that are. So if ENG is first on the list of selected languages, the track id for all the removed languages are changed to point to ENG. If the first was DUT, then they'd point to DUT. I could probably add a hidden parameter that gives precedence to some other language.
ok that explains. ENG is indeed usually first. If ya ever have time to put that in a hidden options would be cool.
Old 4th October 2012, 18:55   #15910  |  Link
AmigaFuture
AmigaFuture's Avatar
Toy Story 1 (and 2): I removed AnyDVD and installed an older version 6.7.6.0..and noticed a difference in handling this disk with most recent releases; with respect to the ripping to HDD vs ISO. BD-RB is unable to create a backup of Toy Story without A/V "jerkiness" with my machines, even the almost completely stock Windows 7. Installed games, Firefox and Crome are the only things keeping it from being stock Windows 7. BD-RB does render a good MKV as an alternate output. I read a little more about "linking" which is why 3D Blu-ray disks are to be ripped as ISO. Toy Story isn't 3D, but I wonder if BD-RB isn't "linking" the segments correctly!? Just pondering... Thanks for reading.
Until something changes with BD-RB or some other clue is noticed, I'm out of ideas.
Old 4th October 2012, 23:24   #15911  |  Link
Adbear
The reason 3D discs need to be ripped as ISO's is so the right eye doesn't get unpacked and make it to big to fit back onto a disc, this is not the same as seamless branching that you get on 2D discs
Adbear is offline   Reply With Quote
Old 4th October 2012, 23:34   #15912  |  Link
AmigaFuture
Adbear: I was reading about that on the SlySoft forums when someone else talked about it. Now I get "Why" without all the details. Okay, I'll change it to seamless branching..perhaps that's what's happening with Toy Story 1 and 2 here with BD-RB. I'm not sure. Seems odd to me to call it "the right eye" when it's not an actual "Eye"...but only data for it. Ah, well. Hehe. I appreciate your reply, thanks.
Old 5th October 2012, 03:53   #15913  |  Link
sytyguy
So does that mean one can rip a 3D movie with BD-RB if it is ripped as an ISO???
sytyguy is offline   Reply With Quote
Old 5th October 2012, 12:55   #15914  |  Link
That doesn't explain why it worked correctly for hundreds of others -- including myself.
Here's what I'd like to happen. I want you to run "Toy Story" again -- then , without changing anything, I'd like you to copy the config/ini file contents and send them to me (dvd-rb@dvd-rb.com). I will load your settings and run "Toy Story" one more time. If I can repeat your issue -- I'll get it fixed. If it runs correctly for me, then I'll just have to tell you that the problem is on your end and be done with it.
Old 5th October 2012, 17:53   #15915  |  Link
Ch3vr0n
Yes and no. BDRB will be able to produce a 2D only backup disc provided the disc containts both a 2D & 3D version on the same disc. BDRB simply ignores the SSIF folder and processes the rest. If it is a 3D only disc, then no BDRB can't handle it. The only way to backup a 3D disc and retain full functionality like the original is 1:1
Old 5th October 2012, 17:59   #15916  |  Link
sytyguy
I know the documentation indicates it cannot, but "Adbear" mentioned, "3D discs need to be ripped as ISO's", so I thought something had changed.
Thanks for the reply.
Old 5th October 2012, 23:44   #15917  |  Link
drmih
If a 3D disc is ripped to a folder the size is effectively twice the size on disc. Therefore it makes sense to rip to an iso for storage. The only software that can currently create a bd-25 iso of a 3D disc with everything cloned is dvdfab.
Old 6th October 2012, 00:05   #15918  |  Link
Ch3vr0n
euhm you're wrong on that part. DVDCrap can shrink BD3D to BD25 as much as i'm santa. it can't, it does the same thing BDRB does. Ignore the SSIF folder, but keeps the menu intact. Result BD25 disc on which the 3D stream doesnt work.
Old 6th October 2012, 00:19   #15919  |  Link
drmih
Just do your homework. I have version 8.2.1.2 and it works on my discs - I've backed up 30 or so of my discs and the copies are full 3D copies on bd-25. The stupid thing about the software is that the option lets you write to a folder or iso image, and normally I'd just go to a folder. If you do this it does ignore the SSIF folder - it only works properly if you select iso as the output.
Here's a listing of the bd50 and bd25 discs:
Volume in drive E is CLASH OF THE TITANS 3D BD
Volume Serial Number is 0118-93E6
Directory of e:\bdmv\stream\ssif
25/06/2010 22:30 <DIR> .
25/06/2010 22:30 <DIR> ..
25/06/2010 22:30 40,643,745,792 00002.ssif
25/06/2010 22:30 50,583,552 00004.ssif
25/06/2010 22:30 1,910,784 00006.ssif
25/06/2010 22:30 8,091,648 00008.ssif
25/06/2010 22:30 1,044,480 00010.ssif
25/06/2010 22:30 125,884,416 00012.ssif
25/06/2010 22:30 2,537,472 00014.ssif
25/06/2010 22:30 693,061,632 00016.ssif
25/06/2010 22:30 239,616 00018.ssif
9 File(s) 41,527,102,064 bytes
2 Dir(s) 0 bytes free
Volume Serial Number is F7D6-93DD
01/01/1970 01:00 <DIR> .
08/09/2012 19:30 <DIR> ..
08/09/2012 19:23 22,236,856,320 00002.ssif
08/09/2012 19:24 26,529,792 00004.ssif
08/09/2012 19:30 1,910,784 00006.ssif
08/09/2012 19:24 5,947,392 00008.ssif
08/09/2012 19:24 485,376 00010.ssif
08/09/2012 19:30 141,821,952 00012.ssif
08/09/2012 19:23 1,572,864 00014.ssif
08/09/2012 14:18 495,814,656 00016.ssif
08/09/2012 19:23 24,576 00018.ssif
9 File(s) 22,910,966,780 bytes
Don't forget my present this year Santa!
Old 6th October 2012, 00:42   #15920  |  Link
Ch3vr0n
In that case i have some testing to do. It didn't do that the last time i heard about it's so called "shrinking" option. Which option do i pick. Got a couple discs lying arround, i wonder what the quality will be
