Old 14th November 2007, 16:35   #201  |  Link
avdw
Banned
Originally Posted by buzzqw View Post
@avdw
use the manual crop and use the preview
OK, that seems like the only trustable solution here. Too bad you have to open/close the Preview "movie" a couple of hundred times....
i am waiting your tool or your suggestion how to fix it
Seriously, I dunno, I thought there were so many different tools avaliable that do it correctly ? StaxRip's method works correctly. MeGUI's autocrop works too (A miracle, since it's about the only thing about it that DOES work)
what preset you used ?
"More Quality (7) = Less Speed 2Pass"
avdw is offline   Reply With Quote
Old 14th November 2007, 16:49   #202  |  Link
buzzqw
HDConvertToX author
mplayer way for detectcrop and megui/automkv AND even staxrip is very similar
every program will analyze some frames (picked all along the movie) and will detect crop
i "may" suppose that et start/END of your file there are some strange black bars...
EDIT: maybe i found your cause of oversize.. please try this build http://www.64k.it/andres/data/automen/AutoMen34a.exe
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
Old 14th November 2007, 17:15   #203  |  Link
blizard
Originally Posted by avdw View Post
Just some simple observations :
1) AutoMen "Detect Crop" suffers from the same disease as AutoMKV's and Auto Gordian Knot's "AutoCrop" , they crop too much, thus cropping away movie content.
..... So, with all these tools, there is something SERIOUSLY WRONG !
First of all, just because something look black at your screen doesn't mean that it is really black in the digital world. There are different level of compression for colour (YV12, YUY2 etc) and it is also possible that some noise are involved which might confuse MPlayer in what cropping value that will work best. Then it is possible that there is a logo or subtitle that is interfering with black vs film border. In other words, it is better to make sure that you crop the correct picture.
2) Setting a Target size of 700MB results in a final AVI which is 711MB and thus does NOT fit on 1 CD.
AVI container do have an overhead which might be part of the problem as MENcoder was designed to work with AVI containers from the very beginning and not MP4 or any other containers of today. That is why you will also see all this "junk" in target folder after MENcoder have first made sound and audio encoded material directly into an AVI container and then need to de-mux it into another container after transcoding are finished.
AVI overhead
3) (Probably due to MEncoder) Why does the final AVI file contains tµhat much junk ?
blizard is offline   Reply With Quote
Old 14th November 2007, 21:31   #204  |  Link
avdw
Banned
BHH
Same problem.
Old 14th November 2007, 22:05   #205  |  Link
buzzqw
HDConvertToX author
thanks for your test
i will reckeck bitrate computing
BHH
Old 14th November 2007, 22:12   #206  |  Link
avdw
Banned
BHH
Hi buzz,
Perhaps you could check AutoMKV too, it suffers from the same problem
Old 15th November 2007, 08:27   #207  |  Link
blizard
Buzz,
Is it possible to make a profile that would play in my cell phone with 320 x 240 display? It is an Sony Ericsson P1i and should handle both MP4 and 3GP containers with Xvid and AAC sound. From MediaInfo I get this info for a file that work in my phone. It might be better to use a lower FPS to save some work load during play back of file, but it looks good on display. I would prefer stereo for AAC LC sound as this file seem to be mono (only one channel).
I have tried to change PSP and make use of Xvid profile without any luck. Would be great if you could help me out of this.
[HTML] General #0
Count : 177
Count of stream of this kind : 1
Kind of stream : General
StreamKindID : 0
Count of video streams : 1
Count of audio streams : 1
Count of text streams : 0
Count of chapter streams : 0
Codecs Video : MPEG-4 Visual
Audio codecs : AAC LC
Complete name : P:\svt071114aktuellt21.mp4
Folder name : P:
File name : svt071114aktuellt21
File extension : mp4
Format : MSNV
Format : MPEG-4
Format/Info : Sony PSP
Format/Family : MPEG-4
Format/Url : http://www.sony.com/
Format/Extensions : mp4
Codec : MSNV
Codec : MPEG-4
Codec/Info : Sony PSP
Codec/Family : MPEG-4
Codec/Url : http://www.sony.com/
Codec/Extensions : mp4
File size : 170284377
File size : 162 MiB
File size : 162 MiB
File size : 162 MiB
File size : 162 MiB
File size : 162.4 MiB
PlayTime : 1800133
PlayTime : 30mn 133ms
PlayTime : 00:30:00.133
Bit rate : 756763
Bit rate : 757 Kbps
StreamSize : 401071
StreamSize : 392 KiB
StreamSize : 391.7 KiB
Encoded date : UTC 2007-11-14 20:58:19
Tagged date : UTC 2007-11-14 20:58:19
Video #0
Count : 74
Kind of stream : Video
StreamKindID : 0
Codec : MPEG-4V
Codec : MPEG-4 Visual
Codec/CC : 20
Codec settings/BVOP : No
Codec settings/QPel : No
Codec settings/GMC : 0
Codec settings/Matrix : Default
PlayTime : 1800133
Bit rate : 691308
Bit rate : 691 Kbps
Bit rate mode : VBR
Width : 320
Width : 320 pixels
Height : 240
Height : 240 pixels
Aspect ratio : 1.333
Aspect ratio : 4/3
Frame rate : 29.970
Frame rate : 29.970 fps
FrameCount : 53950
Resolution : 8
Resolution : 8 bits
Interlacement : PPF
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.300
StreamSize : 155555839
StreamSize : 148 MiB
StreamSize : 148.3 MiB
Audio #0
Count : 60
Kind of stream : Audio
StreamKindID : 0
Codec : A_AAC/MPEG4/LC
Codec : AAC LC
Codec/Info : AAC Low Complexity
Codec/CC : 40
PlayTime : 1790933
PlayTime : 29mn 50s
PlayTime : 29mn 50s 933ms
PlayTime : 29mn 50s
PlayTime : 00:29:50.933
Bit rate : 64000
Bit rate : 64 Kbps
Bit rate mode : CBR
Channel(s) : 1
Channel(s) : 1 channel
Sampling rate : 24000
Sampling rate : 24 KHz
SamplingCount : 42982392
Resolution : 16
Resolution : 16 bits
StreamSize : 14327467
StreamSize : 13.7 MiB
StreamSize : 14 MiB
StreamSize : 14 MiB
StreamSize : 13.66 MiB
[/HTML]
Old 15th November 2007, 09:10   #208  |  Link
buzzqw
HDConvertToX author
update to 3.5 , link in first post
fixed: bitrate computing now take overhead in account
added: copy audio for XVID and FF4 profile
@blizard
actually i use this "profile" for my Nokia E65
"mencoder.exe" -vf harddup,crop=720:432:0:72,scale=320:-3,hqdn3d -sws 2 -priority idle -o "_aaa_automen.avi" -ovc xvid -xvidencopts bitrate=552:pass=1:turbo:max_bframes=0:vhq=1:me_quality=6:chroma_me:chroma_opt:hq_ac:trellis:lumi_mask:bvhq=1 -nosound  "_aaa.vob"
"mencoder.exe" -vf harddup,crop=720:432:0:72,scale=320:-3,hqdn3d -sws 2 -priority idle -o "_aaa_automen.avi" -ovc xvid -xvidencopts bitrate=552:pass=2:max_bframes=0:vhq=1:me_quality=6:chroma_me:chroma_opt:hq_ac:trellis:lumi_mask:bvhq=1 -nosound  "_aaa.vob"
mplayer "_aaa.vob" -quiet -vc null -vo null -ao pcm:fast:waveheader:file=audio.wav
normalize.exe audio.wav
enc_aacPlus.exe audio.wav audio.aac --cbr 64000 --lc
"mp4box.exe" -add "_aaa_automen.avi"#video -add "audio.aac"#audio -keep-all -fps 25.000 "_e65.mp4"
i must use enc_aacPlus.exe because audio done by mencoder isn't fully compatible ..
anyway i am looking for a new way to handle profiles (but it's a long term project)
BHH
Old 17th November 2007, 03:30   #209  |  Link
blizard
@blizard
BHH
Where can I find enc_aacPlus.exe? I can only find different references to outdated storage places and I don't wish to install winamp, if that is possible to avoid.
So far I have mange to get a Xvid encoded picture to show after forcing output in resize of 320:240 (didn't work with 320:-2) in your profile for Xvid.bat. It seems to be that sound is not working when encoded in MEncoder. I can play this video on all other player on my computer (FFDSHOW/VLC w FFMPEG), so I think there is some limits to how my phones capabilities to decode AAC work. H.264 doesn't work well at all, but did show some jumpy picture with a podcast that was encoded in H.264, so my phone should be able to use some features of H.264 as long as it is light on resources to decode.
All those expriments was done with MP4 container.
I will try out your setting from nokia later, but for now it seem to be that I only need to get sound to work.
Thank you for your effort to help me in finding out these matter.
Old 17th November 2007, 04:09   #210  |  Link
Dkruskie
You can find it here
http://www.box.net/public/c1mrbbcq7g
I googled it and it was on the bottom of the first page
Dkruskie is offline   Reply With Quote
Old 17th November 2007, 09:49   #211  |  Link
buzzqw
HDConvertToX author
you can find enc_aacPlus.exe, enc_aacplus.dll and nscrt.dll in \exe\besweet folder of automkv
BHH
Old 19th November 2007, 13:13   #212  |  Link
buzzqw
HDConvertToX author
update to 3.6
fixed preview of telecined film
fixed manual bitrate with some audio settings
added option to force 4cc to DIVX for FF4 encoding, so the avi will be SAP compatible
BHH
Old 19th November 2007, 16:56   #213  |  Link
weaver4
Very cool!
weaver4 is offline   Reply With Quote
Old 19th November 2007, 17:14   #214  |  Link
Dkruskie
update to 3.6
BHH
Thanks buzzqw
Old 19th November 2007, 17:23   #215  |  Link
buzzqw
HDConvertToX author
to all!
it's my pleasure!
BHH
Old 20th November 2007, 14:19   #216  |  Link
bowo
Hello,
Thanks for all this great work
'Know that it exist a queue but trying to encode all my HI8 files (actually in mpg) in divx...
Do you thing it'll possible to select a txt file (inluding the name of all the files to encode), then select parameters (sames for all the files) then click a DoIt button and Automen encode all the files ?
I Ask this because i have 2800 files :-)
Thanks for all
BoWo
bowo is offline   Reply With Quote
Old 20th November 2007, 14:31   #217  |  Link
buzzqw
HDConvertToX author
@bowo
First of all Welcome to the Forum!
.. 2800 files ??? ouch.. actually not possible
i can search a simply way (already have some ideas).. but.. don't know when will be applied
BHH
Old 24th November 2007, 21:38   #218  |  Link
weaver4
I am having a problem where automem won't run at all.
I am single pass mp4. With the progressive filter.
Here is the command line from mp4.bat file and the result:
"C:\Tools\AutoMem\mencoder.exe" -ofps 24000/1001 -vf harddup,crop=720:352:0:62,scale=640:-2,hqdn3d -sws 2 -priority idle -o "D:\Movies-H264\VTS_05_PGC_01_1_automen.avi" -ovc x264 -x264encopts crf=18:threads=auto:frameref=3:bframes=2eblock:direct_pred=auto:level=41artitions=none:me=hex:me_range=8:subq=5:chroma_me:mixed_refs:brdo:bime:trellis=0:weight_b:nr=0 -aid 128 -af volnorm=2 -oac faac -faacopts br=96:mpeg=4bject=1 -channels 2 "D:\aa-Rips\Transformers.PGC\VTS_05_PGC_01_1.VOB"
D:\Movies-H264>"C:\Tools\AutoMem\mencoder.exe" -ofps 24000/1001 -vf harddup,crop
rames=2:Deblock:direct_pred=auto:level=41:partitions=none:me=hex:me_range=8:subq
 -oac faac -faacopts br=96:mpeg=4:object=1 -channels 2  "D:\aa-Rips\Transformers
MEncoder Sherpya-SVN-r25088-4.2.1 (C) 2000-2007 MPlayer Team
CPU: Intel(R) Core(TM)2 Duo CPU     E4500  @ 2.20GHz (Family: 6, Model: 15, Step
ping: 13)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled with runtime CPU detection.
Option lavfopts: Unknown suboption i_certify_that_my_video_stream_does_not_use_b
_frames
Warning unknown option lavfopts at line 48
_frames
Warning unknown option lavfopts at line 60
_frames
Warning unknown option lavfopts at line 72
_frames
Warning unknown option lavfopts at line 97
Option x264encopts: Unknown suboption Deblock
Setting process priority: idle
success: format: 0  data: 0x0 - 0xffff0000
MPEG-PS file format detected.
VIDEO:  MPEG2  720x480  (aspect 3)  29.970 fps  9800.0 kbps (1225.0 kbyte/s)
[V] filefmt:2  fourcc:0x10000002  size:720x480  fps:29.97  ftime:=0.0334
Opening audio decoder: [liba52] AC3 decoding with liba52
Using SSE optimized IMDCT transform
Using MMX optimized resampler
AUDIO: 48000 Hz, 2 ch, s16le, 448.0 kbit/29.17% (ratio: 56000->192000)
Selected audio codec: [a52] afm: liba52 (AC3-liba52)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [hqdn3d]
Opening video filter: [scale w=640 h=-2]
Opening video filter: [crop w=720 h=352 x=0 y=62]
Crop: 720 x 352, 0 ; 62
Opening video filter: [harddup]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred colorspace: Mpeg PES)
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
Try appending the scale filter to your filter list,
e.g. -vf spp,scale instead of -vf spp.
VDecoder init failed :(
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
VDec: vo config request - 720 x 480 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
SwScaler: reducing / aligning filtersize 6 -> 8
SwScaler: reducing / aligning filtersize 7 -> 6
[swscaler @ 00D73510]SwScaler: BICUBIC scaler, from yuv420p to yuv420p using MMX
2
[swscaler @ 00D73510]SwScaler: using 8-tap MMX scaler for horizontal luminance s
caling
[swscaler @ 00D73510]SwScaler: using 8-tap MMX scaler for horizontal chrominance
 scaling
[swscaler @ 00D73510]SwScaler: using n-tap MMX scaler for vertical scaling (YV12
 like)
[swscaler @ 00D73510]SwScaler: 720x352 -> 640x264
FATAL: Cannot initialize video driver.
Exiting...
D:\Movies-H264>
Old 24th November 2007, 22:07   #219  |  Link
avdw
Banned
This is some real funny command-line !
Old 24th November 2007, 22:44   #220  |  Link
buzzqw
HDConvertToX author
update 3.7 http://www.64k.it/andres/data/automen/AutoMen37.exe
FIXED: Deblock (with D capitalized). only happen on 1 specific profile ) thanks to weaver4
ADDED: Support for List of file.
Drag and drop a file.txt with your file to encode (do this by dir /S/B *.vob > list.txt for example) and the same settings will be applied to all files (suggestion by bowo)
BHH
automen, ffmpeg, handbrake, mencoder, x264
