Old 1st April 2009, 13:43   #61  |  Link
jj420
so to keep the DTS audio in MultiAVCHD, in audio settings keep all audio tracks checked will keep its original state provided that the audio stream is in DTS?
jj420 is offline   Reply With Quote
Old 1st April 2009, 13:51   #62  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
popBD will never touch audio.
multiAVCHD will never reencode standard DTS to AC3.
If it is Master/HighResolution audio DTS then in multiAVCHD you need to uncheck [x] TrueHD/DTS-MA.... to [xxx] kbps AC-3 and LPCM in Audio/Subtitles tab.
it is unchecked by default anyway.
Old 1st April 2009, 14:09   #63  |  Link
jj420
thanks Dean for helping me understand...i'm not an A/V guy so i'm just learning as I go along...
Old 1st April 2009, 14:15   #64  |  Link
deank
deank's Avatar
No problem. Let me know if you run into troubles with any of these programs.
Yes, use [x] Keep all audio tracks. Otherwise only the first one will be kept.
Old 1st April 2009, 17:09   #65  |  Link
GenesisPT
Hi Deank,
About the flickering we where talking about in the multiAVCHD thread, I've juste noticed that my TV says that the video is now 1080i not 1080p. This might be the problem but I don't know how this happened as the original is 1080p.
GenesisPT is offline   Reply With Quote
Old 1st April 2009, 17:20   #66  |  Link
herrde
Originally Posted by GenesisPT View Post
Hi Deank,
Just to let you know - I have replied to your flickering issue, but again over at the multiAVCHD thread as I think it's not uncropMKV-related. See my post here.
Best,
Gero
herrde is offline   Reply With Quote
Old 1st April 2009, 17:36   #67  |  Link
deank
deank's Avatar
Honestly I have no ideas.
Please make sure you have the latest Haali and ffdshow and have all postprocessing in ffdshow disabled.
I never witnessed anything similar. I'm using PAL PS3 -> HDMI -> 1920x1080p plasma tv.
Check your PS3 settings for 1080p output.
multiAVCHD menu is in 1080i - are you sure you didn't confuse it with the movie?
Old 1st April 2009, 18:58   #68  |  Link
b66pak
b66pak's Avatar
hi,
can you add a check/uncheck box for turning off the PC when encoding ends (and maybe a timer)? ([x] turn off PC after encoding)?
_
b66pak is offline   Reply With Quote
Old 1st April 2009, 19:01   #69  |  Link
deank
deank's Avatar
I should ask CalcIt developer about it. Once I find out how - I'll add this option.
Old 1st April 2009, 23:52   #70  |  Link
Simply execute shutdown.exe with proper switch
Old 2nd April 2009, 04:23   #71  |  Link
tyee
Hi Dean
One quick question, does your x264 command line include the "--threads auto" switch? Just want to confirm that I'm getting the fastest speed.Thanks.
tyee is offline   Reply With Quote
Old 2nd April 2009, 08:22   #72  |  Link
deank
deank's Avatar
He gave me the API call function, so I'll use it.
Originally Posted by tyee View Post
Hi Dean
Yes.
Old 2nd April 2009, 10:28   #73  |  Link
deank
deank's Avatar
You can now download the updated .exe. It includes the shutdown option and small interface change.
Old 2nd April 2009, 14:46   #74  |  Link
deank
deank's Avatar
A little update:
I added functionality to import various video-formats. If input file is not MKV, uncropMKV will use mkvmerge to generate a MKV and will process it.
Example:
1) I loaded AVI file (XVID 624x352 23.98fps) with MP3 audio
2) Set resize option to 720x480 (16:9 anamorphic)
3) Clicked Queue and then Start
4) Took the output (-uncropped.mkv) file and loaded it into multiAVCHD
5) multiAVCHD converted the MP3 audio to AC3
6) ...and I got a nice AVCHD folder with my AVI video
I also tested it with MP4 and MOV.
*** edit: there are some audio sync problems if original audio is not AC3/DTS/PCM/WAV but I'll find a solution. It works with CBR mp3/mp2 audio.
Old 2nd April 2009, 20:21   #75  |  Link
edward1963
uncropMKV not working
Hi Deank
unfortunately uncropMKV seems not to be working on my computer
everything from avisynth and ffdshow ist installed and working(with other programs like megui encoder)
When I load the mkv file into the program: "video properties" doesn't show anything besides n/a. It somehow doesn't read the file!? I suspect is has something to do with the directshow filters (although otherwise they seem to be working). Any idea?
Anyway thanks for multiAVCHD, works like a charm,terrific program!
No problems here. A great item would be popup menus,but probably a big hassle to program.
Greetings Arthur
edward1963 is offline   Reply With Quote
Old 2nd April 2009, 20:29   #76  |  Link
deank
deank's Avatar
if you don't get a preview or 'video properties' it means that either you don't have tools\mkvinfo.exe or your file is not mkv.
download the latest FULL uncropMKV (link in 1st post) and try again.
Also I'd suggest to READ ALL that's in the first post in this thread.
Old 2nd April 2009, 21:46   #77  |  Link
b66pak
b66pak's Avatar
thanks a lot...
_
Old 3rd April 2009, 00:29   #78  |  Link
b66pak
b66pak's Avatar
it would be nice to add a .log file (in case something going wrong!)...
_
Old 3rd April 2009, 00:38   #79  |  Link
deank
deank's Avatar
You can re-download the .exe. It will create a log file in uncropMKV.exe folder.
[02:36:37] Pre-processing input file (captivity-tlr2_h1080p.mp4)...
[02:36:48] Detected video: ID#1:V_MPEG4/ISO/AVC:1920x800 23.976fps (AR:2.4)
[02:36:48] Video height not compliant (480/576/720/1080)!
[02:36:48] Detected audio: ID#2:A_AAC:audio (44100Hz/2ch) Language: und
[02:36:52] Will keep track#2, Audio, A_AAC, und, 44100Hz 2ch
[02:36:52] File queued: captivity-tlr2_h1080p_new.mkv
[02:36:54] Re-encoding with x264 (captivity-tlr2_h1080p_new.mkv)...
[02:36:58] Will keep track#2, Audio
[02:36:58] mkvmerge: ...
[02:37:00] Done!
Old 3rd April 2009, 13:57   #80  |  Link
jj420
quick question Dean. if the source file has h.264 & DTS audio is there a way to convert the audio to AC3 and still keep the DTS stream? essentially i want to get to a file that now has the h.264 file + DTS audio & AC3 audio
avchd, bdmv, compliant, mkv, multiavchd
