20th July 2020, 23:12 | #18621 | Link | |
when i want to mux it to dvhe.04, muxer will fail, as BL has different number of frames as EL+RPU... so it is a problem.. without HDR10+ metadata, encode has the same exact frame numer... so problem would be in x265, whe used with HDR10+ JSON
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD |
20th July 2020, 23:31 | #18622 | Link |
Is frame number correctly detected in ripbot?
Is frame number correctly displayed in x265 during encoding?
20th July 2020, 23:47 | #18623 | Link |
yes and yes. but output is not correct. it doesn't matter which GUI i use... always few frames missing at the end. without HDR10+ JSON everything is OK, encoded with the same JSON but with nVidia GPU, frames are OK.
28th July 2020, 14:15 | #18624 | Link |
Hi
What could be the reason why the Encoding server won't start up correctly? In 9 out of 10 reboots the encodingserver process shows in taskmanager but I do not see the tray icon and whenever this happens the encoding client can't connect. thx for any help |
28th July 2020, 16:27 | #18625 | Link |
Some application running in background (from MSI/Gigabyte/Logitech and so on) blocks encodingserver.exe. Known issue. There is nothing I can do about that because that is not my fault.
29th July 2020, 13:19 | #18627 | Link |
Auto Cropping and 4K
Atak, can an option be added for a number of threads to open for cropping or to limit it based on memory. Using auto cropping with 4K will use up 16GB of memory and Windows will kill other processes, including the Encoding Client.
I'm having to use manual cropping for 4K if I don't want processes killed. |
3rd August 2020, 14:33 | #18628 | Link |
I'm having a slight issue with colors, specifically skin tones. For some reason, when I encode with RipBot, it's altering the colors slightly on the video, and I cannot figure out why.
Here is an example: https://imgsli.com/MjAwMTM The encoded video makes the skin look slightly orange. Other colors are affected as well, but the skin is the most noticeable. I'm not using any settings that would change the colors, so I'm not sure what the deal is. |
3rd August 2020, 14:35 | #18629 | Link | |
3rd August 2020, 15:43 | #18630 | Link |
Original
Video ID : 1 ID in the original source medium : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings : CustomMatrix / BVOP Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=12 Format settings, picture structure : Frame Codec ID : V_MPEG2 Codec ID/Info : MPEG 1 or 2 Video Duration : 24 min 21 s Bit rate mode : Variable Bit rate : 4 412 kb/s Maximum bit rate : 9 000 kb/s Width : 720 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.426 Time code of first frame : 00:59:59:00 Time code source : Group of pictures header GOP, Open/Closed : Open GOP, Open/Closed of first frame : Closed Stream size : 769 MiB (92%) Language : English Default : No Forced : No Original source medium : DVD-Video Encoded Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L3@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 24 min 21 s Bit rate : 1 477 kb/s Width : 632 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.162 Stream size : 257 MiB (79%) Writing library : x265 3.2+34-8e6db24c1517:[Windows][GCC 9.2.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=4 / numa-pools=+ / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=632x480 / interlace=0 / total-frames=1797 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=30 / keyint=300 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=0 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=16 / min-cu-size=8 / no-rect / no-amp / max-tu-size=16 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=9 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / selective-sao=4 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=18.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=16 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 |
4th August 2020, 07:12 | #18631 | Link |
DVD video usually has color primaries BT.601, as usual for "vintage" media with SD resolutions. Between BT.601 and BT.709, you will experience some green/red shift: see http://avisynth.nl/index.php/Colorimetry
The simple solution should be to tell the encoder to flag its encoded output as BT.601 (or Rec601). Last edited by LigH; 4th August 2020 at 07:14. |
4th August 2020, 12:11 | #18632 | Link | |
Grumpy Old Man.
Either a Custom Script or modding one ???
8th August 2020, 11:20 | #18633 | Link |
Over the last week the Output Speed option has started giving problems. If I use any setting other than default then
After which the script goes directly to the final re-encode and shows 'Error: The file 'H:\Temp\RipBot264temp\job2\video.265' could not be opened for reading: open file error.' Re-setting Output Speed to default allow the program to run. I use this option where I have used MkvCutter to edit and re-encode the start of a video. As it re-encodes at 24 fps regardless of the speed of original, I need to use the Output Speed to prevent the audio and video being out of sync. I have tested on the same video, before and after using MkvCutter, in each case RipBot264 runs normally if Output Speed is default and fails for any other setting. |
8th August 2020, 13:12 | #18634 | Link | |
Grumpy Old Man.
Have you heard of VideoRedo or AviDemux ?? https://www.videohelp.com/software/s...itors-h264-avc
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 8th August 2020 at 13:19. |
8th August 2020, 13:57 | #18635 | Link | |
8th August 2020, 14:01 | #18636 | Link | |
Grumpy Old Man.
There's not a lot going on with RB, atm, unfortunately.
10th August 2020, 03:59 | #18637 | Link |
Another minor potential improvement idea:
When you enter the AviSynth menu and immediately exit it without changing the settings (I do it all the time to double check I didn't forget to setup denoising, etc.), the program still hangs for a while with the "Please Wait...Gathering Information..." tooltip. Usually it's quick, but in some cases the waiting process can take a while. Theoretically (and again, without knowing the internal workings of the program), it should be very easy to set up a quick boolean flag code for tracking changes and allow exiting the menu without any delays or updates if no changes were made. Not sure if you want to bother with this one, but as a loyal and dedicated user of your software I'll just keep throwing every minor flaw or room for improvement I can find out there in case they may interest you. |
10th August 2020, 08:00 | #18638 | Link | |
Grumpy Old Man.
23rd August 2020, 13:54 | #18639 | Link |
New x266 codec is coming,
https://www.extremetech.com/extreme/...tep-towards-8k I hope ripbot will get that add on soon.... |
24th August 2020, 07:30 | #18640 | Link |
Any H.266 / VVC codec is not automatically "x266". These x26# brands are usually related to the VideoLAN network.
