27th October 2018, 10:12 | #361 | Link |
gMKVExtractGUI author
Hi people! I just release a new version (v2.4.0) to address the issues introduced with v2.3.0.
Download link: https://sourceforge.net/projects/gmk....0.7z/download Changelog:
As always, enjoy people! |
9th November 2018, 20:21 | #365 | Link |
Dear gpower2,
When I try to extract an image attachment from a MKV container, the module gMKVToolNix.dll throws me an error stating that "the file ...cover.jpg" could not be opened for writing:create_directory() failed. When I replace the said gMKVToolNix.dll with 2.3.0 version, the error disappears, and the image extracts fine. Could this just be happening on my system? Thanks! |
15th November 2018, 09:40 | #367 | Link |
Hi there,
I'd like to make a request for gMKVExtractGUI. That is, to zero-pad track numbers. Current example: _track8_ Future example: _track08_ The reason is simple: so they would show up in correct order in my file manager. (08,09,10,11 instead of 10,11,8,9) Thank you!
Best regards: Csimbi |
17th November 2018, 07:48 | #368 | Link |
Hi Gp2, is it possible to add an option to extract tracks with its title property? Especially useful for subs (forced subs, sdh etc) and audio (lossless, lossy, different channels mix etc) where there are multiple of them in the same language and currently it's not easy to differentiate them by name.
An option to extract based on number of chapters/attachments entries each file has would also be very useful! Last edited by dissory; 21st November 2018 at 23:31. |
21st November 2018, 09:29 | #369 | Link |
Hi!
gMKVExtractGUI 2.4.0.0 mkvtoolnix 28.2.0 (x64) Win 7 x64 Ultimate If one item is selected, there is no problem. https://i.imgur.com/uFztT6V.png If two or more items are selected, then an error. https://i.imgur.com/forsNZd.png https://i.imgur.com/BXDaUU6.png |
16th December 2018, 17:12 | #371 | Link |
Your OS installation must be corrupted. It's definitely not gMKVExtractGUI's fault.
You can see more info about your error here: https://stackoverflow.com/questions/...rectory-dialog |
18th January 2019, 17:34 | #372 | Link |
Acid fr0g
I have a strange issue, probably not due to gMKVExtractGUI but to MKVInfo.
Get a m2ts stream from a BD, containing video track and huge audio (DTSHD or similar). Drag into MKVToolnix and select just a couple of those audio tracks, no video. A .mka will be output. Now try to drop into gMKVExtractGUI. When a mkv it takes only a few seconds to display tracks, when mka it takes ages or simply crashes, leaving MKVInfo as appended process.
@turment on Telegram |
2nd February 2019, 13:51 | #373 | Link |
Anime addict
Hi, I found bug with path file when trying extract attachments.
https://www.dropbox.com/s/rcbv3k0rl5...oject.mp4?dl=0
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
3rd February 2019, 12:30 | #374 | Link |
Hi everyone, time for a small fix version! As some of you reported, v2.4 had broken attachment extraction. I had this fixed in 2018, however I never released a new version, silly me!
Download link: https://sourceforge.net/projects/gmk....1.7z/download Changelog:
Enjoy people! |
5th February 2019, 12:57 | #375 | Link |
Anime addict
Thanks for fixing it.
6th February 2019, 18:53 | #377 | Link |
Hi tormento,
Are you using latest version of gMKVExtractGUI? I believe that mkvinfo is not being used after v1.9.0 or something like that, so it is really curious that you see mkvinfo.exe hanged. Have you tried waiting for mkvinfo to finish? EDIT: I think I found what is happening here... gMKVExtractGUI attempts to find the track delays, assuming the video track as an anchor. However, there is no such need in matroska files that don't contain any video tracks. New version coming soon... EDIT2: New version is up! I think that the issue is now fixed! Thanks for your feedback! Download link: https://sourceforge.net/projects/gmk....2.7z/download Changelog
7th February 2019, 16:13 | #378 | Link |
Thanks gpower for the continuing work on the software, since the old MKVExtractGUI2 is no longer maintained your MKVExtractGUI is pretty much the only game in town...
Talking about track delays one of the differences to the old GUI is that your software determines the delays and writes the audio delay value into the extracted audio file name. And this feature keeps confusing me over and over. I am used to how this works for MPEG2 files. Demux the file with DGIndex, the delay value gets written into the file name. Remuxing this audio file with the M2V video track (using MuxMan or Cuttermaran) the audio delay is read from the file name, and the muxing process honors this delay value. This results in a new MPEG2 file in perfect sync. With gMKVExtractGUI and MKVToolnix this is very different. The delay value is also written into the extracted audio file name, and when remuxing this audio track into a new MKV using MKVMerge the delay value is also detected and honored in the muxing process. BUT THIS IS WRONG. The resulting MKV will be out of sync. To get a new MKV without sync problems the audio delay value needs to be ignored. Either set the delay to 0 in the MKVToolnix GUI, or remove the delay value from the audio track name. Do you have an explanation for this? Could it be that mkvextract.exe corrects any delays before extracting tracks? Cheers manolito Last edited by manolito; 7th February 2019 at 16:15. |
7th February 2019, 16:56 | #379 | Link |
Hi manolito, thanks for your kind words, I really appreciate it!
As for the delays, it's been thoroughly discussed in this thread, the effective delay is required in order to re-merge the tracks and be in sync with each other. |
7th February 2019, 20:16 | #380 | Link | |
Please have a look at this file: https://www.sendspace.com/file/dsauzo It is a real world DVB-T2 captured clip, I deal with such clips every day. It comes in an MTS container, I repacked it to MKV using the latest MKVToolnix. It has a huge audio delay, but it plays in perfect sync in all my software players. Next thing I did was extracting the audio track with gMKVExtractGUI. The filename of the extracted track was "test_track2_[mis]_DELAY -1446ms.aac". Then I remerged this extracted audio file into the original MKV. In my uploaded MKV this remerged audio track appears as audio track #2. Now please play this file in any software player which allows to switch audio tracks during playback. What do you think about the audio sync for track #2? Sorry I only found a German channel where lip sync can be judged, but I think you can get the idea without speaking German. For the files I regularly work with the audio delay feature in gMKVExtractGUI does not work, I always need to turn it off. Cheers manolito |
extractor, gmkvextractgui, matroska, mkv, mkv extract, mkvextract, mkvextractgui |
