Old 24th May 2019, 20:14   #121  |  Link
soresu
Bricks are a new one to me, or is this just a slight variant on the tile technique?
soresu is offline   Reply With Quote
Old 30th May 2019, 21:05   #122  |  Link
iwod
So nothing new came out of the MC-IF meeting?
https://www.mc-if.org/mc-if-meeting-and-outreach
iwod is offline   Reply With Quote
Old 30th May 2019, 21:19   #123  |  Link
iwod
There is a new article from BBC R&D
https://www.bbc.co.uk/rd/blog/2019-0...ssing-hevc-vvc
I can't find any reference but I assume they tested it with VTM 5.0.
Results looks, good especially for single pass and Streaming. I Still wish VVC will push further in bitrate reduction. For resolution I cared about, which is NOT 4K / UHD, I think the reduction was only 25%.
Old 30th May 2019, 21:34   #124  |  Link
Jamaika
Lot of advertising, zero effect playback.
https://www.5kplayer.com/video-music...nload-free.htm
Old 30th May 2019, 22:33   #125  |  Link
benwaggoner
I can find any reference but I assume they tested it with VTM 5.0.
Nrr, another mean PSNR study, no subjective quality analysis. PNSR is the least well subjectively correlated metric we ever use.
Also, past studies have shown that libaom shows better PSNR but similar or slightly worse subjective quality than HEVC HM. A study that had PSNR and subjective data would let us see if AV1 is getting psychovisual improvements. The hope is libaom would be evolving to improve psychovisual quality even if it reduces PSNR.
Ben Waggoner
My Compression Book
Old 1st June 2019, 08:03   #126  |  Link
Jamaika
- new fixes for codec VVC 5.0 2019.06.01
#define JVET_N0063_VUI 1 // JVET-N0063: Video Usability Information
#define JVET_N0847_SCALING_LISTS 1 //1: default mode, 2: user defined mode
#define JVET_N0438_LOOP_FILTER_DISABLED_ACROSS_VIR_BOUND 1 // loop filter disabled across virtual boundaries
#define JVET_N0067_NAL_Unit_Header 1 // NAL Unit Header
#define JVET_N0349_DPS 1 // Decoding Parameter Set
#define JVET_N0857_TILES_BRICKS 1 // VTM-5 basic Slices/Tiles/Bricks design, rectangular slices not supported yet
#define JVET_N0124_PROPOSAL1&2 1 // JVET-N0124 Proposal 1 & 2
#define JVET_N0150_ONE_CTU_DELAY_WPP 1 // one CTU delay WPP
#define EMULATION_PREVENTION_FIX 1 // fix for start code emulation reported in #270. Diverges from specification text
delete #define HEVC_DEPENDENT_SLICES 1
https://www.sendspace.com/file/zce506
Old 27th June 2019, 21:55   #127  |  Link
Jamaika
- new fixes for codec VVC 5.0 2019.06.27
#define JVET_N0047_Merge_IDR_Non_IDR 1 // merging IDR and non-IDR pictures
#define JVET_N0276_CONSTRAINT_FLAGS 1 // JVET-N0276: On interoperability point signalling
#define JVET_N0278_HLS 1 // JVET-N0278: HLS for MPEG requirements on immersive media delivery and access
#define JVET_N0805_APS_LMCS 1 // JVET-N0805: Reference to APS from slice header for LMCS
#define JVET_N0070_WRAPAROUND 1 // reference wraparound simplifications
#define JVET_N0857_RECT_SLICES 1 // Support for rectangular slices and raster-scan slices (i.e., multiple tiles/brick in a slice)
#define JVET_M0128 1 // Implementation of RPL as in JVET-M0128
Delete old function HEVC:
delete #define HEVC_USE_DC_PREDFILTERING
delete #define HEVC_USE_HOR_VER_PREDFILTERING
https://www.sendspace.com/file/live4q
Old 11th July 2019, 16:15   #128  |  Link
IgorC
Subjective tests between VVC and HEVC
http://phenix.it-sudparis.eu/jvet/do...T-O0451-v1.zip
IgorC is offline   Reply With Quote
Old 11th July 2019, 17:56   #129  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
I've converted it to PDF:
https://www.scribd.com/document/416562888/JVET-O0451
You can also get it from here.
Old 11th July 2019, 20:21   #130  |  Link
iwod
So around 35% to 40% reduction.
Are there any similar test done for EVG?
Old 11th July 2019, 20:33   #131  |  Link
MoSal
Is the Sedof sequence available somewhere?
https://github.com/MoSal
MoSal is offline   Reply With Quote
Old 16th July 2019, 16:15   #132  |  Link
Jamaika
New VVC codec v5.2
https://www.sendspace.com/file/uianz2
delete HEVC_TOOLS
Old 27th July 2019, 13:25   #133  |  Link
Jamaika
New Viable Video Codecs on the Way? Maybe
VVC isn’t far enough along in its development to properly assess its practicality as a next-generation MPEG codec. One of its developers, Fraunhofer, says the technology has gained 30-35 percent improved efficiency over HEVC with an eventual target of 50 percent. A finalized standard is due sometime in 2020. On the licensing side, observers say VVC will not be free, but anything beyond this eventuality is pure guesswork.
There are some caveats cloud MPEG-5/EVC, however:
1.EVC will not deliver as much efficiency over HEVC as VVC promises.
2.What IP will be used and what royalty rates for the EVC main profile will be are not known.
3.MPEG-VCEG (Video Coding Experts Group) is working with VVC, not EVC.
New VVC codec v5.2 27.07.2019
#define JVET_O1136_TS_BDPCM_SIGNALLING 1 // JVET-O1136: Unified syntax for JVET-O0165/O0200/O0783 on TS and BDPCM signalling
#define JVET_O0219_LFNST_TRANSFORM_SET_FOR_LMCMODE 1
#define JVET_O0426_MRL_REF_SAMPLES_DC_MODE 1 // JVET-O0426: align MRL reference samples used for DC intra mode prediction
#define JVET_O0366_AFFINE_BCW 1 // JVET-O0366: Simplifications on BCW index derivation process
#define JVET_O1168_CU_CHROMA_QP_OFFSET 1 // JVET-O1168: cu chroma QP offset
#define JVET_O0368_LFNST_WITH_DCT2_ONLY 1 // JVET-O0368/O0292/O0521/O0466: disable LFNST for non-DCT2 MTS candidates normatively
#define JVET_O0106_ISP_4xN_PREDREG_FOR_1xN_2xN 1 // JVET-O0106: use 4xN prediction regions for 1xN and 2xN subblocks
#define JVET_O0500_SEP_CTX_AFFINE_SUBBLOCK_MRG 1 // JVET-O0500: Different ctx models for inter affine flag and subblock merge flag
#define JVET_O0414_SMVD_LTRP 1 // JVET-O0414: long-term reference picture restriction for SMVD
#define JVET_O0258_REMOVE_CHROMA_IBC_FOR_DUALTREE 1 // JVET-O0258 Remove chroma IBC when dualtree is used
#define JVET_O1161_IBC_MAX_SIZE 1 // Limit largest IBC luma CU size to 64x64 per discussion of JVET-O1161
#define JVET_O0315_RDPCM_INTRAMODE_ALIGN 1 // JVET-O0200/O0205/O0296/O0342/O0463/O0542: Intra prediction mode alignment for BDPCM
#define JVET_O0284_CONDITION_SMVD_MVDL1ZEROFLAG 1 // JVET-O0284: condition sym_mvd_flag on mvd_l1_zero_flag
#define JVET_O0122_TS_SIGN_LEVEL 1 // JVET-O0122: Sign context and level mapping of TS residual coding.
#define JVET_O0438_SPS_AFFINE_AMVR_FLAG 1 // JVET-O0438: affine AMVR control flag conditioned on affine control flag in SPS
#define JVET_O0065_CABAC_INIT 0 // JVET-O0065: CABAC initialization
#define JVET_O0052_TU_LEVEL_CTX_CODED_BIN_CONSTRAINT 1 // JVET-O0052 Method-1: TU-level context coded bin constraint
#define JVET_O0105_ICT 1 // JVET-O0105: inter-chroma transform (ICT) as extension of joint chroma coding (JCC)
#define JVET_O0543_ICT_ICU_ONLY 1 // JVET-O0543: ICT only in Intra CUs (was Intra slices, modified during adoption)
#define JVET_N0288_PROPOSAL1 1 // JVET-N0288 Proposal 1
#define JVET_O0090_ALF_CHROMA_FILTER_ALTERNATIVES_CTB 1 // JVET-O0090 test 2: CTB selection of ALF alternative chroma filters
#define JVET_O0216_ALF_COEFF_EG3 1 // JVET-O0216/O0302/O0648: using EG3 for ALF coefficients coding
#define JVET_O0256_ADJUST_THD_DEPQUANT 1 // JVET-O0256: Fast encoder with adjusted threshold in dependent quantization
#define JVET_O0619_GTX_SINGLE_PASS_TS_RESIDUAL_CODING 1 // JVET-O0619/O0623 : Single pass coding of abs_level_gtx_flag[x] for TS residual coding
#define JVET_O0272_LMCS_SIMP_INVERSE_MAPPING 1 // JVET-O0272: LMCS simplified inverse mapping
#define JVET_O0247_ALF_CTB_CODING_REDUNDANCY_REMOVAL 1 // JVET-O0247: not signal APS index when number APS is 2
#define JVET_O0297_DMVR_PADDING 1 // JVET-O0297 DMVR Padding
#define JVET_O0637_CHROMA_GRADIENT_LINE_SELECTION 1 // Choose line0 and line3 for gradient computation when chroma is same size as luma
#define JVET_O0288_UNIFY_ALF_SLICE_TYPE_REMOVAL 1 // JVET-O0288: remove slice type dependency in ALF
#define JVET_O0064_SIMP_ALF_CLIP_CODING 1 // JVET-O0047/O0058/O0064/O0067/O0290/O0301/O0430: use FLC for alf clipping indices, always signal alf clipping indices
#define JVET_O0529_IMPLICIT_MTS_HARMONIZE 1 // JVET-O0529/O0540: Harmonization of LFNST, MIP and implicit MTS
#define JVET_O0669_REMOVE_ALF_COEFF_PRED 1 // JVET-O0425/O0427/O0669: remove prediction in ALF coefficients coding
#define JVET_O0541_IMPLICIT_MTS_CONDITION 1 // JVET_O0541: Decouple the intra implicit transform selection from an inter MTS related SPS flag
#define JVET_O0163_REMOVE_SWITCHING_TMV 1 // JVET-O0163/JVET-O0588: Remove switching between L0 and L1 for temporal MV
#define JVET_O0655_422_CHROMA_DM_MAPPING_FIX 1 // JVET-O0655: modify chroma DM derivation table for 4:2:2 chroma format
#define JVET_O1109_UNFIY_CRS 1 // JVET-O1109: Unified CRS derivation
#define JVET_O0590_REDUCE_DMVR_ORIG_MV_COST 1 // Reduce the DMVR cost of the original MV
#define JVET_O0432_LMCS_ENCODER 1 // JVET-O0432: LMCS encoder improvement
#define JVET_O0429_CRS_LAMBDA_FIX 1 // JVET-O0429: fix encoder lambda rounding used in CRS
#define JVET_O0428_LMCS_CLEANUP 1 // JVET-O0428: LMCS cleanups
#define JVET_O0164_REMOVE_AMVP_SPATIAL_SCALING 1 // JVET-O0164/JVET-O0587: remove spatial AMVP candidate scaling
#define JVET_O0162_IBC_MVP_FLAG 1 // JVET-O0162/O0331/O0480/O0574: IBC mvp flag conditioned on MaxNumMergeCand>1
#define JVET_O0055_INT_DMVR_DIS_BDOF 1 // integer-distance DMVR cost to disable BDOF and disable BDOF early termination
#define JVET_O0277_INTRA_SMALL_BLOCK_DCTIF 1 // JVET-O0277: DCT-IF interpolation filter is always used for 4x4, 4x8, and 8x4 luma CB
#define JVET_O0267_IBC_SCALING_LIST 1
#define JVET_O0280_SIMD_TRIANGLE_WEIGHTING 0 // JVET-O0280: SIMD implementation for weighted sample prediction process of triangle prediction mode
#define JVET_O0364_PDPC_DC 1 // JVET-O0364 Part 4: align PDPC process for DC with the one for Planar
#define JVET_O0364_PDPC_ANGULAR 1 // JVET-O0364 Part 5: simplify PDPC process for angular modes
#define JVET_O0094_LFNST_ZERO_PRIM_COEFFS 1 // JVET-O0049: CE6-2.1a, LFNST involves zeroing of primary only coefficient positions
#define JVET_O0294_TRANSFORM_CLEANUP 1 // JVET-O0294: Context modelling for MTS index
#define JVET_O1124_ALLOW_CCLM_COND 1 // JVET-O1124/JVET-O0196: CCLM restriction to reduce luma-chroma latency for chroma separate tree
#define JVET_O0078_SINGLE_HMVPLUT 1 // JVET-O0078Single HMVP table for all CUs inside the shared merge list region for IBC
#define JVET_O0126_BPWA_INDEX_CODING_FIX 1 // JVET-O0126 align BPWA index coding with specification
#define JVET_O0592_ENC_ME_IMP 1 // JVET-O0592 encoder ME improvement
#define JVET_O0108_DIS_DMVR_BDOF_CIIP 1 // JVET_O0108 CE9-2.2: disable DMVR and BDOF for CIIP
#define JVET_O1140_SLICE_DISABLE_BDOF_DMVR_FLAG 1 // JVET-O1140 slice level disable flag for BDOF and DMVR
#define JVET_O0567_MVDRange_Constraint 1 // JVET-O0567: constrain the signalled MVD value to the range of [-2^17, 2^17-1]
#define JVET_O0596_CBF_SIG_ALIGN_TO_SPEC 1 // JVET-O0596 align cbf signaling with specification
#define JVET_O0193_REMOVE_TR_DEPTH_IN_CBF_CTX 1 // JVET-O0193/JVET-O0375: remove transform depth in cbf context modeling
#define JVET_O0594_BDOF_REF_SAMPLE_PADDING 1 // JVET-O0594/O0252/O0506/O0615/O0624: BDOF reference sample padding using the nearest integer sample position
https://www.sendspace.com/file/6w2ryp
Old 8th August 2019, 18:08   #134  |  Link
Jamaika
New VVC codec v5.2 08.08.2019
#define JVET_O0119_BASE_PALETTE_444 1 // JVET-O0119: Palette mode in HEVC and palette mode signaling in JVET-N0258. Only enabled for YUV444.
#define JVET_O0304_SIMPLIFIED_BDOF 1 // JVET-O0304: Reduction of number of multiplications in BDOF
#define JVET_O0455_IBC_MAX_MERGE_NUM 1 // JVET-O0455: Control the max number of IBC merge candidates independently from regular merge candidates
#define JVET_O0650_SIGNAL_CHROMAQP_MAPPING_TABLE 1 // JVET-O0650: Signal chroma QP mapping tables and move chroma PPS/slice offsets after mapping table
#define JVET_O0502_ISP_CLEANUP 1 // JVET-O0502: Enable PDPC and all 67 intra modes and apply the cubic filter always (also included in JVET-O0341) for ISP
#define JVET_O0640_PICTURE_SIZE_CONSTRAINT 1 // JVET-O0640: Picture width and height shall be a multiple of Max(8, minCU size)
#define JVET_O_MAX_NUM_ALF_APS_8 1 // JVET-O: number of ALF APSs is reduced to 8
#define JVET_O0925_MIP_SIMPLIFICATIONS 1 // JVET-O0925: Simplifications of MIP
#define JVET_O0070_PROF 1 // JVET-O0070 method 4-2.1a: Prediction refinement with optical flow for affine mode
#define JVET_O0570_GRAD_SIMP 1 // JVET-O0570/JVET-O0211, SMID friendly spatial gradient calculation
#define JVET_O1170_IBC_VIRTUAL_BUFFER 1 // JVET-O1170/O1171: IBC virtual buffer
#define JVET_O1170_CHECK_BV_AT_DECODER 1 // For decoder to check if a BV is valid or not
#define JVET_O0538_SPS_CONTROL_ISP_SBT 1 // JVET-O0538: SPS control for ISP and SBT transform
#define JVET_O0634_BDOF_SIZE_CONSTRAINT 1 // JVET-O0634: BDOF applied CU size align with DMVR
#define JVET_O0213_RESTRICT_LFNST_TO_MAX_TB_SIZE 1 // JVET-O0213: Block size restriction of LFNST to maximum transform size
#define JVET_O0617_SIG_FLAG_CONTEXT_REDUCTION 1 // JVET-O0617: Significant flag context reduction
#define JVET_O0244_DELTA_POC 1 // JVET-O0244: weighted prediction in SPS and delta POC
#define JVET_O1153_INTRA_CHROMAMODE_CODING 1 //JVET-O1153: simplified intra chromamode coding
#define JVET_O0159_10BITTCTABLE_DEBLOCKING 1 // tc table for 10-bit video
#define JVET_O0061_MV_THR_DEBLOCKING 1 // a deblocking mv threshold of half pel
#define JVET_O0220_METHOD1_SUBBLK_FLAG_PARSING 1 // JVET-O0220 method-1: Parse merge_subblock_flag conditioned on MaxNumSubblockMergeCand
#define JVET_O0263_O0220_SUBBLOCK_SYNTAX_CLEANUP 1 // JVET-O0263/ JVET-O0220: Syntax cleanup on subblock merge
#define JVET_O0060_4x4_deblocking 1 // deblock on 4x4 grid
#define JVET_O0046_DQ_SIGNALLING 1 // JVET-O0046: Move delta-QP earlier for 64x64 VPDU processing, applied to CUs >64x64 only
#define JVET_O0616_400_CHROMA_SUPPORT 1 // JVET-O0616: Various chroma format support in VVC
#define JVET_O0265_TPM_SIMPLIFICATION 1 // JVET-O0265/JVET-O0629/JVET-O0418/JVET-O0329/JVET-O0378/JVET-O0411/JVET-O0279:Simplified motion field storage for TPM
#define JVET_O0409_EXCLUDE_CODED_SUB_BLK_FLAG_FROM_COUNT 1 // JVET-O0409: exclude coded_subblock_flag from counting context-coded bins in transform skip
#define JVET_O0057_ALTHPELIF 1 //AMVR_HPEL
#define JVET_O0919_TS_MIN_QP 1 // JVET-O0919: Minimum QP for Transform Skip Mode
#define JVET_O0050_LOCAL_DUAL_TREE 1 // JVET-O0050: avoid small intra chroma block by a "local dual-tree" technique
#define JVET_O0526_MIN_CTU_SIZE 1 // JVET-O0526: Minimum CTU size 32x32
#define JVET_O0545_MAX_TB_SIGNALLING 1 // JVET-O0545: Configurable maximum transform size
#define JVET_O0379_SPEEDUP_TPM_ENCODER 1 // JVET_O0379: Speedup mode decision process for triangle prediction mode
#define JVET_O0364_PADDING 1 // JVET-O0364 Part 2: clean up padding process in intra prediction
#define JVET_O0681_DIS_BPWA_CIIP 1 // JVET-O0681 disable BCW for CIIP, method 2 inherit BCW index
#define JVET_O0249_MERGE_SYNTAX 1 // JVET-O0249: merge syntax change
#define JVET_O0376_SPS_JOINTCBCR_FLAG 1 // JVET-O0376: add the JointCbCr control flag in SPS
#define JVET_O0472_LFNST_SIGNALLING_LAST_SCAN_POS 1 // JVET-O0472: LFNST index signalling depends on the position of last significant coefficient
https://www.sendspace.com/file/2hd62d
https://jvet.hhi.fraunhofer.de/trac/vvc/ticket/428
WPP & SPLIT PARALLELISM options are not really maintained. Patches are still appreciated, but may be worked on only with very low priority.
Some comments:
JVET_O macros are normative changes. These can't just be turned off.
55:#include "mingw.mutex.h"
seems very platform specific.
Old 9th August 2019, 10:42   #135  |  Link
jonatans
Sorry for the late response. There was a press release after the Yokohama meeting: https://www.businesswire.com/news/ho...es-Work-Groups although it is only a very high level overview of the event - most of the actual work happens in the work groups.
Next MC-IF event will be held in Amsterdam during IBC: https://www.mc-if.org/ , direct link to: invitation letter
Jonatan Samuelsson
Co-founder and CEO at Divideon
www.divideon.com | xvc.io
jonatans is offline   Reply With Quote
Old 13th August 2019, 20:37   #136  |  Link
Adonisds
When do you think VVC will reach the market? When it does, will it be possible to use a PC with an old CPU to play AV1 and VVC videos if you buy a new video card?
Adonisds is offline   Reply With Quote
Old 13th August 2019, 23:24   #137  |  Link
hajj_3
It will be ratified by the end of 2020. Yes a new gpu that has a VVC hardware decoder would let you decode it smoothly.
Old 18th August 2019, 16:51   #138  |  Link
Jamaika
New VVC codec v6.0 18.08.2019 with application HDRTools and WPP & SPLIT PARALLELISM
https://gitlab.com/standards/HDRTools/tree/0.19-dev
https://www.sendspace.com/file/tx8jea
Old 27th August 2019, 09:39   #139  |  Link
iwod
It depends, AV1's software decoding is still progressing, but judging from the presentation, I still think VVC will be easier to decode than AV1, both in Hardware and Software.
Of course companies are waiting for licensing, which is what MC-IF was suppose to solve / improve. While there were no official announcement, I believe Velos Media wasn't listed in 2018, and it is now included in members page means All major player in the HEVC licensing are under MC-IF. Even those who refuse to participate with MPEG-LA or other patents pool are there as well like Technicolor.
This is a very encouraging sign. Hopefully the licensing terms will be out as soon as the codec get finalised.
Old 27th August 2019, 20:53   #140  |  Link
benwaggoner
It depends, AV1 is software decoding is still progressing, but judging from the presentation, I still think VVC will be easier to decode than AV1, but in Hardware and Software.
Of course companies are waiting for listening, which is what MC-IF was suppose to solve / improve. While there were no official announcement, I believe Velos Media wasn't listed in 2018, and now it has included in its members page means All major player in the HEVC licensing are under MC-IF. Even those who refuse to participate with MPEG-LA or other patents pool are here like Technicolor.
This is a very encouraging sign. Hopefully the listening terms will be out as soon as the codec is finalise.
Yeah, so much about AV1's future is dependent on codec licensing and businesss issues that AOM has no control over.
VVC will definitely offer better compression efficiency than AV1, and it seems increasingly probably it can do so with fewer MIPS/watts/mm^2 of silicon.
Of course, the more viable AV1 is, the more pressure there would be on VVC patent holders to come up with a clearer licensing story than HEVC has been dealing with.
Ben Waggoner
My Compression Book
