Old 3rd August 2019, 17:30   #28641  |  Link
gonca
Originally Posted by cartman0208 View Post
Actually I was just playing with the settings
So, it is reasons 2 & 3
Could you come up with something for compatibility so I am 3/3?
Old 3rd August 2019, 17:31   #28642  |  Link
Originally Posted by FilipeAmadeuO View Post
@jdobbs
I am trying to rebuild a UHD in order to replace on subtitle/sup file by another with diferent languague (from BD) without reencoding.
Just on the process i have the following error:
"BD Rebuilder experienced an error 1802
UHD_Correct_M2TS() 00006 8102"
I tried to replace the 00062.track_4771.sup subtitle before the m2ts is created. Any sugestion or idea why this error happens ?
All I can tell from that is that it is an overflow error. I'd need more information to figure out why.
Old 3rd August 2019, 17:35   #28643  |  Link
BD Rebuilder v0.60.18
I've updated the first post of this thread with a link to the latest release of BD-RB. Changes for this version:
August 3rd, 2019 - v0.60.18
- Corrected an issue in which attempting to
  reencode an imported UHD pseudo-BD that
  was encoded in a format other than HEVC
  causes a "UHD_Correct_M2TS() 00009  8102"
  error during BD-RB'S UHD correction.
August 1st, 2019 - v0.60.17
- Added muxing routines that remux HEVC
  UHD M2TS files, recover lost frames, and
  corrects TSMUXER timing issues. Please
  remember that UHD capability is still
  under development and may need further
  work.
- Corrected an error in which imported input
  files that have SRT files muxed in a
  format other than sequential might set
  languages incorrectly or even fail during
  output to ALTERNATE formats.
- Corrected an error in which attempts to
  extract HEVC secondary streams could
  cause BD-RB to fail.
- Added a check during start-up that will
  prevent a "Runtime Error 52" issue when
  some network or other paths previously
  specified are not reachable.
- Made changes that correct audio sync
  issues when outputting to UHD-BD.
- Created a workaround for issues in which
  the combination of X265 and TSMUXER can
  cause stutter issues at higher bitrates.
- Added hidden option FIXED_BITRATE which
  is similar to FIXED_CRF.  If set, the
  source will be reecoded at that bitrate
  and any output sizing control is removed.
- Corrected an issue that could result in
  audio sync problems after reencode of
  certain imported sources.
- Corrected an issue in which imported SRT
  files that start at offset 0 could, under
  certain conditions, clear the first spoken
  subtitle.
- Fixed an issue in which the ALTERNATE_BLURAY
  hidden setting was allowing long keyint
  sequences (outside bluray compatibility).
  This can be overridden by turning it off or
  setting a fixed vKeyint value in the
  ALTERNATE.TXT preset being used.
- Added code to perform MPA to AC3 conversion
  during DVD import. MPA is not supported in
  BD format and was previously ignored.
- Added OGG Vorbis as a legal audio format for
  imported video files (converted to AC3).
- Updated the included version of X264-64.EXE
  to  the latest release (r2969).
- Updated the included version of X265-64.EXE
  to v3.1+1 10 bit version.
NOTES:
1. DOLBYVISION is not yet supported.
2. All UHD code is still experimental.
I noticed a bug shortly after I posted V0.60.17... so I thought I'd fix it and post an update.
Old 3rd August 2019, 17:41   #28644  |  Link
AmigaFuture
AmigaFuture's Avatar
@ MrVideo
DVD is still in the minds of people before Blu-ray players. I talk with people in stores. People looking for interesting new ideas, products..but as cool as BD resolution is, the prices are still high [to them]. Often I also still hear, "I don't see any difference." "Some kind of fancy Upper scaling or something like that?" So, it's DVD players that are bought...lots and lots where I live. Some people come to my residence and get to see Blu-ray in action, and then I go into some depth with them, displaying DVD vs Blu-ray..since a lot of movies came/come with both. The hype does not exceed the people's understanding in this area. It takes a while for minds to change and venture.
When you're around this stuff a lot, you can alter your awareness that not everyone is keenly into newer tech or willing to spend the money on it. Particular "belief systems" are still dominant around the world, though we know so much more now...and meditation is very helpful to the mind, but that's also...still slow to catch on.
I have friends who also have Blu-ray players but only buy DVDs "For now. Maybe some time I'll get into Blu-ray, but DVDs are still a lot cheaper."
Old 3rd August 2019, 17:48   #28645  |  Link
But, on the other hand, the post being discussed was about creating BD-5/9 output on DVD media. That won't play on a DVD player, it requires a BD player.
When I first created BD-RB a blank DVD-R was a lot cheaper than a blank BD-R. These days BD-R media has gotten so cheap that there rarely is a need to create a BD-5/9. But that's in my little world in my little section of the planet -- so it's still supported to make sure I cover all bases.
Old 3rd August 2019, 18:29   #28646  |  Link
MrVideo
MrVideo's Avatar
I don't remember for sure if it is the old (not connected) Sony player, or the Samsungs that I have, but the player refused the BD authored DVD disc because it wasn't on BD media. So, creating a BD5/9 doesn't mean that your BD player will play it.
Old 3rd August 2019, 18:56   #28647  |  Link
Sharc
My Samsung player refused to play DVD5/9 which played fine with my old SONY player (BDP-S360), so I had to re-author these for BD25, putting 3 to 4 BD5 on one BD25 using BD-RB.
I didn't try strict AVCHD on BD5/9 as there was no cost advantage any more.
Old 3rd August 2019, 19:38   #28648  |  Link
zamengo
I've updated the first post of this thread with a link to the latest release of BD-RB. Changes for this version:[code]August 3rd, 2019 - v0.60.18
Thanks for .18, but I still got this error:
- [13:49:23] Multiplexing M2TS
- [14:17:50] UHD_Correct_M2TS() 00009 8102
zamengo is offline   Reply With Quote
Old 3rd August 2019, 20:01   #28649  |  Link
FilipeAmadeuO
Movie was STAR WARS SOLO 4k and I was trying to replace Korean subtitles by the Portuguese subtitles extracted from BD.
What info can I send to help ?
Same error happens with v0.60.18
It happens at 99,98% of the Adjusting files for UHD-BD format...
FilipeAmadeuO is offline   Reply With Quote
Old 3rd August 2019, 20:35   #28650  |  Link
zamengo
Me too, but with Avengers Endgame.
I trying without reencode, with no success.
But now I will try with a full encode.
Old 4th August 2019, 00:02   #28651  |  Link
84lion
Any idea why this is happening? This also happens with other seamless branching titles (e.g. - The Martian Extended Edition).
[08/03/19] BD Rebuilder v0.60.18
[18:59:38] Source: GLADIATOR_2000_00391
- Input BD size: 76.55 GB
- Approximate total content: [02:50:56.829]
- Target BD size: 46.26 GB
- Windows Version: 6.2 [9200]
- MOVIE-ONLY mode enabled
- Quality: Very Good (Very Fast), ABR
- Decoding/Frame serving: FFMPEG
[18:59:41] PHASE ONE, Encoding
- [18:59:41] Processing: VID_00498 (1 of 22)
- [18:59:41] Extracting A/V streams [VID_00498]
- Error in attempt to extract audio/subs.
- Can't parse play list file "X:\GLADIATOR4KBR\GLADIATOR_2000\BDMV\\PLAYLIST\00391.mpls"
[18:59:45] - Failed to retrieve audio, aborted
84lion is offline   Reply With Quote
Old 4th August 2019, 03:41   #28652  |  Link
Yeah. Most accept it, but not all. I think pretty much all will accept it in strict AVCHD format. But, as you mentioned, there's not a lot of incentive to do BD-5/9 these days with a 50 pack of high-end (Verbatim) BD-R blanks costing less than $40.
Old 4th August 2019, 03:54   #28653  |  Link
The problem with debugging these UHD reports is that even if I know the disc name, I have no way of getting my hands on them so I can try to repeat/fix the problem.
Old 4th August 2019, 04:40   #28654  |  Link
That error is coming from TSMUXER when it is trying to demux using the MPLS. I don't think I've see that before.
Old 4th August 2019, 06:44   #28655  |  Link
CV91913
Is the directory tree BDMV\\PLAYLIST a valid path?
CV91913 is offline   Reply With Quote
Old 4th August 2019, 08:09   #28656  |  Link
Acerjen
Jdobbs,
Do you have any UHD discs? Which ones? Just curious.
Acerjen is offline   Reply With Quote
Old 4th August 2019, 10:09   #28657  |  Link
MrVideo
MrVideo's Avatar
https://www.ebay.com/itm/100-OQ-6x-2...72.m2749.l2649
I print on the discs. Inkjet printing doesn't come close to professional printing, but it is better than nothing.
Old 4th August 2019, 13:44   #28658  |  Link
Good catch. I didn't notice that.
Old 4th August 2019, 13:50   #28659  |  Link
Originally Posted by Acerjen View Post
Jdobbs,
Yes, of course, just for testing. But very few. They all work with BD-RB... I also have 4K MKVs that I have created for testing of imports.
Old 4th August 2019, 13:57   #28660  |  Link
84lion
Yeah, that looks like the problem. I don't know why the program is evidently inserting the extra forward slash. I'm not doing it, at least knowingly. Is there any way to specify the directory tree in BD-Rebuilder?
Also had this problem this morning - everything purring along beautifully and then...so close to completion...
[20:07:25] Source: HULK_UHD_UPK1_00801
- Input BD size: 80.29 GB
- Approximate total content: [02:18:06.444]
- Quality: Better (Faster), ABR
[20:07:32] PHASE ONE, Encoding
- [20:07:32] Processing: VID_00026 (1 of 1)
- [20:07:32] Extracting A/V streams [VID_00026]
- [20:13:58] Reencoding video [VID_00026]
- Source Video: HEVC, 3840x2160
- Rate/Length: 23.976fps, 198,676 frames
- Bitrate: 35,000 Kbs
- [20:13:58] Reencoding: VID_00026, Pass 1 of 1
- [08:35:56] Video Encode complete
- [08:35:56] Processing audio tracks
- Track 4357 (eng): Keeping original audio
[08:38:16]PHASE ONE complete
[08:38:16]PHASE TWO - Rebuild Started
- [08:38:16] Rebuilding BD file Structure
- Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta
- Bitstream exception Unknown exception. It does not have to be! Please contact application support team for more information.
[08:38:31] - Failed to REBUILD
And Jdobbs - for all the great work you do. I appreciate it!
