Old 8th October 2019, 00:41   #41  |  Link
Loomes
I tried to get a JSON from ffprobe to get sidedata information, but it seems the generated JSON ist malformed and therefore not convenient for further processing. My command:
ffprobe -read_intervals %+#2 -select_streams v:0 -show_frames -show_entries side_data "source.mkv" -print_format json -of json > "source_sidedata.json"
The resulting JSON looks like
    "packets_and_frames": [
            "type": "packet",
            "type": "packet",
            "type": "frame",
            "media_type": "audio",
            "stream_index": 1,
            "key_frame": 1,
            "pkt_pts": 171,
            "pkt_pts_time": "0.171000",
            "pkt_dts": 171,
            "pkt_dts_time": "0.171000",
            "best_effort_timestamp": 171,
            "best_effort_timestamp_time": "0.171000",
            "pkt_duration": 21,
            "pkt_duration_time": "0.021000",
            "pkt_pos": "313258",
            "pkt_size": "1522",
            "sample_fmt": "fltp",
            "nb_samples": 1024,
            "channels": 6,
            "channel_layout": "5.1"
Obviously the problem is the comma which is always set after the last line ""type": "packet" in the "packets_and_frames" section. ffprobe usually gives me proper JSON files but the comma problem appears when "-show_entries side_data" is used. Am I missing something or is this a bug?
Loomes is offline   Reply With Quote
Old 2nd March 2020, 21:57   #42  |  Link
Grojm
Hi, I want you to point to this discussion: https://trac.ffmpeg.org/ticket/7037#no1
There some user called "Balling" is referencing this thread multiple times; thinks there was a fix or something for a problem posted here, he got very upset that no one mentioned this here (he is not capable to post it himself for whatever reason). Yeah, so whatever... have a look yourself: https://trac.ffmpeg.org/ticket/7037#comment:60 https://trac.ffmpeg.org/ticket/7037#comment:74
Grojm is offline   Reply With Quote
Old 5th March 2020, 23:30   #43  |  Link
Balling
This was fixed in https://trac.ffmpeg.org/ticket/8228 in https://git.videolan.org/?p=ffmpeg.g...10ceeef46eb224
"not capable to post it himself for whatever reason" What a liar.
Balling is offline   Reply With Quote
