Old 29th June 2020, 12:57   #29521  |  Link
Originally Posted by Ch3vr0n View Post
2h22m compared to what for you @jdobbs? 16hrs? ^^
2h22m was the length of the movie. The actual job only about 45 minutes start-to-finish (before correcting the HEVC stream). And, yes, using X265 it would have probably taken somewhere in the neighborhood of 16 hours.
Old 29th June 2020, 14:21   #29522  |  Link
cartman0208
Can't wait to do some alpha tesing
Old 29th June 2020, 14:59   #29523  |  Link
Ch3vr0n
I don't suppose this will be of benefit for 3D encoding would it. Last time i tried hw acc FRIM it resulted in severe artifacts for software based players.
Old 29th June 2020, 18:01   #29524  |  Link
Sorry, no.
I haven't looked at FRIM or 3D in a while, but I seem to remember that problem as being related to drivers.
Old 29th June 2020, 18:02   #29525  |  Link
Ch3vr0n
I believe a while back someone said there was an updated FRIM build that supposedly fixed that problem. I just have no idea where to get it.
Sent from my Pixel 3 XL using Tapatalk
Old 29th June 2020, 19:24   #29526  |  Link
musiclover
https://www.videohelp.com/software/FRIM and https://forum.doom9.org/showthread.php?t=169651
Old 29th June 2020, 21:27   #29527  |  Link
Ch3vr0n
Which one would i need for BDRB, the 32bit version? My cpu is a 9900K
Old 29th June 2020, 21:32   #29528  |  Link
gonca
32 bit
Old 29th June 2020, 22:56   #29529  |  Link
Mike-uk
bdrebuilder uses frim 1.25, there has been 5 updates and now 1.31
Mike-uk is offline   Reply With Quote
Old 30th June 2020, 01:46   #29530  |  Link
Anybody else experiencing this?
I can start NVENCC with a fixed command line.
When I start the job it seems to be slower than I'd expected -- about 125fps. So I stop the job and restart it. Suddenly I'm getting 420fps... with the exact same command line. Try it again... and it's random. I might get either of the two speeds. Weird.
Now THAT's confusing.
Old 30th June 2020, 03:44   #29531  |  Link
MrVideo
MrVideo's Avatar
Well... even a broken clock is right twice a day.
Not if it is a digital clock and the display goes dark/blank.
Old 30th June 2020, 07:45   #29532  |  Link
Sharc
Strange. Did you check the GPU load and temperature (e.g. using GPU-Z)? Is the speed limited by the GPU or by the bus transfers/memory access? Are you using HDD or SSD? Virus scanner interference, or some other background process interfering?
What I noticed here (NVEncC x264 1050Ti) is an initial speed increase during the first few (say 10) seconds which then settles to a steady value.
Old 30th June 2020, 10:17   #29533  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
An app being quicker on second run is no mystery, happens with sore more SW.
Its just that these date are still kept in RAM.
Like with tsMuxeR, muxing time went from 9..10 min first run
down to 1,5 minutes for the same 10GB test stream on second and third run.
(Magnetic platter HDDs used, with SSD maybe unnoticeable)
I just extensively tested for one particular stream losing packets at the end.
(solved since the 2020-06-27 build for me, BTW)
Would fit the available 32GB RAM. (Did not run RAMMap though to confirm)
Why it would be slower on third run, I cannot comment.
But if I close the app and allow the RAM to be flushed, then it may take the full first running time again.
Old 30th June 2020, 11:56   #29534  |  Link
cartman0208
Can you post that commandline?
Old 30th June 2020, 12:44   #29535  |  Link
Mike-uk
ohhh looks like nvencc has fixed/added the repeat issue
Old 30th June 2020, 13:23   #29536  |  Link
Mike-uk
hmm im only get 66 FPS regardless how many time i restart, just a note 400 fps sounds too quick, gpu encoding doesnt give same quality as cpu, so id be happy for gpu to be spitting out the best quality it can do "--preset quality" even if that means less fps, im sure gpu at max quality will be a lot quicker than cpu, will be nice to have the option of HW excelearion, will you be including 264 hw exceleration also ?
in using a RTX 2070 Super
NVEncC (x64) 5.06 (r1569) by rigaya, Jun 16 2020 13:25:14 (VC 1916/Win/avx2)
  [NVENC API v9.1, CUDA 10.1]
 reader: raw, y4m, avi, avs, vpy, avsw, avhw [H.264/AVC, H.265/HEVC, MPEG2, VP8, VP9, VC-1, MPEG1, MPEG4]
Environment Info
OS : Windows 10 x64 (19041)
CPU: Intel Core i7-8700K @ 3.70GHz [TB: 4.30GHz] (6C/12T)
RAM: Used 7414 MB, Total 16311 MB
#0: GeForce RTX 2070 SUPER (2560 cores, 1800 MHz)[PCIe3x16][451.48]
NVEnc features
Codec: H.264/AVC
Max Bframes               4
B Ref Mode                yes
RC Modes                  63
Field Encoding            no
MonoChrome                no
FMO                       no
Quater-Pel MV             yes
B Direct Mode             yes
CABAC                     yes
Adaptive Transform        yes
Max Temporal Layers       0
Hierarchial P Frames      no
Hierarchial B Frames      no
Max Level                 62
Min Level                 10
4:4:4                     yes
Min Width                 145
Max Width                 4096
Min Height                49
Max Height                4096
Multiple Refs             yes
Max LTR Frames            8
Dynamic Resolution Change yes
Dynamic Bitrate Change    yes
Forced constant QP        yes
Dynamic RC Mode Change    no
Subframe Readback         yes
Constrained Encoding      yes
Intra Refresh             yes
Custom VBV Bufsize        yes
Dynamic Slice Mode        yes
Ref Pic Invalidiation     yes
PreProcess                no
Async Encoding            yes
Max MBs                   65536
Lossless                  yes
SAO                       no
Me Only Mode              yes
Lookahead                 yes
AQ (temporal)             yes
Weighted Prediction       yes
10bit depth               no
Codec: H.265/HEVC
Max Bframes               5
B Ref Mode                yes
RC Modes                  63
Field Encoding            no
MonoChrome                no
Quater-Pel MV             yes
B Direct Mode             no
Max Level                 186
Min Level                 30
4:4:4                     yes
Min Width                 129
Max Width                 8192
Min Height                33
Max Height                8192
Multiple Refs             yes
Max LTR Frames            7
Intra Refresh             yes
PreProcess                no
Async Encoding            yes
Max MBs                   262144
Lossless                  yes
SAO                       yes
Me Only Mode              yes
Lookahead                 yes
AQ (temporal)             yes
10bit depth               yes
NVDec features
  H.264/AVC:  nv12, yv12
  H.265/HEVC: nv12, yv12, yv12(9bit), yv12(10bit), yv12(12bit), yuv444, yuv444(9bit), yuv444(10bit), yuv444(12bit)
  MPEG1:      nv12, yv12
  MPEG2:      nv12, yv12
  MPEG4:      nv12, yv12
  VP8:        nv12, yv12
  VP9:        nv12, yv12, yv12(9bit), yv12(10bit), yv12(12bit)
  VC-1:       nv12, yv12
Old 30th June 2020, 17:23   #29537  |  Link
Ch3vr0n
i'll experiment with the updated version. I'll have to go into the bios to enable the iGPU. That's a job for upcoming weekend.
Old 30th June 2020, 17:27   #29538  |  Link
I've deleted it. Right now I'm in the middle of system backups, but I'll post an example later.
Old 30th June 2020, 17:32   #29539  |  Link
Wow. That's are really quick response! I just downloaded it and will do some testing after my backups finish. I added code to BD-RB yesterday to scan/add the headers -- but I'm very happy to remove it! I'd much rather have the encoder do it!
Old 30th June 2020, 20:18   #29540  |  Link
MrVideo
MrVideo's Avatar
[...] will be nice to have the option of HW excelearion, will you be including 264 hw exceleration also?
I think you mean acceleration. Also, when posting long lists like that, please CODE wrap them.
