#29841 | Link | ||
Ok, I went and had a look at a competitive product (Staxrip) and guess what ... there's no issues with the file ... my TV shows that HDR10+ is played
Here's the commandline used: Quote:
Now I have to figure out what causes the issues ... any clues? [edit] Here the BDRB Command line Quote:
#29844 | Link |
Had some issues getting back on Doom9
Here are the differences between the two command lines, all common switches removed Don't have HDR10+ capability so you gonna have to test Staxrip Code:
--vbrhq 0 --level 5.1 --max-bitrate 30000 --vbr-quality 0 --aq --bref-mode each --strict-gop --output-buf 128 --colorrange auto --max-cll "1000,0" Code:
--repeat-headers --qp-min 0 --vbr 0 --vbr-quality 25 --keyfile "U:\OUTPUT\WORKFILES\VID_00685.CHP" --pic-struct --vbv-bufsize 45000 --max-bitrate 48000 --gop-len 48 Last edited by gonca; 10th August 2020 at 23:56. |
#29845 | Link |
![]() Join Date: Oct 2001
Working on a recent bug report by cartman0208, and guess what... I found a bug that apparently has been there since at least 2012 (see this post). That has to be a record for time-from-report-to-fix.
[Edit] Nope. It wasn't a record. I found a reference to that error dating back to 2009! It was a really obscure error that can only happen under very rare certain circumstances and only then if there is secondary video. Last edited by jdobbs; 11th August 2020 at 04:08. |
#29846 | Link | |||
#29847 | Link | |
I hope there aren't more surprises like that. |
#29848 | Link | |
Howls Moving Castle
Thanks! |
#29849 | Link |
OK, after 2 days of testing, gradually removing paramters from the stax-string and then adding the parameters from the BDRB string (which I should have done the other way around, because I found it on the second-to-last parameter
![]() If the --pic-struct is removed from the command line string, the file plays fine. But I also noticed, some scenes are WAY to dark on my TV. A file with intact video (vFormat=8 in the alternate.txt) on the other hand is bright in the same scenes. I'll do some more testing to find the cause for that... |
#29850 | Link |
Bug on HEVC/V3 BluRays and x264/LAVF frameserving:
[08.12.20] BD Rebuilder v0.61.10 [20:38:07] Source: SONNTAG_IN_NEW_YORK_1963_1080P - Input BD size: 29,48 GB - Approximate total content: [01:48:22.412] - Target BD size: 4,41 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), Two Pass - HEVC/V3 mode for BD disc enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 - Resuming from previously started job. [20:38:09] PHASE ONE, Encoding - [20:38:09] Processing: VID_00001 (2 of 4) - [20:38:09] Multiplexing M2TS - Error in attempt to multiplex: MUX_00001.meta - Can't open file: Q:\4K\WORKFILES\VID_00001.AVS.hevc [20:38:13] - Failed to build structure, aborted ---------------------- [08.12.20] BD Rebuilder v0.61.10 [20:39:11] Source: SONNTAG_IN_NEW_YORK_1963_1080P - Input BD size: 29,48 GB - Approximate total content: [01:48:22.412] - Target BD size: 4,41 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), Two Pass - HEVC/V3 mode for BD disc enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 - Resuming from previously started job. [20:39:12] PHASE ONE, Encoding - [20:39:12] Processing: VID_00001 (2 of 4) - [20:39:12] Multiplexing M2TS - [20:39:17] Processing: VID_00002 (3 of 4) - [20:39:17] Extracting A/V streams [VID_00002] - [20:39:21] Reencoding video [VID_00002] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 557 frames - Bitrate: 1.424 Kbs - [20:39:21] Reencoding: VID_00002, Pass 1 of 2 - [20:40:12] Reencoding: VID_00002, Pass 2 of 2 - [20:40:49] Video Encode complete - [20:40:49] PredictAndEncode() 00053 2809 [20:40:56] - Aborted by user request ---------------------- [08.12.20] BD Rebuilder v0.61.10 [20:40:59] Source: SONNTAG_IN_NEW_YORK_1963_1080P - Input BD size: 29,48 GB - Approximate total content: [01:48:22.412] - Target BD size: 4,41 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), Two Pass - HEVC/V3 mode for BD disc enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 - Resuming from previously started job. [20:41:01] PHASE ONE, Encoding - [20:41:01] Processing: VID_00002 (3 of 4) - [20:41:01] Processing audio tracks - [20:41:01] Multiplexing M2TS - Error in attempt to multiplex: MUX_00002.meta - Can't open file: Q:\4K\WORKFILES\VID_00002.AVS.hevc [20:41:05] - Failed to build structure, aborted ---------------------- [08.12.20] BD Rebuilder v0.61.10 [20:41:22] Source: SONNTAG_IN_NEW_YORK_1963_1080P - Input BD size: 29,48 GB - Approximate total content: [01:48:22.412] - Target BD size: 4,41 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), Two Pass - HEVC/V3 mode for BD disc enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 - Resuming from previously started job. [20:41:23] PHASE ONE, Encoding - [20:41:23] Processing: VID_00002 (3 of 4) - [20:41:23] Multiplexing M2TS - [20:41:27] Processing: VID_00003 (4 of 4) - [20:41:27] Extracting A/V streams [VID_00003] - [20:41:31] Reencoding video [VID_00003] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 279 frames - Bitrate: 2.160 Kbs - [20:41:31] Reencoding: VID_00003, Pass 1 of 2 - [20:42:27] Reencoding: VID_00003, Pass 2 of 2 - [20:43:18] Video Encode complete - [20:43:18] PredictAndEncode() 00053 2809 [20:43:21] - Aborted by user request ---------------------- [08.12.20] BD Rebuilder v0.61.10 [20:43:30] Source: SONNTAG_IN_NEW_YORK_1963_1080P - Input BD size: 29,48 GB - Approximate total content: [01:48:22.412] - Target BD size: 4,41 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), Two Pass - HEVC/V3 mode for BD disc enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 - Resuming from previously started job. [20:43:31] PHASE ONE, Encoding - [20:43:31] Processing: VID_00003 (4 of 4) - [20:43:31] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:43:32] Multiplexing M2TS [20:43:35]PHASE ONE complete [20:43:35]PHASE TWO - Rebuild Started - [20:43:35] Rebuilding BD file Structure [20:43:36] - Encode and Rebuild complete [20:43:36] Writing BD structure to ISO file - ImgBurn completed successfully - SONNTAG_IN_NEW_YORK_1963_1080P folder removed. - WORKFILES folder removed. [20:43:47] JOB: SONNTAG_IN_NEW_YORK_1963_1080P finished. With directshow no problems. |
#29851 | Link | |
[Edit] I went back through requirements of the BD standard information that I have to see when the pic-structure is needed, and I think removing that parameter will be ok. Last edited by jdobbs; 12th August 2020 at 21:18. |
#29852 | Link | |
With that said -- I'll do some testing to see why the filename issue is popping up. Last edited by jdobbs; 12th August 2020 at 20:37. |
#29853 | Link | |
#29854 | Link | |
If not, then it might be enough if the parameter is removed in alternate output only. What does this parameter do anyway? I read something about shutter timings ![]() |
#29855 | Link | |
#29858 | Link |
After some more testing I'm pretty sure, that's an encoder thing ...
My TV is showing the HDR10+ logo when playing the intact file, which is bright, also the file encoded with x265 and metadata. Same brightness on an encoded file, either x265 and nvenc (surprisingly), without HDR10+ metadata, TV then shows a HDR-Logo A file encoded with nvencc plus metadata also shows the HDR10+ logo, but dark scenes are much too dark, barely visible... where in the same scene on the other files everything was distinguishable... I tried playing with maxcll values, but that doesn't help either ... plus - I don't want to mess up the original settings I even tried to set my TV to max backlight and brightness, still too dark Any ideas what else I could try? |
#29859 | Link | |
I wish I could help, but I have no equipment that has the ability to playback HDR10+. Last edited by jdobbs; 13th August 2020 at 22:19. |
#29860 | Link | |
The file is extracted with Code:
ffmpeg -i "input.m2ts" -c:v copy -vbsf hevc_mp4toannexb -f hevc - | hdr10plus_parser.exe -o metadata.json - Problem might be, that rigaya does not have the equipment either. I think I'll post an issue on his github page. I suggest to disable the feature by default and only enable it optional... until the root cause is found. |
