Old 22nd February 2014, 17:58   #19361  |  Link
soneca
How strange! I have had this problem converting on two different machines.
I have tested the latest version of Haali some time, you think there is any relation to this problem?
[02/22/14] Checking System Settings
- BD-Rebuilder v0.46.13 (beta)
- Windows Version: 6.1 [7601]
- Working Path Free Space: 539,50GB
- HAALI Splitter: Isn't recommended version
- FFDSHOW: 4515, Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[02/22/14] Systems Settings Check complete
Old 22nd February 2014, 19:29   #19362  |  Link
Crocluvr92
Inspect is a part of BD-RB now (HELP menu)... but you already got the report in your output.
Have you tried uninstalling/reinstalling BD-RB, HAALI, AVISYNTH, and FFDSHOW? When you're getting crashes, that's always a good place to start. As for X264 crashing. I'd almost always consider system instability caused by overheating. Yours did die immediately, though, so you'd have to be running hot already if that were the problem.
I did the uninstall/re-install and still no luck. The h.264 error still keeps happening and there is no way I am overheating. I have 10GB of RAM and Quad-Core 2.80 GHz Processor. The issue got fixed on the prior version, but it fails instantly on the re-encode and this did not happen until the new beta came out. What else could be wrong?
[02/22/14] BD Rebuilder v0.46.13 (beta)
[11:26:51] Source: AKIRA
- Input BD size: 46.39 GB
- Approximate total content: [03:55:25.903]
- Target BD size: 23.31 GB
[11:26:52] PHASE ONE, Encoding
- [11:26:52] Processing: VID_00001 (1 of 6)
- [11:26:52] Extracting A/V streams [VID_00001]
- [12:20:37] Reencoding video [VID_00001]
- Rate/Length: 23.976fps, 179,017 frames
- [12:20:51] Reencoding: VID_00001, Pass 1 of 1
- Encode failed. Aborting.
- Working Path Free Space: 158.16GB
- FFDSHOW: 4504, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[12:21:04] - Failed video encode, aborted
Crocluvr92 is offline   Reply With Quote
Old 22nd February 2014, 19:31   #19363  |  Link
HWK
HWK's Avatar
- FFDSHOW: 4515, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
This post may apply to you.
http://forum.doom9.org/showpost.php?p=1461291&postcount=5
Old 22nd February 2014, 19:35   #19364  |  Link
HWK
HWK's Avatar
- FFDSHOW: 4504, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
Uninstall all supporting application and reinstall them again and see if it is any different.
Also post your setting info.
Old 22nd February 2014, 19:57   #19365  |  Link
Capsbackup
Does it only happen with this Blu-ray? Can you backup any other Blu-ray rips?
Old 22nd February 2014, 19:59   #19366  |  Link
Crocluvr92
Which supporting applications do you speak of? x264, Aften, faad, etc. comes with the bd rebuilder pack. I also uninstalled and reinstalled AviSynth,Matroska Splitter, ffdshow and bd rebuilder and followed the exact instructions as was told per jdobbs instructions on the beta page and still I get this error. Everything was fine until this new beta came along
Old 22nd February 2014, 20:01   #19367  |  Link
Crocluvr92
It happens with all blu-rays, such as Akira, Salo, American Reunion and so on. I had a similar issue with v0.44.17 but it was fixed with replacing the x264 codec but I tried that with this beta but I did not have this big of an issue until the new beta was released.
Old 22nd February 2014, 20:02   #19368  |  Link
- FFDSHOW: 4504, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
Go back to the previous version. My guess is that it will fail also.
X264 is the exact same version as in the last several releases. Your problem is much more likely to be system stability or a CODEC issue. X264 is very stable.
Old 22nd February 2014, 20:13   #19369  |  Link
Crocluvr92
What type of codec issue could it be? And I wouldn't mind going back to the other version but it doesnt allow it. It says beta has expired.
Old 22nd February 2014, 20:20   #19370  |  Link
Capsbackup
Look for any codec packs in add/remove programs folder.
Old 22nd February 2014, 22:03   #19371  |  Link
One thing you could do is open the AVS file with Media Player Classic (included with BD-RB) to see if it will play.
Old 22nd February 2014, 22:49   #19372  |  Link
soneca
@soneca
That job (with 47 parts) completed and I tested it at several of the connection points and didn't experience any problems. I'll try a smaller one (fewer parts).
[Edit] Ok, I just did one with only three parts and it played back without glitches at the joins also... so I guess I'd need more information to go any further. I don't think I have "Crimson Tide" on BD...
Jdobbs, thanks for testing.
I returned to the recommended version of Haali but nothing has changed, really do not know what might be happening on both machines.
Please, if you need any info, let me know.
Old 22nd February 2014, 22:52   #19373  |  Link
soneca
It was not the case, I was really testing the latest version of Haali.
Thank you.
Old 22nd February 2014, 22:54   #19374  |  Link
Is it just that disc, or are you having trouble with more than one?
Old 22nd February 2014, 23:04   #19375  |  Link
soneca
With the disc "The Counselor" too.
I'll test other titles.
Old 23rd February 2014, 18:57   #19376  |  Link
mparade
@jdobbs
Do you have in your future plans the MVC support for full disc backups?
Anyway, thank you again for this great program!
Old 23rd February 2014, 21:06   #19377  |  Link
@jdobbs
Yes. But currently it can't be done without halving the bitrate because there is no easy way to create an ISO -- and the SSIF files should point to the same sectors as the two 3D M2TS files. If TSMUXER doesn't offer the option sometime soon I will start working on my own ISO creation.
Old 23rd February 2014, 21:16   #19378  |  Link
Ch3vr0n
if you manage to pull that one off, i'll will try to find the funds to do another donation. Tight budget here. But that functionality will defo get tested by me. Plenty of 3D discs
Old 24th February 2014, 01:10   #19379  |  Link
ChldsPlay
I am having a problem with The Big Bang Theory S21.
After re-encoding all the files when it goes to put everything back together in the target folders, it has the error:
CopyDirStructure() 00076 1200
When I check the target folder it creates a lot of repeating sub folders. Like the main folder for the backup is called "backup" so it looks like:
backup
Big Bang Theory Season 2
backup
backup
And so on. The workfiles directory is in the topmost "backup" folder. I had a very similar problem to this years ago with either G.I. Joe or Big Trouble in Little China, but everything has worked fine since then.
[18:41:23] Source:  THE_BIG_BANG_THEORY_S2_D1
  - Input BD size: 38.88 GB
  - Approximate total content: [04:21:12.156]
  - Target BD size: 22.95 GB
  - Windows Version: 6.0 [6002]
  - Auto Quality: Good (Very Fast), Two Pass
[18:41:23] PHASE ONE, Encoding
 - [18:41:23] Processing: VID_00001 (1 of 13)
 - [18:41:23] Extracting A/V streams [VID_00001]
 - [18:42:34] Reencoding video [VID_00001]
   - Rate/Length: 23.976fps, 31,441 frames
   - Bitrate: 9,374 Kbs
 - [18:42:34] Reencoding: VID_00001, Pass 1 of 2
 - [18:56:47] Reencoding: VID_00001, Pass 2 of 2
 - [19:12:18] Video Encode complete
 - [19:12:18] Processing audio tracks
 - [19:12:18] Multiplexing M2TS
 - [19:12:44] Processing: VID_00002 (2 of 13)
 - [19:12:44] Extracting A/V streams [VID_00002]
 - [19:13:56] Reencoding video [VID_00002]
   - Rate/Length: 23.976fps, 30,601 frames
   - Bitrate: 9,353 Kbs
 - [19:13:56] Reencoding: VID_00002, Pass 1 of 2
 - [19:27:03] Reencoding: VID_00002, Pass 2 of 2
 - [19:40:22] Video Encode complete
 - [19:40:22] Processing audio tracks
 - [19:40:22] Multiplexing M2TS
 - [19:41:03] Processing: VID_00009 (3 of 13)
 - [19:41:03] Extracting A/V streams [VID_00009]
 - [19:42:23] Reencoding video [VID_00009]
   - Bitrate: 9,369 Kbs
 - [19:42:23] Reencoding: VID_00009, Pass 1 of 2
 - [19:55:03] Reencoding: VID_00009, Pass 2 of 2
 - [20:08:00] Video Encode complete
 - [20:08:00] Processing audio tracks
 - [20:08:00] Multiplexing M2TS
 - [20:08:25] Processing: VID_00018 (4 of 13)
 - [20:08:25] Extracting A/V streams [VID_00018]
 - [20:08:32] Reencoding video [VID_00018]
   - Rate/Length: 23.976fps, 8,159 frames
   - Bitrate: 2,294 Kbs
 - [20:08:32] Reencoding: VID_00018, Pass 1 of 2
 - [20:10:28] Reencoding: VID_00018, Pass 2 of 2
 - [20:12:23] Video Encode complete
 - [20:12:23] Processing audio tracks
 - [20:12:23] Multiplexing M2TS
 - [20:12:27] Processing: VID_00021 (5 of 13)
 - [20:12:27] Extracting A/V streams [VID_00021]
 - [20:13:49] Reencoding video [VID_00021]
   - Rate/Length: 23.976fps, 30,817 frames
 - [20:13:49] Reencoding: VID_00021, Pass 1 of 2
 - [20:26:48] Reencoding: VID_00021, Pass 2 of 2
 - [20:40:06] Video Encode complete
 - [20:40:06] Processing audio tracks
 - [20:40:06] Multiplexing M2TS
 - [20:40:47] Processing: VID_00022 (6 of 13)
 - [20:40:47] Extracting A/V streams [VID_00022]
 - [20:42:05] Reencoding video [VID_00022]
   - Rate/Length: 23.976fps, 28,849 frames
   - Bitrate: 9,364 Kbs
 - [20:42:05] Reencoding: VID_00022, Pass 1 of 2
 - [20:54:28] Reencoding: VID_00022, Pass 2 of 2
 - [21:07:05] Video Encode complete
 - [21:07:05] Processing audio tracks
 - [21:07:05] Multiplexing M2TS
 - [21:07:29] Processing: VID_00023 (7 of 13)
 - [21:07:29] Extracting A/V streams [VID_00023]
 - [21:08:52] Reencoding video [VID_00023]
   - Rate/Length: 23.976fps, 30,265 frames
   - Bitrate: 9,361 Kbs
 - [21:08:52] Reencoding: VID_00023, Pass 1 of 2
 - [21:22:43] Reencoding: VID_00023, Pass 2 of 2
 - [21:38:27] Video Encode complete
 - [21:38:27] Processing audio tracks
 - [21:38:27] Multiplexing M2TS
 - [21:38:52] Processing: VID_00025 (8 of 13)
 - [21:38:52] Extracting A/V streams [VID_00025]
 - [21:40:14] Reencoding video [VID_00025]
   - Rate/Length: 23.976fps, 30,505 frames
 - [21:40:14] Reencoding: VID_00025, Pass 1 of 2
 - [21:53:09] Reencoding: VID_00025, Pass 2 of 2
 - [22:06:14] Video Encode complete
 - [22:06:14] Processing audio tracks
 - [22:06:14] Multiplexing M2TS
 - [22:06:48] Processing: VID_00026 (9 of 13)
 - [22:06:48] Extracting A/V streams [VID_00026]
 - [22:08:04] Reencoding video [VID_00026]
   - Rate/Length: 23.976fps, 29,041 frames
   - Bitrate: 9,348 Kbs
 - [22:08:04] Reencoding: VID_00026, Pass 1 of 2
 - [22:20:14] Reencoding: VID_00026, Pass 2 of 2
 - [22:32:37] Video Encode complete
 - [22:32:37] Processing audio tracks
 - [22:32:37] Multiplexing M2TS
 - [22:33:11] Processing: VID_00027 (10 of 13)
 - [22:33:11] Extracting A/V streams [VID_00027]
 - [22:34:23] Reencoding video [VID_00027]
   - Rate/Length: 23.976fps, 30,361 frames
   - Bitrate: 9,366 Kbs
 - [22:34:23] Reencoding: VID_00027, Pass 1 of 2
 - [22:47:07] Reencoding: VID_00027, Pass 2 of 2
 - [23:00:09] Video Encode complete
 - [23:00:09] Processing audio tracks
 - [23:00:09] Multiplexing M2TS
 - [23:00:42] Processing: VID_00028 (11 of 13)
 - [23:00:42] Extracting A/V streams [VID_00028]
 - [23:01:55] Reencoding video [VID_00028]
   - Rate/Length: 23.976fps, 30,697 frames
   - Bitrate: 9,389 Kbs
 - [23:01:55] Reencoding: VID_00028, Pass 1 of 2
 - [23:14:50] Reencoding: VID_00028, Pass 2 of 2
 - [23:28:01] Video Encode complete
 - [23:28:01] Processing audio tracks
 - [23:28:01] Multiplexing M2TS
 - [23:28:27] Processing: VID_00029 (12 of 13)
 - [23:28:27] Extracting A/V streams [VID_00029]
 - [23:29:40] Reencoding video [VID_00029]
   - Rate/Length: 23.976fps, 30,313 frames
   - Bitrate: 9,363 Kbs
 - [23:29:40] Reencoding: VID_00029, Pass 1 of 2
 - [23:42:32] Reencoding: VID_00029, Pass 2 of 2
 - [23:55:38] Video Encode complete
 - [23:55:38] Processing audio tracks
 - [23:55:38] Multiplexing M2TS
 - [23:56:12] Processing: VID_00030 (13 of 13)
 - [23:56:12] Extracting A/V streams [VID_00030]
 - [23:57:24] Reencoding video [VID_00030]
   - Rate/Length: 23.976fps, 30,793 frames
   - Bitrate: 9,387 Kbs
 - [23:57:24] Reencoding: VID_00030, Pass 1 of 2
 - [00:10:19] Reencoding: VID_00030, Pass 2 of 2
 - [00:23:30] Video Encode complete
 - [00:23:30] Processing audio tracks
 - [00:23:30] Multiplexing M2TS
[00:24:05]PHASE ONE complete
[00:24:05]PHASE TWO - Rebuild Started
 - [00:24:05] Rebuilding BD file Structure
 - [00:24:05] CopyDirStructure() 00076  1200
[18:06:15] - Aborted per user request
[02/23/14] Checking System Settings
  - Working Path Free Space: 444.83GB
  - FFDSHOW: 4504, Ok
  - FFDSHOW VC-1 set incorrectly: [0]
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
ChldsPlay is offline   Reply With Quote
Old 24th February 2014, 15:55   #19380  |  Link
@Childsplay
That routine is executed on every full backup made. This is the only report ever received of this type. Since the code is executed so often on so many systems, I have to believe the issue is local to your machine. That makes me think one of two things.
1. If the source is pointing to a local drive onto which you've ripped the disc, your drive is having issues with circular references. You may want to do a CHKDSK to find any issues. If this is a network or externally connected drive, it could also be a driver issue.
2. If you are reading directly from a disc it could either be a driver issue, or it could be a new type of copy protection that isn't being addressed by the ripping software.
I'll order the discs and see if I can repeat the issue in the case of #2.
