Old 14th November 2019, 10:15   #6821  |  Link
kedautinh12
Thank anyone ������
Old 14th November 2019, 12:47   #6822  |  Link
Barough
Barough's Avatar
x265 v3.2+15-04db2bfee5d6 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.2.0)
Old 23rd November 2019, 12:26   #6823  |  Link
kedautinh12
I think need function import .avs, .avsi to save time like function Load DLL in tab scripts on avisynth script creator
Old 26th November 2019, 21:33   #6824  |  Link
Bazzu85
Yes, seems than the error: Ignoring subtitle track as it is too small
abort all the subtitle management.
It is a bug for Zathor, maybe after holidays...
sorry for stressing...
but are you working or have resolved the bug? thx
Bazzu85 is offline   Reply With Quote
Old 28th November 2019, 10:19   #6825  |  Link
kedautinh12
https://github.com/HolyWu/L-SMASH-Wo...ks_20191127.7z (built by HolyWu)
when i decoding LWLibavVideoSource("***.ts",repeat=true) with repeat=true can Fix MPEG-2 decoding issue with RFF flags (cause decoding video with duration don't match duration of audio) (patched by maki-rxrz) and Fix interlaced H.264 decoding issue in some files. Very nice
Example: https://drive.google.com/file/d/1rUa...5CiiGomr1/view
Old 28th November 2019, 13:26   #6826  |  Link
RyaNJ
RyanJ
I've added DGIndexNV to my installation of MeGUI and have configured the paths and license and whatnot. I have VapourSynth x64 installed but every time I attempt to use DGIndexNV it keeps stating that the 32-bit binaries cannot be loaded into the 64-bit AviSynth.
I don't understand why it's saying that since, as far as I know the current DGIndexNV is x64? Does anyone have a clue what might be going on here?
Cheers.
RyaNJ is offline   Reply With Quote
Old 28th November 2019, 18:18   #6827  |  Link
Taurus
Taurus's Avatar
In the DGDecodeNV package is a 32bit and a 64bit version of DGIndexNV.
Take your poison.
Make sure you put the right one to your plugin folder.
Old 28th November 2019, 20:01   #6828  |  Link
RyaNJ
RyanJ
Take your poison.
I understand that. I have the 64-bit package added into the tools folders and configured via the settings.
I wasn't aware that I had to drop other bits anywhere else?
Old 15th December 2019, 01:36   #6829  |  Link
leon
Just tried to encode with MeGUI after a while and throws an error out of nowhere. Seems like it wrongly detects the 32-bit AviSynth as being 64-bit. Tried with both portable and installed AviSynth.
[Error] Log
-[Information] Versions
--[Information] MeGUI: 2913 x86
--[Information] MeGUI Debug Data: available
--[Information] Update Check: Disabled
--[Information] System Information
---[Information] Operating System: Windows 7 Ultimate x64 SP1 (6.1.65536.7601)
---[Information] .NET Framework: 4.0 (4.0.0.0)
---[Information] .NET Framework: 4.8 (4.8.03761)
---[Information] Redistributables
----[Information] Microsoft Visual C++ 2008 x64:  9.0.21022
----[Information] Microsoft Visual C++ 2008 x86:  9.0.21022
----[Information] Microsoft Visual C++ 2010 x64:  10.0.40219
----[Information] Microsoft Visual C++ 2010 x86:  10.0.40219
----[Information] Microsoft Visual C++ 2012 x64:  11.0.61030
----[Information] Microsoft Visual C++ 2012 x86:  11.0.61030
----[Information] Microsoft Visual C++ 2013 x64:  12.0.30501
----[Information] Microsoft Visual C++ 2013 x86:  12.0.30501
----[Information] Microsoft Visual C++ 2015-2019 x64:  14.23.27820
----[Information] Microsoft Visual C++ 2015-2019 x86:  14.23.27820
---[Information] DPI: 100% (96/96)
---[Information] Monitor 1
----[Information] Resolution: 1360x768
----[Information] Primary Screen: True
--[Information] Component Information
---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013)
---[Information] Haali DSS2:  (14-04-2013)
---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
---[Information] MediaInfo: 18.05.0.0 (08-05-2018)
---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
---[Information] 7z: 9.20 (18-11-2010)
--[Information] AviSynth Information
---[Information] AviSynth Wrapper
----[Information] Version: 1.0.2847.0
----[Information] Date: 06-05-2018
----[Information] Interface: 3
----[Information] AviSynth Status: ignored as portable build is forced
---[Information] AviSynth portable
----[Information] File Version: 0.1
----[Information] File Date: 20-12-2018
----[Information] File Name: AviSynth+ 0.1 (r2772, MT, i386)
----[Information] File Path: c:\program files\megui\avisynth.dll
----[Information] AviSynth Version: AviSynth+ 0.1 (r2772, MT, i386)
----[Information] AviSynth+: true
----[Information] AviSynth MT: true
----[Information] AviSynth Status: active
-[Information] Update detection
--[Information] [15/12/2019 03:24:29] Automatic update is disabled
--[Information] [15/12/2019 03:24:29] Using cached update config and server: http://megui.org/auto/
--[Information] [15/12/2019 03:24:29] No package requires an update
-[Information] FileIndexer
--[Information] [15/12/2019 03:24:42] MediaInfo
---[Information] File: C:\1.mp4
---[Information] General
----[Information] Format: MPEG-4
----[Information] FileSize: 13634107
----[Information] PlayTime: 00:00:48.482
---[Information] Video
----[Information] ID: 2
----[Information] StreamOrder: 1
----[Information] CodecID: avc1
----[Information] CodecIDInfo: Advanced Video Coding
----[Information] Format: AVC
----[Information] FormatInfo: Advanced Video Codec
----[Information] Width: 1280
----[Information] Height: 720
----[Information] FrameCount: 1453
----[Information] FrameRate: 29.970
----[Information] FrameRateOriginal: 29.970
----[Information] FrameRateMode: CFR
----[Information] FrameRateModeString: Constant
----[Information] Duration: 00:00:48.482
----[Information] ScanType: Progressive
----[Information] Bits Depth: 8
----[Information] AspectRatio: 1.778
----[Information] AspectRatioString: 16:9
----[Information] PixelAspectRatio: 1.000
---[Information] Audio
----[Information] ID: 1
----[Information] StreamOrder: 0
----[Information] CodecID: mp4a-40-2
----[Information] Format: AAC
----[Information] FormatInfo: Advanced Audio Codec
----[Information] FormatProfile: LC
----[Information] SamplingRate: 44100
----[Information] SamplingRateString: 44.1 kHz
----[Information] Channels: 2
----[Information] ChannelsString: 2 channels
----[Information] ChannelPositionsString2: 2/0/0
----[Information] BitRateMode: VBR
----[Information] [15/12/2019 03:24:42] The language information is not available for this track. The default MeGUI language has been selected.
-[Information] Log for job29 (idx, 1.mp4 -> 1.mp4.lwi)
--[Information] [15/12/2019 03:24:51] Started handling job
--[Information] [15/12/2019 03:24:51] Preprocessing
--[Information] [15/12/2019 03:24:52] AviSynth script
---[NoImage] LoadPlugin("C:\Program Files\MeGUI\tools\lsmash\LSMASHSource.dll")
---[NoImage] LSMASHVideoSource("C:\1.mp4")
--[Information] [15/12/2019 03:24:55] Postprocessing
---[Information] [15/12/2019 03:24:58] Deleting intermediate files
--[Information] [15/12/2019 03:24:58] Job completed
-[Error] Log for job30 (video, 1.mp4.avs -> 1.mp4.264)
--[Information] [15/12/2019 03:25:41] Started handling job
--[Information] [15/12/2019 03:25:41] Preprocessing
--[Information] [15/12/2019 03:25:41] AviSynth input script
---[NoImage] # Set DAR in encoder to 16 : 9. The following line is for automatic signalling
---[NoImage] global MeGUI_darx = 16
---[NoImage] global MeGUI_dary = 9
---[NoImage] #deinterlace
---[NoImage] #crop
---[NoImage] #resize
---[NoImage] #denoise
---[NoImage] #ChangeFPS(25000, 1000)
---[NoImage] #Trim(424, 19670)
---[NoImage] #AssumeFPS(22000, 1000)
--[Information] [15/12/2019 03:25:42] resolution: 1280x720
--[Information] [15/12/2019 03:25:42] frame rate: 30000/1001
--[Information] [15/12/2019 03:25:42] frames: 1453
--[Information] [15/12/2019 03:25:42] length: 00:00:48.482
--[Information] [15/12/2019 03:25:42] aspect ratio: 16:9 (1.778)
--[Information] [15/12/2019 03:25:42] color space: I420
--[Information] [15/12/2019 03:25:42] changing --ref to 9
--[Information] [15/12/2019 03:25:42] Job command line: "cmd.exe" /c ""C:\Program Files\MeGUI\tools\ffmpeg\ffmpeg.exe"
 -loglevel level+error -i "C:\1.mp4.avs" -strict -1 -f yuv4mpegpipe - | "C:\Program Files\MeGUI\tools\x264\x264.exe"
 --level 4.1 --preset veryslow --tune film --crf 26.0 --keyint 300
 --qpmin 10 --qpmax 51 --vbv-bufsize 78124 --vbv-maxrate
 62500 --no-fast-pskip --colorprim bt709 --transfer bt709
 --colormatrix bt709 --sar 1:1 --frames 1453 --output "C:\1.mp4.264" --stdin y4m -"
--[Information] [15/12/2019 03:25:42] Process started
--[Information] [15/12/2019 03:25:42] Standard output stream
--[Error] [15/12/2019 03:25:42] Standard error stream
---[Information] [15/12/2019 03:25:42] [avisynth @ 00000000005617c0] [error] Cannot load a 32 bit DLL in 64 bit Avisynth:
'C:/Program Files/MeGUI/tools/lsmash/LSMASHSource.dll'.
---[Information] [15/12/2019 03:25:42] (C:\1.mp4.avs, line 4)
---[Information] [15/12/2019 03:25:42] [error] C:\1.mp4.avs: Unknown error occurred
---[Error] [15/12/2019 03:25:42] y4m [error]: bad sequence header magic
---[Error] [15/12/2019 03:25:42] x264 [error]: could not open input file `-'
--[Error] [15/12/2019 03:25:42] Process exits with error: 0xFFFFFFFF (-1)
--[Information] [15/12/2019 03:25:42] Job completed
Don't know what's wrong but it doesn't let me attach the txt file.
leon is offline   Reply With Quote
Old 15th December 2019, 12:46   #6830  |  Link
tebasuna51
tebasuna51's Avatar
@leon
- Using last MeGUI version and AviSynth portable 32 bits
- The job29 work fine with the .avs (all 32 bits)
- The job30 crash with the same .avs, maybe your C:\Program Files\MeGUI\tools\ffmpeg\ffmpeg.exe is 64 bit, must be 32 bit.
Check it:
Old 15th December 2019, 23:39   #6831  |  Link
leon
@tebasuna51
That was it, I had accidentally replaced it with a 64-bit ffmpeg. Thank you.
Old 18th December 2019, 08:11   #6832  |  Link
Barough
Barough's Avatar
x265 v3.2+22-a8a2c4c37267 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.2.0)
Old 20th December 2019, 22:02   #6833  |  Link
hello_hello
It's not a bad idea, but if you install Avisynth and put plugins and avsi scripts in the "installed" Avisynth plugins folder they'll be auto-loaded when Avisynth runs, even if MeGUI is using it's own portable version of Avisynth. I'd actually forgotten the script creator has a section for loading plugins "manually" as I haven't needed to use it for a long time.
Old 21st December 2019, 04:57   #6834  |  Link
imsrk48
imsrk48's Avatar
Dear Sir Why You Removed Directshowsource and Avisource Support in Latest Build?
imsrk48 is offline   Reply With Quote
Old 21st December 2019, 11:26   #6835  |  Link
tebasuna51
tebasuna51's Avatar
Not removed, only not recommended:
Old 21st December 2019, 16:18   #6836  |  Link
imsrk48
imsrk48's Avatar
i have tried to Enable it but not working even i have changed different Windows and tried but not working Sir.
Old 21st December 2019, 16:20   #6837  |  Link
imsrk48
imsrk48's Avatar
anyway I'll try again
Old 22nd December 2019, 03:27   #6838  |  Link
hello_hello
imsrk48,
You have to open a file as the video input for the script creator to be offered a Avisource/DirectshowSource choice, not with the file indexer. A window will popup asking how you want to open the video, and Avisource or DirectshowSource should be a choice for most file types.
Keep in mind, if there's an existing index file for the source in the same folder, MeGUI will probably just use it without giving you a choice.
Old 22nd December 2019, 12:25   #6839  |  Link
imsrk48
imsrk48's Avatar
imsrk48,
are you trying to say i don't know about MeGUI?
for your kind information i know MeGUI very well. I'm not a beginner dear sir
Old 22nd December 2019, 12:52   #6840  |  Link
StainlessS
StainlessS's Avatar
imsrk48, H.H, is just trying to help.
I sometimes post sober.
